Artemis Опубликовано 4 июня, 2007 Жалоба Поделиться Опубликовано 4 июня, 2007 Собственно. стырил с АТТ для того чтобы ощественность ознакомилась. Common Crisis Configurations: (courtesy of T0nkaTruckDriver) These suit names were developed from the following rough pattern: Plasma Rifle: "Knife/Blade" Missile Pod: "Fire" Fusion Blaster: "Forge" Burst Cannon: "Storm" Airbursting Fragmentation Projector: "Thunder" Cyclic Ion Blaster: "Ion" One Weapon Suits: These consist of one twinlinked weapon and a support system (or Flamer) in the third hardpoint. Sunforge (SF): Twinlinked Fusion Blaster Deathrain (DR): Twinlinked Missile Pod Burning Eye (BE): Twinlinked Plasma Rifle Heatwave (HW): Twinlinked Flamer Two Weapon Suits: These consist of two weapons and a Multitracker. If one of the weapons is twinlinked, the configuration name will be followed by a number which is the strength of the twinlinked weapon. The Multitracker will then therefore be Hardwired. Fireknife (FK): Plasma Rifle + Missile Pod Helios: Plasma Rifle + Fusion Blaster Bladestorm / Blinding Spear / Aurora: Plasma Rifle + Burst Cannon Fireforge: Missile Pod + Fusion Blaster Firestorm: Missile Pod + Burst Cannon Stormforge: Burst Cannon + Fusion Blaster Hailstorm: Shas'Vre Twin Linked Burst Cannon + Airbursting Fragmentation Launcher. Ion Knife: Cyclic Ion Blaster + Plasma Rifle Ion Storm: Cyclic Ion Blaster + Burst Cannon Three Weapon Suits: Consists of three weapons and a Hardwired Multitracker Sunfire: Plasma Rifle + Missile Pod + Fusion Blaster Other Unique Configurations: O'Ninja: Shas'O with VRT, Stim Injectors, 2 weapons of your choice and a HW Multitracker. Designed to assault into close combat, tie up shooty units during the opponent's turn, and then jump out to allow them to be shot at during your turn. Centurion: Shas'El with Plasma, CIB, Target Array and HW Multitracker. Name derived from his even 100 point cost. Ссылка на комментарий Поделиться на другие сайты Поделиться
Brenner Опубликовано 4 июня, 2007 Жалоба Поделиться Опубликовано 4 июня, 2007 Надо же, как все интересно :) Спасибо! Надо ли понимать так, что это творчество игроков? Ссылка на комментарий Поделиться на другие сайты Поделиться
d2 Опубликовано 5 июня, 2007 Жалоба Поделиться Опубликовано 5 июня, 2007 Надо ли понимать так, что это творчество игроков? вот начало http://uk.games-workshop.com/tau/battlesui...nfigurations/1/ Ссылка на комментарий Поделиться на другие сайты Поделиться
Kor'Vesa Опубликовано 5 июня, 2007 Жалоба Поделиться Опубликовано 5 июня, 2007 AFP - Thunder и CIB - Ion это уже общепринято или только IMHO автора? Вроде Burst cannon еще имеет название Surge. twinlinked Flamer не помню. Уже придумали? Еще не хватает twinlinked Burst. Ссылка на комментарий Поделиться на другие сайты Поделиться
Artemis Опубликовано 5 июня, 2007 Автор Жалоба Поделиться Опубликовано 5 июня, 2007 AFP - Thunder и CIB - Ion это уже общепринято или только IMHO автора? Вроде Burst cannon еще имеет название Surge. twinlinked Flamer не помню. Уже придумали? Еще не хватает twinlinked Burst. Все названия, всех возможный конфигов кризисов ужо придуманы... Я привел самые рспространенные (и играбельные, соответственно). Ссылка на комментарий Поделиться на другие сайты Поделиться
Kor'Vesa Опубликовано 5 июня, 2007 Жалоба Поделиться Опубликовано 5 июня, 2007 Ссылку Плиз? Ссылка на комментарий Поделиться на другие сайты Поделиться
Artemis Опубликовано 5 июня, 2007 Автор Жалоба Поделиться Опубликовано 5 июня, 2007 Ссылку Плиз? Ломает. :) Полазь по АТТ.. Тама все есть и даже еще больше... Ссылка на комментарий Поделиться на другие сайты Поделиться
Raspfile Опубликовано 6 июня, 2007 Жалоба Поделиться Опубликовано 6 июня, 2007 Было б вобще здорово, если б кто-нибудь расписал, какие конфигурации для каких целей используются... Ссылка на комментарий Поделиться на другие сайты Поделиться
Kor'Vesa Опубликовано 6 июня, 2007 Жалоба Поделиться Опубликовано 6 июня, 2007 Было б вобще здорово, если б кто-нибудь расписал, какие конфигурации для каких целей используются... Давай рассуждать вместе. Из целей мы имеем TEQ, MEQ, GEQ (терминаторы, мары, гаунты), Легкая техника, Тяжелая техника. И особняком Индепы. Для TEQ нужно АП1-АП2 Соответственно Плазма и Фьюжен. Это же пригодится для индепов. Для MEQ Надо бы АП3, но его у кризисов нету. Так что сойдет куча выстрелов как для GEQ (Ракеты, пулемет) или таже плазма + фьюжен. Легкая техника (броня<12) сбивается ракетницей или плазмой. Для Тяжелой только фьюжен. Fireknife Хорош своей универсальностью. Разве что ландрейдер не подобьешь, но для этого есть рельсы. ;) CIB и AFP вещи редкие и уникальные, но подходят только для отстрела мелочи. Ссылка на комментарий Поделиться на другие сайты Поделиться
RussianKamikaze Опубликовано 6 июня, 2007 Жалоба Поделиться Опубликовано 6 июня, 2007 CIB и AFP вещи редкие и уникальные, но подходят только для отстрела мелочи. про циб не согласен. хорш он против MEQ и TEQ. у меня играет отлично - маров и терминаторов отстреливать. эдакий недорендинг. Ссылка на комментарий Поделиться на другие сайты Поделиться
Kor'Vesa Опубликовано 6 июня, 2007 Жалоба Поделиться Опубликовано 6 июня, 2007 про циб не согласен. хорш он против MEQ и TEQ. у меня играет отлично - маров и терминаторов отстреливать. эдакий недорендинг. Мнэээ Из 5 выстрелов будет от силы 1 шестерочка. Нет, точнее (5*5)/(6*6)=0,69(4). и еще от "нерендинга" (5*5)/(6*6*3)=0,23(148). Везет тебе просто! ;) Ссылка на комментарий Поделиться на другие сайты Поделиться
Maxim Опубликовано 6 июня, 2007 Жалоба Поделиться Опубликовано 6 июня, 2007 (изменено) Fireknife Хорош своей универсальностью. Разве что ландрейдер не подобьешь, но для этого есть рельсы. ;) Как всякий универсал – равно слаб во всём. :) В частности – попадает редко. Если, конечно, он не тимлидер-монат с BS4. CIB и AFP вещи редкие и уникальные, но подходят только для отстрела мелочи. Ну, как сказать... мелочь, сидящая в кавере – зло. А AFP, ИМХО, против неё вельми хорош. Сейчас гоняю секунд-коммандера со спаренной плазмой, «миномётом» и ХВ-мультиком. Фан, но кое-что может. Иногда, впрочем, меняю ему плазму на бурсты. Дешевле и по оркам/даркам/патфайндерам злее. про циб не согласен. хорш он против MEQ и TEQ. у меня играет отлично - маров и терминаторов отстреливать. эдакий недорендинг. Суслик – это оружие прушников. Для меня, с моим талантом кидать шестёрки только на лидершип-тестах... слишком нестабильно. Именно, что недорендинг. Изменено 6 июня, 2007 пользователем Maxim Ссылка на комментарий Поделиться на другие сайты Поделиться
