Dwarfs -2014
Монгол
5 коробок же.
Точно, забыл про анвил и трон.
Интересно, на каких они будут подставках? Трон верховного короля на подставке 40x60 мм...
  • Ответов 2 тыс
Котел у дарков тоже раньше маленьким был. Но сейчас эра гигантизма :)
Хаевские тени/сестры показывают, что не обязательно.
При динамичности поз слаеров думаю это будет весьма затруднительно
Всю эту тему можно объявить вишлистингом и закрыть КЕМ =)
ФБ вон, возможно, совсем закроют, а вы тут пушку обсуждаете =)
На варсире новый всплеск... достоверность сомнительна :), но тем не менее:
- The dual box for H/IB (yeah, I know nothing new and awesome)
- Characters will have the option of a gromril shield which gives +2 as, 5+ parry save
- Thunderers cost going down by 1 point, cannons also cheaper (don't know how much).
- Engineers giving bonuses to thunderers
- No more shieldbearer option for lords besides the named character of Alrik
- Some rumour about a new bigger cannon, from my intel it's suppose to be a bigger grudgethrower hitting with a big template.
And now the fun parts:
-The big machine - a dwarf centurion/golem/dreadnought call it what you like. And about this thing the guy was specific, giving a 8T, 6W, 3+ AS stat, and mounted bolt thrower option, the whole mini mounted on a dragonscale base.
- Organ guns and flame cannons might be rune upgraded.
I have tons of new rumours from my source. He was spot on with the dark elves (including the peg leg fleetmaster) so I do believe him.
Runelord can't add DD
Dwarf army can add 2 DD every magic phase
Anvil is Boune spell (can plus the S for dwarf)
Dwarf Gyrocopter(new models) can make two version:
1 is bomber(max can take 2)
2 is fight with machine gun (max can take 6)
A lot new special character
1: king of Eight Peaks
2: the engineer with big gun
All the new models are infantry (with out Gyrocopte):
1: Hammerer
2: Black smith
3: Long beard
4: Slayer
5: Irondragon(name not confirm) new shooting unit
like choas dwraf IG 4+armor S4 T4 weapon is flaming attack
(The hammerer black smith and long beard is in same box, the slayer
other box because no armor, Irondragon other box. all the new models
very cool.)
All the rune are same and warmachine too
The magic item:
1: The armmr can give the user T10
Орфография оригиналов сохранена...
Изменено пользователем John Silver
Бред вообще, особенно последний!
Все порции слухов противоречат друг другу.
/Последние слухи бред полностью. Первые бред наполовину. Пожалуй, сейчас можно верить только картинкам юинтов, по которым можно будет понять кто был прав.
А вообще то чарджанддай был на 100% прав при релизе дарк эльфов... Так что кто его знает что как будет...
А я не понял, что бредового во второй порции слухов. Там только с юнитами хрень, остальное +\- в тему и достаточно правдоподобно.
Изменено пользователем старый гном
Согласен, но и с отрядами вполне правдоподобно... Возможно - это первая волна.
Ну если дварф 25го , то в середине следeующей недели будут норм слухи.
Мне кажется, что слухи сильно не противоречат тем, что были раньше. Просто кто-то другой увидел тоже самое, но воспринял по своему, так что ИМХО старый слух про 2 коробки пехоты и НЕХ остается.
Ну если дварф 25го
Дварф же отменяют и запускают два новых журнала - один еженедельный (White Dwarf Visions), а второй ежемесячный (Warhammer Visions).
Непонятно только, с этого уже месяца или нет.
Ну даже если с этого то в одном из новых изданий должна быть премьера бородатых.)
хз, что там на самом деле, но я хз.
что за Черные Кузнецы?
что за Железные Драконы(стрелки какие-то?)
с кем эти перцы в дуалките?
почему Хаммеры не в паре с Брэйкерами(или их тупо не записали?)?
с кем в паре ДлинноБороды?
с кем в паре Слэеры?
Ня! Серьезно! И они оба будут электронные?
Вообще говоря, если это так, то мы имеем САМОЕ серьезное "перетрахивание" традиций ГВ, потому что Вайт Дварф жил почти 30 лет - и оба-на.
Так я реально поверю в то, что ФБ закрывают.
Не уточняется пока, вроде. Но мне кажется, что как минимум один - будет.
Перемены с Белым Гномом якобы со следующего месяца, в этом ещё по-старому.
А Железных Драконов источник сравнил с Инфернальной Стражей гномов Хаоса.
Теперь написанием Кодексов и Армибуков ФВ займется: http://forums.warforge.ru/index.php?showto...p;#entry3205398
З.Ы. Или я опять что-то не так понял...
Изменено пользователем Kotov
Я так понимаю речь идет про то, что форджа будет делать кодексы/армибуки под свою продукцию и только.
Кстати, опция с громриловым щитом - здравая идея ИМХО. Таким макаром сейв брейкеров добивается до 2+ 5++ в хтх
