Carnage Опубликовано 1 февраля, 2011 Жалоба Поделиться Опубликовано 1 февраля, 2011 (изменено) Weapon • Grenade Launchers – 100R, 20P, 15T Equip the General and his retinue with grenade launchers; effective against infantry & garrisoned infantry. Grants the 'Move! Move! Move!' ability, increasing the speed of infantry. • Sniper Rifle – 75R,35P, 15T Equips the General with a Sniper Rifle. Grants the 'Fire on my Target!' ability, granting increased range to weapons. Retinue weapons are default. • Melta Guns – 100R, 25P, 15T Equip the General and his retinue with meltaguns. 'Grants Fight Harder!' ability, lowering weapon cooldowns. Armour • Carapace Armour – 150R, 20P, 20T Grants the 'Stand Firm' ability, rendering infantry immune to suppression. • Stabilisers – 150R, 20P, 20T Grants the 'Back in the Fight!' ability, healing infantry over time. • Flak Jacket – 150R, 20P, 20T Grants the 'Incoming!' ability, decreasing damage taken by infantry. Supplementary • Sergeant - 30R, 5P, 20T Adds Sergeant to the retinue. Grants the 'Distribute Med-pack' ability. • Commissar – 40R, 10P, 20T Adds a Commissar to the retinue. Grants the 'Call Reinforcements' ability. • Vox Operator – 120R, 25P, 15T Adds a Vox Operator to the retinue. Grants the 'Refractor Field' ability. Default Abilities • n/a Globals • Imperial Guard Bunker - 150R, 5POP, 75Z Deploy an Imperial Guard bunker that can be garrisoned by infantry. Can be upgraded to a medical or repair bunker, and can be booby trapper. • Heavy Turret - 300R, 40P, 5POP, 100Z, Tier 2 Deploy a Heavy Turret equipped with Vanquisher Cannon that is effective against vehicles. Can be upgraded to an Excecutioner Cannon which is effective against all targets. • Basilisk Creeping Barrage - 175Z, Tier 2 Off-map Basilisks fire a wave of artillery shells that advance in the direction of your choice, knocking down and damaging all units. • Valkyrie Leman Russ Drop - 650R, 18POP, 275Z, Tier 3 A Valkyrie delivers a Leman Russ battle tank to the targeted location. • Rocket Run - 500Z, Tier 3 Calls in 2 Valkyries to perform targeted rocket pod runs to devastate all units. В этой теме обсуждаем Лорда-Генерала. P.S со временем как появится качественный перевод, обновлю первый пост. Изменено 1 февраля, 2011 пользователем Carnage 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Leclerc Опубликовано 2 февраля, 2011 Жалоба Поделиться Опубликовано 2 февраля, 2011 Всё-таки связист в свите дает рейнфорс, а комиссар - защитное поле. Можете проверить. Где-то в переводе и локализации закралась ошибка. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Carnage Опубликовано 2 февраля, 2011 Автор Жалоба Поделиться Опубликовано 2 февраля, 2011 Снайперка генерала совершенно бесполезная штука, такая же ненужная как и кастом шута варбоасса, только эта на т2 и стоит 35 энергии, вроде как снимает по 20 урона с выстрела, еретиков убить даже не получается. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
apocalipsis Опубликовано 3 февраля, 2011 Жалоба Поделиться Опубликовано 3 февраля, 2011 нужен ли грейд на мелты? или лучше пусть остаётся с гранатамётами? и какую бронь лучше всего использовать?(я хилящей пользуюсь) 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Leclerc Опубликовано 3 февраля, 2011 Жалоба Поделиться Опубликовано 3 февраля, 2011 (изменено) Гранатометы на т1 - очень хороши. И дамаг хороший и абилка. Особенно хороша абилка, при хорошем микро может помочь спастись от рукопашников противника или вывести отряды из-под огня. Правда я пока не приучился, и не всегда получается так действовать Мельты - вот как жест отчаяния. Когда нету никакого антитеха, а к тебе приехал вартрук или разорбэк - вполне хватит, чтобы с ним разобраться. Был конечно случай, где КС с мельтами уничтожил полностью игнорящий его Леман Русс, но в этом вина владельца танка. Лично я броню пока не распробовал, вроде все неплохи, надо подробнее смотреть. Изменено 3 февраля, 2011 пользователем RuW)Leclerc 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Brutalizer Опубликовано 4 февраля, 2011 Жалоба Поделиться Опубликовано 4 февраля, 2011 (изменено) Броня, на мой взгляд, вообще не нужна, только энергию зря жрёт, всё самое нужное даётся от свиты. Изменено 4 февраля, 2011 пользователем Rat pack 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Leclerc Опубликовано 5 февраля, 2011 Жалоба Поделиться Опубликовано 5 февраля, 2011 Броня дает полезные приказы-абилы, например на реген всей толпы игов, например на уменьшение урона толпе игов и т.д. Если собирается толпа из 3х паков ИГ + штурмачи, то броня обязательно пригодится. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Brutalizer Опубликовано 5 февраля, 2011 Жалоба Поделиться Опубликовано 5 февраля, 2011 (изменено) например на реген всей толпы игов, например на уменьшение урона толпе игов и т.д. хил даёт сержант, щит даёт комиссар Я к тому что выгоднее покупать свиту, так как похожие абилки + один дополнительный ствол в отряд + любой мужик из свиты стоит дешевле чем броня. Хотя, хозяин-барин. Изменено 5 февраля, 2011 пользователем Rat pack 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Leclerc Опубликовано 5 февраля, 2011 Жалоба Поделиться Опубликовано 5 февраля, 2011 Я говорил именно про блоб-атаки. Там массовая защита куда лучше щита коми, который может взять еще 1 отряд кроме КС по дсвою защиту. Абилка же брони берет большой радиус и как правило накрывает весь блоб. Реген от сержанта полезно давать отрядам типа штурмовиков\огров, .т.е отрядам которые часто попадают под огонь, будучи одни. А блоб выгоднее регенить весь, т.к. там урон часто распределяется по всей пехоте (абилы, сплеш) и на всех аптечками можно и не напастись. Вобщем если есть ресы, то броня абузой точно не будет =) 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
IMS^Scouty Опубликовано 6 февраля, 2011 Жалоба Поделиться Опубликовано 6 февраля, 2011 Поиграл вчера в 2вс2 генералом немного. Гранатомет очень понравился абилкой. Можно вынудить противника отступить и тут врубить абилку и к его генам прибежать. Да и глобалы у генерала неплохие. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Сержант Пэнк Опубликовано 7 февраля, 2011 Жалоба Поделиться Опубликовано 7 февраля, 2011 У меня абилка лечения 2-ой брони генерала работает только вне боя это нормально? 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
hrenoGuard Опубликовано 17 февраля, 2011 Жалоба Поделиться Опубликовано 17 февраля, 2011 нет это не нормально, точнее нормально она так то работает, просто ты видимо не замечаешь результата под огнем то. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
KachiAT Опубликовано 18 февраля, 2011 Жалоба Поделиться Опубликовано 18 февраля, 2011 Реген от сержанта полезно давать отрядам типа штурмовиков\огров, .т.е отрядам которые часто попадают под огонь, будучи одни. Вообще похорошему постоянно держать все отряды с аптечкой, спасает намного чаще чем какой-то там реген. Даром, что аптечка используется даже если все лицом в пол лежат и пытаются подняться. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Сержант Пэнк Опубликовано 18 февраля, 2011 Жалоба Поделиться Опубликовано 18 февраля, 2011 Реген работает как в кампании: пока далеко от противника здоровье восстанавливается с бешеной скоростью. Также работает на свиту, а мне казалось это пофиксили в патче 3.8. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
USSRxCiaphasCain Опубликовано 19 февраля, 2011 Жалоба Поделиться Опубликовано 19 февраля, 2011 Да он имба герой с ним войско ппц не убиваемое... аптечки+пополнялка войск+баф на стрельбу+зашита... главное аптечки заранее раздать чтобы энергии на остальное хватило 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
khulster Опубликовано 19 февраля, 2011 Жалоба Поделиться Опубликовано 19 февраля, 2011 Да он имба герой с ним войско ппц не убиваемое... аптечки+пополнялка войск+баф на стрельбу+зашита... главное аптечки заранее раздать чтобы энергии на остальное хватило И если что сам по себе работает как антипех (грены) или антитех (мелта). Ну и пушка глобальная прекрасная у него. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Сержант Пэнк Опубликовано 20 февраля, 2011 Жалоба Поделиться Опубликовано 20 февраля, 2011 Мельты командника самый дешёвый антитех - 100/20. Но и делает они не сказать что много. Дальность небольшая урон средний. Абилка не самая злая, казнь коммисара бафает сильнее. Ещё свита из мельтаганщиков умирает в первую очередь... Интересно как работает механика на абилку ускорения от гранатомётов. По анимации действует исключительно на свиту, но командник всё же ускоряется, хотя не так как остальная пехота. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
KachiAT Опубликовано 20 февраля, 2011 Жалоба Поделиться Опубликовано 20 февраля, 2011 Абилка командника с мельт бафает мама не горюй если вокруг отрядов много ) Абилка ускоряет всех КРОМЕ генерала. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
apocalipsis Опубликовано 20 февраля, 2011 Жалоба Поделиться Опубликовано 20 февраля, 2011 Абилка командника с мельт бафает мама не горюй если вокруг отрядов много ) Абилка ускоряет всех КРОМЕ генерала. Командование только раздаёт приказы, но не следует им :D Кто какой бронёй пользуется, и для каких случаев? 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
KachiAT Опубликовано 20 февраля, 2011 Жалоба Поделиться Опубликовано 20 февраля, 2011 Против нидов хорошо идёт броня на иммунитет к супрессу, в остальных случаях как правило игнорирую броню(покупаю последней) и покупаю как правило ту, что даёт защиту отрядам, т.к. защищает от всех форм урона, насколько я могу судить. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
khulster Опубликовано 20 февраля, 2011 Жалоба Поделиться Опубликовано 20 февраля, 2011 Против нидов хорошо идёт броня на иммунитет к супрессу, в остальных случаях как правило игнорирую броню(покупаю последней) и покупаю как правило ту, что даёт защиту отрядам, т.к. защищает от всех форм урона, насколько я могу судить. Точно так же стараюсь. Вторая бронь на лечение как-то не впечатляет - аптечки надежней. А связка абилок с последней брони и мельты (защита от урона + скорострельность) производит фееричный эффект, особенно когда 3 на 3 идут блобом. Так же крайне полезным бывает абилка-реинфорс всех отрядов за недорого. Особенно актульано огринов восстанавливать бывает - дорогие они гады. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Trojan1 Опубликовано 20 февраля, 2011 Жалоба Поделиться Опубликовано 20 февраля, 2011 Изредка покупаю 3 бронь) 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
LittleBelchonok Опубликовано 21 февраля, 2011 Жалоба Поделиться Опубликовано 21 февраля, 2011 Беру первую бронь, если противник опирается на пулемёты (две сюрки, два дева и т.п.). Вторую не беру никогда, бесполезная. На Т2-3 изредка беру третью, если считаю состав армий благоприятным, а деньги есть. 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Холодное Тело Опубликовано 18 марта, 2011 Жалоба Поделиться Опубликовано 18 марта, 2011 Точно так же стараюсь. Вторая бронь на лечение как-то не впечатляет - аптечки надежней. А связка абилок с последней брони и мельты (защита от урона + скорострельность) производит фееричный эффект, особенно когда 3 на 3 идут блобом. Так же крайне полезным бывает абилка-реинфорс всех отрядов за недорого. Особенно актульано огринов восстанавливать бывает - дорогие они гады. А его мельта против пехоты лучше гранатомёта или хуже? 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Баал Опубликовано 18 марта, 2011 Жалоба Поделиться Опубликовано 18 марта, 2011 По именно прямому урону хуже, но дает неплохую абилку, увеличивающую боевой потенциал своей пехоты в немаленьком радиусе... На тир2 ближе к тир3 гранатомет уже не столь актуален как на первом и раннем втором тире, так что можно смело выдавать мельту в середине игры. И к технике какой-никакой, а каунтер, и пехота под абилкой, появляющейся вместе с мельтой становится злой и неприветливой по отношению к врагами Империума... 0 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Присоединяйтесь к обсуждению
