SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Ладно, идем по пунктам 1. Multiple Barrages If a unit fires more than one shot with the Barrage special rule, they fire together, as follows: The Barrage weapon closest to the target unit fires first. Place the blast marker over the target, then roll for scatter as described earlier. 1.1. All Barrage weapons use blast markers and consequently use the rules for Blast weapons, as indicated by their profile, with the following exceptions 1.2. When firing a Blast weapon, models do not roll To Hit. Instead, just pick one enemy model visible to the firer and place the 3" blast marker with its hole entirely over the base of the target model (see diagram), or its hull if the target is a vehicle. The hole at the centre of the marker must be within the weapon’s maximum range. You cannot place the blast marker so that the base or hull of any friendly model is even partially under it. The large area affected by the blast means it’s going to be very hard to miss completely. Nonetheless, the shot might not land exactly where intended. Roll for the blast marker to scatter and subtract the firer’s Ballistic Skill from the distance (if any) that it scatters, to a minimum of 0". Note that it is possible, and absolutely fine, for a shot to scatter beyond the weapon’s maximum or minimum range and line of sight. This represents the chance of ricochets, the missile blasting through cover and other random events. In these cases, hits are worked out as normal and can hit and wound units out of range and line of sight (or even your own units, or models locked in combat). If the shot scatters so that the hole in the centre of the marker is beyond the table’s edge, the shot is a complete miss and is discarded. Once the final position of the blast marker has been determined, take a good look at it from above – each unit suffers one hit for each of their models which is fully or partially beneath the blast marker, even if those models are not within the firer’s line of sight. Once the number of hits inflicted on the unit has been worked out, roll To Wound and save as normal. Remember that any Wounds inflicted by weapons with the Blast special rule must be allocated to the closest model in the target unit even if it is out of sight of any models from the attacking unit. 1.3. Blast Weapons and Re-rolls If a model has the ability to re-roll its rolls To Hit and chooses to do so after firing a Blast weapon, the player must re-roll both the scatter dice and the 2D6. 2. Once the first marker is placed, roll a scatter dice for each other Barrage weapon shot fired by the unit. If an arrow is rolled, place the marker in the direction indicated so that it is next to and touching the edge of the first marker placed (see diagram below). If a Hit! is rolled, the firing player places the marker so that it touches any part of any marker in the group that has already been placed. Note that it is perfectly fine if some markers are placed overlapping one another (including being directly over the top of a previous marker). Как видно из правил, только 1ый пункт предполагает полную отработку, аналогично бластовому оружию т.е. правила твин линка применимы только на первый выстрел Изменено 7 ноября, 2014 пользователем SmallEvilman Ссылка на комментарий Поделиться на другие сайты Поделиться
KSV Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Судя по твоим постам выше - линканутость можно сразу игнорировать, поскольку её нет Почему? Первый выстрел по ТЛБ, а дальше мультибарраж. До настоящих сложных ситуаций (про CCS с минометом и орданкой я уже упоминал). Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Почему? Первый выстрел по ТЛБ, а дальше мультибарраж. А почему на мультибарраж не действует реролл на тухит? Впрочем, стоит отметить. Я не пытаюсь убедить вас. Это невозможно. Я скорее хочу показать другим, что ваша позиция неправильна.:) Изменено 7 ноября, 2014 пользователем HorrOwl Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Я скорее хочу показать другим, что ваша позиция неправильна.:)Тогда апеллируй к правилам, я привел выше пост с циатами из правил, вполне четко объясняющими мою позицию Ссылка на комментарий Поделиться на другие сайты Поделиться
KSV Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) А почему на мультибарраж не действует реролл на тухит? На оружие с мультибарражем и без правила бласт правила на реролл могут действовать на все выстрелы, а не только на те, у которых 2д6 есть. PS Знаю, такого оружия нет. Но хочу подчеркнуть, что blast и barrage (и производные правила от них) - разные правила. Не надо их мешать в кучу. Изменено 7 ноября, 2014 пользователем von Speer Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Я уже апеллировал. Но фигли толку? Глас разума сопротивления между ухов не встречает :( Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Я уже апеллировал. Но фигли толку? Глас разума сопротивления между ухов не встречает :(Никакого конструктива, как и раньше, теперь и оскорбления, опять в своем репертуаре. <_< Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Конструктив тебе был уже высказан. Фигли толку? Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Конструктив тебе был уже высказан. Фигли толку?То что ты приводил не подтверждено правилами, так что это ничего кроме твоих хотелок Изменено 7 ноября, 2014 пользователем SmallEvilman Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 о что ты приводил не подтверждено правилами, так что это ничего кроме твоих хотелок Да-да, конечно-конечно. Ты только не нервничай, это вредно.:D Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Да-да, конечно-конечно. Ты только не нервничай, это вредно.:DЛалка что ли? =) xD Изменено 7 ноября, 2014 пользователем SmallEvilman Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Лалка что ли? Судя по сленгу, ты из вконтактика или с имиджборд. Тогда твои наркоманские трактовки правил неудивительны. Средний уровень контингента там... весьма низок Изменено 7 ноября, 2014 пользователем HorrOwl Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Судя по сленгу, ты из вконтактика или с имиджборд. Тогда твои наркоманские трактовки правил неудивительны. Средний уровень контингента там... весьма низок ну-ну, а ты у нас высокоинтеллектуальный птиц, вот только в отсутствии адекватных аргументов скатываешься в... <_< Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) ну-ну, а ты у нас высокоинтеллектуальный птиц, вот только в отсутствии адекватных аргументов скатываешься в... Адекватные аргументы тебе уже высказали. Толку как видишь, не было. Потому "лалируй" дальше, кили как там это у вас называется, я в жаргонах не силён. Изменено 7 ноября, 2014 пользователем HorrOwl Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Адекватные аргументы тебе уже высказали.Ни одного cтройного доказательства кроме твоих "хотелок" я так и не увидел, Так что окажи услугу, если не трудно, напиши полную компиляцию, подтвержденную цитатами из правил Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Ни одного cтройного доказательства кроме твоих "хотелок" я так и не увидел, Разумеется. Я был бы искренне удивлён если бы таки да.:D Так что окажи услугу, если не трудно, напиши полную компиляцию, подтвержденную цитатами из правил Читай тему, я уже всё тут написал. Твои же "тут у нас правило бласта, тут оно, конечно, не используется, но поскольку ограничения прописаны для него, и если игнорировать то, что написано в определении скаттера, то..." и прочий софистический треш я то что обсуждать или контраргументировать, я уже читать желания не имею.:D Мне хватило грав оружия и каверсейва.:D Изменено 7 ноября, 2014 пользователем HorrOwl Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Твои же "тут у нас праивло бласта, тут оно, конечно, не используется, но поскольку ограничения прописаны для него, и если игнорировать то, что написано в определении скаттера, то..." и прочий софистический треш я более читать не имею никакого желания.Я, еще раз, прошу тебя написать мне свои доказательства, стройно, четко, по пунктам, про то что работает как ты написал, подтвержденные цитатами из правил, а не урывками из контекста, коими изобилует тема. Свои доказательства я уже привел http://forums.warforge.ru/index.php?showto...t&p=3535835 Изменено 7 ноября, 2014 пользователем SmallEvilman Ссылка на комментарий Поделиться на другие сайты Поделиться
aivazovski Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 ... До настоящих сложных ситуаций (про CCS с минометом и орданкой я уже упоминал). Я ж тебе написал. Орданка отдельно кидается. Ниче сложного нет. Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Я, еще раз, прошу тебя написать мне свои доказательства, стройно, четко, по пунктам, про то что работает как ты написал, подтвержденные цитатами из правил, а не урывками из контекста, коими изобилует тема. Я уже их писал. если тебе лень не позволяет читать тему - то мне тем более не позволяет копипастить. Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Я уже их писал. если тебе лень не позволяет читать тему - то мне тем более не позволяет копипастить.И в 3ий раз прошу с цитатами из правил по пунктам расписать. Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 И в 3ий раз прошу с цитатами из правил по пунктам расписать. В 3й раз отвечаю - читай тему. Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 В 3й раз отвечаю - читай тему.Тему я читал Я прошу тебя по пунктам расписать Понимаешь? По пунктам и с конкретными цитатами из правил их подтверждающими Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 (изменено) Тему я читал Тогда, из настойчивых требований, я делаю вывод, что из неё ничего не понял?X- Понимаешь? По пунктам и с конкретными цитатами из правил их подтверждающими Я уже ответил. И не раз даже... 2 страницы разжёвывал. Переварил уже практически. Изменено 7 ноября, 2014 пользователем HorrOwl Ссылка на комментарий Поделиться на другие сайты Поделиться
SmallEvilman Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 Тогда, из настойчивых требований, я делаю вывод, что из неё ничего не понял?X- Я уже ответил. И не раз даже... 2 страницы разжёвывал. Переварил уже практически.Так скомпилируй, пожалуйста, по пунктам и с цитатами из правил, не уж то это настолько тебя затрудняет? Ссылка на комментарий Поделиться на другие сайты Поделиться
HorrOwl Опубликовано 7 ноября, 2014 Жалоба Поделиться Опубликовано 7 ноября, 2014 не уж то это настолько тебя затрудняет? Не вижу смысла. Если тебе две страницы разжёвывали, а на это ты выдал "аргументов нема", то [ну уж нет]рена мне тратить время на компиляцию, про которую будет сказано то же самое? Ссылка на комментарий Поделиться на другие сайты Поделиться
