Daddymoroz Опубликовано 25 октября, 2008 Жалоба Поделиться Опубликовано 25 октября, 2008 (изменено) "High Level Armor Sets - 101 Did you know that there are a total of 19 sets of armor available for each career? These armor sets can be found throughout the Warhammer world, and at higher levels can be incredibly helpful (if not imperative) for certain encounters. For example, the highest end sets feature special resistances called Wards. On these high end sets, there are five pieces of armor which grant a 10% reduction in damage per piece when worn in specific endgame encounters, for a possible cumulative of around 50% reduction. With these set pieces, players can emerge victorious from what would otherwise be much more difficult battles. The five pieces of armor in these high end sets which feature the Wards are: chest, boots, gloves, helmet and shoulders. Please note: images are a random sampling of certain armor sets. All sets are available for all careers. Lesser Ward Bloodlord Armor Set Found in: Bastion Stair Requirements: Ranks: Ranks 37-39 Annihilator Armor Set Found in: Tier 4 RvR Requirements: Ranks: Ranks 35-39 and Renown Ranks 31-35 Both sets can be used in any combination to offer the Lesser Ward, which is required for City High Level Dungeons and Fortress encounters. There are five pieces of armor in each set. Greater Ward Sentinel Armor Set Found in: City High Level Dungeons Requirements: Rank 40 Conqueror Armor Set Found in: Fortresses Requirements: Rank 40 and Renown Ranks 45-50 Both sets can be used in any combination to offer the Greater Ward, which is required for both the Lost Vale and the City Invasion PQs. The Sentinel and Conqueror sets also provide the effects of the Lesser Ward. There are six pieces of armor in each set. Superior Ward Darkpromise Armor Set Found in: Lost Vale Requirements: Rank 40 Invader Armor Set Found in: Invasion PQs Requirements: Rank 40 and Renown Ranks 55-60 Both sets can be used in any combination to offer the Superior Ward, which is required for Sub-Boss PQs. The Darkpromise and Invader sets also provide the effects of the Lesser Ward and Greater Ward. There are six pieces of armor in each set. Excelsior Ward Warlord Armor Set Found in: Sub-Boss PQs (in cities while contested) Requirements: Rank 40 and Renown Ranks 64-70 The Sub-Boss PQs are the only means of acquiring the Excelsior Ward which is required for the King Fights. The Excelsior Ward includes the effects of all previous armor sets. There are seven pieces of armor in this set. Supreme Ward Sovereign Armor Set Found in: King Fight (in cities while contested) Requirements: Rank 40 and Renown Ranks 73-80 The Sovereign armor set is the highest level armor set, and includes the wards from all previous sets. There are eight pieces of armor in this set. Изменено 25 октября, 2008 пользователем Daddymoroz Ссылка на комментарий Поделиться на другие сайты Поделиться
Lorgar Опубликовано 26 октября, 2008 Жалоба Поделиться Опубликовано 26 октября, 2008 Неплохо, только избранный подкачал. Он же не кхорнит, а тзинчист все-таки, а брони как на кхорните. :? Ссылка на комментарий Поделиться на другие сайты Поделиться
Insert Опубликовано 27 октября, 2008 Жалоба Поделиться Опубликовано 27 октября, 2008 Не, имхо, на избранном бронька в самый раз. Тир 4 паладинов из ВоВ курит - фиолетовый вошел в моду :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Daddymoroz Опубликовано 27 октября, 2008 Автор Жалоба Поделиться Опубликовано 27 октября, 2008 Не, больше всего меня радует броня класса Суверен для Черного Орка- вот это броненосец =) Жалко правда достать Суверен можно только через убийство Императора <_< Ссылка на комментарий Поделиться на другие сайты Поделиться
