Curator Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 (изменено) Варсир о новой ИГ Army wide special rule: I think it’s called Platoon Drill or something like that. Basically, units from the same platoon may ignore intervening squads when shooting. So enemy units targeted in this way do not receive the 4+ save. Apparently this only works if the Platoon command squad is alive and within 12” of the rest of the platoon. I’ve been told that this is just one of the abilities guard Platoons may get, but only as long as the chain of command is intact (whatever that means). So loosing your HQ Command Squad may be a really bad thing. Doctrines are for sure gone (I think we all knew this), but have been replaced by more mutable platoons. Instead of Armoured fist squads you can buy Chimeras for a whole platoon. Or buy the whole platoon grav-chutes to give them deep strike, or drop the heavy weapons from squads and give the platoon Scout. Veteran squads become upgrades to platoons (i.e. they are not elites anymore). Apparently infantry platoons let you attach certain types of support vehicles to them(kinda like back in second edition). Things like sentinels, hellhounds and demolishers can be attached to platoons. They still take up a FOC spot, but become part of the platoon and so will benefit from the Platoon Drill rule. The Leman Russ can be bought as a squadron so you can get 3 for a single FOC. They can not be attached to platoons however. Sniper Squads can now infiltrate, get stealth, range finders and all models in the squad have sniper rifles (and BS 4!). Like the Land Raider, a new plastic sprue for the Leman Russ has been made that will allow plastic demolishers and a 3rd variant (my money is on the Exterminator). The Baneblade in NOT in the new codex. It just doesn’t work (i.e. overpowered)in games that are not Apocalypse in size. However Stormtrooper squads can now take Valkyries as transports. Both will be getting a plastic kit. Valkyries follow the rules for skimmers I’ve been told. Again, they want to keep flyers and super heavies out of ”normal games” but give people the ability to use them with all the special rules in Apocalypse and Planet-strike (if the ever get around to that.) This last one makes me wonder what’s they are doing, but apparently there is a new HQ in the book; Inquisitor and Retinue much like the elites from the current Daemon Hunters/Witch Hunters books. More info if I get it. Изменено 7 апреля, 2009 пользователем Cтепaн. Ссылка на комментарий Поделиться на другие сайты Поделиться
Captain Beefheart Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Things like sentinels, hellhounds and demolishers can be attached to platoons крута... Да еще леманы сквадронами. Похоже мы увидим сплошное АС вместо того ИГ, что сейчас Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Что-то как-то жидковато, хотя новости о пластиковых штурмачах очень порадовали. В основном названны очевидные вещи. А вот как нпример будет решать ся вопрос с разными полками? ИМХО Катачанцы от Вальхальцев отличаються посильнее чем Вайт скары от Ультрамаринов - модификацией листа засчет АШ КУ уже не обойдешься ИМХО. Интересен Командный платун, так и останеться камнем на шее, который тепер ьеще и крайне не желательно терять, или получит больше опций.(ну там кавалерийский, танковый.... еще что-то там.) Ссылка на комментарий Поделиться на другие сайты Поделиться
Чудесный Маклейн Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 А перевод будет? О о Я,например,мало что понял. Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 ЛР сквадронами? Хотел бы я посмотреть на это... Фигня. Особенно по пятерке. Больше 3 мы так и не увидим. Ссылка на комментарий Поделиться на другие сайты Поделиться
Sarn Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Блин, маловато понял. Кто-нибуть ,может, возьмется за перевод? Ссылка на комментарий Поделиться на другие сайты Поделиться
SPINDLE Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 (изменено) Чот я ниасилил..Беню теперь и по ИА нельзя брать чтоль? Армия получит новое спец правило : Я думаю оно будет зваться Platoon Drill или как-то так. Суть в том что стрельба с одного платуна будет игнорировать промежуточные сквады при стрельбе. То есть вражеские по которым ведется стрельба не получают 4+ сэйв ( Видимо они не считаются заскринеными другим сквадом, комментарий переводчика) Но это работает только если Командный платун находиться в 12ти дюймах от стреляющего платуна. Но я бы сказал что это только одна из абилок(спец правил) которые может брать платун. Таким образом потеря командного платуна крайне нежелательна. Мои коменты: А это спец правило надо будет покупа интересно? И кому оно присваиваеться ? Команднику или платуну? Если платуну то у всех платунов оно должно быть одинаково или каждому можно брать своё? Вобщем пока больше вопросов. Доктрин не будет (Думаю мы все знали это), но их заменили более опциональными платунами. Вместо арморед фист сквадов Armoured fist squad’ов мы можем покупать Химеры на весь платун. Или покупать на весь платун гравишуты, давая платуну дипстрайк (интересно а они будут входить в новые наборы? Комент переводчика) или не брать тяжёлое оружее и делать платун скаутами (я так понял инфильтра, коментари переводчика) Взвод ветеранов улучшаеться до платуна (а не наоборот? Комментарий переводчика) (Таким образом они больше не элита) Мои коменты. Хех... Интересно а карапас дадут? Прикиньте иг с поголовным 4+ сэйвом и 4м балистиком… Наверно прикольно. Вероятно пехотным платунам дадут возможность присоеденять опрделённые виды техники поддержки (Как во второй редакции) Например sentinels, hellhounds и demolisher’ы. Они будут занимать ФОС, но становяться частью платуна и буду получать их спецправило Platoon Drill (видимо и другие тоже, примечание переводчика) Леман Расы будут сквадронами, таким образом на 1 ФОС мы берём 3 Леман Раса. Однако они не могут быть присоединены к платунам. Снайперы теперь инфильтра,получат stealth,и range finders (Стелс видимо +1 ккавер сэйву, а range finders это типа таргетер видимо. ), и все мождели в сквадемогут брать снайперские винтовки. Как и Лэнд Райдер, новые пластиковые спруи получит Леман Расс, Пластиковый Демолишер и новый 3йвидЛеман Раса. (Ставлю деньги на экстерминатор) Бэйнблэйда не будет в новом кодексе. Его нельзя использовать в играх (вот тут тоже недопонял, толи его тока в апоке можно будет использовать толи в играх на большое количество очков как в апоке) (видимо оверпавер) Штурмовики получат возможность брать Валкирии в качестве транспорта. И штурмовики и валкирии буду в пластике. Валкирия будет иметь правило скимера. Видимо ГВ хочет отстрогироваться от правил для флаеров и супер хэви в «обычной игре» но дать возможность играть по ним в расширениях, апоке и планетстрайке (фиг его знает чо он в скобках написал, что-то типа если они когда-нибудь разродять) Мои коменты. Ну задолбали а.. нельзя сделать одну полноценную игру? говна всякого понаделают и хрен его знает по каким правилам играть.. теперь настолку реликам продают.. ваще хз чо будет. И то что меня удивило больше всего, но это только вероятно, это новая ХаКу в кодексе. Инквизитор и ретюна наиболее похожая на элиту из нынешнего кодекса Демонхантеров\Вич Хантеров. Изменено 1 июня, 2008 пользователем SPINDLE Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Лемы Сквадронами это - протезы АС, ну типа ДЖет Бяков в трупсе у Эльдар - протезы Сейм Хана. Если развить мысль, то трупсе минимум мото пехота на химераха, тогда какое Ха Ку? Ссылка на комментарий Поделиться на другие сайты Поделиться
Alex Kholev Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Хмм. Стоящий впереди сквад одного платуна дает 4+ кавер заднему, но не дает его врагам. Забавно. ЛР сквадами не пугает, стоимость большая - скоринга ноль. А вот хэлхаунды в платуны по пятерки могут и пожечь (и в прямом, и в переносном смысле слова.) Ссылка на комментарий Поделиться на другие сайты Поделиться
Bezumie Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Меня особенно порадавала не-элитность ветеранов. Интересно, опции те же останутся? Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 1 июня, 2008 Автор Жалоба Поделиться Опубликовано 1 июня, 2008 Да, скорящие ветераны - это хорошо. Только вряд ли их оставят такими же крутыми, как сейчас. + не совсем понятно, что сделают с гренками? Ссылка на комментарий Поделиться на другие сайты Поделиться
Темный Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Забавно. Если нам дадут ветеранов в трупсе по правилам платунов, то можно ждать дофига лазок с 4 БС. Жду! ЛР в сквадронах (Даешь 5 орданок в ход!!!). Жду! теперь из интересного. что будет с конями-огринами-командником? Ссылка на комментарий Поделиться на другие сайты Поделиться
Cormac Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Меня особенно порадавала не-элитность ветеранов. Интересно, опции те же останутся? Это вряд ли, готов поспорить, оставят мораль 8, инфильтру, а всё остальное будет как и у обычных ИГэшников. Ссылка на комментарий Поделиться на другие сайты Поделиться
tilindir Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Интересно, будет ли трупсовая приаттачченная техника скорить? Ссылка на комментарий Поделиться на другие сайты Поделиться
Mikhail Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 (изменено) Гренки-карапас в платуны? З.Ы. Ребят, а когда он выходит то? Изменено 1 июня, 2008 пользователем Эль Мигель Ссылка на комментарий Поделиться на другие сайты Поделиться
Cormac Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Интересно, будет ли трупсовая приаттачченная техника скорить? Насколько я понял, они будут только формально частью платуна, оставаясь на самом деле в своём родном Хэви Саппорте. Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Гренок будут прадовать, тк они ведь вроде(как я понял) заяволены в пластике. Продавать их будут Инквизиции и ИГ, значит в ИГ они как-то да заиграют. Ссылка на комментарий Поделиться на другие сайты Поделиться
shock trooper Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 (изменено) А это спец правило надо будет покупа интересно? И кому оно присваиваеться ? Команднику или платуну? Если платуну то у всех платунов оно должно быть одинаково или каждому можно брать своё? Вобщем пока больше вопросов. Фраза "Army-wide special rule" тонко так намекает, что оно будет действительно всегда и постоянно для всех платунов армии... get stealth, range finders Получают скрытность (это, видимо, +1 коверсейв?) и дальномеры (таргетеры, наверное. Возможность в шутингфазу померять расстояние ДО стрельбы) ветеранов улучшаеться до платуна (а не наоборот? Комментарий переводчика) Отряд ветеранов является дополнением\улучшением для взводов. (трактовать можно двояко. Либо отряд ветеранов аттачится к взводу (как ремнантс, например), либо до ветеранов апгрейдится одно из "штатных" отделений взвода). И если еще хоть один <zensur> переведет squad как взвод - укопаю самолично минусами. <_< "валкирьи" - плюспиццод. "Валькирии" они... П.С. Совсем забыл чего спросить-то хотел: нет сведений как это будет интегрироватся с кодексами Вх\Дх? Выглядит-то вкусно (логично, что фишки с кастомизацией платунов не порежут для индактедов, ибо не доктрины же это - а значит у нас будет вменяемый дропъ и аф квады никуда не уйдут!), но мну чует, что ГВшники как всегда извратнуцца... Изменено 1 июня, 2008 пользователем shock trooper Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 1 июня, 2008 Автор Жалоба Поделиться Опубликовано 1 июня, 2008 Интересно заявления о втором ха ку - недоинкивзиторы. И кому нужен их психик худ с 8(9) лидаком? Как контр чардж они тоже вряд ли будут ценны. Вообще нафига козе баян пока не ясно, просто не вижу роли, которую этот юнит будет выполнять. Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Худ с 9ым лидаком - вполне жизнеспособен, все дело в цене вопроса. Ссылка на комментарий Поделиться на другие сайты Поделиться
MegaVolt Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Худ с 9ым лидаком - вполне жизнеспособен, все дело в цене вопроса. +1 Если цена будет нормальная, то можно и 9м удовлетвориться, всё лучше чем никакой. А если у них ещё и мистики будут, то вообще отлично. Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 1 июня, 2008 Автор Жалоба Поделиться Опубликовано 1 июня, 2008 Как можно удовлетворяться 9 я не понимаю. Что нужно контрить в первую очередь? Лэш и эльдар. Там 10. своим 9 контрить не получится, зря только очки тратить. Ссылка на комментарий Поделиться на другие сайты Поделиться
MegaVolt Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Как можно удовлетворяться 9 я не понимаю. Что нужно контрить в первую очередь? Лэш и эльдар. Там 10. своим 9 контрить не получится, зря только очки тратить. Играя и за эльдар и за СМ я не раз обламывался фарсирами и эпистоляриями об кодициров. Так что определённая эффективность у 9го лидака есть,главное, чтоб цена была адекватная и какие-то дополнительные возможности были. Ссылка на комментарий Поделиться на другие сайты Поделиться
SPINDLE Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 Вот по поводу дальномера тоже не всё ясно..таргетер можно использовать только после стрельбы гес рэнджем....а тут может другое правило. А вот со стэлсом тут видимо в точку, чот не подумал я про это. Ссылка на комментарий Поделиться на другие сайты Поделиться
shock trooper Опубликовано 1 июня, 2008 Жалоба Поделиться Опубликовано 1 июня, 2008 таргетер можно использовать только после стрельбы гес рэнджем ...И вот тут я понял, что нифига-то я правил не знаю или не понимаю:)... Ссылка на комментарий Поделиться на другие сайты Поделиться
