Фаланга
ANF
первые две главы на хаммере и болтере ввели меня в ступор.сарпедона высаживают на планету полную некрон по приказу "винни" владимира пью с задачей умереть в бою. лисандер с механикус чтото творят с копьем души ну и обьявился лично сам капеллан дредноут дениятос. в общем книга намечается насыщенная событиями ;)
охренеть! его же называли погибшим.. и он чуть ли не с основания ордена... откуда он притопал?
Изменено пользователем VerdenZ
он жил и жив и его путь описан в одноименной книге дениятос
http://forums.warforge.ru/index.php?showtopic=83845
Orfos stepped slowly away from the doors. ‘Whoever you may be,’ he called, ‘whatsoever fate you may have decided for me, know that I will fight it! I am an Imperial Fist! Die here I may, but it is as a Fist I shall die!’
The doors were open. The lump of ice inside, hooked up to the walls by thick cables hung with icicles, shuddered. An inner heat sent cracks blinking through its mass. Chunks of ice fell away. Orfos glimpsed ceramite within, painted dark purple under the frost.
The ice crumbled to reveal a shape familiar to Orfos. A massive square body on a bipedal chassis, squat cylindrical legs supported by spayed feel of articulated metal. The blocky shoulder mounts each carried a weapon – one a missile launcher, the other a barrel-shaped power fist ringed with flat steel fingers.
It was a Dreadnought – a walking war machine. All the Dreadnoughts of the Imperial Fists were piloted by Space Marines who had been crippled in battle, who were kept alive by the Dreadnought’s life-support systems and permitted to carry on their duties as soldiers of the Emperor even after their bodies were ruined and useless. The Dreadnought’s sarcophagus was covered in purity seals and the symbol of a gilded chalice was emblazoned across the front.
Orfos’s bolt pistol would do nothing to the Dreadnought’s armoured body. The power fist could crush Orfos with such ease the pilot, if there was one, would barely register the resistance provided by Orfos’s body before his armour and skeleton gave way.
It would be quick. An Astartes did not fear pain, but Orfos did not see the need to pursue it as some Imperial Fists did. He had made his stand. He had not run, he had done his best to keep his battle-brothers alive. His conscience was clear. He told himself he could die. He tried to force himself to believe it.
The Dreadnought shifted on its powerful legs and the fingers of the power fist flexed. Flakes of ice fell off it. The cables unhooked and fell loose, showering the chamber floor with more chunks of ice. Lights flickered as the Dreadnought’s power plant turned over and the chamber was filled with the rhythmic thrum of it.
‘All this talk of death,’ came the Dreadnought’s voice, a synthesised bass rumble issuing from the vox-units mounted on the hull. ‘Such morbidity. I have no wish to disappoint you, novice, but you will not die here.’
Orfos swallowed. ‘What are you?’ he said. ‘Why lie you here, in a place designed to kill?’
‘Your obtuseness has not yet been trained out of you,’ said the voice again. Orfos looked for some vision slit so he might glimpse the pilot inside, but he could find none. ‘My tomb was built to ensure that none but an Astartes could make it this far. So sad the Imperial Fists chose to send Scouts to do the work of a full battle-brother. But you have made it, and I have no intention to see you go the way of that unfortunate brother who lies behind you.’
‘That is an answer to only one question,’ said Orfos. ‘I asked you two.’
‘Then I shall introduce myself,’ said the Dreadnought. ‘I am Daenyathos of the Soul Drinkers.’
Изменено пользователем Простой Русский НекоДуче Анфарий
Разве?
"Раскрывающийся текст"
В первых двух главах Сарпедона точно никуда не высаживают. Он тихо-мирно сидит на "Фаланге", ждет суда и готовит себе оправдательную речь. И если он все хорошо объяснит, то ему позволят умереть в бою, а если нет - то сдохнет как собака...
Вот так примерно :)
Изменено пользователем Nordan
оу я немного забежал вперед из спойлеров.. но так илли иначе "знающие" говорят что куда то паукадраука выгрузят для постановки точек над И
‘I see,’ said Voar. ‘Your information has been logged and will be made available to all those given the honour of examining this device.’
‘In return for this,’ said Lysander with obvious disdain for Voar’s manner, ‘the Chapter Master expects the Adeptus Mechanicus to conduct their part in the trial with all the honour that your status as a guest here demands. This is no place to settle a feud between the Soul Drinkers and the Mechanicus. No place for vengeance.’
‘Your battle-brothers are not all of the same mind,’ said Voar. ‘Nor, logic suggests, will many of the visiting Astartes agree with such a stance. There is a great deal of vengeance sought on the Phalanx, and the better part of it stems not from the Mechanicus.’
‘Chapter Master Vladimir Pugh has pronounced on the subject,’ said Lysander. ‘He has tasked me, among others, with seeing his word made law.’
‘Then it shall be abided by,’ said Voar with a nod of his head. It seemed the archmagos was not capable of any gesture of greater deference. ‘Our interest is in justice.’
‘If you cared about justice, archmagos, you would give the Soulspear to us.’
‘And if you cared about justice, brother-captain, then Sarpedon would have died on Selaaca.’ Archmagos Voar wheeled around and left the forge, the Soulspear clutched in his bionic hand.
Ему ножки хоть ампутировали? :)
А то каунтер дровосек...
Две, еще шесть осталось. Но ведь это только две первые главы :)
Йорик попросил выложить перевод одного из отрывков. :)
Орфос медленно отошёл от дверей.
- Кем бы ты ни был, и какую бы судьбу мне не уготовил, знай, что я буду сражаться! Я – Имперский Кулак! Возможно, я умру, но умру как Кулак!
Двери были открыты. Внутри содрогалась глыба льда, прицепленная к стенам покрытыми сосульками толстыми проводами. От внутреннего жара по поверхности промчались трещины, и куски льда отвалились. Орфос разглядел под ледяной коркой тёмно-фиолетовый керамит.
Лёд треснул, и появилось нечто, что было знакомо Имперскому Кулаку. Массивное квадратное тело на двуногом шасси, толстые цилиндрические ноги на опорах из членистого металла. В каждом массивном плечевом отверстии установлено оружие – в одном ракетная установка, а в другом похожий на бочку силовой кулак с плоскими стальными пальцами.
Это был дредноут – боевая ходячая машина. Всеми дредноутами Имперских Кулаков управляли космодесантники, которые были искалечены в битве, но оставались в живых благодаря системам жизнеобеспечения и могли исполнять свой долг перед Императором даже после того, как их тела стали бесполезны. Печати чистоты покрывали саркофаг дредноута, на лицевой стороне которого был выгравирован символ – позолоченная чаша.
Болт-пистолет Орфоса никак не мог повредить бронированной шкуре дредноута. А силовой кулак машины мог раздавить Имперского Кулака так легко, что пилот, если он и был в машине, вряд ли заметит, как трещат под его руками доспехи и скелет.
Это будет быстро. Астартес не бояться смерти, но Орфос не стремился к ней, как некоторые из Имперских Кулаков. Он примет бой. Не убежит и сделает всё возможное, чтобы уберечь жизни своих боевых братьев. Сознание было ясным. Орфос сказал себе, что он может умереть. И пытался заставить себя в это поверить.
Дредноут повернулся на могучих ногах и размял пальцы силового кулака, с которых упали ледяные чешуйки. Провода отсоединились, обвисли, и на пол попадали новые куски льда. Лампы замерцали, когда активировалась силовая установка дредноута, и комнату наполнил её ритмичный гул.
- Все эти разговоры о смерти... – раздался голос дредноута, рокочущий синтезированный бас из встроенных в корпус вокс-устройств, - Как нездорово. Не хочу расстраивать тебя, новичок, но ты не умрёшь здесь.
Орфос сглотнул.
- Тогда кто ты? И почему лежал здесь, в месте, предназначенном для убийства?
- Тренировки ещё не выбили из тебя глупость, - голос раздался вновь. Орфос оглядел дредноут в поисках смотровой щели, чтобы хотя бы мельком увидеть пилота, но ничего не нашёл, - Моя гробница была построена так, чтобы сюда могли добраться только Астартес. Как жаль, что Имперские Кулаки решили послать скаутов на задание для настоящего боевого брата. Но ты добрался сюда, и я не хочу, чтобы тебя постигла судьба неудачливого боевого брата, который лежит снаружи.
- Это ответ лишь на один вопрос, а я задал два.
- Тогда позволь мне представиться, - сказал дредноут, - Я – Дениятос из Испивающих Души.
http://anfarius.livejournal.com/
в общем я был вынужден
да похоже что кулаки учли все ошибки выпивох и решили отдать по бобру по здорову
кстати в хаммере мне не понравились сереброчерепушки сары коуквел джульетта пишет круче и душевнее
Вот и тюфяки. Ладно "Выпивохи", но выпилить Имперских Кулаков никто бы не решился. Плюс они могли бы кинуть клич - Копье Дорна отобрали и нагло над ним насильничают. Как бы на такое отреагировали теже БТ? Тем более блин, оружие самого Примарха огромной мощи. И так его прокакать. Мне кажется это фейл
п.с. Я так и представляю. Прилетает корабль Механикус на Клык и говорит. "Доспех вашего Примарха, что вы нашли в храме Хаоса, содержит в себе супер пружины, СШК которых утеряны, мы реквизируем этот доспех". Реакция Волков? =)
Изменено пользователем Daddymoroz
зная волков их расстреляют на орбите
И Волкам за это ничего не будет =)
[ Добавлено спустя 3 минуты 40 секунд ]
Мб это какая-нить хитрая комбинация...хотя зная Кулаков, сомневаюсь. Мб решили заручиться поддержкой шестеренок? Пожертвовать малым, чтобы получить че-нить более значительное? Или, к примеру, выпилить сомнительных личностей-черночашечников, но шоб все шито-крыто?
Ага, блады тоже расфигачат АМ за один намёк выдать им тушку Сани на эксперементы. Они на Марсе главного фабрикатора убьют, и им за это ничего не будет.
Бэковым ... или настоящим ... маринам из первого основания ваще ничего не грозит :D Они могут делать все, шо хош
Сарепдончику лапки в порядке эксперимента отпилили, или он их в честном бою потерял? Как же бедняга передвигается?
Ультрасы соберут всех главных техножрецов, и убьют их прямо перед троном Импи. И им за это тоже ничего не будет.
отрезали ради лулзов отрезали... на брюхе как еще
А вообще - да, дикость какая-то. В эпицентре воплощения не только имперского, но и маринского пафоса, т.е. на Фаланге, находится мутант, "облагодетельствованный" высшим демоном Тзинча. Сюрреалистичная картина, ИМХО.
Изменено пользователем Реанн
Погодите, ребята, куда-то вас не туда занесло :) . Если бы это было так, то Ересь до сих пор бы не кончилась.
И еще цитата из "Фаланги":
‘This is the Soulspear,’ said Voar flatly.
‘As seized at the Lakonia Star Fort,’ said Lysander. ‘The seed of the conflict between the Priesthood of Mars and the Soul Drinkers. We recovered it from the Brokenback before it was scuttled. I understand that it is to be considered your property. It was taken from you by the Soul Drinkers, and as heretics they have no right to it. Therefore its possession defaults to the Adeptus Mechanicus. Specifically, you.’
Т.е. реликвия реликвией, а законные права на артефакт - у шестеренок. Чему Кулаки совсем не рады, но "закон есть закон". Поэтому не надо обвинять их в бесхребетности, они просто маниакально честные.
Первую ему уже давно хаосит отрубил, а вторую - некроны на Селаасе. Шести оставшихся Сарпедону пока достаточно (мы, вон, вообще двумя обходимся :) ). Кулаки его пока просто исследуют - болезненно, но без членовредительства.
И еще - жизнь ему никто не обещает, при любых раскладах. Вопрос только в том, как именно он умрет.
А про остальных Душепийцев ничего нет? Даже просто упоминания? Не, ну, понятно, что они на Фаланге. Проходят те же "стандартные процедуры", что и Сарпи?
В основном там о Сарпедоне
причем его психосилы "заглушили", поэтому об остальных он ничего не знает и сильно по этому поводу переживает.
Упоминается еще только один Испивающий по имени Kaiyon, из паствы Иктиноса. Кстати, Лисандер сказал Сарпедону, что к тому моменту как этих "овечек" схватили капеллан что-то такое сотворил с их мозгами, что они все свихнулись.
Помнится, Кайону это не помогло. И он под пытками выдал всё.
Ну, как справедливо заметил Лисандер, через "перчатку боли" проходят все Имперские Кулаки и не считают это пыткой. И Кайон выдал всё не из-за боли, а именно по причине своего безумия.
И кстати - сегодня первый номер "Hammer & Bolter" вывесили в свободный доступ на сайте BL, так что каждый может составить свое мнение.
  • 1 месяц спустя...
тем временем в 4й главе роковые орлы
‘This daemon prince,’ said Hamilca, sitting opposite Varnica and taking a book for himself. ‘It is active now? The Red Night was some form of sacrifice to it?’
‘It is possible. There is more. Here – a record of its deeds. It polluted the gene pool of a triad of worlds, so they became barbarians and warred with one another. An obscene tale about Saint Voynara, who before she died gave in to despair and called upon this prince to deliver her. And its masterpiece, the crowning glory... by Terra, what foulness I see before my eyes!’
Hamilca leaned forwards. ‘Librarian? What is it? What have you seen?’
‘It took a Chapter of Adeptus Astartes,’ read Varnica, ‘and it found in them a fatal flaw. It was their pride. That same sin we all commit, brother. Our pride, our weakness. And it turned this Chapter into an instrument of its will, through trickery compelling them to do its bidding while they thought they were doing the Emperor’s work.’
‘What Chapter was this?’ asked Hamilca. ‘Many have fallen from grace or disappeared. Is this the truth behind the fall of the Brazen Claws or the Thunder Barons?’
‘No,’ replied Varnica. ‘This daemon prince, when its name was spoken, was called Abraxes. The Chapter it commanded was the Soul Drinkers.’
