Dr Darog Опубликовано 21 февраля, 2013 Жалоба Поделиться Опубликовано 21 февраля, 2013 (изменено) At one point you had rules posted for a couple of characters not in a book, one of which was Master Harath Shen from the Salamanders chapter. Do you have any plans to rerelease the rules for this character? Forge World Once they are amended for 6th Edition, yes So when do i get my updated rules for Death Korps of Krieg and Renagdes and Heretics? • Forge World That's because Imperial Armour Volume One is about Imperial Guard vehicles generally, not Death Korps specifically. There's an FAQ online now, and otherwise the DKK army lists will be made available in a fully updated 6th ed form in the next couple of months, we hope. As you can appreciate, we're currently testing and tweaking before trying to find the resource to get the files laid out and pdf'd Will the rapier quad launcher be getting a model, or is it the imperial one with space marine crew? Forge World The Imperial Guard Rapier still has a Laser destroyer; we've got plans for alternate weapon options in the future though Question: Is there an update in the works to be able to use the Badab War Characters in 40k (aka the 40,000 stamp)? Thanks for any help Gents..... Forge World Yeah, but IA9 and 10 are separate books, hence the FoC selection text in each and every character. We get your point, but it's worth noting that if something states it is an X choice for a Codex whatever army, it's supposed to be used in 40k games REGARDLESS of whether we've put the stamp on or not. ;) Изменено 21 февраля, 2013 пользователем Dr Darog Ссылка на комментарий Поделиться на другие сайты Поделиться
Юрий Игоревич Опубликовано 22 февраля, 2013 Жалоба Поделиться Опубликовано 22 февраля, 2013 ! Предупреждение: За темой слежу. За форджсрач буду наказывать. Ссылка на комментарий Поделиться на другие сайты Поделиться
Bjorn Stormwolf Опубликовано 22 февраля, 2013 Жалоба Поделиться Опубликовано 22 февраля, 2013 Негде выразить радость по поводу того что делают механикумовских таллаксов, наконец можно будет запилить годную армию механикумов, а не солянку из игшных техпристов с сервиторами в химерах и маровских техмаров в ринах и с сервиторами и тандерфаер кенонами) Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 22 февраля, 2013 Автор Жалоба Поделиться Опубликовано 22 февраля, 2013 Негде выразить радость по поводу того что делают механикумовских таллаксов, наконец можно будет запилить годную армию механикумов, а не солянку из игшных техпристов с сервиторами в химерах и маровских техмаров в ринах и с сервиторами и тандерфаер кенонами) В след. книге по ереси будет полноценный лист АМ. Правда он только для 30к, в 40к, кроме, как на апок, его не поставишь. Ссылка на комментарий Поделиться на другие сайты Поделиться
Bjorn Stormwolf Опубликовано 22 февраля, 2013 Жалоба Поделиться Опубликовано 22 февраля, 2013 (изменено) В след. книге по ереси будет полноценный лист АМ. Правда он только для 30к, в 40к, кроме, как на апок, его не поставишь. Что нам по этому поводу говорит фак форджи: Q: Are the armies and units in the Horus Heresy books by Forge World meant to be used in games against regular Codex armies, such as say Grey Knights or Orks? A: While Forge World’s on-going range of Horus Heresy books and their game content are all designed to use and be compatible with the Warhammer 40,000 rules, they have been fine-tuned and focused on playing battles in the milieu of the Horus Heresy rather than in conjunction with the Codexes representing warfare in the 41st Millennium, and this will remain the case. Designer’s Note: This means that while you are, of course, free to have fun and play games against your friends using any forces you like, and Horus Heresy forces will be broadly ‘a fair fight’ with Codex forces of the same scale, certain rules anomalies and inconsistencies may be thrown up that you have to deal with, although these should not seriously affect the game in most cases. (For example, certain units, such as those with the Stubborn special rule are at a premium costing in Horus Heresy armies over their regular Codex counterparts, owing to the results of play testing within their own sphere.) In terms of using Lords of War and the Primarchs, however, these are definitely not intended to be used in standard Warhammer 40,000 games, but only in games where both sides use the Age of Darkness Force Organisation chart, and the specific provisions within, and in games of 2,000 points or greater. http://www.forgeworld.co.uk/downloads/prod..._FAQ_Errata.pdf Изменено 22 февраля, 2013 пользователем Bjorn Stormwolf Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 22 февраля, 2013 Автор Жалоба Поделиться Опубликовано 22 февраля, 2013 Что нам по этому поводу говорит фак форджи: While Forge World’s on-going range of Horus Heresy books and their game content are all designed to use and be compatible with the Warhammer 40,000 rules, they have been fine-tuned and focused on playing battles in the milieu of the Horus Heresy rather than in conjunction with the Codexes representing warfare in the 41st Millennium, and this will remain the case. Спасибо КО Я это и написал. Портировать кодексы орков, некронов, дэ, эльдар, иг в 30к можно портировать, они были во время ереси. Портировать 30к в 40к нельзя. Ссылка на комментарий Поделиться на другие сайты Поделиться
Bjorn Stormwolf Опубликовано 22 февраля, 2013 Жалоба Поделиться Опубликовано 22 февраля, 2013 While Forge World’s on-going range of Horus Heresy books and their game content are all designed to use and be compatible with the Warhammer 40,000 rules Как-то так) и вообще, как договоришься, собсна как с обычной форджой) К тому же армия Механикумов штука сочная, годная, и надеюсь не сильно читополомная (я по крайней мере в текущем листе ничего такого не нашел). В покрасе проста и приятна (для уровня нормальной игровухи). Где-то видел конверсию ИГ для Механикумов, там скитарии были сделаны из Игшников с кучей бионики, легкие роботы - машинки на основе циклопов Крига с тушкой и мельтой\плазмой, катафракты - какие-то альтернативные мини с лазкой\хб\автокеноном, играющие по правилам хвт, с соответствующей базой. Фоток нет, погибли при крахе харда (( А тут прям полная армия АМ в пару кликов, все круто) Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 22 февраля, 2013 Автор Жалоба Поделиться Опубликовано 22 февраля, 2013 While Forge World’s on-going range of Horus Heresy books and their game content are all designed to use and be compatible with the Warhammer 40,000 rules Как-то так) и вообще, как договоришься, собсна как с обычной форджой) К тому же армия Механикумов штука сочная, годная, и надеюсь не сильно читополомная (я по крайней мере в текущем листе ничего такого не нашел). А тут прям полная армия АМ в пару кликов, все круто) Как=то так не так. Имеется в виду, что используется БРБ 6ки, а не 40к как сетинг. Нельзя, портировать 30к в 40к никак. Это чит. Талаксы - имба в рамках ереси, если что. Это да, это хорошо) Ссылка на комментарий Поделиться на другие сайты Поделиться
Bjorn Stormwolf Опубликовано 22 февраля, 2013 Жалоба Поделиться Опубликовано 22 февраля, 2013 (изменено) А тогда такой вопрос (чисто из интереса): Ордо Редуктор как я понял, существует и в 40К (в случае если бэк из ай оф террор валиден до сих пор) Что технически ему мешает использовать те же игрушки, которые они использовали в 30к? Изменено 22 февраля, 2013 пользователем Bjorn Stormwolf Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 22 февраля, 2013 Автор Жалоба Поделиться Опубликовано 22 февраля, 2013 А тогда такой вопрос (чисто из интереса): Ордо Редуктор как я понял, существует и в 40К (в случае если бэк из ай оф террор валиден до сих пор) Что технически ему мешает использовать те же игрушки, которые они использовали в 30к? Бек из ай оф террор валиден, с чего он ему перестать? Но он тут не причем. 1. Это 30к, его нельзя портировать в 40к. 2. Никто не знает, что в 40к есть у ордо. 3. Это осадная армия АМ, в обычных стычках на мелкие форматы до 5к, они вряд ли участвуют. Ссылка на комментарий Поделиться на другие сайты Поделиться
MAXREM Опубликовано 25 февраля, 2013 Жалоба Поделиться Опубликовано 25 февраля, 2013 (изменено) А я правильно понимаю что в следующей книге появятся Саломандры, Вороны и прочие которые устроли финал западни и подорвали перевес сил лояльного импнримуа? А по поводу АМ было бы логично создать ИА бук добавляющий эту армию в сороковню. Изменено 25 февраля, 2013 пользователем MAXREM Ссылка на комментарий Поделиться на другие сайты Поделиться
Locke Опубликовано 25 февраля, 2013 Жалоба Поделиться Опубликовано 25 февраля, 2013 В следующей книге будут четыре легиона из тех, что засветились на Истваане V. Точно будут Железные Руки и Несущие Слово. Ссылка на комментарий Поделиться на другие сайты Поделиться
Lej Опубликовано 25 февраля, 2013 Жалоба Поделиться Опубликовано 25 февраля, 2013 А о NL ничего не слышно? Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 25 февраля, 2013 Автор Жалоба Поделиться Опубликовано 25 февраля, 2013 А я правильно понимаю что в следующей книге появятся Саломандры, Вороны и прочие которые устроли финал западни и подорвали перевес сил лояльного импнримуа? А по поводу АМ было бы логично создать ИА бук добавляющий эту армию в сороковню. Нет, не правильно, это разговор об ИА. В следующем ИА12 минотавры. Две книги по Истваану выхожят через несколько месяцев, точнее через 3-4 первая, через полгода вторая. ИА12 уже совсем скоро. В одной из книг по Истваану 5 будут салмандры прехерси, они к 40к не имеют никакого отношения. Ссылка на комментарий Поделиться на другие сайты Поделиться
Анчар Опубликовано 25 февраля, 2013 Жалоба Поделиться Опубликовано 25 февраля, 2013 (изменено) А о NL ничего не слышно? После Истваановской эпопеи пророчат Битву за Просперо, там и будет лист ТС. ПС По поводу ИА 12, а на сколько скоро? Изменено 25 февраля, 2013 пользователем Ancharis Ссылка на комментарий Поделиться на другие сайты Поделиться
Hide Опубликовано 25 февраля, 2013 Жалоба Поделиться Опубликовано 25 февраля, 2013 После Истваановской эпопеи пророчат Битву за Просперо, там и будет лист ТС. Человек вообще-то про Найт лордов спрашивал Ссылка на комментарий Поделиться на другие сайты Поделиться
Дарт Йорикус Опубликовано 25 февраля, 2013 Жалоба Поделиться Опубликовано 25 февраля, 2013 (изменено) А о NL ничего не слышно? Повелители Ночи будут в одной из 2 книг про бойню на Исстване-Истваане 5, ясно же. В какой именно неизвестно. Изменено 25 февраля, 2013 пользователем Йорик Ссылка на комментарий Поделиться на другие сайты Поделиться
Анчар Опубликовано 25 февраля, 2013 Жалоба Поделиться Опубликовано 25 февраля, 2013 Человек вообще-то про Найт лордов спрашивал Ох ё...совсем заработался О_о Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 26 февраля, 2013 Автор Жалоба Поделиться Опубликовано 26 февраля, 2013 Иа12 гле-то в марте. потом нн2 про истваан, потом иа13, нн3 про истваан. Потом нн4 про просперо, иа14 и нн5 про калт после некронов в иа появятся дэ, ниды и тзинчиты. Ссылка на комментарий Поделиться на другие сайты Поделиться
Анчар Опубликовано 26 февраля, 2013 Жалоба Поделиться Опубликовано 26 февраля, 2013 Иа12 гле-то в марте. потом нн2 про истваан, потом иа13, нн3 про истваан. Потом нн4 про просперо, иа14 и нн5 про калт после некронов в иа появятся дэ, ниды и тзинчиты. в смысле в одном, или раздельно?О_о Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 26 февраля, 2013 Автор Жалоба Поделиться Опубликовано 26 февраля, 2013 в смысле в одном, или раздельно?О_о Естественно раздельно. [ Добавлено спустя 34 секунды ] И соответственно с кем-то из них будут саламандры. Ссылка на комментарий Поделиться на другие сайты Поделиться
Knijnik Опубликовано 27 февраля, 2013 Жалоба Поделиться Опубликовано 27 февраля, 2013 Как я понял, ИА12 это криг, Минотавры, некроны. А по слухам в ИА13 будут Темные Эльдар. Так ли это? Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 27 февраля, 2013 Автор Жалоба Поделиться Опубликовано 27 февраля, 2013 Как я понял, ИА12 это криг, Минотавры, некроны. А по слухам в ИА13 будут Темные Эльдар. Так ли это? Или ниды Ссылка на комментарий Поделиться на другие сайты Поделиться
Дарт Йорикус Опубликовано 27 февраля, 2013 Жалоба Поделиться Опубликовано 27 февраля, 2013 Дарог, бегло просмотрел конец ролика "Games Day UK 2012: Forge World Designers Talk Horus Heresy Book 2" в твоём блоге: в части, где шла речь про ЕГ2 там показывались Железные Руки, Повелители Ночи, Несущие Слово и Саламандры. В текст, правда, не вслушивался, так как занят. Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 27 февраля, 2013 Автор Жалоба Поделиться Опубликовано 27 февраля, 2013 Вроде того, я напишу о видосе чуть позже подробно. Ссылка на комментарий Поделиться на другие сайты Поделиться
