Imperial Armour Apocalypse II
Heres a little review of all the datasheets:
Imperial Guard.
Annihalator is only 130pts
Minotaur gets struck on the weakest armour
Baneblade variants same as GW datasheets (which have dried up now)
Hades breaching drill is an elite option though doesnt take up an FOC slot biggrin.gif
Hell raker battery: 3 minotaurs and a baneblade; big firepower
castellan sentry gun defense force, can change fire mode,
Imperial Navy
Carrion Claw; s5 ap3 apoc barrage attack, imagine A10 thunderbolts attacking in unison
SM
Chaplain dread can take flamestorm cannon
City breaker squadron, land raiders that can fire pintle weapons twice, reroll terrain tests and can reroll pen hits against a selected building
Iron cyclone; dreads in pods with deathstorm. cluster bombs, then deathstorms and then dreadnaughts in pods, very cool
Thunderhawek interdictor, tempests are flyers
Imperium
Chorus of Faith, Exorcists with 2d6 missiles, cannot fire next turn
Convocation of wrath, +1 S to flamer weapons
Orks
Junka has all the cool mek gear, turbo engines similar to BA
Big Trakk, reroll terrain tests at combat speed. Lots of weapon options
Kustom Battle Fortress, can take up to 3 supa weapons and 4 pintle wepaons
Mega rippa crew, rerolol pen hits against big things, waagh!!!
Eldar
CobraDestroyer that ignores all types of shields
Death web, s6 ap- barrage, dangerous terrain test next turn
Raiding force, missiles change to s4 ap 5ignore cover, reroll shuriken cannon against infantry
Tau
Hazard has new wepaons, ion gun, assault 4 rending, fusion cascade, d3 melta, pulse submunitions rifle, 5"blast, Same rules
Broadside phalanx, reroll pen hits on nominated target
protector wing, Hazards and their dedicated and modifed orca, has a 5++ save
Chaos
Aetaos'Rau'Keres, reflect pyschic powers, d6+3 horrors, upgraded daemonic gifts, summon power of staff and call a massive barrage that ignores cover saves. Will try and destory dameon lrods etc...
Blood Slaughter, impaler is a short range missile launcher hits on a 4+ now and if it penetrates or wounds an MC it gets dragged 2d6
Mamons get improves poison of plaguebearers, can destory an objective
Urake's Headhunters force a pinnig test on everyone and can mark an IC etc... for destruction and it counts as an objective if killed
plague ogryns are more expensive and have SaP. Can eb taken in a Nurgle CSM army
Covenant of corruption, leader spawn has a 4++ save and each model killed by anythign in the fomraiton may come back as a spawn
Lament of the damned are real slaanesh dreads that can be used in normal 40k for appropriate points
Anything missed is because its stayed the same as previously updated. I hope I havent broke any copyright laws here. This should stop people asking questions for rules and stats
Весьма интересно. А когда сие чудо ожидать?
Ах чёрт, оно уже вышло, совсем я отстал от жизни )
Изменено пользователем VipeR
Судя по интерактивным страницам на ЛРР серых рыцарей наконец-то можно устанавливать ММ :) Ура! Неужели письма в ФорджВорлд не исчезли в мусорных корзинах, а возымели хоть какое-то действие :))))
Дред-чаплин радует. По превьюшке форджа и рассказам очевидцев - стоит лишь на 10 очков дороже обычного веника (тот, правда, сам по себе дикий оверпрайс, но эт неважно), имеет + 1 атаку в профиле, капелланский переброс ту-хит при чардже и может брать вторую хтх руку (или, как здесь уже сказали, флеймшторм с его С 6 ап 3 темплейтом). Т.е. 4-5 атак по 5 ВС с рероллом на ту-хит с чарджа - полтактички в один присест.
Интересно, как они слаанешевских дредов сделали. В принципе, дред с 5-й иней и дум сиреной / бластмастером это не менее интересно, вопрос лишь в очках.
Насколько я помню, он имеет те же 2 атаки, что и обычный вен. Но флеймшторми и 4+ инвуль это несомненно круто и пафосно =)
У Бьёрна 5+ инвуль есть против всех скользящих и проникающих попаданий.
И что? Вординг инвулф бьорна кто-нить читал? Не? Не будет у чапи инвуля.
За Бьёрном Импи присматривает, а Чаппи дреду только если мега распятие за спину, пусть генерирует 4++)))
вчера книжечка доехала, посомтрел правда бегло, что запомнилось:
капелан дреднот:
статы веника, т.е. 2 атаки, но может брать 2ю руку, правда тока с шб, может брать флеймшторм вместо руки. розариус не таскает, но в императора верит :)
люциус патерн:
как на ФВ в апдейте к ИА2
ЛР с 4мя спареными болтерами:
270 монет, -1 к кавер сейву от него, +1 к резервам если он на столе (не складывается с прочими бонусами), может реролить на найт-файт, 10 мест. странная хрень еще и слот элиты жрет. они издеваются. задел шикарен, но исполнение...
ГК ЛР редимер:
270 монет, 12 мест, флеймштормы игнорят инвули(джаги, джаги!), вместо асолтки псайка(дятл, дятл!), можно брать все приблуды уважающего себя ЛРа, включая ГКшные приблуды и кажется дозерблейд. теперь задержали дыхание...если из него чарджат ГК, то иня 10 и пох на террейн. начинаю задумываться о собирание ГК.
оркам дали дред с 13м лбом и 5м инвулем, раз в игру может флитануть, но на 1ку стопориться. еще дали прикольную тачанку для мека - 11 лоб, опен топед, можно воткнуть 3 спаренных роккита, поле и ШАГ(!). был бы орком взял бы 2 :).
ХСМ как всегда разгулье -
блад слотерер идет в ХС (бу-га-га), 13й лоб, +Д3 атаки на чардже, 4я иня(!), рэйдж, сквадроны по три, флит, за 5 очков берет лэш-копье - 8 сила, ап3 попадает с 4х (зачем спрашивается балистик 2й написали, или новые колдуны бладов будут убивать по балистику? :) ), если попал в технику/монстру, то по кратчайшей к себе на 2д6 сквозь все, кроме импасов. сквадроны по 3.
дрон как ожидалось скимер фаст имеет риперку (2й БС) и блевомет - 36" С8 АП3 шаблон или как огнемет с АП3, кажется. сквадроны по три. фаста.
плаг-халк, за 200 монет дефайлер с 13м лбом, блевомет как на дроне, всегда 5й кавер. берут в ХС как ХСМы так и демоны.
ИГ дали полкниги одинаковых танков, включая хрень с С6 ап3, хеви 15, которая стреляет 2 раза, если малыш стоит. еще он возит 40 парней, и считается опен-топед, но не для опонента ;).
еще дали клевую дрель, которая таки жрет слот элиты, возит ветов. имеет помороченный мельтаган. выходит дип страйком (death from below!) - кладем здоровый шаблон, скатерим, все в шаблоне ловит мельта-шот. потом выходят веты и сама хрень, что с ней делать дальше пока туманно :).
эльдарам дали очередную фантазию - как слепить 3-4 фалькона в длинну, таусятам робота в фасту, которого уже обсосали на форуме.
А у ВХ, у ВХ-то что?
ГК ЛР редимер:
плачу кровавыми слезами :image022: хаосо страдат :D
а дефа хаосятская дорогущая просто ужос
Изменено пользователем Aleksa Spektor
ГК Редимер определенно хорош, да :)
Дороговат конечно,но своих денег стоит. И даже больше =)
ВХ дали 2 формации.
3-5 экзов, один главный. раз за игру могут шмальнуть на 2д6 выстрелов в 1 цель, после чего ход не стреляют.
3 огнеметных разора + что-то там еще (3 рины с тактичками, кажется), в 1м разоре героиня с селестианками. всей тусе +1 сила огнеметам и халявные дозерблейды, если не путаю.
у чаппи-дреда нет инвуля.
ГКшный ЛР очень хорош, позволяет решить их главную проблему. был бы еще с ласками...
Там, по рассказам очевидцев, в хаоситской формации дредов слаанеша должны быть цены и статы этих самых дредов, причем цены для обычных, не-апоковых игр, это так?
там кажется за небольште очки просто меняешь основной калибр на бластмастер или этот автоматик странный (не помню как зовется), а вместо огнемета берешь дум-сирену. главный дред тоже что-то получает. но это дано только в контексте формации (т.е. надо еще заплатить за формацию в целом), отдельной энтри по слаанешитскому дреду нет, так что не ясно как юзать на турнире, например.
новый дятл, просто очередной супер-грейтер, стоит 999 очков, энтри даже не читал, ибо зачем? :)
Изменено пользователем Skiv
Какая то хрень, Скив, а зачем в ИА 7 Дрон был и Слоттерер с БС 1? По какой книжке то теперь в обычных играх играть? :(
А Imperial Armour Apocalypse II, случайно, не для апока онли? :)
Именно так))
Скив, выложи статы Темпеста, плиз, он же флайером стал?
Именно так))
А фраза на обложке: NEW RULES FOR WARHAMMER 40,000 and WARHAMMER 40,000 APOCALYPSE, просто так, для красоты присутсвует?
Более того, в первой книге для всех моделей (не формаций!) было указано, к какому слоту в Таблице Организации Армии они относятся (что для апока не нужно).
Во второй, что ли не так же?
