Темный Опубликовано 29 августа, 2010 Жалоба Поделиться Опубликовано 29 августа, 2010 HAQQISLAM ────────────────────────────────────────────────────────────────────── Grupo 1 (Reg: 7/Irr: 2): SALADIN Lieutenant Combi Rifle, Nanopulser / Pistol, CCW (37) MOV:4-2 CC:15 BS:13 PH:12 WIP:16 ARM:3 BTS:-3 W:1 Regular, Not Impetuous, Cube Repeater, Strategos L3, V: No Wound Incapacitation, Lieutenant KUM Chain Rifle, Smoke Grenades, Light Smoke Grenade Launcher / Pistol, Shock CCW (11) MOV:8-6 CC:18 BS:11 PH:13 WIP:15 ARM:1 BTS:0 W:1 Irregular, Impetuous, No Cube Motorcycle, V: Dogged MAGHARIBA MULTI HMG, Heavy Grenade Launcher / (97 | 1.5) MOV:6-4 CC:17 BS:14 PH:17 WIP:14 ARM:8 BTS:-6 STR:3 Regular, Not Impetuous, Cube ECM, Braces, MAGHARIBA PILOT Pistol, Knife MOV:10-10 CC:13 BS:11 PH:10 WIP:13 ARM:0 BTS:0 STR:1 Regular, Not Impetuous, Cube Pilot FARZAN Boarding Shotgun, Contender / Pistol, Knife (32) MOV:4-4 CC:15 BS:12 PH:11 WIP:14 ARM:0 BTS:0 W:1 Regular, Not Impetuous, No Cube CH: Camouflage, Infiltration, Religious Troop, Chain of Command RAGIK HMG / Pistol, CCW (38 | 1.5) MOV:4-2 CC:14 BS:12 PH:12 WIP:15 ARM:2 BTS:0 W:1 Regular, Not Impetuous, Cube AD: Combat Jump, V: Dogged, Religious Troop 2x NAFFATÛN Rifle + Heavy Flamethrower / Pistol, Knife (12) MOV:4-4 CC:13 BS:11 PH:10 WIP:14 ARM:1 BTS:0 W:1 Regular, Not Impetuous, No Cube DJANBAZAN HMG / Pistol, CCW (36 | 1.5) MOV:4-2 CC:14 BS:12 PH:11 WIP:14 ARM:2 BTS:0 W:1 Regular, Not Impetuous, Cube Multiterrain, Regeneration, Multiespectral Visor L2 HUNZAKUT Rifle + Light Grenade Launcher, Antipersonnel Mines / Pistol, Knife (24 | 0.5) MOV:4-4 CC:13 BS:11 PH:12 WIP:14 ARM:0 BTS:0 W:1 Irregular, Not Impetuous, No Cube CH: Camouflage, Infiltration, Forward Observer, Deployable Repeater 299 Points | SWC: 5 ARMY CODE: eNozMVQ1slAzVDOsMTJRMwZShlCeoZoBiGcE5hkik1DKUg0oBwC0OA24 Army Infinity v.3.0. - http://www.devilteam.com Саладин стоит в уголке и дает два приказа махарибе\куму. Кум несется вперед что=нибудь убить из чеин раифла. Фарзан нужен на случай если Салах-ад-Дина. Рагик ждет удобного момента чтобы выпрыгнуть и застрелить. Наффатюны сидят на махарибе сидят и ждут звездного часа. Джанбазан стоит где-нибудь на высоте и прикрывает всех из снайперки. Хунзакут маркает для махарибы цели. Коментарии? Ссылка на комментарий Поделиться на другие сайты Поделиться
Ghost from warp Опубликовано 29 августа, 2010 Жалоба Поделиться Опубликовано 29 августа, 2010 Саладин с его кумом, а где жена,теща и зять??)) Много народу неспособных наступать без прикрытия. Это плохо. Нет инфильтры - может стать проблемой. Махарибу разберут (той же шайтан трубой) и будет много проблем. А в целом играбельно, но требует рук. Ссылка на комментарий Поделиться на другие сайты Поделиться
saydzi Опубликовано 29 августа, 2010 Жалоба Поделиться Опубликовано 29 августа, 2010 Махарибу непросто разобрать, самый мелкий по росту таг, легко прячется. Тем более что шайтан трубу тут есть чем погасить. Кум в первый же ход накидает столько дыма, что прикрытия хватит всем. По джанбазану я так понял "Лучшая снайперка - это пулемет"? По сути лишний тут только рагик с ХМГ (ну нафига оно тебе?), для махарибы лучшая команда - 2 нафатюни верхом. Лучше вместо рагика взять миуба с ЛГЛ - стабильный все-таки дым, а еще хорошо бы рема с мислой, раз уж ханзик тут. Ну и фарзан тут не особо логичен, лучше уж одалиску для охраны батьки. Ссылка на комментарий Поделиться на другие сайты Поделиться
