Astra Militarum+White Scars [1850]
"Старый"
Astra Militarum
HQ1: Leman Russ Punisher (Knight Commander Pask; Lascannon; Multimelta) [170]
Leman Russ Punisher (Lascannon; Multimelta; Relic plating) [173]
Leman Russ Punisher (Lascannon; Multimelta; Dozer blade; Camo netting) [190]
HQ2: Ministorum Priest [25]
HQ3: Ministorum Priest [25]
HQ4: Ministorum Priest [25]
HQ5: Enginseer [40]
Troops1: Infantry Platoon [483]
Platoon Command Squad (4 Flamer)
Infantry Squad (Vox; Sniper rifle; Lascannon; Melta bombs)
3x Infantry Squad (Sniper rifle; Lascannon; Melta bombs)
40 Conscripts
Troops2: Veterans (Camo gear; Snare mines; 3 Sniper rifle; Lascannon) [101]
HS1: Wyvern (Heavy flamer) [65]
Librarius Conclave (White Scars)
HQ1: Librarian (Space Marine Bike; Mastery Level 2; The Hunter’s Eye) [130]
HQ2: Librarian (Space Marine Bike; Mastery Level 2) [110]
HQ3: Librarian (Space Marine Bike; Mastery Level 2) [110]
HQ4: Librarian (Space Marine Bike; Mastery Level 2) [110]
Astra Militarum
HQ1: Commissar Yarrick [145]
HQ5: Primalis Psyker (Mastery Level 2) [75]
Troops1: Infantry Platoon [443]
Platoon Command Squad (4 Sniper rifle)
5x Infantry Squad (Meltagun; Lascannon)
Troops2: Infantry Platoon [443]
HS2: Wyvern (Heavy flamer) [65]
Fort1: Aegis Defense Line [50]
HQ1: Librarian (Space Marine Bike; Mastery Level 2; The Hunter’s Eye; Melta bombs) [135]
HQ2: Librarian (Space Marine Bike; Mastery Level 2; Melta bombs) [115]
HQ3: Librarian (Space Marine Bike; Mastery Level 2; Melta bombs) [115]
HQ4: Librarian (Space Marine Bike; Mastery Level 2; Melta bombs) [115]
Перепиленный вариант. Слабые стороны очевидны - низкая маневренность. С другой стороны - под обкастом мы довольно живучие и можем влить неплохо кубов с игнором ковра. Изменено пользователем raven2061
Конклав роляет игнор ковра для паска
Сразу видно эксперта и опытного игрока, да.
мне кажется, надо убрать конскриптов и добить платун до 50 рыл, живым фирлессным скрином сейчас никого не напугать :)
и честно, я бы избавился от паска или оставил бы два леманрасса, а варлордом сделал или Яррика (для приказов платуну, ему нужна мобильность) или обычного лорда комиссара (для вариативного
варлорд трейта, у ИГ они вкусные- и инфильтра платуну и релентлесс и приказы).
В танках начинаю разочаровываться, и от гравов страдают и шальных хайваеров/мельт сейчас полно, новые тау это вообще жуть. А платун под конклавом превращается просто во что-то неубиваемое,
достаточно нароллять инвиз и 4++ по дивинации
Просто топикстартеру не мешало еще почитать рульбук))
Одна пропущенная запятая становится всем обсуждением ростера. Форжик такой форжик.
Собственно, платун и конскрипты с хнр, платун с игнором ковра, энжинсир для паскостара. Конклав роляет игнор ковра, для паска 4++ и прочие баффы. Осталось немного очков на докачку.
Я руководствуюсь опытом своего метагейма, но:
Дозер лучше перекинуть Паску. Если застрянет Паск, отряду придется либо бросить варлорда одного, либо кататься рядом, ограничив себе таким образомманевр. При этом иммобиль простого панишера позволяет нам разделить стрельбу отряда на три цели и использовать застрявший танк как приманку для особо жадного оппонента. Релик тоже лучше перекинуть на Паска, поскольку жить тот должен до полного уничтожени сквадрона.
Кмк, имеет смысл сменить лазки и ММ на друзьях Паска на ХБ, поскольку сам Паск с 24" ломает большую часть не-СХ техники, его же друзья обычно отрабатывают по живой силе, к тому же при 3 БС и отсутствии танкхантинга справляются с техникой они хуже.
Неплохо было бы достать сетку второму танку - иметь кавер с двух направлений лучше, чем с одного.
Сильно огорчает отсутствие ККСа. Обычно альтернативные источники игнора ковра нужны, когда хочется дать приказ на ТХ/МХ, тут же его никак не достать, что сниает эффективность платуна.
Закачка ПКСа непонятна. Обычно этот юнит или по максимуму не отсвечивает, прячась за лосблоками и коврами, а то и вообще в резере, а раз попав на глаза оппоненту быстро умирает. Способов доставки его в рейндж темплейтов в этом ростере нет. Я бы либо полностью снял с ПКСа закачку, либо же дал ему 3-4 снайперских винтовки - постреливать из руины и, возможно, под приказом на пининг выполнить карточку на завал морали/пининга.
Примерно то же самое можно сказать про ветеранов: чаще всего они умирают или от оружия с игнором ковра, или в хтх с небольшими мобильным отрядом типа тройки байков. Если от второго форвардность немного поможет, то от первого не очень.
Либрам нужны мельтабомбы, в случае нехватки очков можно даже снять их с сержантов платуна, поскольку попадает либр с 5ВСом по волкерам и монстре гораздо лучше.
Либрам нужны ауспексы, хотя бы два. Ауспекс сильно помогает настреливать Паску по разнообразным 3им коврам, без него тем же скарам или даркам нет разницы между простой вундой без АП и рендингом, с ним - есть.
Я играл подобным, только платун у меня был ходячий.
Было 2а танка и флеш титерсы как третий детач. От тиррерсов был мефистон и 4 дроппода.
Впринципе вполне играбельная тема. Просто её надо правильно рулить.
так ли нужны мельты в плату[ну уж нет]? рейндж маленький слишком для такого большого пятна, мб лучше 3-4 плазмы?
Помимо блеска очередных знаний правил от топикстартера (быстренько стер то, куда ткнул Печеньк), вопрос - чем это принципиально отличается от стандартных турнирных иг, помимо того, что хуже продумано?
Ну, там было "Конклав роляет игнор ковра для паска 4++ и прочие баффы". Пропущенная запятая она такая. Наличием у меня моделей.
