Крепость-монастырь Космического десанта
» Полная информация «
Fortress-monasteries are enormous fortresses where Space Marine chapters have their headquarters. Chapters are highly monastic as well as military organizations, their fighting members are all warrior-monks, their fortress-monasteries devoted both to battle and worship.
Fortress-monasteries are based on Imperial worlds, or deserted moons and asteroids. In the case of fleet-based chapters the chapter flagship serves as a mobile fortress-monastery. The locations of some chapter planets are hidden while others are well-known. The preferred location for a fortress monastery is an Imperial world, which the Chapter Master is sometimes also the planetary governor of. In other cases the Chapter Master will make a deal with the existing planetary governor, paying a tithe in return for the land they occupy. They are usually welcomed by governors, as the presence of Space Marines deters invasion.
The Fortress-Monastery of the Space Wolves
In the original Rogue Trader rulebook, the Space Wolves fortress-monastery was given a detailed description, and presented as a typical fortress of the Space Marines. At the time, their fortress-monastery was based on a world called Lucan; however in later first edition background it was changed to Fenris.
Company Chapel
The most commonly used place of worship. Every company has its own chapel located within its company block. This worship is part of the Marine brethren's regime of discipline.
Penitorium
Marine battle-brothers guilty of any kind of transgression are held here as a form of remedial and penitent punishment.
Private Chambers
These are private offices and rooms used by the various Masters of the Order, including the Master of the Ships, Master of the Forge and Master of the Ordnance.
Communal Dormitories
These contain the living and sleeping chambers of the Chapter's non-combat staff, including servants, technicians and naval personnel.
Guest Chambers
Relatively luxurious chambers reserved for important visitors such as members of the Administratum.
Foundries
The foundries are where the Marines manufacture and repair their weapons and equipment. The skilled workers of the foundries are known as Brother Artisans. Equipment is evaluated at an adjacent testing and weapon ground.
Shuttle Silos
The bulk of the Space Wolves' fleet is located in orbit and the only vessels located within the fortress are those required to get to the fleet, mostly including couriers and transport vessels.
Teleportorium
These teleporter rooms are spread throughout the base in four places and are the primary means of moving between the fortress and the fleet. Teleportorium One is used to receive guests.
Launcher Pads
Twenty four aircraft are housed in underground hangers beneath the launcher pads, including four large transports and eight high speed scouts.
Armoury
A large but crowded underground complex used to store ammunition and weaponry. The security for the whole complex falls to the Master of Ordnance and each armoury may only be entered in his presence, the doors requiring his gene-print and coded signal. In an emergency the Chapter Commander may override this with a secret spoken code.
Apothacarion
An advanced medical facility, used as a hospital, for research and as a bio-lab. This is where warriors are surgically transformed into superhuman Marines. The skilled medical staff have private quarters above the Apothacarion, while the servants and nurses share a dormitory on a lower level.
Assimularum
This is the largest room in the complex besides the Great Hall. It is a vast and high vaulted room, in which the entire chapter can be gathered. It is used for mass meetings, ceremonies, religious festivals and special feasts.
Reclusiam
The Reclusiam is usually partitioned from the Assimularum by a screen, and is used only for cult activities. It is looked after by a religious officer known as a Reclusiarch and the chapter's holy relics and many of their most precious battle trophies are kept here. The Reclusiarch has an office off to one side, and there are three private chapels dedicated to Leman Russ, The Emperor Deified and The Emperor Oracular.
Refectory
This area is for the main dining procedures and includes kitchens, store-rooms, disposal units and purification vats. The strict and simple diet of the fighting warriors are augmented by a complex bio-chem designed to maintain their superior bodies. Meals are eaten in silence following prayers of thanks by the most senior brother present.
Oratorium
There are several Oratorium spread throughout the base and are used for private meetings, lectures, briefings and small assemblies.
Librarium
The Librarium is more than a collection of books as it also acts as the central repository of records and the main seat of communications. The chapter's astropaths spend most of their time here, monitoring and broadcasting messages from the base. The Chief Librarian is in overall command of the written histories and communications within and without the base as well as the base defences. These defences are controlled from an armoured room in the Librarium. Based within this room are also the Communications Officers and a number of librarians, astropaths and technical assistants.
Cells
A cell is given to a brother to live in. They are arranged in blocks of ten, directly related to the members of a fighting squad with each of the ten blocks representing a company. Each block has a small administrative office and the private chambers of the captain.
Hydro-culture
This area contains a supply of local produce and exotic or seasonal vegetables collected and grown for the benefit of the chapter. Other chapters often maintain much larger facilities than the Space Wolves however.
Terrarium
This space is dedicated to the maintenance and propagation of plants from throughout the galaxy. It provides both a restful area and a source for some of the drugs used in the Apothacarion.
Scriptory
There are several Scriptories spread around the base and they provide instant access to unclassified Librarium files. These are accessed through a computer terminal and allows users to select, consult and record new entries for the main library.
Solitorium
The Solitorium is a remote location (outside the fortress) designed to provide brothers with a space for contemplation. It can be occupied for anything from a few days to years on end. Marines who seek promotion are expected to search their souls and go through self-deprivation for weeks on end to prove their worth.
Dungeon
The Dungeons lie deep beneath the Apothacarion and are home to the common prisoners, but not brothers who would be placed in the Penitorium. The walls are lined with reinforced diamantine although prisoners don't spend long in the dungeons before being taken to the Apothacarion for interrogation.
Generatorum
The power source for the fortress-monastery on Lucan is a group of four huge crystal-piles which penetrate the surface of the planet and convert underground heat into energy via a phased crystal interface (presumably there are many other ways of generating energy on this scale, this is but one example of the possibilities).
Defence Laser
These lasers are mounted in armoured turrets and thirty two of them remain permanently switched on. The other eighty eight may be brought to bear within four days of activation.
Local Defences
The perimeter of the base is covered by 317 separate weapons turrets including four laser cannons and a missile launcher in each.
Missile Silos
Over 400 Missile Silos are spread over Lucan and are the main force of the Space Wolves' ground to orbit weapons. They are each controlled from the armoured room within the Librarium.
Catacombs
The catacombs are the burial place for the Space Wolves and are home to many ancient heroes of the chapter.
Great Hall
The Great Hall is the first room you come to when entering the base. It is designed to awe the visiting guests and is the largest single room on the planet (Lucan). It contains many of the battle trophies of the Space Wolves and paintings of famous battles are displayed on the walls. Ancient weaponry and armour from as far back as the Horus Heresy are on display behind plexi-glass. The spacecraft Medusa, flown by Leman Russ himself, hangs from the ceiling of the room and spans its entire length.
Barbican
The Barbican is the massive gate house that leads into the Great Hall. This has a permanent guard to receive guests from overland, air and orbit.
Изменено пользователем Darog
  • Ответов 72
Company Chapel
Penitorium
Private Chambers
Guest Chambers
Foundries
Shuttle Silos
Teleportorium
Launcher Pads
Armoury
Apothacarion
Assimularum
Reclusiam
Refectory
Oratorium
Librarium
Cells
Hydro-culture
Terrarium
Scriptory
Solitorium
Dungeon
Generatorum
Defence Laser
Local Defences
Missile Silos
Catacombs
Great Hall
Barbican
А про БТ-шные ничего нет?
В кодексе написано, что они вроде как поменьше обычных полноценных крепостей и небольшие.
Каких именно помещений там нет? И какие есть, каких нет в обычной крепости-монастыре?
Ну, рог может и устарел, но там есть бесценная инфа, которая, кстати, частично не противоречит новому бек. Так что коверкать ее не получится. Кстати, советую почитать про крепость волков - это не только сама скала.
На картине - крепость СВ. Изображения остальных крепостей нет в виде схемы. Есть картинка крепости-монастыря кулаков в космосе и изображение форпоста темпларов.
Если кто знает, еще делитесь инфой.
2Darog, вывеси картинку с базой Кулаков, будь другом)
Изменено пользователем Максим Анатольевич
Блин, кажись ее потерли, а она была(( я поищу в своих архивах... но ваще странно. Она в BFG была.
Хм...как-то она на "Фалангу" не похожа...хотя если щас приму таблеточку, то там и кораблики залетает...
Кхм... Космические Волки? :?
А нафига им... Библиотека?! O_o
Случайно не она.
а это какбе разве не Скала?
Забавная штукенция. Хотя я себе это дело несколько иначе представлял: что-нибудь по форме вроде Lexx'a (какой-нибудь астероид с "хвостиком"). А так эта "Фаланга" действительно сильно похожа на крепость-монастырь Тёмных Ангелов :-
С той разницей, что у IF всё-таки астероид с моторчиком :P
Космические волки, в книге о Рагнаре он даже ходил в эту библиотеку, и там сказано, что она одна из самых лучших в Империуме. Не надо из волков делать примитивов)
На скалу вроде другой арт был. А Фаланга по описанию из "Полета Изи" как раз большой астероид с моторчиком у кучей укреплений.
<_< И совершенно не надо делать ботаников из космических волков!
Типа "знает, где книжки лежат - значит умный"? Недаром же это дело Librarium называется, что предполагает наличие Librarian'ов, которых у SW никогда не было.
У SW вместо библиариев - Рунные Жрецы, которые хранят историю легиона/ордена в устной форме. А записывают они не буковки на бумажках, но руны на оружие и броне. А что касается более долговременного носителя информации, чем Rune Priest, то такой имеется - Dreadnought. Разбудил Бьёрна нажал на кнопочку "Play", послушал истории разные и отправил дедушку опять баиньки. Вот такая продвинутая аудиокнига получается
Примитивные, не примитивные... ноги, крылья... главное - у кого хвост! Так что нечего в крепости SW делать всяким там библиотекам! У SW библиотеками должны называтся 3-4 помещения:
1. Зал для пиров,
2. Зал, где спят дредноуты (на дредах есть руны, дреды вполне могут начать рассказывать сказки уже в этом зале после пробуждения).
3-4. Арсенал и гараж (руны на оружие и транспортных средствах).
Вот, где у SW ИМХО должны дислоцироваться "знания ордена", а для чего у SW Librarium - я не знаю. Точно не для хранения знаний о родном легионе.
Разве что для персонала крепости нужна техническая литература, чтоб за техникой и помещениями сделить. А так... Волкам положено охотится, а затем пировать в своих берлогах :rolleyes:
Книжки читать - для этого есть другие чаптеры и организации в Империуме. У SW в монастыре Librarium только бы зря место занимал:
молодеж - рвется в бой, старики - учат молодеж, одинокие волки - бегают по лесам в тылу противника; им всем книжки читать некогда, а вот эпос заценить по время пира - самое оно! Ты ещё скажи, что у них в Библиотеке есть 1-е издание Кодекса Астартес и Гримнар его тайком по ночам почитывает! :D
Может, оно тут из-за просроченности бэка? Там вон у тебя по тексту ещё и про Chief Librarian что-то говорится... это у SW то? :?
_____
Что касается сабжа, то очень занятная и полезная схема. Единственная "претензия" к чертежу - "Маловато! Маловато будет!". Если это что-то вроде "перевалочного пункта", то самое оно! Крепость-монастырь для одной-двух рот. Но на целый орден?! Как-то не сильно солидно... :-
Много букаффок
На картинке только часть крепости, большая часть Клыка, по беку, в самой скале и ее подземельях. Так что вполне себе.
А теперь по порядку, опять мифотворчество, один миф о личности Русса, мы развеяли, приступил к уничтожению другого.
В книге о Рагнаре предельно четко описано, что БИБЛИОТЕКА У СВ ЕСТЬ. ТЧК.
Причем одна из самых лучших и знания в ней хранятся не только в книгах, но и в информационных кристалах и есть даже старинные и очень умные машины, а еще маринам вживляют при промывке мозгов туеву кучу информации обо всем на свете.
И, кстати, Рагнар не брезговал литературой.
Фигней страдает только молодежь по неопытности и глупости, когда взрослеют и вырастают клыки, они берутся за ум и начинают самообразовываться - значит уже не блад, а уже серый охотник, когда стал совсем умным и мудрым - станешь лонгфангом... ну, а когда стратежностю овладеешь, могут и до Лорда повысить.
Рунные Жрецы хоть и хранят всю инфу в мозгах и передают ее в устной форме, основная инфа, и в том числе о ордене хранится в базах данных и в мозгопромывочных машинах. Кстати, в кодексе СВ и ИА написано Рунные Жрецы - это те же библиарии, только использующие силы по другому.
Дредноутов, по беку, будят только в редких случаях (правда, такое ощущение очень часто эти редкие случаи наступают).
Зал для пиров - конечно есть, и он тоже описан в книгах о Рагнаре.
Ну, и напоследок, я повторю, у СВ одна из самых больших библиотек среди маров, так что ИА там точно есть... когда Русс хотел поржать хорошенько с друзьями, он брал эту книгу и они гоготали до упаду.
Не надо мифотворчества, есть прекрасный и красивый бек.
это как "один из миллиарда жителей империума видит в своей жизни СМ" - но при этом 90% книжек таки про СМ, а не про работников автоматической совковой лопаты. нормально. героическая вселенная.
опять и в который раз сам себе противоречишь. ты решись, где у них инфа - в книжках(емнип как раз с книжками там напряг был) или в инфокристаллах и машинках, плюс в головах рунжреца, который авось что расскажет, когда в настроении будет
И где я себе противоречу (Я, вообще, никогда себе не противоречу)? Умный вы наш. Информация хранится во всех видах массовой коммуникаций у СВ: ифно-кристаллах, кагитаторах, книгах (это тоже СМИ, если вы не знали), умах жрецов и промытых мозгах маринов. Все зависит от ее объема и особенности.
И после этого МНЕ лепят пред за безграмотность?
Противоречишь ты в том, что сначала говоришь, что основной источник - книги, но помимо этого есть кристаллы и тд, а потом говоришь, что основной источник как раз в базах данных и чудо-машинках.
В целом надо будет уточнить-перечитать, после чего вернуться к этому топику. ) Спасибо)
Посмотри на время, да.
Цитата:" В книге о Рагнаре предельно четко описано, что БИБЛИОТЕКА У СВ ЕСТЬ. ТЧК.
Причем одна из самых лучших и знания в ней хранятся не только в книгах (это опровержение предыдущего поста Гримнара, что книг у СВ нет), но и в информационных кристаллах и есть даже старинные и очень умные машины, а еще маринам вживляют при промывке мозгов туеву кучу информации обо всем на свете.
Вот где, здесь противоречия?
Читай-читай. Это есть в куске, когда Рагнар спускается в хранилище за какой-то инфой, и там все это описывается: как жрец ищет инфу на кристаллах, про машины и т.д.
Darog смирись с этим, как называли волков алкашами так и будут, как называли плагов говномаринами (ну или подобным) так и будут. Кто то где то сказал что волки тупые необразованные не чёсанные варвары в силовых доспехах, теперь все повторяют это. Это называется стадный инстинкт, тоже самое с оригинальной фразой какой нибудь, кто то один сказал потом каждый оратор считает своим долгом её упомянуть (последний писк моды блекджек и шлюхи)
Можно хоть днями и ночами доказывать что волки это не только бухло и морды волосатые а ещё и один из культурнейших орденов, всё рано это ничего не изменит.
Меня это так же бесит как и тебя, но с этим ничего не поделать <_<
А за стремление хоть что то изменить респект и уважуха тебе :)
>('На правах оффтопика или Нафиг Librarium из крепости SW!
А не у этого ли автора в книгах можно встретить "нечто прекрасное" вроде вот такой вот цитаты:
"A few heartbeats after the alchemical fires subsided the Thunderhawks were on the ground and what looked like every Wolf in the Fang poured out. They're all here - Ranek, the Librarians, the Iron Priests. There's a huge monster-machine they call Bjorn the Fell-Handed. / После того как завершилось действие ракет, «Громовые Ястребы» сели, и из них вывалились едва ли не все Волки Клыка. Тут и Ранек, и Библиарии, и Железные Жрецы... Здесь даже один дредноут, которого зовут Бьорн Разящая Рука."?
Это же совсем другое дело! Раз у Волков есть Librarians, то уж и Librarium должОн быть!!! <_<
Фанфики Кинга могут идти туда же, куда и фанфики Гото и многих прочих аффтаров BL. В кодексе волков ничего про Librarium не сказано. У них, насколько я помню, даже своего Chief Librarian'a нету.
Может, у волков и есть какая-нибудь библиотечка с технической литературой и т.п. - ради бога. Какая-нибудь подсобка для этого в Клыке найдется. Но к такой штуке как Librarium это отношения не имеет.
ИМХО дело тут скорее в носителе информации. Ну что такое книга??? Бумаженция в обложке! Другое дело, когда носитель информации - герой и мега крутой воин-шаман. И когда какой-нибудь чудик будет испытывать волнение, листая древний фолиант, волки над ним будут только смеяться! Одно дело получить историю с бумажки, совсем другое - из уст друдноута! Вот это действительно та "книга", открывая которую испытываешь благоговейный трепет! Понимаешь, о чем я?
Книжку Кинга я не читал, но если Кинг нашел такой способ (космоволк идущий в библиотеку в свободное от работы время и получающий от чтения неописуемое наслаждение) только для того, чтобы показать, что его герой не тупорылое "а ещё я в неё ем", то это исключительно его проблемы. Волк в очках и с книжкой в руках - это ни разу не "Вау! Какой он оказывается образованный! Букафки знает!".
Это просто нелепо и смешно. Космические волки же серьезные люди, а не латентные библиофилы!
Ага, также как и Wolf Priest это тот же капеллан + апотекарий. Но всё-таки вульф-прист - это вульф-прист, а не капеллан или апотекарий. Также и рунный жрец - это рунный жрец. Чизбургер у них называется "ройал чиз" и картошку фри они жрут с майонезом!!!
IA (WD # 258): "While the role that Rune Priests play within the Chapter is not so different from the traditional Codex role, it is in the methods they employ where they differ significantly. They act as record keepers, much like Codex Librarians, though they memorise their histories in great Sagas rather than in written form. / Роль, которую Рунные Священники играют внутри своего Ордена, не отличается от традиционных требований Кодекса, однако, методы которыми пользуются Библиарии Волков, в корне расходятся с Кодексом. Как и обычные Библиарии, Рунные Священники являются хранителями знаний и истории, свидетельства которых они складывают в великие Саги, которые, впрочем, являются устными повествованиями, а не письменными."
Кодекс космодесанта 4-й редакции: "The Librarium is also charged with the task of recording the annals of the Chapter <...>"
1) В кодексе черным по серому написано, что
- у SW не библиарии, а рунные жрены,
- а эти рунные жрецы суть хранители "устной истории" ордена.
Нет Librarians - нет и Librarium (Librarius).
Да и не говорится в кодексе SW о Librarium'e. Да и у Кинга в книгах вряд ли упоминается слово Librarium. Наверное, всё-таки Library. Но тут уж я тебе больше доверяю - я книги эти не читал. Но что я думаю о наличии библиотеки у SW - я уже сказал.
2) Смотрим на миньки:
на миньках библиариев из кодекс-чаптеров обычно имеются книги (иногда - даже пара), у SW - нету никаких книг. Рунные Жрецы не записывают истории в книги.
Какие книги могут быть важнее тех, в которых записывается история родного ордена? Никакие!
Так что выделять значительное место под никому не нужные истории - глупо. А уж тратить время на эти истории - ещё глупее. Только лишнее место и лишнее время.
И книжки для этого читать совершенно не обязательно! Когда читаешь книжки, то становишься начитанным. А это далеко не тоже самое, что и мудрым/умным.
Необходимые знания можно, например, получить, выпив кровь и сожрав носителя необходимых знаний. Испытав что-то на своеё шкуре и т.п.
Так что не надо, пожалуйста, нести всякую тзинч знает что и переиначивать красивый и стильный бэк Космических Волков.
Не надо нам волков-ботаников, когда есть хитрые и сильные зверюги :165_guns:
Все уже обсуждено до нас ©
Космические Волки
На посты Максима советую обратить внимание.
Никто конечно не выставляет целый орден библиотекарями. Но то что они живут в антарктиде не обязывает относиться к книгам наплевательски. Да еще и с такой роскошной библиотекой.
Изменено пользователем Неуловимый Джо
2Lord Lamer
несмотря на то что тема уже исчерпана , смею заметить что у Спейсвульфов в кодексе кроме пары небольших бековых рассказов про то как они дружно дают тумаков кому либо вообще больше ничего не написано, как и во многих других кодексах 3шки.
както так.
много букаффок
По порядку.
1) Это арт ГВ, если у тебя есть претензии, пиши им письма, я тут не причем. Не нравится бек, ок, так и скажи, мне по фигу на бек.
2) Кинг - официальный писатель БЛ, сотрудник ГВ. Кстати, один из вменяемых авторов. Любой пост в стиле, автор БЛ - не беков будет считаться нарушением локальных правил форума, которые не я придумал. С Гото разорвали контракт, а с Кингом продлили, он пишет еще одну книгу про волков.
3) Там библиотека\архив, я уже не помню, но сути это не меняет, тот же Либрарирум.
4) Рунные жрец - библиарий - от перемены мест слагаемых сумма не меняется, так и тут название сути не меняет. Рунные жрецы - это те же либры только немножко другие, со своими особенностями, это написано в ИА и кодексе волков. Это офф позиция ГВ.
6) Еще раз, не надо из волков делать идиотов и тупых вояк, все сложнее, и самое главное - в беке этого нет. Леман Русс, каким он был на самом деле, боремся с глупыми мифами - тут мы уже доказали, что Русс не был алкашней, а был мудрым воином и стратегом, который любил культурно провести время.
7) Тут болшей частью Имхо, которому нет подтверждения в беке.
8) Кроме историй ордена, есть еще куча информации по врагам ордена, по тем же тысячи сынам и т.д.
9) Кроме книг есть еще и инфокристаллы, кагитаторы и т.д.
10) Откуда такая ненависть книгам? Что они тебе сделали плохого?
И ваще тема не о том, есть ли у волков библиотека, она у них есть, это доказано беком от ГВ, есть и все. Тема о крепостях космических десантников вообще.
