Локи Насмешник Опубликовано 9 июля, 2007 Жалоба Поделиться Опубликовано 9 июля, 2007 Вот, чем я играю в последнее время. Проявляет себя нелпохо, но чувствую, что чего-то не хватает... IG: Doctrines Army 0 Choose Doctrines (HQ) @ 0 Pts Allow Rough Riders [0] Regimental Organisation: Grenadiers [0] Skills and Drills: Veterans [0] Skills and Drills: Die Hards [0] Regimental Organisation: Drop Troops [0] 0 Command Platoon (HQ) @ 99 Pts 3 Command Squad @ [99] Pts Heavy Bolter; Lasguns (x1); Laspistol and CCW (x1) 1 Heroic Senior Officer @ [77] Pts Bolt Pistol; Power Weapon Frag Grenades [1] 1 Veteran @ [12] Pts Bolt Pistol; Close combat Weapon; Standard Bearer 9 Hardened Veterans (Elites) @ 165 Pts Lascannon; Lasguns (x5); Plasma Guns (x3); Die Hards 1 Hardened Veteran Sergeant @ [33] Pts Laspistol; Power Fist 9 Hardened Veterans (Elites) @ 165 Pts Lascannon; Lasguns (x5); Plasma Guns (x3); Die Hards 1 Hardened Veteran Sergeant @ [33] Pts Laspistol; Power Fist 9 Hardened Veterans (Elites) @ 165 Pts Lascannon; Lasguns (x5); Plasma Guns (x3); Die Hards 1 Hardened Veteran Sergeant @ [33] Pts Laspistol; Power Fist 4 Grenadiers @ 70 Pts Hellguns (x2); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Sergeant @ [10] Pts Close combat Weapon; HellPistol; Frag Grenades; Krak Grenades 4 Grenadiers @ 70 Pts Hellguns (x2); Plasma Gun (x2); Frag Grenades; Krak Grenades 1 Grenadier Sergeant @ [10] Pts Close combat Weapon; HellPistol; Frag Grenades; Krak Grenades 1 Hellhound (Fast Attack) @ 116 Pts Inferno Cannon; Hull Heavy Bolter Searchlight [1] 1 Hellhound (Fast Attack) @ 116 Pts Inferno Cannon; Hull Heavy Bolter Searchlight [1] 8 Rough Riders (Fast Attack) @ 88 Pts Hunting Lances 1 Leman Russ Battle Tank (Heavy Support) @ 160 Pts Battle Cannon; Hull Heavy Bolter; Heavy Bolter Sponsons Extra Armour [5] 1 Leman Russ Battle Tank (Heavy Support) @ 160 Pts Battle Cannon; Hull Heavy Bolter; Heavy Bolter Sponsons Extra Armour [5] 1 Basilisk (Heavy Support) @ 125 Pts Earthshaker Cannon; Hull Heavy Bolter Models in Army: 58 Total Army Cost: 1499 Не подскажите, чтобы еще такого сделать? Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 9 июля, 2007 Жалоба Поделиться Опубликовано 9 июля, 2007 А гренок ты как используешь? Ссылка на комментарий Поделиться на другие сайты Поделиться
Локи Насмешник Опубликовано 9 июля, 2007 Автор Жалоба Поделиться Опубликовано 9 июля, 2007 Стоят в кустах стреляют, не дают подойти к Васе. Ссылка на комментарий Поделиться на другие сайты Поделиться
Rjak Опубликовано 9 июля, 2007 Жалоба Поделиться Опубликовано 9 июля, 2007 Я знаю чего тут не хвататет - гвардейцев. 10 человек всего :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Локи Насмешник Опубликовано 9 июля, 2007 Автор Жалоба Поделиться Опубликовано 9 июля, 2007 Гвардейцы отстали. Остальные на броне доехали. По существу высказывания будут? Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 9 июля, 2007 Жалоба Поделиться Опубликовано 9 июля, 2007 Гвардейцы отстали. Остальные на броне доехали. По существу высказывания будут? Да ИМХо все норм. Бэк хромает, конечно, ну и трупса взята, что бы слоты забить. Многие считают это не красивым. Можно скинуть фисты и 1 хелл, взять еще лошадок, не верю я в гвардейские фисты, хотя когда их 3 может и сработает... Знамени я бы выдал лайт инфантри, что бы не отставать от инфильтрирующихся ветеранов, а то традемарков то у тя нет. Ссылка на комментарий Поделиться на другие сайты Поделиться
Brenner Опубликовано 9 июля, 2007 Жалоба Поделиться Опубликовано 9 июля, 2007 Возможно, имеет смысл вместо Die-hards дать Hardened Fighters, а ветеранам заметить лазганы на лазпистоли и CCW. Да и всей технике можно бы дать и экстра армор, и смоки, всего-то +8 очков за танк... Я так понимаю, на технику здесь делается достаточно большой упор, вот и не помешало бы ей пожить подольше. Разумеется, это все мое ИМХО. Ссылка на комментарий Поделиться на другие сайты Поделиться
Curator Опубликовано 10 июля, 2007 Жалоба Поделиться Опубликовано 10 июля, 2007 Возможно, имеет смысл вместо Die-hards дать Hardened Fighters, а ветеранам заметить лазганы на лазпистоли и CCW. Да и всей технике можно бы дать и экстра армор, и смоки, всего-то +8 очков за танк... Я так понимаю, на технику здесь делается достаточно большой упор, вот и не помешало бы ей пожить подольше. Разумеется, это все мое ИМХО. Харду не давать, дай хардс можно оставить, но если есть лишние очки. Ветеранам оставить лазганы, смоки нужны, экстраармор по желанию. Енто ИМХО. Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 10 июля, 2007 Жалоба Поделиться Опубликовано 10 июля, 2007 ИМХО имеет смысл заменить ЛР на Демолишеры. Раз уж армия стремится к боям на средних дистанциях... Да и поживучее они. Ссылка на комментарий Поделиться на другие сайты Поделиться
