Вопросы-ответы
Thorward
Лось ты не понял. В блитзкриге как раз таки поляки гарцуют на кавалерийских повозках, а чем они отличаются от обычных повозок нигде не написано.
  • Ответов 4,9 тыс
в 2 редакции они различались мувом: cav.wagon road 10, cross 8, rough 4
wagon road 6, cross 6, rough 4
в 3 редакции их упразднили до просто wagon road 12, cross 8, rough 4
Спасибо! Остался второй вопрос...
Нинаписано - значит ничем... В книге их нет, в рульбуке нет - значит нет такой сущности.Все просто...
Polish Special Rules
The Fate of the Nation, Night
Counterattack, Batalion Piechoty
(Centralised Control), Lancers, and
Szwadron Kawalerii (Centralised
Control) special rules remain unchanged.
The Deck Turret, One-man Turret, and
the remainder of the Cavalry rules are
replaced with those in the rulebook.
Replace the fifth paragraph of the
Bypassed special rule with:
When the bypassed company does
arrive, roll another die. On a roll of 1
the company arrives on the table edge
to the left of the opponent’s Deployment
Area. On a roll of 2, the company arrives
within 16”/40cm of the left-hand corner
of the opponent’s Deployment Area. On
a roll of 3 or 4, the company arrives
from the table edge at the back of the
opponent’s Deployment Area. On a roll
5, the company arrives within 16”/40cm
of the right-hand corner of the opponent’s
Deployment Area. On a roll of 6 the
company arrives on the table edge to the
right of the opponent’s Deployment Area.
If the Deployment Area is one or more
quarters of the table, pick one corner of
the table in the opponent’s Deployment
Area instead. On a roll of 1 or 2, the
left of the corner. On a roll of 3 or 4, the
company arrives within 16”/40cm of the
corner. On a roll of 5 or 6, the company
arrives on the table edge to the right of
the corner.
The guns on Polish Taczanka machine-
gun wagons are hull-rear weapons.
Polish Tanks
7TP dw and 7TP jw tanks have a
mobility rating of Standard Tank.
Taczanka machine-gun wagons are not
HMG Carriers. Their machine-guns are
hull-rear weapons.
Taczanka machine-gun wagons, cavalry
limbers, and cavalry wagons have a
mobility rating of Wagon.
Саш, по секрету, как модер говорю, приведи текст к удобочитаемому виду, который занимает меньше места.
Добрый день. Вопрос насколько жизнеспособны германские войска Confident Trained по сравнению с ConfidentVeteran.
Так как в варианте ростера с трейнд получается более менее приличное количество танков и панцергренадер.
Ровно точно так же.
Меньшая живучесть компенсирована большим количеством.
Друзья, я узнал, что есть смонтированный русский рульбук. Прошу прислать в личку или ссылку дать
В контакте в группе FOW есть.
Парни, я ищу минирулбук, в котором на английский текст наложили русский, а не вордовский док файл с русским текстом. Кто может дать ссылку?
В группе ФОВ вконтакте я нашел только русский док файл
Что-то туплю, ткните пож-та пальцем, где Кариус на мид? Нарва это же только лейт?
Спецправила в ВИ ИИРЦ. Вроде в этой теме Саша Пивной сканы выкладывал...
Возник следующий вопрос: Книга Оверлорд, британский арморед сквадрон, если его собирать как 4 armoured brigad, то можно ли брать лоррид райфл платуны, или нет. Вопрос возник в связи с тем, что в для пехоты на лорри нет возможности выбора их как 4 armoured brigad. Или их можно брать, то танки будут из 4 armoured brigad, а пехота на лорри из 11 armoured devision?
Можно, но в этом случае вся поддержка должна набираться из 11ой дивизии (т.е. поддержку 4ой бригады брать нельзя).
Такая возможность прямо прописана на с. 90:
You may take an armoured squadrom from the 4th Armoured Brigade, as a 3 RTR Armoured Squadron. If you do so all support platoons must be from 11th armoure division.
а лоррид платуны же не саппорт платуны, а випон платуны, или я что-то не понимаю?
Если мы говорим об Armoured Suadron'е на странице 90, то lorried rifle platoon обозначен как Brigade support platoon
К weapon platoon'ам у танкистов относятся только зенитные и разведывательные танки.
В первый раз решил сыграть сапёрами, поэтому два вопроса. Каждую базу из HQ можно присоединять к отдельному взводу или роте ? Вагон можно присоединить в одиночку или с ним нужны сапёры ?
1. Вагон является частью саперного отряда, но по правилу ХК саппорта ( если он докупается из ХК сапорта), он может быть присоединен к комбат или веапон платуну (т.е. становится частью отряда), при этом он дает реролл на Даг Ин отряду в 2 дюймах от комманд базы.
2. в любой пропорции в комбат и веапон платуны или вместе с SiC сформировать отдельный взвод.
Изменено пользователем bad снотлинг
