Темный Опубликовано 13 ноября, 2007 Жалоба Поделиться Опубликовано 13 ноября, 2007 (изменено) IG: Custom Doctrines Army 0 Command Platoon (HQ) @ 174 Pts 4 Command Squad @ [174] Pts Plasma Gun (x4) 1 Junior Officer @ [40] Pts 1 Chimera @ [94] Pts Heavy Bolter; Hull Heavy Bolter Extra Armour [5] Smoke Launchers [3] Searchlight [1] 7 Grenadiers @ 214 Pts Hellguns (x5); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Veteran Sergeant @ [31] Pts Plasma Pistol; Power Weapon; Frag Grenades; Krak Grenades 1 Chimera @ [93] Pts Heavy Bolter; Hull Heavy Bolter Extra Armour [5] Smoke Launchers [3] 7 Grenadiers @ 214 Pts Hellguns (x5); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Veteran Sergeant @ [31] Pts Plasma Pistol; Power Weapon; Frag Grenades; Krak Grenades 1 Chimera @ [93] Pts Heavy Bolter; Hull Heavy Bolter Extra Armour [5] Smoke Launchers [3] 7 Grenadiers @ 214 Pts Hellguns (x5); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Veteran Sergeant @ [31] Pts Plasma Pistol; Power Weapon; Frag Grenades; Krak Grenades 1 Chimera @ [93] Pts Heavy Bolter; Hull Heavy Bolter Extra Armour [5] Smoke Launchers [3] 1 Leman Russ Demolisher (Heavy Support) @ 180 Pts Demolisher Cannon; Hull Lascannon; Heavy Flamer Sponsons Extra Armour [5] 1 Leman Russ Demolisher (Heavy Support) @ 180 Pts Demolisher Cannon; Hull Lascannon; Heavy Bolter Sponsons Extra Armour [5] 1 Leman Russ Battle Tank (Heavy Support) @ 171 Pts Battle Cannon; Hull Lascannon; Heavy Bolter Sponsons Extra Armour [5] Searchlight [1] 4 Hardened Veterans (Elites) @ 75 Pts Lasguns (x1); Plasma Guns (x3); Drop Trooper 1 Hardened Veteran Sergeant @ [13] Pts Close combat Weapon; Laspistol 4 Hardened Veterans (Elites) @ 75 Pts Lasguns (x1); Plasma Guns (x3); Drop Trooper 1 Hardened Veteran Sergeant @ [13] Pts Close combat Weapon; Laspistol 0 Choose Doctrines (HQ) @ 0 Pts Regimental Organisation: Grenadiers [0] Skills and Drills: Veterans [0] Regimental Organisation: Drop Troops [0] Models in Army: 46 Total Army Cost: 1497 Изменено 13 ноября, 2007 пользователем RAINMAN Ссылка на комментарий Поделиться на другие сайты Поделиться
Rjak Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Хорошо, только командник надо в ХтХ подзакачать и найти место для Хеллхаунда а лучше двух Ну и дроп трупперы не в кассу смотряться Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Хорошо? 3 Транспорта, 3 Танка с 14 лбом и 2 отряда а-ля Облитераторы? На 1500? Для СМ/ХСМ хорошо. А для ИГ? =) Ссылка на комментарий Поделиться на другие сайты Поделиться
Rjak Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Для иг очень неплохо 3 танка 2 хеллханда 4 химеры с гренками Играет замечательно для ИГ :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Угу, если Гренадеры не по 10 в отряде, то играет неплохо. Как Арморд Компани. Если доходит что-то с Т5+ и 3+ вундами, то всё. Сливаем воду. Ссылка на комментарий Поделиться на другие сайты Поделиться
Rjak Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 (изменено) Угу... В данном ростере я вижу по 8 гренок в химере... В приведенном мною - было 6 Вопрос, брать ли лишние две вунды в отряд гренок и дроп, или лучче таки танчегов побольше - дело вкуса автора. Ростер вполне играбелен и интересен. Единственно что реально не в кассу - так это парашутисты... Туда бы еще коней :) А то контрчарджа нету :) Во всяком случае гораздо интереснее чем Танки, кони и платуны :) Изменено 14 ноября, 2007 пользователем Rjak Ссылка на комментарий Поделиться на другие сайты Поделиться
Cormac Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Откровенный слив будет только если противник в исключительно противотанковой закачке. Ссылка на комментарий Поделиться на другие сайты Поделиться
Темный Опубликовано 14 ноября, 2007 Автор Жалоба Поделиться Опубликовано 14 ноября, 2007 Командник в рукопашном варианте не айс (он стоит 201 очко без химеры), я к тому же с ним в пехотной ИГ играю. И кста. читаем кодекс ИГ 4 отряда гренок взять нельзя (только 3), дроп нужен чтобы казнить там всякий индерект или добивать Т5 и 3+ W. Ссылка на комментарий Поделиться на другие сайты Поделиться
Rjak Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Вру, да... 3 химеры с гренками и одна с командником Ссылка на комментарий Поделиться на другие сайты Поделиться
Brenner Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Командник в рукопашном варианте не айс (он стоит 201 очко без химеры), я к тому же с ним в пехотной ИГ играю. И кста. читаем кодекс ИГ 4 отряда гренок взять нельзя (только 3), дроп нужен чтобы казнить там всякий индерект или добивать Т5 и 3+ W. Это что у тебя за такой дикий ХтХ-командник? Опиши закачку, искренне интересно. Если есть желание, взять можно хоть 6 отрядов гренадеров\штурмовиков. 3 в Трупс, 3 в Элиту. Вопрос в том, насколько это целесообразно... Ссылка на комментарий Поделиться на другие сайты Поделиться
Темный Опубликовано 14 ноября, 2007 Автор Жалоба Поделиться Опубликовано 14 ноября, 2007 Командник как командник папа с инвулем фистом, гварды с ЛП и ЦЦВ, коми с фистом, знамя. если папа 2 вунды то на 181 умещается. Ссылка на комментарий Поделиться на другие сайты Поделиться
Гость Andreus Anfarius Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 (изменено) А по моему человек создал если не мега читнявую то просто читнявую роспись. С припиской: долбитесь о нас лбом :deever: и умрите. Кланяюсь, падаю и бормочу хвалы на демоническом :image107:, потом отползаю и ищу беспечную жертву, чтобы принести её в жертву человеку дождя. Изменено 14 ноября, 2007 пользователем Andreus Anfarius Ссылка на комментарий Поделиться на другие сайты Поделиться
KillBoy Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 А по моему человек создал если не мега читнявую то просто читнявую роспись. С припиской: долбитесь о нас лбом :deever: и умрите. Кланяюсь, падаю и бормочу хвалы на демоническом :image107:, потом отползаю и ищу беспечную жертву, чтобы принести её в жертву человеку дождя. :boyan: Да и дроп здесь, имхо, лишний. Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 А по моему человек создал если не мега читнявую то просто читнявую роспись. С припиской: долбитесь о нас лбом :deever: и умрите. Кланяюсь, падаю и бормочу хвалы на демоническом :image107:, потом отползаю и ищу беспечную жертву, чтобы принести её в жертву человеку дождя. Сколько назвать ростеров, которые этот сожрут на завтрак? :D Ссылка на комментарий Поделиться на другие сайты Поделиться
Темный Опубликовано 14 ноября, 2007 Автор Жалоба Поделиться Опубликовано 14 ноября, 2007 (изменено) Вульф давай по пунктам. 2 Andreus Anfarius: Что ты это не читня этог очень даже слив. [Добавлено позже] Unnamed1500 Pts - IG: Custom Doctrines Army 0 Command Platoon (HQ) @ 170 Pts 4 Command Squad @ [170] Pts Plasma Gun (x4) 1 Junior Officer @ [40] Pts 1 Chimera @ [90] Pts Multi-Laser; Hull Heavy Bolter Extra Armour [5] 5 Grenadiers @ 194 Pts Hellguns (x3); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Veteran Sergeant @ [31] Pts Plasma Pistol; Power Weapon; Frag Grenades; Krak Grenades 1 Chimera @ [93] Pts Heavy Bolter; Hull Heavy Bolter Extra Armour [5] Smoke Launchers [3] 5 Grenadiers @ 194 Pts Hellguns (x3); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Veteran Sergeant @ [31] Pts Plasma Pistol; Power Weapon; Frag Grenades; Krak Grenades 1 Chimera @ [93] Pts Heavy Bolter; Hull Heavy Bolter Extra Armour [5] Smoke Launchers [3] 5 Grenadiers @ 194 Pts Hellguns (x3); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Veteran Sergeant @ [31] Pts Plasma Pistol; Power Weapon; Frag Grenades; Krak Grenades 1 Chimera @ [93] Pts Heavy Bolter; Hull Heavy Bolter Extra Armour [5] Smoke Launchers [3] 1 Leman Russ Demolisher (Heavy Support) @ 190 Pts Demolisher Cannon; Hull Lascannon; Plasma Cannon Sponsons Extra Armour [5] 1 Leman Russ Demolisher (Heavy Support) @ 190 Pts Demolisher Cannon; Hull Lascannon; Plasma Cannon Sponsons Extra Armour [5] 1 Leman Russ Battle Tank (Heavy Support) @ 173 Pts Battle Cannon; Hull Lascannon; Heavy Bolter Sponsons Extra Armour [5] Smoke Launchers [3] 1 Hellhound (Fast Attack) @ 120 Pts Inferno Cannon; Hull Heavy Bolter Extra Armour [5] 4 Hardened Veterans (Elites) @ 75 Pts Lasguns (x1); Plasma Guns (x3); Drop Trooper 1 Hardened Veteran Sergeant @ [13] Pts Close combat Weapon; Laspistol 0 Choose Doctrines (HQ) @ 0 Pts Regimental Organisation: Grenadiers [0] Regimental Organisation: Drop Troops [0] Models in Army: 36 Total Army Cost: 1500 Вот я немного переделал. Изменено 14 ноября, 2007 пользователем RAINMAN Ссылка на комментарий Поделиться на другие сайты Поделиться
Leonid Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 RAINMAN, ты не пробовал химеры с огнемётами? В принципе когда они выбросили пацанов они уже близко к противнику и могут пожечь (особенно всяких хиляков в кавере) + они получаются подешевше :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Гость Andreus Anfarius Опубликовано 14 ноября, 2007 Жалоба Поделиться Опубликовано 14 ноября, 2007 Вульф давай по пунктам. 2 Andreus Anfarius: Что ты это не читня этог очень даже слив. Дело я ясное что не читнявое, но весёлое очень. А для Иг в принципе неплохо! Конечно порвут её очень многие(а иг и так часто избивают), но идея очень понравилась! Фан да и только. Прошу оценивать ростер с позитива. Так интересней! Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 15 ноября, 2007 Жалоба Поделиться Опубликовано 15 ноября, 2007 Мех ИГ на Гренках, без изьянов. Все, впринципе, на своем месте. Разве что коней добавить :D Советы: Командник лучше НЕ закачивать в пожарники. Или дать мислу\лазку + химера и струлять, или 4 плазмы и в дроп. Химера НЕ рино. Она по-другому играет. Лучше ездить и стрелять, из мультика\хб, чем возить смертников. А на освободившиеся очки купить еще сквад ветеранов. 2 Демы сменил бы на 2 лемы, а 1 лему на васю. (будет 2 лемы+ вася) При таком варианте получается вариативность тактики - ты можешь КАК ехать вперед и пресинговать, так и престреливаться с разными тау. Во втором варианте Гренки идут пешком отдельно, химеры ездят и стреляют отдельно. Химера с фламером играет, но она просто не нужна. При рапиде сквада гренок всякие арли\драконы\ревенеры\ и тп кончаются и так. А тот же хб поможет проредить их на подходе. Ну и последнее - коней не желаете? Всеж таки за скрином из химер они играют еще лучше, чем просто в пешей иг. Какие наступательные операции можно проводить! Да и просто добить ккого-нить ДП коцаного очень даже вариант. Он 10 раз подумает, выбегать ли на твою мех колонну, если позади химер будет стоять 1-2 сквада лошадей. Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 15 ноября, 2007 Жалоба Поделиться Опубликовано 15 ноября, 2007 Люблд я нешего мехкавалериста читать =) На позитив настраивает. Куратор, я тебе 100 раз говорил, если на моего ДП ты бросишь 2 отряда лошадок, я буду счастлив до усрачки. Ибо в 30% ДП останется еще и скорингом, сожрав 2 отряда, в 40% останется живым. а в оставшихся 30% сольется прихватив с собой 2 отряда кавлерии. Что в общем-то является разменом по очкам. Вообще я бы играл так: 1-2 отряда Плазмасмерти на Химерах, а остальное либо Ветераны, либо Платунги. бо в варианте 4 Химеры - 400 очков не скорят вообще. Учитывая малое кол-во моделей в ростере - это является его основной проблемой. А не гипотетичесике ДП и Вибропушки. Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 15 ноября, 2007 Жалоба Поделиться Опубликовано 15 ноября, 2007 (изменено) А я тебе говорил, что на целенького ДП я коней кидать не собираюсь. А вот добить подранка - милое дело! А плазмо смерть на химерах не катит. За машинку нужно отдать 93 поинта. Это совсем не 50 или 58 за ринку, ага? А если ездить все время по 12, то плюсы химеры перед ринкой нивелируются. Ну и в 10 бок напихают дай боже. Плазмо смерть нужно дропать. Изменено 15 ноября, 2007 пользователем Curator Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 15 ноября, 2007 Жалоба Поделиться Опубликовано 15 ноября, 2007 Я так не считаю. Поиметь 5 выстрелов плязмой с БС 4 или 9 с БС 3 - совсем неплохо. Кроме того, такой юнит нуден в любой армии. А то что он на Химере - если Иг может взять что-то другое - надо брать. Не может? Ну что ж... Зато лоб 12. Ссылка на комментарий Поделиться на другие сайты Поделиться
Rjak Опубликовано 15 ноября, 2007 Жалоба Поделиться Опубликовано 15 ноября, 2007 А может таки мултилазер заместо ХБ? Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 15 ноября, 2007 Жалоба Поделиться Опубликовано 15 ноября, 2007 (изменено) А может таки мултилазер заместо ХБ? !!!!!!!!!!!!!! Только сейчас заметил! Райнман, даже не выдумывай, ставь мультики. ГОРАЗДО лучше хб. <font size="-4">[Добавлено позже]</font> Я так не считаю. Поиметь 5 выстрелов плязмой с БС 4 или 9 с БС 3 - совсем неплохо. Кроме того, такой юнит нуден в любой армии. А то что он на Химере - если Иг может взять что-то другое - надо брать. Не может? Ну что ж... Зато лоб 12. Из дропа будет все те же 7 \ 13 выстрелов плазмы. При чем они будут более гарантировано. По эльдарам \ тау довести химеру с плазмой - та еще задачка, а дроп более гарантирован. Такой юнит нужен, но он нужен не на химере, а в дропе. Изменено 15 ноября, 2007 пользователем Curator Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 15 ноября, 2007 Жалоба Поделиться Опубликовано 15 ноября, 2007 Ключевой момент - Химеру вообще никуда водить не надо. Она должна тусоваться в твоём деплое. Ссылка на комментарий Поделиться на другие сайты Поделиться
