Daddymoroz Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Вылетает игра(((( А еще каждый раз когда выхожу, мне пишут ошибку "игра мол неправильно закрылась" Ссылка на комментарий Поделиться на другие сайты Поделиться
DeathRoller Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 (изменено) Возрадуйтесь, братия, ибо принес я благую весть от пророка SOE, Мэтта Хигби! На 30 января сего года намечается выход Обновления 2 и вот примерный список того, что в нем будет содержаться: General performance increases, particularly for lower end GPUsExperience (XP) system enhancements:Dynamic XP system for player kills, players who have more kills on their current life are worth more XP. Freshly spawned players will be worth a fraction of the current kill reward.Partial damage XP for dealing damage to vehicles that you don't end up killingPopulation XP / Resource bonus moved over to continent population instead of globalBetter display of XP sources for things like defensive bonuses & population bonusesRebalancing of XP rewards to help support tasksServer transfer token available in DepotUI changes to emphasize score per minute as a primary metric of player comparisonSortable columns on outfit management & addition of "last online" columnNew weapon type for all empires: SMGShort period of invulnerability will be added to freshly spawned / revived players - breaks upon game actions such as entering a vehicle or using a weapon.Dynamic / player configurable colors for minimap & overhead indicators for enemies, friendlies, and squads within a platoonNew Hot Spot system that displays where active fights are occurring on the mapNew spawn buildings with more exits, protected balconies and easy roof access to make them less campable.Tunnel systems for amp and tech facilities to give access from spawn rooms to interior of bases and base walls without having to go above ground.Making MAXes render more reliably at long distances for players in vehiclesAA improvements, notably flak changes for turrets and skyguards, giving them some better ability to aim, although not drastically impacting their DPS.Fixes to missiles so that they more reliably detonate and actually blow stuff upAir vehicle weapon tweaksIncreases to reload speed for certain HE ground vehicle weaponsAnd of course... lots of bug fixes Изменено 9 января, 2013 пользователем DeathRoller Ссылка на комментарий Поделиться на другие сайты Поделиться
NigatiF Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 player kills, players who have more kills on their current life are worth more XP такой то не разу не буст для кемперов. Ссылка на комментарий Поделиться на другие сайты Поделиться
DeathRoller Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 А хде там буст? Таки оно должно сдлать спаун-кемпинг невыгодным занятием. Ссылка на комментарий Поделиться на другие сайты Поделиться
Тюрьминатор Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 такой то не разу не буст для кемперов. А чем это кемперов-то бустит? :? Ссылка на комментарий Поделиться на другие сайты Поделиться
капитан Никчемность Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 invulnerability will be added revived players. вот это сразу стягивает на дно все положительные моменты патча. а еще Хигби ксенофил. Ссылка на комментарий Поделиться на другие сайты Поделиться
NigatiF Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 А хде там буст? Таки оно должно сдлать спаун-кемпинг невыгодным занятием. А чем это кемперов-то бустит? Простите, я просто жопой читаю >_< Ссылка на комментарий Поделиться на другие сайты Поделиться
Inja Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Tunnel systems for amp and tech facilities to give access from spawn rooms to interior of bases and base walls without having to go above ground. Вот это весьма радует. А то надоел эпичный квест по защите в три рыла рандома АМП от набегающихх вану >_< Ссылка на комментарий Поделиться на другие сайты Поделиться
Skinnie Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 а еще Хигби ксенофил. Потому что сам за них играет. Так что останутся карабины, убивающие через пол-карты. Поставил хотфикс. Теперь игра вылетает при запуске. Зашибись пофиксили. Стим при проверки выкачивает файлы по новой и после все равно не запускается. Мне одному везет?? Ссылка на комментарий Поделиться на другие сайты Поделиться
Тюрьминатор Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 вот это сразу стягивает на дно все положительные моменты патча Зато не будет респа в виде трупа, а то я с таким уже сталкивался пару раз. Ресашься на сандерере, появляется картинка - а в ней твой труп. Или набивание экспы на воскрешаемых медиком - фишка в том что встающий "труп" можно пристрелить до того как он встал и начал чо-то делать. Каюсь, грешил этим делом иногда при обороне. Другой вопрос, почему некоторые упорно пытались так воскреситься по 5-6 раз подряд.... ;) Ссылка на комментарий Поделиться на другие сайты Поделиться
NigatiF Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Поставил хотфикс. Теперь игра вылетает при запуске. Зашибись пофиксили. таж бабуйня Ссылка на комментарий Поделиться на другие сайты Поделиться
Skinnie Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 (изменено) После 3-й проверки кэша запустил-таки, но оно говорит, что Церес закрыт. Не unavailable, а именно locked. Блин, надо было на работу идти. Изменено 9 января, 2013 пользователем Skinnie Ссылка на комментарий Поделиться на другие сайты Поделиться
капитан Никчемность Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Потому что сам за них играет. я об этом же. так что ненадо кого попало в пророки записывать. Зато не будет респа в виде трупа, а то я с таким уже сталкивался пару раз. Ресашься на сандерере, появляется картинка - а в ней твой труп. Или набивание экспы на воскрешаемых медиком - фишка в том что встающий "труп" можно пристрелить до того как он встал и начал чо-то делать. Каюсь, грешил этим делом иногда при обороне. Другой вопрос, почему некоторые упорно пытались так воскреситься по 5-6 раз подряд.... ;) теперь будут просто пехотные колонны медиков ресающих друг друга до бесконечности. качаный паяльник поднимает труп за полторы или две секунды с полным хп а теперь еще и и бессмертного, зашибись как хорошо. Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 (изменено) И зачем нужны SMG если есть карабины? И где обещанный ап пруши? Бессмертие еще и от медиков будет? Да что за бред, насколько мне рассказывали, непроходимые спанрумы придумали как раз в ПС2, и имхо это полный бред. Теперь еще и медики, ну блин. А главное хотелось бы систему, в которой игрок стремится не "фармить" в наиболее горячей точке, а двигать линию фронта. Изменено 9 января, 2013 пользователем Curator Ссылка на комментарий Поделиться на другие сайты Поделиться
Sir Lawrence Gentleshark Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 я об этом же. так что ненадо кого попало в пророки записывать. теперь будут просто пехотные колонны медиков ресающих друг друга до бесконечности. качаный паяльник поднимает труп за полторы или две секунды с полным хп а теперь еще и и бессмертного, зашибись как хорошо. Любые действия отменяют бессмертие. Единственное-забавно будет наблюдать людей, сломавших этот механизм и бегающих в инвуле. Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 (изменено) Here's what server tokens mean. On day 1 of the tokens being available, thousands or tens of thousands of players are going to transfer over to the highest population server on their region. This compounds the problem of the low pop servers - already low on people, they will become critically low and almost unplayable. At that point, you basically will have to transfer to the popular server because there's no one left on yours. If they charge a high price for this token, many thousands of people will just say screw it and quit the game rather than pay. Кстати вот согласен с человеком. Как только дадут возможность переехать - скорей всего все выберут самый густонаселенный сервак. ПС2 такая игра, где чем больше тем лучше. Тут нет инстансов. Так что если сделают возможность трансфера - погодите к нам на Церес селиться, может мы тоже куда переедем. Кстати ваш Миллер же вроде самый заселенный евро-сервак, разве нет? Изменено 9 января, 2013 пользователем Curator Ссылка на комментарий Поделиться на другие сайты Поделиться
Skinnie Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 (изменено) У меня внезапно сбросился френд-лист о_О И в аутфите не показывает никого, даже меня. Ждем короче хотфикса на хотфикс. Жесть. Изменено 9 января, 2013 пользователем Skinnie Ссылка на комментарий Поделиться на другие сайты Поделиться
Mokare Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 По последним данным Миллер все еще топ евро, а вот Церес опережает Мэллори на 0.5% по населенности. Трансферу им надо учиться у того же ВоВ. На малозаселенные сервера там почти всегда был открыт бесплатный трансфер, а вот на самые густозаселенные зачастую трансфер закрывали. И в конце концов мы тут собрались в свою кучу собраться а не тупо укатить на самый жырный серв. Ссылка на комментарий Поделиться на другие сайты Поделиться
капитан Никчемность Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 (изменено) Любые действия отменяют бессмертие. Единственное-забавно будет наблюдать людей, сломавших этот механизм и бегающих в инвуле. не любые. в текущей формулировке только стрельба и погрузка в транспорт. И зачем нужны SMG если есть карабины? зачем нужны смг надо спрашивать у тех кто играл в альфу. вообще есть некоторая вероятность что у них всеже будет сколько-то серьезный роф и они добавят альтернативу дробовикам для внезапного дакка-дакка из-за угла в спину в упор, но до появления фактических дааных гадать бессмысленно. Кстати ваш Миллер же вроде самый заселенный евро-сервак был. Изменено 9 января, 2013 пользователем Йольский кот Ссылка на комментарий Поделиться на другие сайты Поделиться
Daddymoroz Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 А они не планируют серверам мощности увеличивать и сливать в итоге в 1-3? Ссылка на комментарий Поделиться на другие сайты Поделиться
Mokare Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Вы ж все в курсе что при жарких зарубах включается замечательная фишка игры и пехота перестает отображаться на большом расстоянии? Танки остаются, сандереры, турели всякие, а пехоту ближе чем с 20 метров не видно. Особенно когда несколько платунов с трех сторон за корону. И ладно бы не видно - их невозможно атаковать! Стрельба по местам скопления противника фугасами не даст вообще ничего. КАК ОНО МЕНЯ КАК ВОДИТЕЛЯ ПРОТИВОПЕХОТНЫХ ТАНКОВ И АВИАЦИИ БЕСИТ!!!!!1111разразодинадцать. Они то, пехоты клятые, тебя за километр видят, а ты даже не знаешь чего ждать. Летишь себе мирно так, вокруг никого не видно кроме кучки танков и ТУТ ТЕБЯ НАЧИНАЮТ РАЗБИРАТЬ 4 ДВУСТВОЛЬНЫХ АА-МАКСА И У ТЕБЯ ОТВАЛИВАЕТСЯ ХВОСТ А ОТТУДА НА ГОЛОВУ ПАДАЮТ КИРПИЧИ НО НЕ НАНОСЯТ УРОНА ПОТОМУ ЧТО ДАЛЬНОСТЬ ВЗАИМОДЕЙСТВИЯ СЛИШКОМ МАЛА. Наблюдал картину боя за кроссроадс - пруля заезжает на холмик, стоит 2 секунды и взрывается к нургловой матери. Ссылка на комментарий Поделиться на другие сайты Поделиться
Sir Lawrence Gentleshark Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Нечего пихотов фармить. им и так плохо, никто их не любит. Ссылка на комментарий Поделиться на другие сайты Поделиться
DeathRoller Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Стим при проверки выкачивает файлы по новой и после все равно не запускается. Мне одному везет?? Steam users, please avoid using the Steam Validate files feature for our game. Their validate feature does not properly calculate what needs updating and could potentially delete up to 3GB of files that you will then need to re-download. We know some of you are playing in countries where you have caps on your monthly download limits and we want to save you unnecessary downloading where possible. If you feel your game assets are damaged or corrupt you should only use the Launchpad Validate Game Assets feature. You can find it by clicking the gear button on the left side of Launchpad. This function will accurately ensure that all of your game data files are in tact and up to date. Thank you Оно уже черт знает сколько на оффоруме висит ;) И где обещанный ап пруши? Тащемта, это не патчноут, а только самые значимые моменты, да. Бессмертие еще и от медиков будет? Да что за бред, насколько мне рассказывали, непроходимые спанрумы придумали как раз в ПС2, и имхо это полный бред. Теперь еще и медики, ну блин Не вижу трагедии в паре секунд инвуля на убежать из опасного места. Ссылка на комментарий Поделиться на другие сайты Поделиться
Mokare Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 Кстати инвуль во время респа на открытой территории или ревайва вполне себе хорошо работает в Батлфилде со времен Бэд Компани 2. Ссылка на комментарий Поделиться на другие сайты Поделиться
NigatiF Опубликовано 9 января, 2013 Жалоба Поделиться Опубликовано 9 января, 2013 МАГНЕ переделали щиток, он стал уже по бокам, но лучше прикрывает ноги. Или так и было и у меня глюки? Ссылка на комментарий Поделиться на другие сайты Поделиться
