Unnamed1500 Pts - IG: Doctrines Army
0 Choose Doctrines (HQ) @ 0 Pts
Regimental Organisation: Grenadiers [0]
Special Equipment: Carapace Armour [0]
Special Equipment: Chem Inhaler [0]
Allow Enginseers [0]
Allow Rough Riders [0]
0 Command Platoon (HQ) @ 188 Pts
4 Command Squad @ [188] Pts
Lascannon; Lasguns (x3); Carapace Armour; Chem Inhaler
1 Junior Officer @ [40] Pts
Close combat Weapon; Laspistol
1 Chimera @ [93] Pts
Autocannon - (IA)
Extra Armour [5]
Smoke Launchers [3]
1 Techpriest Enginseer (Elites) @ 294 Pts
Laspistol; Power Weapon
Servo-arm [0]
Surveyor [2]
4 Gun Servitors - Heavy Bolter [100]
1 Techpriest Enginseer @ [47] Pts
Servo-arm [0]
Surveyor [2]
6 Grenadiers @ 183 Pts
Hellguns (x4); Meltagun (x2); Frag Grenades; Krak Grenades
1 Storm Trooper Sergeant @ [10] Pts
Multi-Laser; Hull Heavy Bolter
Extra Armour [5]
Smoke Launchers [3]
9 Grenadiers @ 234 Pts
Hellguns (x7); Plasma Gun (x2); Frag Grenades; Krak Grenades
1 Grenadier Veteran Sergeant @ [31] Pts
Plasma Pistol; Power Weapon; Frag Grenades; Krak Grenades
Extra Armour [5]
Smoke Launchers [3]
1 Hellhound (Fast Attack) @ 124 Pts
Inferno Cannon; Hull Heavy Bolter
Extra Armour [5]
Smoke Launchers [3]
Searchlight [1]
5 Rough Riders (Fast Attack) @ 99 Pts
Shotguns (x4); Meltagun (x2); Carapace Armour
1 Rough Rider Veteran Sergeant @ [19] Pts
Storm Bolter
1 Leman Russ Battle Tank (Heavy Support) @ 164 Pts
Battle Cannon; Hull Heavy Bolter; Heavy Bolter Sponsons
Extra Armour [5]
Smoke Launchers [3]
Searchlight [1]
1 Leman Russ Demolisher (Heavy Support) @ 214 Pts
Demolisher Cannon; Hull Lascannon; Multi-Melta Sponsons
Extra Armour [5]
Smoke Launchers [3]
Hunter-Killer Missile [10]
Searchlight [1]
Models in Army: 44
Total Army Cost: 1500
З.Ы. Мотоциклистов вижу не в качестве лэнс-деза, а в качестве "занозы" для противника - вполне возможно что они смогут проникнуть в тыл противника, используя терреин, и сбить ему какую-нибудь технику, но их первая роль - отвлечь хоть какую-то часть сил от ударного "кулака" танков...
Ваши мнения?
Изменено пользователем Sar
Тады, может, мелту им дать?
У тебя и так есть, чем ковырять танки, а вот контр чарджа нет. Роль райдеров - контр чардж, и не потому, что как танк хантеры они хуже, а потому, что замены им как рукопашникам в ИГ нет.
Шторм труперы играют либо пешие\в инфильтре с плазмами, либо дроп с мельтами.
Пешие с мельтами - это нонсенс.
На роль танков я бы советовал прошлый вариант - 2 демы с 3хб + мисла + армор + смок
Если есть отряд гренок, кот поедет в химере к врагу зажигать - есть смысл заменить этой химере ХБ на ХФ.
Skills and Drills: Independant Commissars [0]
0 Command Platoon (HQ) @ 194 Pts
4 Command Squad @ [194] Pts
Laspistol and CCW (x4); Vox Caster; Carapace Armour; Chem Inhaler
1 Junior Officer @ [46] Pts
Bolt Pistol; Power Weapon
1 Chimera @ [113] Pts
Extra Armour [5]
Smoke Launchers [3]
Improved Comms [20]
1 Commissar (HQ) @ 91 Pts
Carapace Armour [5]
Medallion Crimson [15]
Refractor Field [15]
1 Techpriest Enginseer (Elites) @ 155 Pts
Servo-arm [0]
Signum [15]
2 Gun Servitor - Heavy Bolter
1 Gun Servitor - Plasma Cannon
4 Hardened Veterans (Elites) @ 106 Pts
Lascannon; Lasguns (x3); Vox Caster; Carapace Armour; Chem Inhaler
1 Hardened Veteran Sergeant @ [14] Pts
Bolter
7 Grenadiers @ 220 Pts
Hellguns (x5); Plasma Gun (x2); Frag Grenades; Krak Grenades; Vox Caster
1 Chimera @ [94] Pts
Multi-Laser; Hull Heavy Flamer
Extra Armour [5]
Smoke Launchers [3]
Searchlight [1]
Extra Armour [5]
Smoke Launchers [3]
Searchlight [1]
1 Hellhound (Fast Attack) @ 123 Pts
Extra Armour [5]
Smoke Launchers [3]
1 Leman Russ Demolisher (Heavy Support) @ 193 Pts
Demolisher Cannon; Hull Lascannon; Heavy Bolter Sponsons
Extra Armour [5]
Smoke Launchers [3]
Extra Armour [5]
Smoke Launchers [3]
Models in Army: 37
Total Army Cost: 1495
Так сказать, подновил ростер, а если быть точнее, то ростер был подвергнут сильным изменениям (см. предыдущий пост). Прошу высказать ваши мнения.
Да, весьма оригинальный взгляд на ИГ. Мое сугубо личное мнение - ну очень мало моделей. Особенно - для ИГ. Поэтому выглядит это все ну очень хрупким. Хотя, конечно, тематическую армию Механикусов из 100+ моделей тоже представить сложно...
Коми играет хуже коней.
4 ХБ У ЖРЕЦА ЛУЧШЕ 2ХБ+ ПЛАЗМА. имхо
Allow Ratlings [0]
0 Command Platoon (HQ) @ 225 Pts
4 Command Squad @ [85] Pts
Missile Launcher; Lasguns (x3); Carapace Armour; Chem Inhaler
6 Anti Tank Squad #1 @ [140] Pts
Lascannon (x3); Lasguns; Carapace Armour; Chem Inhaler
1 Techpriest Enginseer (Elites) @ 145 Pts
Servo-arm [0]
4 Gun Servitor - Heavy Bolter [100]
5 Ratlings (Elites) @ 55 Pts
Sniper Rifle
9 Grenadiers @ 244 Pts
1 Chimera @ [103] Pts
Extra Armour [5]
Smoke Launchers [3]
9 Grenadiers @ 235 Pts
Extra Armour [5]
Smoke Launchers [3]
Searchlight [1]
Extra Armour [5]
Smoke Launchers [3]
Searchlight [1]
Extra Armour [5]
Smoke Launchers [3]
1 Leman Russ Demolisher (Heavy Support) @ 183 Pts
Demolisher Cannon; Hull Heavy Bolter; Heavy Bolter Sponsons
Extra Armour [5]
Smoke Launchers [3]
1 Sentinel (Fast Attack) @ 55 Pts
Heavy Flamer
Armoured crew compartment [15]
Models in Army: 59
Если слить сентинель и одних гренок - можно взять дему + отряд коней с пиками ИМХО будет лучше.
Ратлинги - мне не понравились как играют. 3+ 2+ сейв решает больше, чем тафнес.
Отряд из 3 лазок за 110 притягивает кучу огня, а за такую цену его точно испепелят. Масс Монстр ты и так не победишь, а против остольного у тебя плазма + 2 демы.
В команднике мастер вокс, зачем?
ИМХО:
Крак-гранаты -[ну уж нет].
Экстра-армор- [ну уж нет].
Ратлингов- [ну уж нет].
1)По поводу краков:
Советчики :oops: .
2)Армор можно и сотавить. Если надо куда гренки довозить - то помним, от любого пенетрейта они выпадают.
3)Согласен.
От пенетрейта экстра армор все равно не помогает. А на гленсе всего-то 1/6 выпадения Crew Stunned.
О, чет я сморозил. Армор со смоками спутал, сорри. Можно и без армора, но если требуется довезти гренок - 3 на глэнсе опасна.
П С
У нас же не 15 поинтов она стоит, как у ДА !
[Добавлено позже]
Сентинель странный ИМХО
[Добавлено позже]
Если нужны очки - бери гренки по 8.
Ну и ратлинги спорно, но тут уже писали.
Не знаю, не знаю... На зимнем штурм лично мои ратлинги отожгли на 750птс... Заинфильтрил отрядик за 33 очка за терейн, да постреливай... На мой взгляд отличный юнит. Никто на него внимания не обращает, а он может обжективы скорить, четверти, в конце концов спидбампом работать...
Negative. Tastes differ... Пережили 5 игр из 4. Обычно все заняты танками. А уж с карапасом наверное и того лучше...
  • Отец-основатель
Странный ростер... Гренадеры не нескафе... лучше обычную механизацию брать...
У ГВ есть пример армии АМ. http://uk.games-workshop.com/imperialguard/doctrines/2/
Если брать приведенный пример ИГ, то отряд пехоты в них будет стоить столько же, если не больше, а закачка будет непонятной.
Сравним:
рядовой гренадер: 4+ сейв 4БС 5АП ФГ КГ, цена - 10 очей
рядовой "классический" скитарий: 4+ сейв и 6й Инвуль, 3БС с ре-роллом единиц - 11 очей
В.Сержант гренадеров: 4+ сейв 4БС ПВ ПП ФГ КГ (макс.закачка ИМХО) - 31 оч.
В.Сержант "классиков":4+ сейв 6 Инвуль 3БС с ре-роллом единиц, ццв ПП - 25 оч.
Получается что цена у них примерно одинаковая но учитывая что ребята будут ездить на Химере ИМХО оружие класса Heavy не имеет смысла, а вот 3 ПВ атаки на случай ХтХ и 6 плазма атак на 12" ИМХО были бы неплохим подспорьем.
