Шикарный Манул Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 et's try and summarize what we know so far: Weaponry: https://docs.google.com/spreadsheet/...wZUlCNXc#gid=0 HQ - Fireblade (60 points), Ethereal (50 points) and Commander. The first two are infantry, the last is in a crisis suit. No rules or wargear is known for the Commander, the Ethereal and Fireblade give buffs that mostly assist the Fire Warriors. Both Fireblade and Commander are BS5, the latter has current Shas'o stats. Fireblade LD9. Elites - Crisis 22 pts per suit, same stats as old. +10 points for Shas'vre, LD9. No known cost of wargear etc. 1-3 suits. Stealth suits 30 pts per suit, 1 in 3 may exchange for fusion blaster. +10 points for Shas'vre, LD9. 3-6 suits. Riptide 180 points. BS3 S6 T6 W5 LD9 2+/5++/feel no pain. Comes with a Heavy Burst Cannon and TL-SMS, can exchange the first for an Ion Accelarator for +5 points. The SMS can be exchanged for twin-plasma or fusion, for free. Can overcharge nova reactor, works on 3+ (if you fail, you take a wound). 4 effects: 3+ invulnerable, move 4D6 in assault phase, fire secondary weapon system twice, fire primary weapon system with nova profile. Can take up to two artillery shield drones which sport MP and 4+/4++ @ T6 (+25 points for each). 1 suit. Troops - FireWarriors 9 pts per model, same stats as old but with grenades. Can exchange for Carbines for free (as many as you want). +10 points for Shas'ui. 6-12 models. Kroot 6 pts per model. Can take 3 krootox (+25 each) and 10 hounds (+5 each). Reduced to S3, otherwise same as before. Can buy "precision ammunition", making them snipers for +1 pt per model. 10-20 models. Devilfish: same as before. +10 points for making Drones into SMS, +8 points per seeker (can have 2). Fast Attack - Bomber 160 points. Missile Pod, 2 seeker missiles, markerlight (though not the usual one, as far as I can tell. Might be an array?). Can TL the MP for +5 points. 2 Drones, both of which have twin-linked Ion Rifles. Lots of S7 fire, in other words. BS3 - 11/10/10. 1 model. Fighter 145 points. Quad-ion turret, burst cannon, 2 seeker missiles. Can swap burst cannon for missile pod (+5 points). BS3 11/10/10. 1 model. I can't see anything with regards to Pathfinder's unit entry. Did I miss something? Heavy support - Broadsides 65 points. Same stats as before, they come with TL heavy rail rifles and TL SMS out of the box. +10 points for Shas'vre (LD9). May swap TL heavy rail rifles for TL High Yield Missile Pods for free. May swap TL SMS for TL Plasma, +5 points per model. 1-3 models. Hammerhead 125 points. BS4, 13/12/10. Comes with Railgun and 2 drones out of the box. Can upgrade railgun to have submunition charges (+5 points) and swap drones for either TL BC or TL SMS, both for free. This makes no sense to me as TL SMS is always better, but whatever. May swap railgun for ion cannon, may take up to two seeker missiles for +8 points each. 1 model. Skyray 125 points. BS4, 13/12/10. 6 Seeker Missiles and 2 Networked Markerlights as well as 2 drones. May swap drones same as Hammerhead. 1 model. Sniper Drones 13 points per controller, 15 points per drone. Controllers have markerlights and BS5, Drones have Long-ranged Pulse rifles. Stealth. Drones are T4, otherwise same stats as other drones. Entire unit is LD7. 1-3 controllers, 3-9 Drones. Misc - Iridium suit (XV8-02) gives +1T and 2+ AS. There's some kind of special weapon/equipment which lets you trade all attacks in combat for one @S10, AP1. I suppose it's for commanders, though it makes very little sense to me. Seeker Missiles may now be fired at the vehicle's base BS. Entire army has supporting fire, i.e. they may aid an assaulted unit with overwatch. We get 6 Warlord traits: 1. No LoS! against warlord's shooting 2. One use only, declare at start of turn. Warlord and friendly units within 12" may re-roll to hit rolls of 1 when shooting. 3. 3D6 Thruster move. 4. One use only. All friendly units can move, shoot and charge even if they have gone to ground. 5. One use only. Warlord + unit gains Skyfire. 6. Warlord and unit can make a perfect deep strike without error. Main source - http://forofreakfactory.mforos.com/1...4-rumores-tau/ Ссылка на комментарий Поделиться на другие сайты Поделиться
Жарптица Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 По поводу Тау, Рельс и ЛРов, спецом для нонеймов, что так стремительно ворвались в тред: Дабы убить ЛР нужно 2 пня, с учетом кавра на 5+, то нужно три. Дабы получить 3 пня, нанося их по ЛРу на 5+, нужно 9 попаданий. Это, при линканутости 3го БСа бродов 12 выстрелов. То есть при наличии у вас 9 бродов, вы ЛР не убиваете за фазу стрельбы. Нубы, ппц, разорались, рельсу отняли. Тут столько дали, что попа треснула бы с рельсой старой. Инстить ДП будете Хаммером, да и вообще, мозг начнете подключать на тему что брать в армию. Слух то о слабости Тау пошел именно с красавцев, что 9 бродов брали и не могли нормально ни с кем играть. Ссылка на комментарий Поделиться на другие сайты Поделиться
Lsd Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Чет среди слухов уже потерялся,было ли подтверждение что карабины штурм 2 стали или нет? И еще теперь получается фаста стала перегружена юнитами,леталки,следопыты? Ссылка на комментарий Поделиться на другие сайты Поделиться
RussianKamikaze Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Пока в хэви-саппорте конкурируют хэд (со спецчаром возможно), пачка бродов обеспечивающих массовость, и снайпера. В принципе, по одному всего нормально влезает... у снайперов же ап5 на винтовках? ну их в пень. по мне лучше 1 хаммер и 2 пачки бродов. и 10 сила есть, и 6 тл рельс + возможность пво. 6 линканутых выстрелов по родному балистику любому флаеру на 4+ глансов накидают. и пни по 1 ап. Ссылка на комментарий Поделиться на другие сайты Поделиться
Habilis Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 (изменено) Дабы убить ЛР нужно 2 пня, с учетом кавра на 5+, то нужно три. Если не считать того, что без маркеров бродам по ЛРу стрелять не следовало, и для нас достаточно было его обездвижить, - в принципе даже остановленный на ход в своем деплое ЛР был уже неплох. Категорически не устраивал из всех результатов только weapon destroyed. Так что - броды были надежным инструментом, теперь его нет, придется выкручиваться как-то по другому. у снайперов же ап5 на винтовках? У снайперов снайперская стрельба - с выцеливанием, рендингом, пинингом, и если верить слухам про дрон-контроллер - то с пятым баллистиком, пока живы наводчики, а если верить переводам абилок эфирных - то при надобности с тремя выстрелами на 24". Изменено 3 апреля, 2013 пользователем Habilis Ссылка на комментарий Поделиться на другие сайты Поделиться
BattleBear Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Лично меня только круты расстраивают. Они же всегда были дикими первобытными рукопашниками, какие из них снайперы? Они там что ли самими таусятами закусили? Ссылка на комментарий Поделиться на другие сайты Поделиться
Sidri_cyberdog Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Нубы, ппц, разорались, рельсу отняли. Тут столько дали, что попа треснула бы с рельсой старой. Инстить ДП будете Хаммером, да и вообще, мозг начнете подключать на тему что брать в армию... Святые слова, ей богу. Народу хочется имбы имбовой, да подешевше, да шоп старые юниты гнули ещё лучше, а новые вообще делали автовин... А, ну да, в бэке так же должно быть прописано как тау нагнули весь пацификус, им Калгар присягнул на верность, тираниды вообще полетели обратно в свою галактику, некроны посылают своих криптеков перенимать технологии, Иг полностью перешла под командование эфирных, сестры битвы открестились от императора и начали поклоняться Большому Бобру... Ссылка на комментарий Поделиться на другие сайты Поделиться
RussianKamikaze Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 У снайперов снайперская стрельба - с выцеливанием, рендингом, пинингом, и если верить слухам про дрон-контроллер - то с пятым баллистиком, пока живы наводчики, а если верить переводам абилок эфирных - то при надобности с тремя выстрелами на 24". снайперы теперь круты, хехе. Ссылка на комментарий Поделиться на другие сайты Поделиться
Locke Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 тау нагнули весь пацификус, им Калгар присягнул на верность Это объяснило бы теплые отношения между Тау и СМ в табличке союзов. Ссылка на комментарий Поделиться на другие сайты Поделиться
WilhelmErbauer Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 (изменено) Чет среди слухов уже потерялся,было ли подтверждение что карабины штурм 2 стали или нет? Да, карабины теперь Assault 2 Лично я вижу очень много интересного и вкусного, при том, что вроде сохраняется необходимость думать )) Ну и с нетерпением жду подробную инфу про пасов и Веспидов, а также таблички с апгрейдами техники и костюмов :) Изменено 3 апреля, 2013 пользователем WilhelmErbauer Ссылка на комментарий Поделиться на другие сайты Поделиться
Rost_Light Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 (изменено) Это объяснило бы теплые отношения между Тау и СМ в табличке союзов. а я наивно думал, что СМ согласно шпаргалке Жиллимана просто не будут стрелять в спину тем кто им помогает в течении того времени пока им помогают. А вот сразу после можно уже обдумать, что перевесит "Смерть ксеносам" или благодарность и бла-а-родство. Тау же вообще всех любят :D да и союзы в таблице тактические же, а не стратегические Кстати. а про Аун'ши в слухах не мелькало ничего кроме того, что он снова есть и что он кефирный? Изменено 3 апреля, 2013 пользователем Rost_Light Ссылка на комментарий Поделиться на другие сайты Поделиться
Habilis Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Лично я вижу очень много интересного и вкусного, при том, что вроде сохраняется необходимость думать )) Ну и с нетерпением жду подробную инфу про пасов и Веспидов, а также таблички с апгрейдами техники и костюмов В общем да, примерно так же. Кстати. а про Аун'ши в слухах не мелькало ничего кроме того, что он снова есть и что он кефирный? Вроде как он все еще может делать свои атаки рендинговыми или перебрасывать сейвы, хотя честно говоря, в упор не представляю как это ему поможет, если что. Ссылка на комментарий Поделиться на другие сайты Поделиться
^Black_Hawk^ Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 "Seeker Missiles may now be fired at the vehicle's base BS. " Э? Без маркеров? Ссылка на комментарий Поделиться на другие сайты Поделиться
Rost_Light Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Вроде как он все еще может делать свои атаки рендинговыми или перебрасывать сейвы, хотя честно говоря, в упор не представляю как это ему поможет, если что. Ну если не будет лютого оверпрайса, можно будет взять в ростер вместо обычного кефирного, чтобы бафы раздавал. Пожертвовать чуток очков ради бэковости (достойный мужик, среди двуличных эфириалов) и фана (тау типа рукопашник :D ). Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Инфантри HQ бафают только ФВ? Фарсайт таки переводит кризов в трупсу? Какие-нибудь слухи по больше одного выбора на слот HQ есть или уже нет? Ссылка на комментарий Поделиться на другие сайты Поделиться
Beast_Therion Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 сестры битвы открестились от императора и начали поклоняться Большому Бобру... А на это я бы посмотрел! =) А по делу - почему никто не рассматривает самолетики? ИМХО, весьма беково, да и квадган опять же... Ссылка на комментарий Поделиться на другие сайты Поделиться
venik Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 (изменено) Инфантри HQ бафают только ФВ? Фарсайт таки переводит кризов в трупсу? Какие-нибудь слухи по больше одного выбора на слот HQ есть или уже нет? По слухам да. Нет берет в свиту до 7. Не знаю. На самолетики нечего смотреть особо,ибо дорогие и картонные.Они бы может и имели смысл еслибы другие самолетики были бы такимиже. Но некронская леталка это 11 по кругу,это таже куча выстрелов 7 силы и это 100 очков.Про вендетты молчу.А этот выглядит как орочий только без вагха. Изменено 3 апреля, 2013 пользователем Cеня Ссылка на комментарий Поделиться на другие сайты Поделиться
Habilis Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 (изменено) Я так понял, предполагаемая крутость истребителя в возможности перелететь веньку/дракона и пострелять ему в спину с турели. Плюс в слухах упоминался девайс дающий флаеру 4+ кавер от выстрелов с интерсептора. Будет точнее инфа - можно будет решать, но пока другие кандидаты в фасте мне субъективно ближе. Тем более, эстетически наши флаеры новые... очень на любителя. p.s. Опять с варсира и неизвестно насколько точное - >> Plasma rifles and missile pods for xv8 costs as much as half a stealth suit. Twin linked version add 5 points. Что-то мне кажется, ракет на кризисах поубавится. Будущее, так сказать, за гелиосами. С другой стороны, если TA так-таки в армори не будет, то с учетом включенного мультитрекера и BSF мы получаем стоимость базового файрнайфа в новом варианте, с одним из двух орудий спареным, с включением та'лиссера - 58 очков. Чуть точнее старого, чуть дешевле, с чуть большими плюшками. Изменено 3 апреля, 2013 пользователем Habilis Ссылка на комментарий Поделиться на другие сайты Поделиться
Abditus Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Играл я от 9 плазмобродов, теперь буду от 9и ракетобродов. накой мне линкованный выстрел с С8 ап1, если у меня их 4 линкованных С7 ап4? В общем кактотак, если скайфайр на ракеты наложить можно :) Ссылка на комментарий Поделиться на другие сайты Поделиться
timonimo Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Отцы играли и играют от трёх танков :) Ссылка на комментарий Поделиться на другие сайты Поделиться
EstelOskora Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 (изменено) Будет забавно, если лонгстрайк дает скайфаер) Изменено 3 апреля, 2013 пользователем EstelOskora Ссылка на комментарий Поделиться на другие сайты Поделиться
Шикарный Манул Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 (изменено) В тему призывается больше конструктива например. Львиная часть кодекса известна , но пока идей высказываеться оч мало. Сразу скажу сам не таувод , но интересно чего теперь ждать от синемордых. Так же интересно как выход новых тау повлияет на общий баланс армий и повлияет ли(вроде меньше самолётиков - больше колдунов). Ну и может мысли по изменившимся матчапам у кого есть. Понятно что для нормальных выводов нужна книжка на руках и поиграть хотя бы пару месяцев, но уже оч достал вайн в теме. Изменено 3 апреля, 2013 пользователем Шикарный Манул Ссылка на комментарий Поделиться на другие сайты Поделиться
HiveTyrant Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Понятно что для нормальных выводов нужна книжка на руках и поиграть хотя бы пару месяцев, но уже оч достал вайн в теме. Сейчас не раскрыта основная фишка Тау - маркеры. Пока не будет ясно с пасами - ничего не ясно. Ну и апгрейды, даже без цен надо бы почитать, иначе грустно теоретизировать. Ссылка на комментарий Поделиться на другие сайты Поделиться
Locke Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Львиная часть кодекса известна , но пока идей высказываеться оч мало. Сразу скажу сам не таувод , но интересно чего теперь ждать от синемордых. Так же интересно как выход новых тау повлияет на общий баланс армий и повлияет ли(вроде меньше самолётиков - больше колдунов). Ну и может мысли по изменившимся матчапам у кого есть. Вангую: шестерка станет окончательно про стрельбу, турнирные рукопашные расписки станут встречаться реже. Потому что желающих ловить овервоч по БС2 с нескольких отрядов - дураков нет. Ссылка на комментарий Поделиться на другие сайты Поделиться
HiveTyrant Опубликовано 3 апреля, 2013 Жалоба Поделиться Опубликовано 3 апреля, 2013 Вангую: шестерка станет окончательно про стрельбу, турнирные рукопашные расписки станут встречаться реже. Потому что желающих ловить овервоч по БС2 с нескольких отрядов - дураков нет. И тут такие БТ на ассолтных ринах с диржкастерами бабах! Ссылка на комментарий Поделиться на другие сайты Поделиться
