Уважаемые, на прошлой неделе RC выдал в открытую бету новый армилист крыс. Я решил собрать все изменение в одном месте:
Лидеры:
  • Изменилась командная способность BroodMother
    "Было"
    Bodyguard: When the Brood Mother is the target of a Shooting attack, you may spend a Special result on your Command Dice to move a Crawler or Stalker one cube into the path of the attack, anywhere along the Line of Sight. Resolve the Shoot action as if it had targeted this model instead.
    "Стало"
    Feral Inspiration:When the Broodmother is close to any of her progeny, she will inspire them to even greater heights of savagery! You may spend an Army Special result on your Command Dice to give all Veer-Myn models within 2 cubes of the Broodmother Frenzy (1) until the end of the Round. If a model already has Frenzy (n) they will gain an additional point of Frenzy. You may not use multiple Army Special results on the same model, although if the Brood Mother moves you may use a subsequent Army Special result to give Frenzy (1) to any new models within range.
  • Цены Progenitor уменьшена с 30pts/3VP до 20pts/2vp, характеристика Recon изменена с 3+ на 4+
  • Добавлен новый лидер Master Creeper
    "Master Creeper"
    20pts/2VP
    Mv2-3
    Ar 0
    Sz 1
    S 5+
    F 5+
    S 5+
    Tactician(1), Scout
    Ray Pistol: R2
    Det Packs (Mag Lock): RF, AP2
    Det Pack (Prox Lock): R2, Blast
    Recon: 3+
    Bomb Expert: Spend an Army Special result to allow the active model to take a Special Action to perform a R2, Blast attack.
    Weapon Options: Leader, Small Arms, Light (All)
    Campaign Ability Options: Command, Melee,
    Specialist
Рядовые:
  • Цены Crawler уменьшена с 12pts/1VP до 10pts/1vp
  • Цены Stalker уменьшена с 10pts/1VP до 8pts/1vp
Специалисты:
  • Malignus Chem Thrower заменён на Malignus: Chem Thrower заменен на Ray Gun, цена уменшена с 18pts/1vp до 12pts/1vp
  • Night Terror with Scythes увеличен Size с 2 до 3, добавлены способности Tought, Beast
  • Night Terror with Spitter увеличен Size с 2 до 3, добавлены способности Tought, Beast
  • Цена Creeper увеличена с 12pts/1vp до 14pts/1vp, значение Shoot улучшено с 6+ до 5+, добавлена способность Scout, оружие Det Pack (Prox Fuse) изменено с R1, AP2 на R2, Blast
  • Цена Nightmare уменшена с 23pts/2vp до 17pts/2vp, значение Armour улучшено с 0 до 1
  • Добавлен новый специалистRat Swarm
    "Rat Swarm"
    14pts/2VP
    Mv2-3
    Ar 0
    Sz 2
    S -
    F 5+
    S 5+
    Agile, Beast, Tough
    Teeth and Claws: RF
    Weapon Options: None
    Campaign Ability Options: None
Техника:
  • У Tangle добавлено свойство Psychic для оружия Visions of Glory
  • Добавлена новая техника Tunnel Runner
    "Tunnel Runner"
    30pts/3VP
    Mv1-4
    Ar 1
    Sz 4
    S 5+
    F 5+
    S 5+
    Vehicle
    Twin Chem Spitters: R6, AP2, Weight of Fire (1), Rapid Fire
    Scythes: RF, AP1, Frenzy (1)
    Weapon Options: Vehicle (Automatic)
    Campaign Ability Options: Ranged
Предметы:
  • В список доступных предметов добавлены новая Toxic Grenade и Stun Grеnade
    "Toxic Grenade"
    Toxic Grenade: The Veer-Myn are known for the poisonous clouds of toxic gas that permeate their warrens and are used in their weapon technology. Clouds of toxic gas are often used to weaken the local populace prior to a Veer-Myn assault. This item follows the same rules as other grenades (page 30 of the Deadzone 2.0 rulebook), except that a toxic smokescreen is placed in the target cube. This toxic smokescreen follows the same rules on page 35 of the Deadzone 2.0 rulebook.
Оружие:
  • Spitter Rifle добавлена группа Light(Sniper)
  • Det Pack (Prox Fuse) изменен на R2, Blast
  • Цена Big Drill уменьшена с 5 до 3, добавлена группа Light(Melee)
  • Цена Pair of Drills уменьшена с 7 до 6
  • Scythes заменены группы с Heavy Beast на Beast(Melee), Vehicle(Melee)
  • Heavy Chem Spitter заменены группы с Heavy(Beast) на Beast(Ranged)
  • Добавлено новое оружие:
    • Twin Chem Spitter 10pts 1vp R6 AP2, Weight of Fire (1), Rapid Fire Vehicle(Automatic)
    • Smoke Grenade Launcher 8pts 0vp R5 Indirect(Smoke) Leader, Light(Explosive)
    • Toxic Grenade Launcher 12pts 1vp R5 Indirect(Toxic) Leader, Light(Explosive)
Еще в факе. После фака он был 14|2 с рэй ганом, стал 12|1.
Вроде всегда таким и было.
Фак не смотрел, т.к. считаю его автоматом включённым.
Там психик был на Вижнз оф дес. На глори небыло.
