Spearhead
  • Ответов 148
ну инвуль... инвуль работает от вундов (описание инвуля, да). техника вунды не получает :)
это как за гротсника труккам дать киборк боди... красиво, но толку нет :)
На леталки формации есть?
Меня это больше всего интересует.
Вальки/вендетты
Игшные? А можно вкратце так...:)
Rapid Descent: All units in a Skyfall Spearhead must be held in
reserve. All gain Deep Strike if they do not already have it. On the
turn they arrive only roll for scatter for the first vehicle to be
deployed; any other vehicles in the spearhead are placed within
4" of a vehicle that has already been deployed and will not
scatter. In addition, shooting attacks made by the vehicles on the
turn they Deep Strike have the pinning characteristic and are
always resolved against a vehicle’s side armour.
Once you’ve selected the spearheads you will use, you
can then pick the specific units that make them up.
Each spearhead lists what type of units you can pick –
in general you will select the units from a Codex, but
some will allow you to pick from other sources.
Сов могет играть своими темпестами по апдейту ИА.
ЛРы терминусы тоже допущены...
Изменено пользователем NigatiF
OMG! O_o
А сколько скиммеров берётся в спирхэд?
Они типа эскадрона или раздельные юниты?
Пехота в них может сидеть?
OMG! O_o
Up to three.
SELECTING A SPEARHEAD
When you fight a Spearhead battle, each player is
allowed to include one spearhead of each type in his
army. Simply look through the spearheads on the
following pages and pick which ones you will use.
There are 12 different spearhead types, although each
of these can be composed in many different ways
leaving countless tactical possibilities. Picking the right
spearheads to use, and deciding which models to build
them with is important and worth careful thought. If
you are an aggressive player, then you may want to
consider formations like a Super-heavy Spearhead. If,
on the other hand, you prefer to out-manoeuvre an
enemy, then the Mechanised Assault Spearhead may be
more your cup of tea, and so on.
CHOOSING UNITS
Unless stated otherwise, all of the units in a spearhead
must be chosen from the same entry in the army list,
though they may take different options and upgrades.
Remember that even though normally an entry allows
you to buy a single vehicle, in some army lists an entry
will allow you to buy an entire squadron of vehicles!
When selected as part of a spearhead, dedicated
transports count as Heavy Support units instead, and
therefore are selected without a transported unit.
The units in a spearhead do not come for free – you
must still pay the points for the units in the spearhead
from the point’s allocation you have agreed with you
opponent. So, if you were playing a 2,000 point
Spearhead battle, then the points for the spearhead
units you use in your army would count towards the
total points value of your army.
In addition, most spearheads have an additional cost,
that covers the special rules associated with the
spearhead.
Note that you don’t have to take any spearhead units
at all if you don’t want to. However, as spearhead units
can eat up your points allocation quite quickly, if you
are going to take any, it is a good idea to select these
important formations first.
We have found playing our regular sized armies and
‘topping them up’ with a spearhead or two is a good
way to get started. We usually allow an extra 500 to a
1,000 points for spearhead units, and use these to top
up a standard army to a total of 2,000 points or so.
However, it is also great fun to play a larger game with
several spearheads on both sides.
SPECIAL RULES
Each spearhead includes one or more special rules that
are listed on the spearhead datasheets. In addition, the
following special rules also apply. Unless noted
otherwise, these rules apply only to the units that make
up the spearhead.
THE SPEARHEAD RULE
Spearheads are either specially trained units or elite
veterans that know how to act in unison and provide
each other with covering fire. To represent this, units in
a spearhead benefit from the following special
'Spearhead rule' when they are within 4" of another
unit from the same spearhead at the start of the
Shooting phase:
• Vehicles other than Walkers, that are moving at up to
cruising speed, can fire one more weapon than would
normally be permitted. In addition, this weapon can be
fired at a different target unit to any other weapons,
subject to the normal rules for Shooting. Note that
vehicles which are moving flat out may not take
advantage of this rule.
• Walkers and Monstrous Creatures may fire one
weapon after they run. Note that they may not shoot
and then run, they must always run first.
DEPLOYING SPEARHEADS
Each spearhead counts as a single unit for the purposes
of deployment and arriving from reserve, unless noted
otherwise in its entry. This means that all units in the
spearhead must either be deployed on the battlefield,
or held in reserve, and that when rolling for the arrival
of reserves a single dice roll is made for the whole
spearhead. In effect, all of the models in the spearhead
(apart from casualties) must either be on the table or
off it.
Есть спирхэды на монстров? отлично, нидам значит перепало.:)
монстрячий спирхед получает рэйдж... так что рады ниды или нет. стадо фексов бордро гарцующих за одинокой риной...
И спирхед монстров есть. Это для нидоводов я так понимаю. ;)
Для тиранидов там - 6 трупсовых подразделений с крак гранатами с силой 7. =)
Такой микро-апок получается. Нечто промежуточное между стандартной игрой и апоком.
Думаю, можно покурить на формат 2500.
У них на этом играют (АрдБойзы) по стандартным правилам, а у нас можно делать ежегодный эвент по правилам Спирхеда.
Ага, согласен, что Спирхед между Вахой и Апоком.
На стандартном столе, без Апоковских заморочек вроде замороченного деплоя и правил на расстановку, но и без стратагем и формаций (хотя формации частично и заменяются спирхедами)
Но, как мне кажется, правила несбалансированные и играть никто особо не будет
Мне идея нравится. :)
Не знаю, чем вам не нравится монстровый спирхед.
60 очков, до 6 монстров, получают КонтрАтаку, ФЧ, Рейдж и Флит.
SPEARHEAD
Up to six units with the monstrous creature unit
type. HQ units may not be selected.
SPECIAL RULES
On the Rampage: The monstrous creatures that make up the
spearhead have the following universal special rules (assuming they
don’t have them already, of course): Counter-attack, Fleet (cannot
be combined with flying creatures), Furious Charge, Rage.
Изменено пользователем Юрий Игоревич
Rage.
"Все карнифексы нашего бруда ненавидят тот спидер и бегают за ним кругами по полю" :D
Или вот:
SPEARHEAD
Two or three Tank or Walker units. One unit (the
Spearhead Leader) must be chosen from a different
army list entry to the others.
SPECIAL RULES
Protection Duty: Each time the Spearhead Leader suffers a
penetrating or glancing hit caused by an enemy shooting attack,
and after any cover saves have been taken, you can choose to
intercept the attack with any of the spearhead’s other vehicles that
are within 4". If you choose to do so, the damage is resolved
against the nominated vehicle instead of the original target
regardless of any different armour values, facings, cover etc.
За 60 очков ваш ЛР с Аббадоном точно доедет.
Я так понимаю, спирхедовские формации берутся вне фока? и 500 очей этих - тоже вне формата? То есть игра на 2000 со спирхедом фактически становится игрой на 3000?
то есть монстров как раньше расстреливали - так и будут расстреливать. а вот тервигоны, например, стоять в задних рядах уже не смогут с такой штукой.
Нет. Всё считается к размеру игры.
С сайта ГВ:
It's new White Dwarf day! Sure, it happens every month, but its not every month you get the full rules for a new Warhammer 40,000 Expansion in White Dwarf. June's issue of White Dwarf is tank-tastic: there are the rules for Spearhead (the aforementioned Expansion), which lets you game with more tanks and in more exciting ways than ever before; features on the new Deathstrike and Manticore tanks; rules for the new Eldar Night Spinner; a tank modelling workshop; and a battle report where the infantry are firmly overshadowed by battle tanks. In fact, here at HQ we were so excited when our office copies turned up this morning that Nick from the post room could have done with a tank or two to keep us at bay. Sorry Nick...
