Skaiger Опубликовано 28 марта, 2009 Жалоба Поделиться Опубликовано 28 марта, 2009 Ну-у-у... Этот значек емнип буква греческого алфавита. ясен пень, что буква. с чего бы тогда назвали омега-маринами? Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 28 марта, 2009 Жалоба Поделиться Опубликовано 28 марта, 2009 Офигеть однако. Точно фибросвязки )) Скорее бы адамантий делать научились. Хотя наши ученые уже выращивают алмазы искуственно.... Нифига вы не понимаете - это миомер. А разработчик случаем не доктор Атлас? BattleMech Construction BattleMechs are built around an internal structure resembling a skeleton, and use an artificial polymer fiber called myomer, which contracts in the presence of an electrical current, for muscles (called "actuators" on BattleMechs). The artificial skeleton and musculature, combined with a large gyroscope system, provides stability for the BattleMech and allows for bipedal movement. Some carry jump jets that provide thrust bursts for short leaps. The power required for the myomers, weapons, and other systems is provided by a fusion reactor mounted in the torso. Although all 'Mechs have heat sinks, heat buildup is a frequent problem, and intense combat action can lead to heat buildups that put physical strain on the pilot, and may even cause an emergency reactor shutdown. Most BattleMechs copy the human form to an extent, which is the deciding factor in their mobility, versatility, and ultimately, superior combat performance. The entire system is controlled by a pilot wearing a neurohelmet that effectively links the 'Mech's central computer to the pilot's sense of balance and nervous system. Augmented by a combination throttle, joystick, and dual pedal system, the 'Mech pilot controls the BattleMech like an extension of his own body, akin to a very large armoured combat suit. Many 'Mechs have fully articulated hands that can be used to climb or grab items. и еще http://star-league.org/myomer.html Так что мы шагаем к Термоядерному Джихаду даже опережая график... надо будет не пропустить Гражданскую войну и уйти в Исход с Николаем Керенским. А то придеться искать Джерома Блэйка и всю жизнь нянчиться с наследными лордами... Ссылка на комментарий Поделиться на другие сайты Поделиться
Лукин Опубликовано 28 марта, 2009 Жалоба Поделиться Опубликовано 28 марта, 2009 (изменено) Скорее бы адамантий делать научились Вроде со времен древнего Рима умеют. Адамантий- он же коринфская бронза. Не особый сплав, если честно :-) Изменено 28 марта, 2009 пользователем Лукин Ссылка на комментарий Поделиться на другие сайты Поделиться
Skaiger Опубликовано 28 марта, 2009 Жалоба Поделиться Опубликовано 28 марта, 2009 может попутал? http://ru.wikipedia.org/wiki/Адамантий Ссылка на комментарий Поделиться на другие сайты Поделиться
EOL Опубликовано 25 февраля, 2010 Жалоба Поделиться Опубликовано 25 февраля, 2010 http://forums.warforge.ru/index.php?showto...p;#entry1386986 [ Добавлено спустя 42 секунды ] http://forums.warforge.ru/index.php?showto...p;#entry1386986 Ссылка на комментарий Поделиться на другие сайты Поделиться
