Monique Опубликовано 18 марта, 2016 Жалоба Поделиться Опубликовано 18 марта, 2016 (изменено) Praetorian of Dorn A Horus Heresy novel As the first assault on the Solar System begins, the strength of the Imperial Fists and the seemingly impregnable fastness they have built is tested at last… READ IT BECAUSE At last, Rogal Dorn and the VII Legion take centre stage in a Horus Heresy novel! And it's a doozy, as the assault on the Solar System begins. Or does it? THE STORY Recalled from the Great Crusade after Ullanor, Rogal Dorn and the VIIth Legion were appointed as the Emperor’s praetorians – but only after the Warmaster’s treachery was revealed did the full extent of that sacred duty become apparent. Now, the Solar System comes under attack for the first time since the war began, and many of the seemingly impregnable defences wrought by the Imperial Fists prove inadequate. With all eyes fixed firmly upon this new threat beyond the gates of Terra, who in turn will protect Dorn from the enemy within? FREE EXTRACT: ePub | Mobi 4.18 / 5 ПЕРЕВОД ГИЛЬДИИ ПЕРЕВОДЧИКОВ INTERNAL ILLUSTRATIONS (всё кликабельно, 800x1228) COVER ARTWORK (кликабельно, 1536x2048) (кликабельно, 1000x629) WALLPAPERS | ОБОИ ДЛЯ РАБОЧЕГО СТОЛА (не официальные, сделаны банальным ресайзом) 2560x1600 2560x1440 1920x1200 1920x1080 Изменено 20 декабря, 2017 пользователем Pictor Jack Ссылка на комментарий Поделиться на другие сайты Поделиться
Ulf Voss Опубликовано 26 марта, 2016 Жалоба Поделиться Опубликовано 26 марта, 2016 The Horus Heresy reaches the Solar System - will the defences of Rogal Dorn and his Imperial Fists hold against the onslaught? Recalled from the Great Crusade after Ullanor, Rogal Dorn and the VIIth Legion were appointed as the Emperor’s praetorians – but only after the Warmaster’s treachery was revealed did the full extent of that sacred duty become apparent. Now, the Solar System comes under attack for the first time since the war began, and many of the seemingly impregnable defences wrought by the Imperial Fists prove inadequate. With all eyes fixed firmly upon this new threat beyond the gates of Terra, who will protect Dorn from the enemy within? http://www.amazon.com/Praetorian-Dorn-Horu...us+heresy+books обложку еще не допилили Ссылка на комментарий Поделиться на другие сайты Поделиться
Zver_506 Опубликовано 26 марта, 2016 Жалоба Поделиться Опубликовано 26 марта, 2016 Так а сколько ж можно толкать один и тот же арт. Если память не изменяет, обрезанный Дорн был уже на облоге одного из рассказов. Ссылка на комментарий Поделиться на другие сайты Поделиться
Ulf Voss Опубликовано 26 марта, 2016 Жалоба Поделиться Опубликовано 26 марта, 2016 Так а сколько ж можно толкать один и тот же арт. Если память не изменяет, обрезанный Дорн был уже на облоге одного из рассказов. Там же написано: вариант не окончательный. Ну а другого Дорна видимо лень было искать. ;) Ссылка на комментарий Поделиться на другие сайты Поделиться
Monique Опубликовано 14 мая, 2016 Автор Жалоба Поделиться Опубликовано 14 мая, 2016 Ссылка на комментарий Поделиться на другие сайты Поделиться
HeHaBucTb Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 Драка в аквапарке. Ссылка на комментарий Поделиться на другие сайты Поделиться
BrEd Pitt Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 Это альфарии в синем? Ссылка на комментарий Поделиться на другие сайты Поделиться
Alfаrius Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 Это альфарии в синем? конечно) Ссылка на комментарий Поделиться на другие сайты Поделиться
Monique Опубликовано 14 мая, 2016 Автор Жалоба Поделиться Опубликовано 14 мая, 2016 Подозреваю, что Альфарий нападёт на Солнечную систему только ради того, чтобы указать Дорну на недочёты в обороне =| Ссылка на комментарий Поделиться на другие сайты Поделиться
Locke Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 Не, это же канарейкофил Френч пишет. У френчевого Дорна не может быть недочётов в обороне. Ссылка на комментарий Поделиться на другие сайты Поделиться
Monique Опубликовано 14 мая, 2016 Автор Жалоба Поделиться Опубликовано 14 мая, 2016 Не, это же канарейкофил Френч пишет. У френчевого Дорна не может быть недочётов в обороне. Альфарий нападёт - а недочётов-то и нет :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Str0chan Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 (изменено) "Картинка:" Что там в иллюминаторе чёрненькое белеется, Марс с Железным Кольцом? Изменено 14 мая, 2016 пользователем Str0chan Ссылка на комментарий Поделиться на другие сайты Поделиться
LND Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 Что там в иллюминаторе чёрненькое белеется, Марс с Железным Кольцом? Вполне возможно. Там слева и справа два небесных тела, это вполне могут быть спутники Фобос и Деймос. Да, и в серии после "Кибернетики" Сандерса всё идёт к битве за Барсум. Да, Деймос должен быть отбуксирован к Титану чтобы стать фабрикой по-производству оружия для СР, почему бы не сделать это после или во время высадки на планету кулаков. Если конечно спутник уже не отбуксировали, его уже отбуксировали или нет? Я уже запутался > Ссылка на комментарий Поделиться на другие сайты Поделиться
Patton Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 Вполне возможно. Там слева и справа два небесных тела, это вполне могут быть спутники Фобос и Деймос. Фобос и Деймос ничтожно малы по сравнению с Марсом, так что в масштабе их врядли видно было бы. Та же Фаланга, к примеру, побольше их будет Ссылка на комментарий Поделиться на другие сайты Поделиться
LND Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 (изменено) Фобос и Деймос ничтожно малы по сравнению с Марсом, так что в масштабе их врядли видно было бы. Та же Фаланга, к примеру, побольше их будет В мире к коему сделана обложка есть: пило-мечи которые режут плоть, генетически модифицированные сверх люди, тараны кораблей другими кора[эх жаль]ми, магия, пскайкерство, боги Хаоса, боги эльдар, искусственно(пока не понятно как) созданные супер-пупер-дупер люди примархами именуемые, и золотой колос - Император Всего Человечества, самый сильный псайкер за всю историю человечества, который прозревал будущие, мог по-настоящему уничтожить душу, который поставил 100000 созданных им сверх-людей и одного примарха на колени, который прожил 30000 лет, Наебал богов Хаоса, победил Дракона Пустоты или его осколок и заточил его на Марсе что привело к появлению Культа Механикум. После всего мной написанного, перечитай ещё раз что написал Фобос и Деймос ничтожно малы по сравнению с Марсом, так что в масштабе их врядли видно было бы. и пойми. Искать логику в соответствие небесных тел, в таком мире просто бессмысленно. Изменено 14 мая, 2016 пользователем LND Ссылка на комментарий Поделиться на другие сайты Поделиться
HeHaBucTb Опубликовано 14 мая, 2016 Жалоба Поделиться Опубликовано 14 мая, 2016 И при всем этом к точкам перехода в варп движутся днями. Далеко не в каждом худпроизведении но в теории тем не менее да Ссылка на комментарий Поделиться на другие сайты Поделиться
CivilWAR Опубликовано 16 мая, 2016 Жалоба Поделиться Опубликовано 16 мая, 2016 мне кажется вряд ли так близко подпустили бы даже альфу к Терре, скорей всего это где то возле Сатурна дело происходит, а в окошке видно сам Сатурн и его кольца Ссылка на комментарий Поделиться на другие сайты Поделиться
sugmar Опубликовано 26 мая, 2016 Жалоба Поделиться Опубликовано 26 мая, 2016 Мне кажется или дорн своего убил взмахом меча???? судя по траектории и трупу под мечом??? Ссылка на комментарий Поделиться на другие сайты Поделиться
Monique Опубликовано 26 мая, 2016 Автор Жалоба Поделиться Опубликовано 26 мая, 2016 Мне кажется или дорн своего убил взмахом меча???? судя по траектории и трупу под мечом??? Он решил, что это переодетый Альфа-легионер :) Ссылка на комментарий Поделиться на другие сайты Поделиться
BrEd Pitt Опубликовано 26 мая, 2016 Жалоба Поделиться Опубликовано 26 мая, 2016 Да, на заднем плане Сатурн. Не думаю, что это орбитальные доки Юпитера. Ну, если вспомнить "мегаспойлер" и роль Омегона в нем, то очень может быть, что это именно омегачи прилетели, а кулаки сдуру без разбора полезли мордобить их. Ссылка на комментарий Поделиться на другие сайты Поделиться
Sorrow_Blast Опубликовано 26 мая, 2016 Жалоба Поделиться Опубликовано 26 мая, 2016 (изменено) Толи альфарий раскачан по методике Александра курицына, толи Лорд Дорн маленький какой-то. Изменено 26 мая, 2016 пользователем Sorrow_Blast Ссылка на комментарий Поделиться на другие сайты Поделиться
Cinereo Cardinalem Опубликовано 26 мая, 2016 Жалоба Поделиться Опубликовано 26 мая, 2016 И в результате все омегачи убьются об Кулаков, в то время как Омегон доберется до Мала (а, может, и до Самого) и окончательно предаст Альфария. Ссылка на комментарий Поделиться на другие сайты Поделиться
Monique Опубликовано 27 мая, 2016 Автор Жалоба Поделиться Опубликовано 27 мая, 2016 Ссылка на комментарий Поделиться на другие сайты Поделиться
brRibbotaim Опубликовано 28 мая, 2016 Жалоба Поделиться Опубликовано 28 мая, 2016 На рабочий стол ушло, спасибо! Ссылка на комментарий Поделиться на другие сайты Поделиться
Legatus Опубликовано 28 мая, 2016 Жалоба Поделиться Опубликовано 28 мая, 2016 Арт хорош и Дорн на нем тоже! Не так давно об оружии Дорна говорили в другой теме. Вот и оно. А потому задам вопрос. Меч Дорна двуручный или мне так кажется? Толи альфарий раскачан по методике Александра курицына, толи Лорд Дорн маленький какой-то. Может это один из примархов Альфа-легиона? Он конечно, должен быть меньше Дорна, но возможно это просто м-а-аленькая погрешность красивого рисунка, чтобы отразить "примаршество" лидера Альфы?! Ссылка на комментарий Поделиться на другие сайты Поделиться
