Анчар Опубликовано 2 марта, 2022 Жалоба Поделиться Опубликовано 2 марта, 2022 И плюс, если я правильно понимаю, толку от этих ребят не особо, как и от чозенов, в смысле для игроков? Это просто немного красивые истории на полку? ну как нет толку. Новые минечки позволяющие разнообразить модельный ряд, разоичными деталями, всегда к месту. Ссылка на комментарий Поделиться на другие сайты Поделиться
Keefer Опубликовано 5 марта, 2022 Жалоба Поделиться Опубликовано 5 марта, 2022 (изменено) Чесно стыбзил перепостил с Старый ламповый фонарь Warhammer 40000 40k Если избирательно по хаосмарам, то: "God specific spells T 4+ inv / N -1 to hit /S 5+ fnp You can't charge after warp time Master of Possession Has a staff that causes perils in combat with a psyker Cast 2 deny 1 When casting, can cause d3 mortals to a friendly non daemonkin unit to gain +2 to cast Enemy psykers suffer one additional wound if they peril within 12" Malefic dis 1. +1 to wound 2. Bring back a daemonkin model 3.4+ inv to Daemonkin units and enemy's take mortals if they charge 4. Beat the models toughness on d6 destroy it 5. 6's to hit auto wound for a daemonkin unit 6. +1 str or toughness (or both if rolled high on test) The is no longer a way to give characters a jump pack, only the daemon prince can still be equipped with wings. My source says the night lord relic is for a fly model (daemon prince being the only one able to take it). Furthermore he himself finds the lack of jump pack characters odd, but says that his playtest rules is one of the first versions, so it might be outdated" Master of Executions (elite slot) Rerolls wounds v char 6" heroic intervene Hits of six does two mortals and the attack ends Axe got worse Doesn't reroll hits Doesn't explode (does with legion) Gains a wound and an attack Dank Apostle all god specific prayers are entirely new to answer the questions, legionaires are the only ones to get the upgrades. EC can still use troop noise marines that get legion traits (but only them) lucius seems to be +3 to current statline." Мастер Одержимости теперь больше в самообмаз и обмаз одержимых. На демонэнжинах его касты теперь смотрятся достаточно слабо. Возможно, на фоне этого, демонэнжины будет как-то усилять варпсмит, помимо унылого ремонта D3 (да хоть стабильные 3) вундов. Изменено 5 марта, 2022 пользователем Locke Ссылка на комментарий Поделиться на другие сайты Поделиться
Разжигатель Войны Опубликовано 6 марта, 2022 Жалоба Поделиться Опубликовано 6 марта, 2022 И плюс, если я правильно понимаю, толку от этих ребят не особо, как и от чозенов, в смысле для игроков? Это просто немного красивые истории на полку? Выйдет кодекс - узнаем. Армия без кодекса всегда стоит на полке. Ссылка на комментарий Поделиться на другие сайты Поделиться
Неизвестный путешественник Опубликовано 7 марта, 2022 Жалоба Поделиться Опубликовано 7 марта, 2022 ^^ а разговоров-то было! Ссылка на комментарий Поделиться на другие сайты Поделиться
Keefer Опубликовано 12 марта, 2022 Жалоба Поделиться Опубликовано 12 марта, 2022 (изменено) "Ещё слухи"Старый ламповый фонарь Warhammer 40000 40k Конкретно по ХСМ: Основные характеристики юнитов: Фортификация - NOCTILITH CROWN T8 14w Lash has 8 shots and improved strength but degrades Increasing aura every turn -1ld 4++ vs shooting PRIEST & PSYKER within 9" can perform an ACTION ACTION, perform leadership test, if equal or below, gain 1 CP, can also replace 1 prayer or 1 spell Лорд Дискордант становится нападающей версией Варп-смита, разадет бонус на ту-хит в файт фазу DISCO LORD +1 to hit daemon engines in melee Instead of healing vehicules can hurt ennemy vehicules Limited to 1 and cant get multiple boosts (i don't understand what this means yet) Сам Варп-смит в общем дефолтный, лечит ваши машины и дает бонус на ту-хит в шутинг: WARPSMITH Can heal vehicules +1 to hit for daemon engines for shooting Не забывают и про старого доброго Эспайринг Чемпиона, который Экзальтед Чемпион - фиксированная закачка как у модели - комби-мельта (на бэкпаке), топор в руке и пистолет). Раздает как и лейтенант только 1 на ту-вунд (а не полный рерол). EXALTED CHAMPION Same loadout as the model (power axe, combi melta & pistol) Is elite and is now a lieutenant (rerolls 1 to wound in 6") Hits better, more wounds, more attacks Cannot change loadout Список юнитов с -1 лидаком: Finally here are the units that have a native -1ld @6" aura: Daemon prince Accursed cultists (mutant/possessed cultists) possessed Chaos spawn Raptors Список юнитов с кейвордом Демонкин: who has the DAEMONKIN keyword: MoP Possessed Warptalons Obliterators Нойзы получили +1 атаку, вунду, лидак meh~ Noise Marines: all their weapons are improved, +1A/W/LD Что могу сказать с ходу. Мастер Одержимости вообще не взаимодействует с демонэнжинами. Если до этого не играл за Несущих Слово с толпами одержимых, возникает вопрос - зачем Мастер вообще нужен? Ответ - для обмаза Облитюков. Вернуть убитого Облитератора (сомневаюсь что со всеми вундами, скорее с D3) и дать им 4+ инвуль. Плюс Мастер может разгонять свои касты на +2 за счёт пушечного мяса-культистов, тяжело их отменить будет. Ну и да, Варпсмит чтобы пострелять демонэжинами, Лорд Дискордант чтобы сходить с ними в хтх. Изменено 12 марта, 2022 пользователем Keefer Ссылка на комментарий Поделиться на другие сайты Поделиться
R'eel Kasrell Опубликовано 12 марта, 2022 Жалоба Поделиться Опубликовано 12 марта, 2022 таки шо, чем играть-то в итоге?) были планы водить демонкин на энжинах и свармой талонов/рапторов под Харкеном, но что-то как-то не вырисовывается. Ссылка на комментарий Поделиться на другие сайты Поделиться
Только Вперед Опубликовано 12 марта, 2022 Жалоба Поделиться Опубликовано 12 марта, 2022 Парадоксально как-то..... вроде должны складывается комбо - но их даже в теории маловато.... снова хавоки и драконы? или все же можно будет сложить вменяемые ростеры... Ссылка на комментарий Поделиться на другие сайты Поделиться
Keefer Опубликовано 13 марта, 2022 Жалоба Поделиться Опубликовано 13 марта, 2022 "Слухи"Старый ламповый фонарь Warhammer 40000 40k "Other custom traits: +1 to wound vs half strength unit (nurgle specific) +1ap on a 6 to wound unmodified (slaanesh specific) +1 to advance and charge rolls +1 to hit when targetting clossest ennemy unit +1 movement & strength This one is all encompassing (so if you take this one you cabt take a second custom trait), also chosen cant take this one: -Ignore CA -Fallback and shoot & fallback and charge, but with -1 to hit for the rest of the turn (unmarked specific, so no marks allowed) DTTFE is no more. Also he says there are no HQ upgrades like space marines. We get marks. Abaddon: - Drachnyen has pierce and sweep profile - 8A s10 ap4 d3, 6+ to wound cuases d3 MW - 16A s7 ap4 d1 - always fights first - -1 to wound - first failed save reduced to 0 damage - +1s on the charge - can only take max 3 damage per phase - full rerolls - charge bonus - supposedly very pricy (would be around 300 ish points) "2 more custom warband traits, and they are god specific! -After charging, in melee 6s to hit autowound (khorne specific) -in melee or shooting, reroll 1 wound or 1 damage (tzeentch specific) Real quick, WB chosen with the khorne custom warband trait is mui caliente. Also NL melta chosen with the tzeentch custom warband trait will flatout wipe the floor in their doctrine. Furthermore, there is a correction, warpsmiths and discolords +1 to hit is for VEHICULES and not just daemon engines. Also there are no boons of chaos. (sad)" Варпсмит и Лорд Дискордант бафают на +1 ту хит не только демонэнжины, но и всю технику. Это хорошо, а то я думал ГВ совсем забило на доересевую технику хаосмаров. Ссылка на комментарий Поделиться на другие сайты Поделиться
Keefer Опубликовано 22 марта, 2022 Жалоба Поделиться Опубликовано 22 марта, 2022 С учётом практически бездумной "гонки вооружений" во всех новых кодексах, не удивлюсь если болтеру пропишут AP -1. Просто так. Ссылка на комментарий Поделиться на другие сайты Поделиться
Неизвестный путешественник Опубликовано 24 марта, 2022 Жалоба Поделиться Опубликовано 24 марта, 2022 (изменено) A Glimpse at a Very Dark Future from AdeptiCon (ссыкло) https://youtu.be/X9UUuQCRC5s Изменено 24 марта, 2022 пользователем Неизвестный путешественник Ссылка на комментарий Поделиться на другие сайты Поделиться
Разжигатель Войны Опубликовано 24 марта, 2022 Жалоба Поделиться Опубликовано 24 марта, 2022 (изменено) но що тут сказать: Позесты 100% Культисты 100% Культисты мутанты 100% далее странности: возможно 1. Какой то герой который несет в руке шлем примариса.. вряд ли отряд, т.к уже вроде все релизы прикрыты, хотя может и тот же позест. 2. Крыло.. Вряд ли позест, т.к они с крыльями вроде не светились на артах, а один крылан на 5 бомжей как то глупо. Так что ставлю на нового ДП. 3. Алатари и иконы.. вот тут непонятно, первая явно среди каких то мутированных зубов.. может террейн, а может какой нибудь НЕХ-икононосец. В общем жирный жир. "А вообще эта икона выглядит так, будто стоит на бекпаке позеста." Изменено 24 марта, 2022 пользователем Разжигатель Войны Ссылка на комментарий Поделиться на другие сайты Поделиться
Locke Опубликовано 24 марта, 2022 Автор Жалоба Поделиться Опубликовано 24 марта, 2022 2. Крыло.. Вряд ли позест, т.к они с крыльями вроде не светились, а один крылан на 5 бомжей как то глупо. Ссылка на комментарий Поделиться на другие сайты Поделиться
Разжигатель Войны Опубликовано 24 марта, 2022 Жалоба Поделиться Опубликовано 24 марта, 2022 (изменено) ну.. просто как дань уважению старому набору? Вроде как да, но нет, щупальцу Термям вот не положили)) А речь была про Арты новых позестов, которые ГВ уже светило. Может будет какая-нибудь отдельная минька позеста, как тот же ЧХ-кастелян, но учитывая тенденцию ГВ что в коробках лежит Варгир, то я сомневаюсь что всему отряду позестов разрешат брать крылья, а выдавать одному из 5-ки.. ну это странно, в текущих реалиях. В общем чем бы ни было все равно шикарно) Изменено 24 марта, 2022 пользователем Разжигатель Войны Ссылка на комментарий Поделиться на другие сайты Поделиться
Keefer Опубликовано 25 марта, 2022 Жалоба Поделиться Опубликовано 25 марта, 2022 С болтером не угадал, что в общем неплохо. Какой-то вариант икононосца должен быть. К иконам, а через них и к маркам Богов Хаоса, будут привязаны вполне себе ощутимые игровые правила, а не просто кейворды, как сейчас. И оно должно на столе чётко отображаться. Ссылка на комментарий Поделиться на другие сайты Поделиться
Разжигатель Войны Опубликовано 25 марта, 2022 Жалоба Поделиться Опубликовано 25 марта, 2022 На уровне Эншента насколько я помню не было ни сливов, ни в текущих реалиях нет ничего подходящего (Хотяя стоп, есть парень с головой мара в руках) Те иконы что показали: Октет не марочный 100% на бекпаке позеста, а вот Кхорнявый - не ясно откуда, но я бы тоже поставил на позестов. Ссылка на комментарий Поделиться на другие сайты Поделиться
Неизвестный путешественник Опубликовано 18 апреля, 2022 Жалоба Поделиться Опубликовано 18 апреля, 2022 (изменено) Two Wounds Are Only the Beginning for Chaos Space Marine Legionaries (ссылка в варп) Изменено 18 апреля, 2022 пользователем Неизвестный путешественник Ссылка на комментарий Поделиться на другие сайты Поделиться
Lot D Опубликовано 18 апреля, 2022 Жалоба Поделиться Опубликовано 18 апреля, 2022 (изменено) Такого тебе ХСМа нарисовали, образованный, легионЭр! Изменено 18 апреля, 2022 пользователем Lot D Ссылка на комментарий Поделиться на другие сайты Поделиться
Locke Опубликовано 18 апреля, 2022 Автор Жалоба Поделиться Опубликовано 18 апреля, 2022 Три атаки у легионера - любо! Ссылка на комментарий Поделиться на другие сайты Поделиться
Анчар Опубликовано 18 апреля, 2022 Жалоба Поделиться Опубликовано 18 апреля, 2022 цепной топор, какой то уж очень злой. Ссылка на комментарий Поделиться на другие сайты Поделиться
Lot D Опубликовано 18 апреля, 2022 Жалоба Поделиться Опубликовано 18 апреля, 2022 цепной топор, какой то уж очень злой. на 4+ то? ну допустим у чемпиона 4 атаки топором на 4+, 2 не попали, 1 не пробила, такое себе Ссылка на комментарий Поделиться на другие сайты Поделиться
Iron Duke Опубликовано 19 апреля, 2022 Жалоба Поделиться Опубликовано 19 апреля, 2022 цепной топор, какой то уж очень злой. просто чайнфист =) Ссылка на комментарий Поделиться на другие сайты Поделиться
Kem Опубликовано 19 апреля, 2022 Жалоба Поделиться Опубликовано 19 апреля, 2022 Три атаки у легионера - любо! Примарис геймбрека уже продался и вышел из моды? F Ссылка на комментарий Поделиться на другие сайты Поделиться
Keefer Опубликовано 19 апреля, 2022 Жалоба Поделиться Опубликовано 19 апреля, 2022 Two Wounds Are Only the Beginning for Chaos Space Marine Legionaries (ссылка в варп) Хм, а они точно в слоте трупсы, а не элиты? Хейтфул ассаулт, пиломечь и легионер непринуждённо выдаёт 5 атак с тушки. Да даже с болтерами 4 атаки, пострелять и забить прикладами. По поводу топора (как и фиста) - Икона Слаанеш (+1 на ту хит в хтх) наше всё, плюс марка на всегда бить первым. Вообще, на данный момент, знамя и марка Кхорна кажутся самыми унылыми. Ссылка на комментарий Поделиться на другие сайты Поделиться
Siegemaster Durak Опубликовано 19 апреля, 2022 Жалоба Поделиться Опубликовано 19 апреля, 2022 Практика показывает, что они кончаются недалеко от деплоя Так что 2 атаки, 3 или 5 - монопенисуально :174_rip: Ссылка на комментарий Поделиться на другие сайты Поделиться
sidestep Опубликовано 19 апреля, 2022 Жалоба Поделиться Опубликовано 19 апреля, 2022 (изменено) Три атаки у легионера - любо! Есть мнение, что это будет вшитая по базе допатака за заглушку-шокассолт, который закономерно уйдёт. Так было бы логично, по крайней мере. Изменено 19 апреля, 2022 пользователем sidestep Ссылка на комментарий Поделиться на другие сайты Поделиться
