Воины Засоа и 9 стрел - или что северяне получили от северян
Aemir
Это в общих рулях прописано
Models with a Mark of the Dark Gods other than Unbound cannot join Units with
one or more models with a Mark of the Dark Gods other than the same as themselves or Unbound.
  • Ответов 609
  • 3 недели спустя...
Вот, часть выложили на общее обозрение:
http://www.the-ninth-age.com/index.php?thr...eaks-of-wow-ab/
Очень весело смотрятся чозены и бруты, раздающие веслами удары 8й-7й силой...
Изменено пользователем Aemir
Отлично переделали блайткингов и врасмонгеров. Вот вам конструктор "собери себе монстр-инфантри мортала")))
Подумали ребята. А вот троли мне жесткими кажутся, с новым регеном то. За пару фаз можно так не хило отряд прокачать если повезет.
где описание марок в файле?? не могу найти ((
или просто подскажите, что сейчас дают марки богов ))
Unbound: Units with majority of models with the Mark of the Dark Gods (Unbound) may reroll failed Panic tests
Pestilence: Enemy models attacking or being attacked by models with Mark of the Dark Gods (Pestilence) have -1 Weapon Skill (to a minimum of 1). Toxic Attacks are at -1 to wound against parts of models with Mark of the Dark Gods (Pestilence).
Lust: Parts of models with the Mark of the Dark Gods (Lust) can reroll charge, pursuit and random movement rolls and are Immune to panic caused by 25% casualties (but not immune to any other kinds of panic: unit destroyed or broken within 6", terror-caused panic etc.).
Change: When Shooting, or at the start of each combat, parts of models with the Mark of the Dark Gods (Change) can choose one of the following Special Rules to apply to their Shooting attacks that Phase or Close Combat Attacks done during that combat: Flaming Attacks, Magical Attacks, Holy Attacks or Hellfire. A Wizard with Mark of the Dark Gods (Change) has +1 Casting Modifier when casting spells.
Wrath: Parts of models with the Mark of the Dark Gods (Wrath) have Immune to Psychology Special Rule and +1 Strength on their attacks for the first round of combat. Furthermore, a Unit with one or more models with this Mark must always Pursue (if able), but are not forced to overrun. Wizards cannot use, have, or gain this Mark in any way.
Wizards with Mark of the Dark Gods must use certain Paths depending on the mark chosen
Change: Path of Change or Alchemy
Lust: Path of Lust or Shadows
Pestilence: Path of Disease or Death
Unbound: Path of Heavens (Lord only) , Alchemy, Shadow, Death or Fire
Там половина файла - описание марок. Вкратце базовая марка изменился только сланешь который дает рероллы на рандомные передвижнния. + появились улучшеннные, которые бафают харки на 1.Нург- тафну, тзинч - +1 вард, кхорн силу, сланешь иня и мув.
Пообщался с неким Эриком Аронсоном. Говорит, чтобы ВоКи не распускали слюни, ибо главный комитет еще не начал бить молотом баланса проверку драфта. У вудов уже походу начали, потому что больше половины плюшек вырезаны.
Со старым регеном. Зато цену подняли до старой, когда их не брали ;).
Изменено пользователем ЧК
ну вот опять этот подход. Люди придумывают некую целостную концепцию, а затем ЦК начинает резать по принципу: здесь ноги надо укоротить на 10 сантиметров, а руки лучше вообще перешить на задницу, так баланснее. Ой, что это никто теперь не берет? Окей, добавим ему пойзон и скримиш, чтоб не плакали.
Изменено пользователем Bugeninka
А если концепция — давайте сделаем каждый отряд имбой? Он вполне целостный) Его тоже трогать не надо?)
Тогда как в анекдоте: надо не кровати переставлять, а куртизанок менять :)
Не надо натягивать... или наоборот притягивать...
Вот Вы Валентин сколько игр сыграли? И с какими армиями? А не одобряете...
А меж тем, над шуткой... Мол Пастернака не читал, но мнение имею... тоже наверняка улыбались...
Комплекснее смотреть надо... шире... Куда Вы с газовой трубочкой лезете к малышу? Еще даже не родился... только в процессе... (с) Шутка предоставлена для всех молодых отцов...
я правильно понял, что у чариоты 4+ сейв за хеви армор+ маунт протекшн, и можно купить бардинг и повысить до 3+ ??
Ну мне в целом нравится. И система марок и пехота новая и гифты. Я доволен. Осталось понять как этим играть :)
Вот такой вопрос: гневные чузены получают +1 силу, это стакается с маркой гнева или нет?
Стакается как я понял, потому как марки то двух уровней то есть обычно сила 5, а в первый раунд комбата ажно 6
То есть спавн амбушер... на второй ход на 3+ входит в любое орудие у края карты? Класс!
Всегда любил бэк спавнов! У меня они есть :о)
