Амфицион Опубликовано 28 марта, 2009 Жалоба Поделиться Опубликовано 28 марта, 2009 (изменено) Вобщем-то к вахе это имеет очень малое отношение(чесно говоря только формальное). но если вы вдумчиво прочитаете все пункты ваши шансы на составление хорошего ростера и адекватное развиетие ситуации на столе возрастают. Twelve Principles of Command 01 Objective. Always keep a clear goal in mind. Without it, the lives you lose are meaningless. 02 Offensive. When given the chance, attack and remain on the offensive for as long as possible. Then enemy is weakest when backing up, and so are you. 03 Unity of Command. Always know who is above and below you in the chain of command and what they are doing. It will not only help you in times of trouble, but it will also give you a better sense of how your mission fits into the overall picture. 04 Strength. Never willingly enter battle at a numerical disadvantage. Even the sloppiest army can defeat you if it is bigger. 05 Economy of Force. Do not waste your effort and supplies. Use just enough of your force to inflict the maximum amount of havoc on the enemy in the minimum amount of time. Save the rest of your strength to exploit your gains or protect yourself from counterattack. 06 Maneuver. Learn the value of maneuverability. Being able to speed across the battlefield in a coordinated wave of force can overwhelm the toughest opponent with a minimum of bloodshed. 07 Surprise. The element of surprise effectively doubles your force. 08 Intelligence. Information is like eggs, the fresher the better. A good guess might win a battle, but a bad one can eventually lose a campaign. 09 Simplicity. If a plan looks messy on paper or in a computer simulation, it is too complicated to succeed. The best plans often turn out to be ones drawn in the dirt and explained with a few hand gestures. A good solution applied with vigor immediately is better than a perfect solution ten minutes later. 10 Maintenance of Morale. Instill pride and sense of duty, worthiness, and loyalty into your soldiers. Keep them informed, rested, and happy. Officers should visit the front often, not to meddle but for personal contact with the troops. 11 Administration. This is the dullest, most mind-numbing of chores, but doing it properly is infinitely better than facing the enemy without ammunition. 12 Mercy. Be firm and win the day, but once the fighting is over, treat your prisoners with respect and courtesy. 12 Not only is it the correct and moral thing for a soldier of the Star League to do, but once enemy soldiers hear of your merciful treatment, they might also be more willing to surrender. -From "A Primer to Tactics and Strategy": 34th Edition, edited by General Aleksandr Kerensky, SLDF Press, 2742 Изменено 28 марта, 2009 пользователем Centurio Ссылка на комментарий Поделиться на другие сайты Поделиться
Preternatural Опубликовано 28 марта, 2009 Жалоба Поделиться Опубликовано 28 марта, 2009 Еще бы русский вариант. Я понимаю про что речь, но это было бы для всех хорошо ;) Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 28 марта, 2009 Автор Жалоба Поделиться Опубликовано 28 марта, 2009 (изменено) Двенадцать Принципов Командования 01 Цель. Всегда ясно представляйте конечную цель. Без этого жизни, которые Вы теряете, бессмысленны. 02 Наступления. Когда есть возможность, нападите и оставайтесь в наступлении максимально долго. Враг слабее, когда отступает, как и вы в подобной ситуации. 03 Единство Командования. Всегда знайте, кто выше и ниже Вас в цепи командования и что они делают. Это не только поможет Вам в случае возникновения проблем, но также даст Вам лучшее понимание того, как Ваша миссия вписывается в полную картину. 04 Силы. Никогда добровольно не вступайте в бой при численном превосходстве противника. Даже самая "бестолковая" армия может победить Вас, если их будет достаточно много. 05 Экономия Ресурсов. Не тратьте впустую свои силы и поставки. Используйте только достаточно своих сил, чтобы причинить максимальное количество ущерба врагу в минимальное количество времени. Сохраните остальную часть Ваших сил, чтобы развить Ваш успех или защитить себя от контратаки. 06 Маневр. Изучите ценность маневренности. Возможность быстро и скоординировано перебрасывать силы через поле битвы может сокрушить самого крепкого противника с минимумом кровопролития. 07 Неожиданность. Элемент неожиданности повышает эффективность Ваших сил в разы. 08 Разведка. Информация похожа на мясо, чем свежее - тем лучше. Хорошее предположение могло бы привести к выигрышу сражения, но плохое может в конечном счете привести к поражению в кампании. 09 Простота. Если план выглядит беспорядочным на бумаге или в компьютерном моделировании, он может быть слишком сложным, чтобы оказаться успешным. Лучшие планы часто оказываются, нарисованными на земле и объясненными несколькими жестами рук. Хорошее решение, энергично примененное немедленно, лучше, чем прекрасное решение десять минут спустя. 10 Поддержание Морали. Привейте гордость и чувство долга, достоинства, и преданности Вашим солдатам. Держите их в курсе происходящего, отдохнувшими, и счастливыми. Офицеры должны часто посещать передовую, не для того чтобы вмешаться, но для личного контакта с войсками. 11 Управление. Это самая унылая и наиболее отупляющая из хозяйственных работ, но выполнение ее должным образом много лучше чем столкновение с врагом в отсутствии боеприпасов. 12 Милосердие. Будьте настойчивы и одержите победу, но как только сражение закончено, относитесь к своим пленникам с уважением и вежливостью. Не только потому, что это правильное и морально оправданное поведение для солдата Звездной Лиги, но и потому что когда вражеские солдаты узнают о Вашем милосердном обхождении, они будут сдаваться в плен охотнее. - из "Учебник для начинающих по Тактике и Стратегии": 34-ый Выпуск, отредактированный Генералом Александром Керенсикм (Aleksandr Kerensky), Издательство Сил Обороны Звездной Лиги (SLDF Press), 2742 г. Перевод: Звездный Капитан Андреас, Клан Койота, Галактика Дельта, 44 Резервный Боевой Кластер. 3067г ЗЫ вот черт: твоя ворона летит быстрее моей :( Изменено 28 марта, 2009 пользователем Centurio Ссылка на комментарий Поделиться на другие сайты Поделиться
sigibert Опубликовано 29 марта, 2009 Жалоба Поделиться Опубликовано 29 марта, 2009 Приветствую! Спасибо за догматы, степень их актуальности в 41 тысячелетии трудно переоценить. Я, например, все рассматриваю через свою призму начинаюшего охотника на ведьм и сестровода :) 1. Цель. Тут все просто: полное уничтожение противника (предатели, мутанты, еретики и пр., противящиеся воле Императора). На всякий случай, необходимо уничтожить всех тех, кто контактировал с врагом, видел врага, просто оказался рядом :) Типичная монодоминантская философия, верный спутник Ордо Еретикус. А насчет напрасно отданных жизней- Империум безграничный ресурс новобранцев для борьбы со злом :) 2. Возможность к постоянному наступлению нам даруют рины, химеры, иммоляторы, а также ленд рейдеры (правда, только для комсостава). Они- наше оружие и одновременно заградительные щиты. Дрожите, еретики :) 3. Тут есть ряд вопросов, кто главнее: инквизитор лорд или канонесса (а может палантинка или вообще прист?). Главнее всех Император и его божественная воля. Идем дальше. 4. Всегда надо внимательно читать ростер оппонента с калькулятором, кодексом и карандашем. Убедился на личном опыте. 5.Иными словами, максимальный урон за минимальные очки (штурмовиков звать, что ли?). И оставляем отряд для контрчарджа. 6. Так я и думал, джамппаки, рины и холи рейдж. А также, некоторые ассасины. Правда, прибежавши на место, надо найти силы, чтобы ударить. В этом уже надо уповать на силу веры... 7. Да, всегда лучше оказаться в месте, где никто не ожидает, например, во вражеском тылу. Правда, если я внимательно читал правила, можно и за краем стола оказаться... и тоже неожиданно (правда уже для меня) 8. Прочтения форумов, других кодексов и словесные выпытывания перед игрой. Все это-основные наши разведданные. 9. А вот это правильно. Надо представлять, что каждый юнит будет делать на столе. Смутные представления оборачиваются сокрушительным поражением :( 10. ЛД 10 и книги св. Люция. У нас нет проблем с моралью, в ростер мы берем только честных девушек!!! 11. Система WH 40000 избавляет нас от этой радостной необходимости. А жаль... вот еще пришлось бы покупать рожки для болтеров и провиант на 25 сестер :) 12.А вот на это враг пусть не расчитывает :) Хотя, если за столом дружественная атмосфера, то даже от поражения можно получить удовольствие От лица Ордосов Инквизиции благодарим Силы Обороны Звездной Лиги, генерала А. Керенского, а также лично Звездного Капитана Андреаса за великолепный перевод и доставку важных сведений в массы :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Umbra Опубликовано 29 марта, 2009 Жалоба Поделиться Опубликовано 29 марта, 2009 Советую также всем желающим почитать "Искусство войны" Суньцзы, там все тоже самое, только подробнее и пунктов меньше :). Ссылка на комментарий Поделиться на другие сайты Поделиться
frei Опубликовано 29 марта, 2009 Жалоба Поделиться Опубликовано 29 марта, 2009 (изменено) А так же "книгу пяти колец" Миямото Мусаси :) Изменено 29 марта, 2009 пользователем frei Ссылка на комментарий Поделиться на другие сайты Поделиться
Mad_Rat Опубликовано 29 марта, 2009 Жалоба Поделиться Опубликовано 29 марта, 2009 Если честно, это как бы и так все понятно) Вот, когда на практике реализовать надо, тогда проблемы. Клаузевица, Клаузевица читайте! Ссылка на комментарий Поделиться на другие сайты Поделиться
Usagi san Опубликовано 29 марта, 2009 Жалоба Поделиться Опубликовано 29 марта, 2009 меньше читайте,больше играйте. Ссылка на комментарий Поделиться на другие сайты Поделиться
Nit Опубликовано 29 марта, 2009 Жалоба Поделиться Опубликовано 29 марта, 2009 (изменено) Точно, точно, поддерживаю Коша. Как говорил Ма́о Цзэду́н, много будешь читать - умнее не станешь. Золотые слова. Изменено 29 марта, 2009 пользователем Nit Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 29 марта, 2009 Автор Жалоба Поделиться Опубликовано 29 марта, 2009 Вообще основной причиной выкладывания было то что после прочтения отдельных тактических опусов в Вархамерской интерпритации - волосы на голове начинают шевелиться. практика, подкрепленная теорией. теория, одушевленная практикой. Ссылка на комментарий Поделиться на другие сайты Поделиться
Xero Опубликовано 29 марта, 2009 Жалоба Поделиться Опубликовано 29 марта, 2009 Тактические изречений в вархаммере(та же Тактика Империалис) кстати вполне хватает для интерпретаций принципов командования) Ссылка на комментарий Поделиться на другие сайты Поделиться
Silence DRAG.ON Опубликовано 30 марта, 2009 Жалоба Поделиться Опубликовано 30 марта, 2009 Для тиранидов пункты 9, 10 и 12 неактуальны =) Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 30 марта, 2009 Автор Жалоба Поделиться Опубликовано 30 марта, 2009 Актуальны. 9) Куда как проще прийти и всех съесть - но работает. 10) Каждое племя\выводок должен находиться пд четким контролем сверх разума, что гарантирует его высокую мотивационную базу =) 12) Генокульт. Ссылка на комментарий Поделиться на другие сайты Поделиться
helbrecht Опубликовано 30 марта, 2009 Жалоба Поделиться Опубликовано 30 марта, 2009 Хорошие советы. Подписать бы сюда варианты тактик и всё отлично будет. :ork-up: Ссылка на комментарий Поделиться на другие сайты Поделиться
Желтый Опубликовано 30 марта, 2009 Жалоба Поделиться Опубликовано 30 марта, 2009 (изменено) Офигенные советы... для армии. Для солдатиков советы и правда странно выглядят... - Сэр, мне кажется, мой сержант как-то странно поглядывает на ту демонетку! - Идиот! Это конверсия головы такая! *БАБАХ* Тут по-моему один дельный совет - думайте головой блин, что, почему и зачем вы делаете. И тогда шансы облажатся будут меньше. Изменено 30 марта, 2009 пользователем Желтый Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 30 марта, 2009 Автор Жалоба Поделиться Опубликовано 30 марта, 2009 (изменено) Офигенные советы... для армии. Для солдатиков советы и правда странно выглядят... - Сэр, мне кажется, мой сержант как-то странно поглядывает на ту демонетку! - Идиот! Это конверсия головы такая! *БАБАХ* Тут по-моему один дельный совет - думайте головой блин, что, почему и зачем вы делаете. И тогда шансы облажатся будут меньше. ну так: но голове нужна смазка и стартер, мазка - индивидуально, а стартер - вопросы и тезисы , типа вот это. касательно МВП - подразумевайте себя и вашего противника. Изменено 30 марта, 2009 пользователем Centurio Ссылка на комментарий Поделиться на другие сайты Поделиться
