Тюрьминатор Опубликовано 19 марта, 2021 Жалоба Поделиться Опубликовано 19 марта, 2021 (изменено) риверы со всеми изменениями по 10 птс это какой-то неадкватный ход кмк То есть враки по 20 штук в 5++ и трансхумане за 8 птс это адекватный?)) Изменено 19 марта, 2021 пользователем Тюрьминатор Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 19 марта, 2021 Жалоба Поделиться Опубликовано 19 марта, 2021 (изменено) враки тоже грязь да , особенно с 5 фнп к этому всему "враки разрывают сраки"(с) Took a look at stratagems: Some stuff got dropped, some stuff changed, some new things. Murderous Descent is going to be bonkers and really hated by our enemies, that's for sure. Cruel Deception - Use it after a unit Falls Back. It can shoot or fight. 2 CP and it can do both. The Great Enemy - pick a unit, it rerolls everything against Slaanesh units until the end of the Fight phase. Toruturer's Craft - Urien or Coven unit, when they are selected to fight. Until the end of phase, re-roll wounds. If used on a character or a unit of 10 or less Wracks, it costs 1. Lightning Fast Reactions - in shooting or fight, pick a targeted drukhari infantry, vehicle or biker (no covens or urien). It is hit on -1. Hunt from the shadows - use in enemy's shooting phase. If a drukhari unit has Light Cover, +1 armor save. Alliance of Agony - if you have a Warlord Realspace Raider Archon, a succubus and a haemy gain a Warlord trait. Tolerated Ambition (NEW) - once per battle, if you have a drukhari warlord, you may generate a trait for a non-warlord. Twice in Strike Force lists, thrice in Onslaught. Prizes from the Dark city - additional relic. twoce om Strike Force Webway Portal - 1 or 3 CP, pick an Infantry, Biker or Beast unit and drop them in from the Webway. One use. Pain Syphon (NEW) -if a Drukhari unit destroys an enemy unit with melee or ranged while 6' form a Cronos, they treat PFP as it was 5th turn all the time. Eviscerating Fly-By - pick a Fly Cult unit at the end of movement. Pick a unit it moved over - on 5+, that unit takes a Mortal. +1 to the roll, if it was an infantry unit. Never Stationary (NEW) - Use after shooting. Pick a non-aircraft drukhari unit. You can make a move of up to 7' with it. It can't charge. 2 CP Prey on the Weak (NEW) - pick a Core unit in shooting or fight phase. Until the end of that phase, that unit re-rolls 1s against units below starting strength and re-rolls all hits against units under half strength. Screaming Jets - you can leave a Vehicle in reserve. Once per battle. Deadly Rivals (NEW) - 2 CP, pick a unit of Helions and a unit of Reavers in the command phase. Until the end of turn, they gain +1 Movement and re-roll all hits in melee. Swift Outflanking (NEW) - 1 CP. Use at the end of the Movement. Select one Transport within 9' of the battlefield's edge. Place in into strategic reserves. Murderous Descent (NEW) - the really, really neat one. Use it after a Transport is placed on the battlefield in the Reinforcment step. A unit in it can DISEMBARK LIKE NORMAL, but it must end it's disembarkment 9' away from enemies. Did someone say 11-slot Raider full of Incubi and Drazhar or Lelith + 10 Bloodbraids? Pray they don't take you alive - If you kill an enemy Warlord in melee with a Drukhari unit, enemy units substract 1 from Combat Attrition test until the end of the battle. Enhanced Aethersails - Pick a Raider or Ravager in movement. It advances 8'. Crucible of Malediction - 2 CP, Use in psychic phase, pick a Haemy. Each psyker within 12' of him takes D3 Mortals on 4+ (roll for each). Once per battle Haywire Grenades - Pick a unit with Haywire grenades who is selected to shot. Select one model from it - it can only make one attack and pick an enemy vehicle within 6' of it. if it hits, it deals D3 Mortals. Hyperstimm Backlash - 2 CP, Use in command, Pick a Wych unit. Double the efect of Los Drogos on it until your next Command. A unit with Phial Bouquet Relic can't be the target of this stratagem. Shock Prow (NEW) - 1 CP. Pick a Shock Prow Unit (if you buy a shock prow for a vehicle, it becomes a Shock Prow Unit) that finished a Charge move. Pick one unit in engage: If a unit is a Vehicle, it takes D3 mortals on 2+ If it's not, roll a D6 for each model in that unit that is within Engagement with the Shock Prow unit. For each dice result that equals or exceeds the unit's T, it takes a Mortal. Time to mow them pesky Primaris. Potent Metallotoxins (NEW) - 2 CP. Pick a Drukhari unit in shooting or fight phase. IT'S POISON WEAPONS CAN NOW AFFECT (Non-Titaic) VEHICLES TILL THE END OF A PHASE. YOU CAN LITERALLY BLOW UP TANKS WITH SQUADS OF KABALITES HOLY BALLS Изменено 20 марта, 2021 пользователем Locke Ссылка на комментарий Поделиться на другие сайты Поделиться
Knijnik Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 хе-хе-хе. Ждем-с наплыва любителей минек и бэка)))) Ссылка на комментарий Поделиться на другие сайты Поделиться
Отец-основатель CHAOS_Stich Опубликовано 20 марта, 2021 Отец-основатель Жалоба Поделиться Опубликовано 20 марта, 2021 Все конечно стало сильно приятнее но пока не ясно - что с денаями. Очень хочется увидеть что то кроме обоссаного шлема для денаев, я уж про морталки Аля некроны и не мечтаю, хоть без этого всякие ктаны становятся реально проблемой Upd - походу мы снова без нормальных денаев :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Knijnik Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 Девочка с котиком твой выбор Ссылка на комментарий Поделиться на другие сайты Поделиться
DarthM Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 хе-хе-хе. Ждем-с наплыва любителей минек и бэка)))) А? Что? :D (сарказм и шутка) Прайсы на наборы еще не утекали? Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 (изменено) я уж про морталки Аля некроны ну буржуи прям ссуться от войдмайнов как возмоность внести оч много морталок. про денай да - не бэково , но нужен был какой-то драубэк - хотя я бы придпочел чуть меньше резайленса , но с денаями Прайсы на наборы еще не утекали? набор друкхари + сестры - 170 доллариев , комбат патруль - 140 Изменено 20 марта, 2021 пользователем Шикарный Манул Ссылка на комментарий Поделиться на другие сайты Поделиться
Отец-основатель CHAOS_Stich Опубликовано 20 марта, 2021 Отец-основатель Жалоба Поделиться Опубликовано 20 марта, 2021 Девочка с котиком твой выбор Она нам теперь ломает павер фром пейн Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 (изменено) сукуба конечно удобно закачивается - 12 атак 2+ 2+ -3 2 при чем без привязки к культу (хотя трейт с морталкам наверное сильно лучше чем +2A если я правильно прочел вординг) Изменено 20 марта, 2021 пользователем Шикарный Манул Ссылка на комментарий Поделиться на другие сайты Поделиться
ApofisHebi Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 Интересно, у Лилит есть возможности 2 раза ударить в конце файт фазы, 1 раз с свою команд абилку если убила модель, и 1 раз за страту культа. Это как работает, одну на выбор или у нас тут какая то шинковалка бомжей с генерацией 4х хитов при "6" с трейтом? Ссылка на комментарий Поделиться на другие сайты Поделиться
literally who Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 >это чувство когда ты скупал геллионов за копейки, начиная с крови феникса. Ну, я думаю кодекс уже все видели. Лильку жалко, а так всё супер. От кодекса в шоке, очень много вкусного, но вичкульт апнули оче сильно. Шок проу и чейн снэрс это просто топчик, уже не терпится закачать рейдеры и вонзацца в хтх по фану. Ждем-с наплыва любителей минек и бэка)))) Ага, у нас уже тауводу рекомендовали пересесть за ДЭ. Ссылка на комментарий Поделиться на другие сайты Поделиться
Тюрьминатор Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 Ага, у нас уже тауводу рекомендовали пересесть за ДЭ. У нас таувод почитал статы варриоров с возможностью апа в труборнов и у него уже на этом моменте конкретно обуглилась жопа. Ссылка на комментарий Поделиться на другие сайты Поделиться
Omen Опубликовано 20 марта, 2021 Жалоба Поделиться Опубликовано 20 марта, 2021 (изменено) Интересно, у Лилит есть возможности 2 раза ударить в конце файт фазы, 1 раз с свою команд абилку если убила модель, и 1 раз за страту культа? за страту культа нельзя, там по кейворду "Вички". а самой лильке чтобы активироваться второй раз нужно кого то зарезать. ЗЫ: риверы по 10 очевидно опечатка. в испанском кодексе они по 20. это старая ошибка, ее уже фиксили. ЗЫЫ: 20 враков в 5++ только на четвертый ход. а так они в 6++ и 5+++. и больше нет имба-страты на рес полного отряда. можно сказать что враки просели в выживаемости заметно Изменено 20 марта, 2021 пользователем Omen Ссылка на комментарий Поделиться на другие сайты Поделиться
Отец-основатель CHAOS_Stich Опубликовано 20 марта, 2021 Отец-основатель Жалоба Поделиться Опубликовано 20 марта, 2021 Эльфы-злодеи правда на вид вышли толковыми - не смотря на сохранившийся перекос в область ХтХ по крайней мере там теперь есть выбор из опций того - как и чем зарезать противника а не просто как в этом самом ХтХ помереть. Здорово что те же Вичи хоть и конкурируют с Инкубами - но реально могут найти свою нишу - с набросом стратегем девочки, судя по калькулятору - могут навалить не хуже клоунов при том что стоят ощутимо дешевле. (набор страток из книжки-кампейнда для культ оф страйф - прям огонь огненный) Так же отрадно что был таки решен вопрос доставки причем по всем фронтам - тут и плюсы к чаржу и чарж после эдванса и +1 место в технике, а дип рейдера с выходом из него за страту - это вообще фактический авточардж. Наконец и в плане стрельбы все стало качественно лучше благодаря нормализации реролами, апа гороха и повышения живучести кабалитов (второй сейв в ковре - это таки не хер собачий, да еще и с инвулем). Только чувака ответственного за псифазу хочется покарать - без изменений оставили не только шлем но и самую всратую стратегему в мире что раздает за 2КП (ДВА!) кп морталки на 4+(!!!) да еще и раз за игру - за эти очки с этим ренжом (12) и таким шансом не кинуть 4+ - эту стратегему никто и никогда не юзал, кроме как по приколу. Ссылка на комментарий Поделиться на другие сайты Поделиться
ApofisHebi Опубликовано 21 марта, 2021 Жалоба Поделиться Опубликовано 21 марта, 2021 за страту культа нельзя, там по кейворду "Вички" Точно, май бэд... это вообще фактический авточардж Что я упустил, там же вроде в 9" от, врага всё так же, даже под обмазами на +1 к примеру и реророл каким, все еще 8", не 9 конечно, но на авточардж не очень похоже? Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 21 марта, 2021 Жалоба Поделиться Опубликовано 21 марта, 2021 Лильку жалко Если речь о миньке - то да , говно . Если о правилам - то она весьма интересна и слабой точно не явлется. Ссылка на комментарий Поделиться на другие сайты Поделиться
Отец-основатель CHAOS_Stich Опубликовано 21 марта, 2021 Отец-основатель Жалоба Поделиться Опубликовано 21 марта, 2021 Точно, май бэд... Что я упустил, там же вроде в 9" от, врага всё так же, даже под обмазами на +1 к примеру и реророл каким, все еще 8", не 9 конечно, но на авточардж не очень похоже? Так после высадки ты можешь ещё идти и эдвансить. Ссылка на комментарий Поделиться на другие сайты Поделиться
dimon_metalist Опубликовано 21 марта, 2021 Жалоба Поделиться Опубликовано 21 марта, 2021 Там же вррде в реинфорсмент, значит двигаться уже нельзя Ссылка на комментарий Поделиться на другие сайты Поделиться
Отец-основатель CHAOS_Stich Опубликовано 21 марта, 2021 Отец-основатель Жалоба Поделиться Опубликовано 21 марта, 2021 Да, точно Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 21 марта, 2021 Жалоба Поделиться Опубликовано 21 марта, 2021 Шо эксперты думают по ФГЛам? ворс ит ? Ссылка на комментарий Поделиться на другие сайты Поделиться
Knijnik Опубликовано 22 марта, 2021 Жалоба Поделиться Опубликовано 22 марта, 2021 Шо эксперты думают по ФГЛам? ворс ит ? Конкретезируй запрос))) Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 22 марта, 2021 Жалоба Поделиться Опубликовано 22 марта, 2021 стоят ли себя новые фантазм гренед лайнчеры) стоит ли их если не максить то брать в заметном кол-ве Ссылка на комментарий Поделиться на другие сайты Поделиться
Knijnik Опубликовано 22 марта, 2021 Жалоба Поделиться Опубликовано 22 марта, 2021 стоят ли себя новые фантазм гренед лайнчеры) стоит ли их если не максить то брать в заметном кол-ве Максить бы не стал, а на сдачу брал обязательно. Морталочка лишней не будет Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 22 марта, 2021 Жалоба Поделиться Опубликовано 22 марта, 2021 Эм я неправильно прочитал вординг и при трех хитах не будет 3х морталок (с одного ФГЛ)? Ссылка на комментарий Поделиться на другие сайты Поделиться
ApofisHebi Опубликовано 22 марта, 2021 Жалоба Поделиться Опубликовано 22 марта, 2021 при трех хитах Да вроде нормально всё. Есть хит есть 2д6 на морталки. Есть 3 хита, 3 по 2д6. Иначе было бы что-то типа "если хотя бы 1 хит" и тп. Ссылка на комментарий Поделиться на другие сайты Поделиться
