Тысяча Сынов
Я не понял - судя по ростеру ТС Магнус теперь не ЛоВ? Или как?
  • Ответов 248
ЕМНИП в стриме упоминалось, что всё-таки ЛоВ.
по тс
Reroll 1s on the invulnerable saves is out. I didn’t catch what new aura we got.
Legion Trait sounded like +6″ spell range (first cast per model).
Dark Matter Crystal (a relic) allows you to remove a unit close to the bearer from the board and redeploy the unit via deep strike.
Dark Hereticus is still in and there are plenty of more spells.
Aspiring Sorcerers can take other spells (unsure if you can take it on top of Smite or if you drop Smite).
Glamour of Tzeentch spell gives one of your unit -1 to hit protection.
Doombolt spell does some damage and reduces target units move.
Temporal Manipulation is another spell but I have no idea of what it does.
Tzaangor Shaman is an elite choice and not HQ. The Shaman can reroll a Psychic test (probably the Elixir from AoS).
Tzaangor Enlightened can take bows and shoot magical arrows that auto-wound on to hit rolls of 6+. Assault 1d3 shots.
Lord of Forbidden Lore Warlord Trait give an additional spell.
There is a stratagem that allows a unit to set up in the webway or something like that. Deep strike. Works on Tzaangors at least.
Veterans of the Long War is still in!
Mutalith Vortex Beast buffs nearby units. Like reroll charge rolls if you’re in the 6″ aura.
Кстати насчёт Муталиса, опять же ЕМНИП там рандомная таблица баффов. Кидаешь каждый ход. Реролл на чарж был вроде на 5-ке.
Mutalith regens 1W a turn, on flyer size base (no flight stand though), grants bonuses to army, can explode when killed. Wounded Mutalith is S7 A4. Mutalith has a table of powers it can use/roll on each turn. One is reroll charges.
Tzaangor have Death to False Emperor
Rubrics and Scarabs have access to spells beyond Smite
Jetbikes have 4W, 80 points before weapons, squad size 3-10
1K Sons codex coming soon/quickly but can’t say exactly when. Being very cagey about 1K Sons info beyond what’s directly relevant to the game. 1K Sons Codex explains why/how they have Hellbrutes
Magnus WT: Knows an additional psychic power (4 total)
Trajaan W7; 250 points
1K Sons Stratagem to improve psychic test(s) – no details
Vexillus Praetor 5W, or 6W in Allarus armor
Tzaangor Enlightened have 3 equipment options, fatecaster greatbows (D2 looks like) and two others to be revealed later. Max Size 9. “Very fast”, compared them to Windrunners
Veterans of the Long War is in for 1K Sons
Castellan axes have the same shooting profile as guardian spears
Чтобы не флудить в теме про кустов напишу сюда
Компиляция честно украдена из постов Шикарного манула
про стрим с игры между невышедшими пока кодексами ТС и Кустодиев нет, не художник
Aspiring Sorcerers can take other spells (unsure if you can take it on top of Smite or if you drop Smite). One they previewed today was giving a friendly squad -1 to hit. Every Thousand Sons Psyker gets an additional 6" to their range.(first cast per model - Legion Trait ).
Mutalith Vortex Beast buffs nearby units. Like reroll charge rolls if you’re in the 6″ aura.Mutalith regens 1W a turn, on flyer size base (no flight stand though), grants bonuses to army, can explode when killed. Wounded Mutalith is S7 A4. Mutalith has a table of powers it can use/roll on each turn. One is reroll charges.
Magnus WT: Knows an additional psychic power (4 total) Magnus lost rerolls to 1s.
Действительно, зачем изобретать и лепить новые миньки - взять все лучшее из ФБ и АОС - вот путь победы!
Непонятно, будут ли каирик аколиты - в кодексе демонов они упоминаются, в батлрепорте - нет
Птицеголовые корчи это лучшее, что есть в АОС у тзинча?
Они хоть демоны-то? Или так, хз кто (птицеголовые_культи_из_рояля_в_кустах) но в т4?
базовые тзаангоры уже были в 40к (давно) , дали шаманов и продвинутых тзаангоров
нет не демоны
Вот кому-кому, но уж точно не тысячникам ныть про старый модельный ряд.
Будет ли Гаунт, интересно? По стилистике он явно ближе к герольдам 40к, чем те же Тзангоры... с луками...
С ЛУКАМИ, КАРЛ!!!! А... Блэээт.... я валяюсь просто! У них же были болт-пистолеты, им нужна была спруя какого-нибудь тех-оружия и все такое, но их оставили тупо с луками!!!
Я понял бы еще, если бы они были демоны. Сейчас бы, в 40к, стрелять в ЛР из лука, блэээт.
Я вот прям буквально пару недель назад выдал в ролевке Черный Поход тзинчиту демонический лук, как в воду глядел)
Цыганрожки с луками это реально перебор. Цыган-Шаман, ещё норм с Тысячниками. Ещё монстр этот смутил, ФБшный, Mutalith Vortex Beast.....Уж кого, кого, а его среди Тысячников я не представлял.....Такое ощущение что он у ГВ плохо продается, и надо было дать дополнительный стимул народу для его покупки.
А он и плохо продается, они уже пытались бустить его дополнительными правилами на марки Тзинча и Кхорна (для его брата, собирающегося из той же коробки) в АоСе.
Вероятно да , плохо продавался . Но это по сути большой спавн. Так что с точки зрения лора монопенисуален.
Его кстати нет в дисциплах тзинча в АоСе кек)
Проблема не в луках кмк , а в том что в АоСе петуханы это "уважаемые" марочные бестигоры и им самое то иметь элиту. А в 40к - скорее скам . И в итоге вместо самобытных дисциплов сыны больше выглядят как цирк на выезде .
С ЛУКАМИ, КАРЛ!!!!
Теоретически им можно поклеить чейнсворды и автопистолеты от обычных птицекозлов, но это будет выглядеть не сильно лучше, а играть сильно хуже
Возможно, пропишут, что луки символизируют что то тзинчитское тугой изгиб зада, показываемого остальной Вселенной, например
Да только это были не дикари с трофейными бенозопилилками, а вполне в себе уверенные звери
Если бы это воплотили в современных реалиях моделькостроения, был бы совсем другой эффект
Ладно с козлами, но муталит ? Хрень, которую , казалось, похоронили вместе с ФБ из-за ее тотальной ненужности и крайней уродливости тащить 5 лет спустя в 40К ?
ну одной жопой решили присесть на два стула(да именно на те два стула)
чсх для ДГ сделали уникальную культоту и не потащили ее в АоС (как и блайткингов в 40к)
ну то есть когда культяпки киркой и гаечным ключом в ЛР долбатся и могу что-то сделать это ок, а магическая тварь, магического бога, стреляющая магическими стрелами из магического лука НУ ЭТО ЭРЕБОР.
То что вархаммер местами не соответствует чьим-то представлениям о прекрасном, то что ж поделать то?
Тзангоры там на планете колдунов ещё с роуг-трейдера тусуются.
И уж если очень хочется техно, то оно есть у них. Правда я бы не сказал что это кардинально меняет дело.
Изменено пользователем Omega-soul
Можно попробовать изловчиться и как-нибудь приделать им снайперки или что-нибудь из экзотических видов вооружения 30к, например. Тогда и "гримдарковость" будет соблюдена и правила на луки к этому хорошо зайдут. Но у меня пока ни одной модели нет, так что даже не представляю насколько это будет сложно сделать.
На правах идеи и обсуждения: винтовки от скитариев очень даже не плохи для подобного. Набрал себе для конверсий под дарк -еси, но если бы стояла задача делать огнестрельное оружие вычурное для тзангорхов, то тоже хорошо бы пошло, как мне кажется.
Конечно. Культяпки и поксики долбятся ТЕХНОЛОГИЧНЫМИ кирками и Технологичными гаечными ключами.
Ну ок, ну ладно - вы прикалываетесь? Взгляните на арбалет Гейфакс - стильно, модно, молодежно. Широкополая шляпа охотника на ведьм из средних веков, но с атрибутикой 40к. Доспехи. Подтянутая задница, на шпильках... ухх.. Да, вот такое 40к мы любим.
А Тзангоры с луками в 40к - это Тзангоры с луками из АОС и ничего больше. А можно было тоже луки стилизовать под 40к.
Но зачем? Это же "Магические луки"... это же "варп" мать его.
Даже Чубакка ходит с боукастером на магнитном ускорении. То есть можно и с луками, конечно, но все-таки как-то привести это все к знаменателю 40к, не?
