Ferlim Опубликовано 15 февраля, 2016 Жалоба Поделиться Опубликовано 15 февраля, 2016 (изменено) Вот навоял ростер, как думаете,что-нибудь сможет? Astra Militarum (1850/1850pt.) http://hq-builder.com/shared/127085 @Primary Detachment [ 1 ] Astra Militarum (Combined arms detachment) @HQ [ 1 ] Knight Commander Pask (390pt.) > 1x - Command Leman Russ Punisher (170pt.); Searchlight; Smoke launchers; Punisher gatling cannon; Lascannon; Multimelta (x2); > 1x - Leman Russ Exterminator (150pt.); Searchlight; Smoke launchers; Exterminator autocannon; Heavy bolter (x3); @Troops [ 2 ] 10x - Veterans (185pt.) > 1x - Veteran Sergeant ; Frag grenades; Close combat weapon; Laspistol; Carapace armour; > 6x - Veteran ; Frag grenades; Lasgun; Carapace armour; > 3x - Veteran (15pt.); Frag grenades; Plasma gun; Carapace armour; > 1x - Chimera (65pt.); Searchlight; Smoke launchers; Heavy flamer; Multi-laser; 10x - Veterans (105pt.) > 1x - Veteran Sergeant ; Frag grenades; Close combat weapon; Laspistol; Carapace armour; > 6x - Veteran ; Frag grenades; Lasgun; Carapace armour; > 3x - Veteran (10pt.); Frag grenades; Meltagun; Carapace armour; @Fast attack [ 2 ] Valkyrie Squadron (135pt.) > 1x - Valkyrie (135pt.); Extra armour; Searchlight; Multi-laser; Multiple rocket pod (x2); Vendetta Squadron (170pt.) > 1x - Vendetta (170pt.); Searchlight; Extra armour; Twin-linked lascannon (x3); @Heavy support [ 1 ] Basilisk Battery (125pt.) > 1x - Basilisk (125pt.); Earthshaker cannon; Searchlight; Smoke launchers; Heavy bolter; @Secondary Detachment [ 1 ] Inquisition detachment @HQ [ 2 ] Inquisitor Karamazov (200pt.) Master-crafted multi melta; Master-crafted power sword; Frag grenades; Krak grenades; Psyk-out grenades; Rad grenades; Orbital strike relay; Ordo Malleus Inquisitor (62pt.) Psyk-out grenades; Power armour; Frag grenades; Krak grenades; Bolt pistol; Daemonblade; Servo-skull (x3); The Grimoire of True Names; @Elites [ 2 ] 7x - Inquisitorial Henchmen Warband (82pt.) > 3x - Acolyte (4pt.); Flak armour; Laspistol; Chainsword; > 3x - Servitor (20pt.); Carapace armour; Plasma cannon; > 1x - Psyker (10pt.); Flak armour; Laspistol; 9x - Inquisitorial Henchmen Warband (396pt.) > 1x - Ministorum Priest (25pt.); Flak armour; Frag grenades; Krak grenades; Rosarius; Laspistol; Close combat weapon; > 4x - Crusader (15pt.); Flak armour; Power weapon; Storm shield; > 4x - Death Cult Assassin (15pt.); Flak armour; Power weapon (x2); > 1x - Land Raider (251pt.); Twin-linked heavy bolter; Twin-linked lascannon (x2); Smoke launchers; Searchlight; Составлялся во многом из того,что есть. С инвизом планируем бороться Карамазовым) Изменено 15 февраля, 2016 пользователем Ferlim Ссылка на комментарий Поделиться на другие сайты Поделиться
Клавиус Опубликовано 16 февраля, 2016 Жалоба Поделиться Опубликовано 16 февраля, 2016 Мои имхи: 1) Василиск не очень смотрится, конкретно в этом ростере. Конечно, можно засунуть его в самый дальний угол, но разбить его даже ответных барражем. Если в радиусе 12" окажется почти любой вражеский юнит - скорее всего, это будет последний ход Васи. 2) Если мелта-ветераны будут лететь на Вендетте - это будет долго и неэффективно. 3) Со временем пришел к мнению, что ветеранам в Химере обычно не нужен третий спешал - дырки две. Хотя с плазмами это может подстраховать в плане перегревов - один помер, а огневая мощь сохранилась. 4) Настоятельно рекомендую изыскать Химере 5 очков на дозер блейд. Хорошо бы и Паску или обоим танкам его, хотя я никогда не ставлю и обхожусь как-то. А вот лендаку дозер сам Император велел присобачить! 5) Минус плазма-сервиторов - они либо не могут ходить, либо не могут стрелять. Плюс из блинов выхлоп не особо - ещё три плазмагана были бы эффективнее. 6) Химеру как раз можно взять инквизиторскую - дешевле и с 5 дырками для ружей. Проблем никаких - сел в начале хода и поехал. А насчет взлетаемости - как карта ляжет. Карамазов стоит как танк, при этом отъехать может достаточно легко - то 10 сила найдется, то форса какая-нибудь. При этом прятать его банально некуда в этом ростере. Ссылка на комментарий Поделиться на другие сайты Поделиться
DropPodVasya Опубликовано 16 февраля, 2016 Жалоба Поделиться Опубликовано 16 февраля, 2016 (изменено) Не очень вижу как это играет на 1850. 1) Танки - лучше найти очков еще на 1 или 2 панишера в такой же закачке,либо хотя бы оторви экстрерминатор от паска. Вепоны у них варьируются от ХБ до Лазок,и задачи не очень схожи - а это потеря огневой мощи. 2) Зачем варбанда на Лэндрейдере?Это ведь жуткий оверпрайс,я понимаю,что из того что есть,но брать лэндак горстке ватных моделей,это не круто. Лучше уж тогда химеру какую нибудь,или ринку (Если они есть у инкви,забыл уже). 3) Соглашусь с комментами выше по поводу Василиска - мне лично вообще кажется что он играет только на апок,24" слепая зона это фи.+ прикрыть/скринить его совсем нечем.Да и огневая мощь у него не жутко страшная - мантикора в разы лучше будет. 4) Если бы не было написано по типу "Слепил из того что было",я бы выкинул отсюда инквизицию как таковую,взял либо больше химерок с ветеранами,либо все превратил в платуны,Валькирию сразу в топку - заменить на 2 вендетту,Василиск на 2 Виверны или Мантикору,сквадрон с паском добить до 3ех панишеров. Но именно сейчас ростер выглядит довольно странновато - даже не маэль.Не рыба,не мясо.Мощных ударных сил - нету,Ганлайна - нету,Маэля - нету нормального.Не рыба,не мясо.Конечно,все имхо. Изменено 16 февраля, 2016 пользователем DropPodVasya Ссылка на комментарий Поделиться на другие сайты Поделиться
StrangeXellos Опубликовано 17 февраля, 2016 Жалоба Поделиться Опубликовано 17 февраля, 2016 (изменено) Жень, а не хочешь сократить пачку хенчей, чтобы утромбовать их в Вендетту? Оттуда же можно сделать суисайд дроп, как раз Карамазова ради. Изменено 17 февраля, 2016 пользователем PROJECT: Xellos Ссылка на комментарий Поделиться на другие сайты Поделиться
