Дамокловы мечи
A high-pitched whine from above became a roar, then a deafening boom. The ground shook hard, jolting Bravestorm even with his command cocoon’s dampeners set to combat mode. A bulky blue invasion pod had crashed into the smoking undergrowth of the magnorail siding behind them, large enough to hold a Broadside battlesuit with room to spare. Ramp-like hull sections fell flat against the earth, clouds of violet dust swirling around them. A barrage of flak burst outward, baffling Bravestorm’s sensor suite with a storm of light and noise. On reflex the commander shot upward in a graceful leap, repulsor jet pack carrying him above the blue-armoured craft. The rest of his team followed his example without needing to be told – all bar the hotheaded Shas’ui Fal’ras, who instead levelled his fusion blaster and plasma rifle at the craft’s interior.
The thing that stormed out of the invasion pod was truly monstrous. Twice the size of a battlesuit and wider than it was tall, it was a hideous caricature of the Hero’s Mantle. It looked like a walking tank rather than a piloted suit, and it had articulated claws in place of ranged weapon systems.
‘Some kind of heavy war drone,’ transmitted Bravestorm. ‘No living thing could survive that impact. Analyse at range, then take it down.’
Splayed feet clanged as the machine crunched down the hull plates of its insertion craft. Flak blasted from frontal launchers that bracketed a slab-like midsection. Fal’ras fell backwards, opening fire. His plasma bolts sizzled ineffectually across the machine’s monolithic hull. Bravestorm and the rest of his team added fire from above. The volley scorched the thing, melting small dents into its hide, but achieved little more.
Fal’ras waited for it to clear the transport and fired his fusion blaster, confident of a point-blank kill. Searing columns of superheated energy shot out, gouging a deep groove into the thing’s hull and cooking off its remaining frag launchers.
The machine did not fall.
Giant claws shot forward with piston quickness. There was a tearing shriek of metal, and Fal’ras’ battlesuit was caught, impaled upon the whirring grinder inside the thing’s right fist. The shas’ui came apart in hideous indignity, suit and pilot mingled horribly in sprays of sparking electricity and hot blood.
Lumbering forward, the Imperial machine made a clumsy grab for Bravestorm’s leg. The commander smoothly rose out of reach before dropping sharply behind it, kicking the machine whilst it was mid-step in an attempt to overbalance it. It was like striking a loaded freight cube. He sent plasma bolts searing into the pistons at its hip, hoping to take its leg and send it sprawling. The white-hot energies spattered away without effect.
The thing was gathering speed, charging for the staggered lines of tau infantry that had formed up near the transmotive. The strike teams pock-marked its frontal armour with streams of plasma, and Bravestorm’s team added their fire. The combined fusillade turned the machine’s armour from cobalt blue to burned and blasted black, but it charged forwards nonetheless.
‘Controlled retreat!’ shouted Bravestorm over the cadre-net. ‘It’s iridium-plated!’
The fire warriors moved backwards in good order, some climbing back into the transmotive as others hurled photon grenades to buy them time. The devices detonated with blinding flashes, but they had as much effect as a pin-torch shone at a rampaging krootox.
A pug-nosed Imperial gunship roared overhead, its chugging anti-personnel cannons cutting down the fire warriors gathered close by the transmotive cylinder. The team’s cohesion broke, but their passage was hindered by the sprawling corpses of their comrades, and the resulting confusion cost them dear. The metal beast bore down on them, its footsteps shaking the earth.
Bravestorm punched his weapons yield to full, siphoning every iota of power from his shield generator to pour shots into the machine’s flank, but the thing barrelled through plasma fire and burst cannon volley alike. He had moments left before it reached the infantry. The thought of the slaughter that would ensue made the commander’s gorge rise.
Bravestorm boosted over the thing’s head, spinning mid-leap to land with a crunch right in its path.
‘Fight me then, monster!’ he shouted, his speakers blaring his challenge loud. He levelled a double shot at the hulking thing’s vision slit. The salvo did little more than scorch it. The war machine took the bait nonetheless, its entire torso swivelling at the waist as it swiped its demolition claw in a backhand arc. The disc of Bravestorm’s shield took most of the impact, but the blow connected hard nonetheless. His battlesuit flew backwards to crunch bodily into the transmotive’s transit cylinder, the impact caving in the reinforced metal of its side.
Muddled pain flared in Bravestorm’s head, his eyesight blurring even as his control cocoon’s systems glitched and shorted. His damage display suite pulsed red, alert chimes ringing insistently. The commander rerouted power, struggling to get the suit back online.
He could feel the Imperial death-machine stomping towards him, deadly purpose in every earth-shaking step.
The sensor suite fizzed back to life, and Bravestorm set his jaw as he levelled another volley. Still it did nothing. The monster had to be built specifically to resist plasma.
The thing was lumbering on, fire warriors scrabbling away from it on all sides. He did not blame them. They had two choices – flee, or die where they stood. Though he felt revulsion to admit it, perhaps the scattering infantry had the right idea.
Wan light glinted from the Imperial walker as it stormed in close, only fifteen feet away now. Its gauntlet fist flexed wide, the drills of its demolition claw whirring.
Bravestorm crouched and triggered his jump jets, shoulder-barging the thing with all the thrust he could muster. He rebounded hard from its torso, triggering his repulsor jets to skid away through the sparse undergrowth of the magnorail siding.
The machine tried to correct its charge, but its momentum was too great. It ploughed into the transmotive with such force it bowled an entire transit section over, twisting the rest of the conveyor along its length with a hideous shriek of alloys.
Bravestorm made use of the reprieve to cast about himself, searching desperately for a weapon that could deal with such heavy armour. Above him, the aerial struggle for supremacy raged on, as many contrails of humanity’s pollutants discolouring the skies as there were clean white traces of the air caste. From the west, an Imperial gunship screamed in towards them for a strafing run, guns levelled.
This time Bravestorm was ready.
‘Form a line on these coordinates!’ Symbols of request-clarification blipped on his command suite. ‘For the Tau’va! Do it now!’
Bravestorm vaulted into the air, spinning to land atop the nearest transit cylinder’s ejection cradles. His team redeployed into a line leading away from the transmotive. Just as Bravestorm had suspected, the Imperial pilot could not resist the choice enfilade in front of him. The gunship thudded fat shells into Bravestorm’s Crisis team, knocking two of them down – but in doing so, it aligned itself with the unstoppable Imperial walker beyond.
Bravestorm’s jump jets flared as he leapt from the roof of the transmotive to soar on a collision course with the gunship. The fist-like prow passed within arm’s reach. At that precise moment the commander opened fire at point-blank range into its cockpit. The plasma bolts burned the pilot to molten sludge just as the gunship’s wing slammed hard into Bravestorm’s side. Tremendous forces tore at him – it felt as if his limbs were being wrenched from his body, but incredibly the suit’s iridium held fast.
The gunship fared much worse. With its wing buckled and its cockpit ablaze, its strafing run turned into a headlong dive. Flames coursed along its fuselage as the bull-nosed gunship hurtled down to earth. Just as the Imperial walker was freeing itself from the stricken transmotive, the ruined aircraft slammed right into it with catastrophic force.
A mangled confusion of gunship, walker and transit cylinder slewed over the magnorail track before detonating spectacularly. The explosion lit the sky, Bravestorm’s displays auto-dimming a moment before a mushrooming cloud of smoke billowed from the carnage. The twisted bodies of the gunship’s Space Marine passengers mingled with the corpses of those fire warriors caught in the transit cylinder, tumbling down the siding in bloody confusion.
Bravestorm landed clumsily, his balance taken by the impact of the gunship’s wing. He overlaid a hostiles filter as he righted himself, sending the data pulsing outward. Those of his battlesuit team still standing after the Imperial craft’s pass went to work. Their plasma rifles, all but useless against the heavy walker, blasted apart the dazed Space Marines that were struggling from the gunship’s wreckage.
More fire warriors emerged from the transit cylinders to either side of the wreck, pulse carbine shots cutting down those gue’ron’sha emerging from the hexodome’s perimeter in support of their fallen kin. Here and there a wounded Imperial warrior returned fire, mass-reactive bolts punching tau infantry into the dirt, but in doing so they signed their own death warrants. Bravestorm eye-flicked target designators one after another, his weapon systems systematically destroying the remaining invaders whenever they revealed their locations. Every time his threat sensor chimed, another Space Marine was cut down.
‘Commander,’ came the transmission from his trusted saz’nami aide Et’rel, ‘there are several invaders here that are well beyond threat parameters, but still technically alive.’
‘Leave them,’ said Bravestorm, his battlesuit picking through the rubble. ‘They fought with courage and pose no further danger to us. Secure a perimeter. I have data to accrue.’
The burning wreckage of the transmotive had buckled in a great loop that dangled over the siding, and the ruined gunship had flipped over to expose the torn passenger bay beneath. In the middle of the carnage was the heavy walker, half-crumpled by the tremendous impact of the crashing aircraft.
Bravestorm hovered closer, his sensor suite on high alert for any sign of threat. There was information to be harvested here, information the earth caste would value highly. Perhaps there were materials the Imperium made use of that surpassed even the hardiness of his battlesuit’s iridium alloy. Unlikely, but O’Vesa would never forgive him if he didn’t at least try to find out.
Milky liquid drizzled from the crippled war machine’s chest unit, bubbling and popping in the electrical fires swathing its legs. Lubricant, thought Bravestorm. He zoomed in. The fluid was shot through with blood.
Something was moving inside the torso unit. Something broken and sick.
Bravestorm held his plasma rifle steady and extruded a hand from his battlesuit’s shield gauntlet. Gripping the blackened metal of the machine’s midsection, he carefully lifted the flaking hull plate up and outward, leaning forward to peer inside.
The creature that stared back made his breath catch.
A twisted and grotesque figure was trapped inside, all barrel chest and atrophied stumps. It stared up at him from sunken sockets, its undisguised hatred almost palpable. Wires and tubes penetrated its horrifically abused body in a hundred places. It wheezed, red-black fluids spilling from a broken jaw that worked and gummed as if it could click back into place through willpower alone.
A glut of milky liquid poured from around its sutured waist as it jerked, spitting a gobbet of half-clotted blood onto Bravestorm’s ochre paintwork. Bravestorm’s sensor suite performed a threat analysis as the liquid burned through his synth layer. The clot was laced with a potent acid.
The commander recoiled as the thing’s stink was filtered through his olfactory relay, and the battlesuit jerked upright in response. His autotrans flashed, spool-script rendering the creature’s slurred words in the tau lexicon.
‘– –DIE IN PAIN – – FOREIGN WORM THING – –’
Standing upright, the commander placed a hoof-like foot upon the creature’s torso and triggered the punch-cylinder under its sole. A thin tube of titanium thumped into the thing’s ruined flesh before withdrawing with a neat click. The device was intended for geological analysis, installed by the earth caste to be used whenever the tau set foot on a new world, but Bravestorm knew from experience it could read biological information just as well.
Keeping one eye on the plasma rifle’s designator, he used the other to scan the assessment screen in the rounded corner of his cocoon. The necrotic thing was human, or a close derivative. Extensive tissue damage, rejuvenation scars, and…
The commander looked again in horror.
Somehow, the vile thing was over six thousand years old.
A macabre realisation crept through Bravestorm’s mind. This abomination had been trapped in its armoured war-coffin long before the tau’s ancestors had first emerged from their caves. What manner of enemy were they fighting upon Dal’yth?
‘– – KILL ME – – VEXING FOOL – –’ spooled the autotrans. ‘– – KILL ME – – OR I SHALL HUNT YOU UNTIL DEATH – –’
Bravestorm triggered his plasma rifle, and the creature met its final oblivion.
Сказ о том, как Дерзкобурец дредноута убивал и от древности его офигевал, осознавая, что мерзость заточили в бронированном гробу ещё до того, как предки тау вышли из пещер. More fire warriors emerged from the transit cylinders to either side of the wreck, pulse carbine shots cutting down those gue’ron’sha emerging from the hexodome’s perimeter in support of their fallen kin. Here and there a wounded Imperial warrior returned fire, mass-reactive bolts punching tau infantry into the dirt, but in doing so they signed their own death warrants. Bravestorm eye-flicked target designators one after another, his weapon systems systematically destroying the remaining invaders whenever they revealed their locations. Every time his threat sensor chimed, another Space Marine was cut down. Ну и ещё систематически валил обычных космодесантников одного за другим, выцеливая их, когда те стреляли в пехотинцев тау. Плачь, Дарог.
  • Ответов 134
Самое веселенькое здесь то, что Отважного Шторма (как мы знаем из дополнения Анклавов) ждёт точно такая же судьба, как дредноута :D
Подождём развернутого спойлера от Rost_Light'a - поскольку это продолжение новой версии "Аркунашской войны" от Фила Келли, интересных моментов тут будет очень много.
еще одна книжка про непобедимых тау :D
забавно да, ну собственно тау надо продавать
Тау и Империум в негласной иерархии гв это как геи и цветные меньшинства. Только тау имеют место повыше. :)
The soulless creations combined the firepower of a Dreadnought with the agility of an Assault Marine.
БСК тау - бездушные творения, сочетающие огневую мощь дредноута с ловкостью штурмового десантника. :rolleyes:
В смысле?Какая судьба может его еще ожидать?)Брэйвсторм и так по сути дредноут - он не может покинуть свой БСК,который является его системой жизнеобеспечения.Он даже по назначению похож,только вместо адамантиевой брони у него иридиумная,а вместо силовых клещней - онагровые перчатки.)
Это просто шедевр - таких определений не было даже в русской версии 4-ки. :D
Изменено пользователем Nelo Angelo
Поскольку эта книга описывает войну за Дал'ит, на момент её начала Отважный Шторм пока что является обычным командующим в БСК. Получить посылку с перчатками-онагр и страшно пострадать в битве за Дал'рю на плоскогорье Чёрного Грома ему ещё только предстоит. Внимательно прочитав приведенный отрывок, вы бы это заметили.
Что касается "всепобеждающих тау", то "Дамокловы клинки" - просто развернутое описание упомянутой кампании на Дал'ите из дополнения анклавов, поэтому было бы странно, если бы содержание книги не соответствовало бэку.
Изменено пользователем Str0chan
Но в сапламенте вроде говорилось что на Дал'ите у Тау все было не так уж и радужно.
Да, но начальное вторжение космодесантников они сдержали довольно быстро и зачистили большую часть плацдармов. Проблемы начались позже, когда высадились бесконечные гвардейцы с титанами и кампания перешла в войну на истощение. В итоге имперцы отступили из-за необходимости драться с тиранидами, но к тау уже подошли подкрепления из других септов, и Зоркий с Тенью считали, что исход борьбы за планету на тот момент ясен.
Ультрадесантники, кстати, отлично показаны в книге: при каждом удобном моменте они тралируют друг друга цитатами из Кодекса, на всех уровнях - от рядового боевого брата до капитана :rolleyes:
То есть космодесантники держал плацдармы для большей части войск?
Всего каких-то девятнадцать полков :rolleyes:
Ультрадесантники, кстати, отлично показаны в книге: при каждом удобном моменте они тралируют друг друга цитатами из Кодекса, на всех уровнях - от рядового боевого брата до капитана rolleyes.gif
:D
Было бы славно, но такие примеры, ка "Пожиратель" Джо Паррино и "Мир-механизм" Каунтера, навевают грустные мысли.
Прошу прощения,перечитал - немного подзабыл забыл хронологию событий ;) Действительно,Брэйвсторм не изобретал бы такой велосипед,чем ему вскрыть броню дредноута,если бы у него были онагровые перчатки.)Теперь я понимаю вашу иронию по поводы судьбы Брэйвсторма,который испытал шок,увидев ''пилота'' дредноута.
Позабавил момент - ''There was information to be harvested here, information the earth caste would value highly. Perhaps there were materials the Imperium made use of that surpassed even the hardiness of his battlesuit’s iridium alloy. Unlikely, but O’Vesa would never forgive him if he didn’t at least try to find out.'')
Брэйвсторм - мародёр. :D
Они пытались захватывать плацдармы в городах гексокуполах, но тау быстро выбивали гуэ'рон'ша оттуда и сразу же начинали отстраивать разрушенное. Сикарий и Нумитор дико батт-тили по этому поводу, как и из-за того, что мирное население тау не паниковало во время боев - как будто это не вторжение всемогущих слуг Императора, а какие-то алкаши ломают палисадники.
Да, что касается 19 полков, тут нужно понимать масштабы. На карте в начале книги есть пометка, что население колоний Первого Сферического Расширения составляет >100 000 тау, а колоний второго - от десяти(!) до 10 000 тау. Учитывая, что в Имперских пехотных полках бывает до миллиона и больше солдат, то, 19 региментов - это очень много.
Ещё из интересных моментов - знаменитый диалог Зоркого с апотекарием Молотов Дорна г-н Келли целиком копирнул из "Анклавов". Что может быть лучше двойного гонорара за один текст? :D
Ну и обе стороны очень активно называют друг друга обидными словами. Ультрадесантники сыпят фразами вроде "ложная утопия", "обман галактических масштабов", "тщедушные рабы поддельного машинного разума" и т.д. Тау не дают себя в обиду и метко именуют неприятелей "крутообезьянами в синих доспехах", и удивляются, что люди направили всего несколько сотен воинов в первой волне атаки на центральный септовый мир - "эти гуэ'ла просто тупые или наглые и тупые?"
И при этом стандартный полк это где-то пятнадцать тысяч человеков и довольно сомнительно то что в полках участвовавших в ДКП были какие-то невероятные количества людей.
Изменено пользователем Faris001
Может,он просто запал ему в душу...А вы сразу про коммерцию... :rolleyes:
Келли кстати, не забыл лишний раз подчеркнуть благородство и уважение тау к противнику на примере Брэйвсторма.
Про Пьюритайда ничего не упоминается?В смысле,раскрытия как персонажа?
Даже не так, Faris001. Полки ИГ в бэке встречались - от тысячи до миллиона гвардейцев, грубо говоря. (Тот же Абнетт. Трацианский в трилогии Эйзенхорна - 750К для крестового похода был собран, а Танитский Первый-и-Единственный - всего 2К). Но как ты верно подметил, в среднем полк ИГ - 10-20 тысяч. Так что 19 полков для крупномасштабной операции это очень и очень мало. Даже по самым оптимистичным прикидкам - это 19 миллионов гвардейцев, по самым пессимистичным - 19 тысяч, по оптимальным - тысяч 200-300. Это мало для крупной межзвездной операции, даже для планетарной и то может быть маловато.
И вообще весь так называемый Дамоклов КП - вообще ни разу по масштабам не крестовый поход - 19 полков ИГ, силы девяти Орденов (около 10 было сказано), объеденные в 5 временных рот, чутка титунов и рыцарей, немного вольных торговцев, и все это дело на дюжине "основных" кора[эх жаль]х Империума - по сути фигня. Блин, да в карательной операции в книге МонтКа было больше сил, чем этом "крестовом походе". Не сравнится вот ни разу по масштабам с тем же крестовым походом Махария или в крестовым походом на миры Саббаты, где участвовало просто невероятные силы - триллион гвардейцев (сотни, да что там, тысячи полков ИГ), целые легио Титанов и несколько Орденов десанта с огромными контингентами. Только в одной крупной операции на одной планете могли быть задействованы силы свыше миллиарда гвардейцев. Ощутите разницу.
Но даже с такими относительно маленькими силами Имперцы в Дамокловом "КП" смогли конкретно так навалять тау. Хоть и с потерями.
Изменено пользователем Boooomm
Пока я прочел только треть книги, но Чистый Прилив появляется только в виде цитат его мудрых изречений, приводимых о'Шовой. Кстати, сам Зоркий благородно не стал стрелять по капитану Ультры во время его дуэли с Ярким Мечом, в результате чего первый из командующих с этим именем и погиб. Правда, о'Шова тут же отомстил за него и расстрелял кэпа.
Booom, ты забываешь, что в КП Саббат триллиону гвардейцев противостоял триллион хаоситов. На Дал'ите же изначально были десятки, даже не сотни тысяч воинов Огня, как и говорится в книге.
Вообще-то ты не прав. Имперцы не знали вообще, какие силы имеются у хаоситов на мирах Саббаты. Они даже полагали, что у них нет общего единого командования, что по сути вести завоевательный поход будет изи. Так как враги не смогут скоординировать все свои силы и можно будет легко, постепенно захватывать планету за планетой, систему за системой. Но когда начался КП, то командование поняло, что ошиблось. Хаоситы имели четкую командную структуру, имели нефиговые, хорошо обеспеченные, вооруженные, обученные и причем скоординированные силы. Хаоситы, также как и Имперцы, могли стягивать огромные силы с других планет, образовывать из разных группировок огромные и слаженные армии. Поэтому КП и длился 23 года. И поэтому Бальгаут захватили спустя 10 лет с начала крестового похода, а не как изначально планировалось - за 2 года.
— То, что происходит сейчас, вряд ли может сравниться по масштабу с Чёрным Крестовым Походом, — мягко заметил один из кастафорейских комиссаров.
Я провел некоторое время в его компании на борту «Благоволения Императора» и решил, что перед ним может простираться достаточно продолжительное и приятное будущее. Он не был откровенной докукой Императора, любил выпивку и карты и достаточно хорошо понимал, когда стоит посмотреть сквозь пальцы и не бросаться на каждое мелкое нарушение, допущенное солдатами.
— Скорее, Чёрная Потасовка, — предположил он. (с)
И как всё это относится к тому факту, что на Дал'ите было меньше ста тысяч воинов огня? :rolleyes: Соответственно, и масштабы крестовых походов против тау и людей-еретиков изначально сравнивать бессмысленно.
Ещё один прекрасный момент: Нумитор гонится за водницей тау по подземному жилкомплексу и настигает её в кабинете, где у той хранится импульсный пистолет (на случай, если придут полицаи эфирных арестовывать её за создание скульптур, что разрешено только касте Земли). Водница начинает заговаривать Нумитору зубы на тему, следует ли благородному рыцарю убивать гражданских, когда рядом столько достойных врагов (а сама тянется за пистолетом). В ключевой момент врывается благородный Сикарий и благородно втаптывает её в пол, а потом плюет на труп :D
Никак. Это относится к твоей фразе про КП на миры Саббаты. И что ты пытаешься спихнуть разницу на оценку потенциального противника. Но ты не прав. Имперцы, когда шли на миры Сббаты не знали силы противника. Просто КП на Дамоклов пролив - фигня, а КП на миры Саббаты - офигенное мероприятие по освобождению и захвату тысяч миров.
И на счет Дал'ита-Прайм. Тау были в меньшинстве, но в обороне. По всем военным трактатам, чтобы успешно провести наступательную операцию нужно обладать семикратным, а то и девятикратным численным превосходством над противником. С учетом того, что нападающие силы равны по качеству обороняющимся. Так что 100 тысяч Тау в обороне - имели преимущество над потенциальными 200-300 тысячами гвардейцев. Но все-равно, тау могли проиграть на Дал'ите-Прайм.
Как в военные трактаты вписываются космодесант и титаны?
опять же никак. но будем честны, тау будут лучше обеспечены, чем ИГ. Качество войск в плане вооружения будет получше. Помимо того, что они обладают нехилым оружием, получше лазгана, по мне, техникой в каких-то аспектах превосходящую Имперские машинки, так и обладают боевыми костюмами, в достаточном количестве. Эквиваленты дредноута. То бишь тау в большом количестве вполне способно справиться с десантом, так как могут что-то противопоставить. + титанов было не так уж и много. Титаны не бессмертны. Достаточное количество огня и их повергнет.
Окей, вот и цифры подъехали. Глава пятая, о'Шова выступает перед офицерами тау.
Ох. Нишутя. У Келли по-ходу полки по миллиону. Хотя, чего удивляться. Ему всегда было класть на бэк (хоть тут и нет никаких противоречий, но все же полк в миллионы - это редкое явление). Изменено пользователем Boooomm
И там же:
Так что Келли, возможно, пересмотрел свою идею с 19-ю полками, потому что tens of millions плюс ещё great numbers - это больше даже самой максимальной оценки.
