Domovoy Опубликовано 22 апреля, 2007 Жалоба Поделиться Опубликовано 22 апреля, 2007 Здравствуйте. Решил попробовать играть за хаос и 1000 сынов в частности, но так как особыми познаниями не обладаю, то составил первый ростер и прошу сказть где я неправ, где совсем неправ, а где откровенно ступил:). Спасибо. HQ: Daemon Prince of Tzeentch (1#, 172 Pts) 1 Daemon Prince of Tzeentch @ 172 Pts Sorceror; Bolt Pistol (x1); Frag Grenades 1 Mark of Tzeentch @ [10] Pts 1 Daemonic Aura @ [15] Pts 1 Dark Blade @ [25] Pts 1 Wind of Chaos @ [20] Pts 1 Spiky Bits @ [10] Pts 1 Disc of Tzeentch @ [30] Pts 1 Daemonic Flight @ [0] Pts 1 Daemonic Mutation @ [0] Pts Troops: Favoured Thousand Sons (12#, 286 Pts) 8 Favoured Thousand Sons @ 286 Pts Bolter (x8) 1 Mark of Tzeentch @ [10] Pts 1 Daemonic Essence @ [0] Pts 1 Rubric Sign @ [0] Pts 1 Favoured Unit @ [0] Pts 1 Aspiring Champion (free) @ [89] Pts Sorceror; Bolt Pistol (x1); Powerfist (x1) 1 Mark of Tzeentch @ [10] Pts 1 Daemonic Mutation @ [10] Pts 1 Bolt of Change @ [30] Pts 1 Thrall Wizard @ [5] Pts 1 Thrall Wizard @ [5] Pts 1 Thrall Wizard @ [5] Pts Troops: Favoured Thousand Sons (12#, 286 Pts) 8 Favoured Thousand Sons @ 286 Pts Bolter (x8) 1 Mark of Tzeentch @ [10] Pts 1 Daemonic Essence @ [0] Pts 1 Rubric Sign @ [0] Pts 1 Favoured Unit @ [0] Pts 1 Aspiring Champion (free) @ [89] Pts Sorceror; Bolt Pistol (x1); Powerfist (x1) 1 Mark of Tzeentch @ [10] Pts 1 Daemonic Mutation @ [10] Pts 1 Bolt of Change @ [30] Pts 1 Thrall Wizard @ [5] Pts 1 Thrall Wizard @ [5] Pts 1 Thrall Wizard @ [5] Pts Troops: Favoured Flamers of Tzeentch (All) (9#, 207 Pts) 9 Favoured Flamers of Tzeentch (All) @ 207 Pts 9 Doombolt @ [0] Pts 1 Favoured: +1 to summoning role @ [0] Pts Heavy Support: Defiler (1#, 175 Pts) 1 Defiler @ 175 Pts Battle Cannon; Heavy Flamer; Reaper autocannon 1 Indirect Fire @ [25] Pts 1 Daemonic Possession @ [0] Pts Heavy Support: Defiler (1#, 175 Pts) 1 Defiler @ 175 Pts Battle Cannon; Heavy Flamer; Reaper autocannon 1 Indirect Fire @ [25] Pts 1 Daemonic Possession @ [0] Pts Heavy Support: Predator (1#, 195 Pts) 1 Predator @ 195 Pts Twin Linked Lascannon; Lascannon Sponsons 1 Daemonic Possession @ [20] Pts 1 Mutated Hull @ [30] Pts Ссылка на комментарий Поделиться на другие сайты Поделиться
Амфицион Опубликовано 22 апреля, 2007 Жалоба Поделиться Опубликовано 22 апреля, 2007 я не знаток благородных газов, но.... А нафиг им фист в отрядах? они особым хтх потенцалом никогда не отличались (см Опус о джорине бладфанге и плач по просперо) это им просто непоможет... И честно скажу броня в армии меня нервирует, какая то она не такая, либо предов больше, либо предов нафиг.... 2 тарелки на 1500 этого достаточно, тем болеее там вся армия шаблонами пестрит(магические болты)... я непонимаю роли одного преда если есть 2 дефайлера, лучше им хул мктировать и пускать стреляют прямой наводкой... А вообще придут знающие люди и нелюди и все объяснят Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 22 апреля, 2007 Жалоба Поделиться Опубликовано 22 апреля, 2007 Классический ростер Сынов на 1500 =) Разве что я бы дал Спайки Аспиринам. Ну и возможно ( тольво возможно) убрал бы Деф и взял бы Пред или закачанный Дред =) Ссылка на комментарий Поделиться на другие сайты Поделиться
Domovoy Опубликовано 22 апреля, 2007 Автор Жалоба Поделиться Опубликовано 22 апреля, 2007 Оказывается все уже давно придумано, надо было только спросить:) Тогда вопрос по Дефайлеру - если у него есть индерект, то у него все равно 36 дюймов мертвая зона есил он может провести линию видимости? Аспирн если жертвует визарда, то ему надо проходить психик тест или нет? Ссылка на комментарий Поделиться на другие сайты Поделиться
Grimnir Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 (изменено) Аспирн если жертвует визарда, то ему надо проходить психик тест или нет? Да, это в правилах описано, и не более 1 в ход. Роспись в целом стандартная, только как вариант взять термо големов и убрать что нибудь из техники. А еще интересно куда ты Лордом своим на диске собрался? в одну то харю. Изменено 23 апреля, 2007 пользователем WraithLord Ссылка на комментарий Поделиться на другие сайты Поделиться
Grave Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 Да, это в правилах описано, и не более 1 в ход. Роспись в целом стандартная, только как вариант взять термо големов и убрать что нибудь из техники. Да щас, читаем самый первый фак по кодексу. И по идее в последних репринтах это должно быть исправлено. Тзинтчиты на магию не проходят психик тесты, даже при использовании траллов. А еще интересно куда ты Лордом своим на диске собрался? в одну то харю. Глупый вопрос... Тогда вопрос по Дефайлеру - если у него есть индерект, то у него все равно 36 дюймов мертвая зона есил он может провести линию видимости? Если он стреляет прямой наводкой, то у него нет мёртвой зоны. Ростер хороший, у меня вместо 1 дефа дред, ГД, и ещё скримеры влазят) Ссылка на комментарий Поделиться на другие сайты Поделиться
Юный натуралист Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 Да щас, читаем самый первый фак по кодексу. И по идее в последних репринтах это должно быть исправлено. Тзинтчиты на магию не проходят психик тесты, даже при использовании траллов. Важное дополнение - тзинчиты не "не проходят" психик тесты, а автоматически их проходят, т. о. тест все же есть. Ссылка на комментарий Поделиться на другие сайты Поделиться
Grave Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 Эхх, если бы оне не проходили, то это было бы супер... Нафиг всякие психик худы, но мир не идеален. Ссылка на комментарий Поделиться на другие сайты Поделиться
Domovoy Опубликовано 23 апреля, 2007 Автор Жалоба Поделиться Опубликовано 23 апреля, 2007 2 Grave: Спасибо за ответы. А поделишься секретом как у тебя вместо дефайлера стока всего влазит, а то считал как-то не получается у меня :) ? И еще вопрос - при демон инстабали и Грейтер демона, написано что неприменимы спас-броски, а непробиваемые можно использовать? (Оговорюсь что у меня похоже первый принт кодекса)? Вопрос по лорду - он тоже будет проходить тест при использовании демон випом или нет? Ссылка на комментарий Поделиться на другие сайты Поделиться
Xagen Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 2 Grave: Спасибо за ответы. А поделишься секретом как у тебя вместо дефайлера стока всего влазит, а то считал как-то не получается у меня :) ? И еще вопрос - при демон инстабали и Грейтер демона, написано что неприменимы спас-броски, а непробиваемые можно использовать? (Оговорюсь что у меня похоже первый принт кодекса)? Вопрос по лорду - он тоже будет проходить тест при использовании демон випом или нет? При провале броска на инстабилити нельзя кидать никакие сейвы. Да , должен проходить тест на лидак , если не прошел -вунда , без любых сейвов Ссылка на комментарий Поделиться на другие сайты Поделиться
Grave Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 У меня там просто в 1 скваде 5 големов с аспирином, призывающем Грейтер Демона. Ссылка на комментарий Поделиться на другие сайты Поделиться
Жарптица Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 А не хочешь попробовать что-то не столь стандартное? Скажем примерно так: Unnamed2000 Pts - CSM: Thousand Sons Army 1 Daemon Prince @ 187 Pts Make Sorcerer; Mark of Tzeentch; CC Weapon (x1) Dreadaxe [25] Daemonic Mutation [15] Daemonic Strength [10] Daemonic Stature [15] Daemonic Flight [20] Daemonic Essence [15] Spiky Bits [10] Frag Grenades [1] Bionics [5] 1 Chaos Lieutenant (HQ) @ 100 Pts Make Sorcerer; Mark of Tzeentch #Bolt of Change [30] Thrall Wizard [5] Thrall Wizard [5] Thrall Wizard [5] 0 Thrall Wizard @ [0] Pts 8 Thousand Sons Chaos Space Marines (Troops) @ 261 Pts Favoured Unit; Mark of Tzeentch; CC Weapon (x8); Bolters #Daemonic Essence [0] 1 Free Aspiring Champion @ [69] Pts Free Aspiring Champion; Make Sorcerer; Mark of Tzeentch; CC Weapon (x1) #Bolt of Change [30] Thrall Wizard [5] Thrall Wizard [5] Thrall Wizard [5] 0 Thrall Wizard @ [0] Pts 8 Thousand Sons Chaos Space Marines (Troops) @ 261 Pts Favoured Unit; Mark of Tzeentch; CC Weapon (x8); Bolters #Daemonic Essence [0] 1 Free Aspiring Champion @ [69] Pts Free Aspiring Champion; Make Sorcerer; Mark of Tzeentch; CC Weapon (x1) #Bolt of Change [30] Thrall Wizard [5] Thrall Wizard [5] Thrall Wizard [5] 0 Thrall Wizard @ [0] Pts 8 Thousand Sons Chaos Space Marines (Troops) @ 261 Pts Favoured Unit; Mark of Tzeentch; CC Weapon (x8); Bolters #Daemonic Essence [0] 1 Free Aspiring Champion @ [69] Pts Free Aspiring Champion; Make Sorcerer; Mark of Tzeentch; CC Weapon (x1) #Bolt of Change [30] Thrall Wizard [5] Thrall Wizard [5] Thrall Wizard [5] 0 Thrall Wizard @ [0] Pts 8 Thousand Sons Terminators (Elites) @ 425 Pts Favoured Unit; Mark of Tzeentch; Power Weapons; Combi-Bolters #Daemonic Essence [0] #Terminator Armour [18] 1 Free Aspiring Champion @ [89] Pts Free Aspiring Champion; Make Sorcerer; Mark of Tzeentch; Power Weapon; Combi-Bolter #Terminator Armour [18] #Bolt of Change [30] Daemonic Strength [5] Daemonic Mutation [10] Daemonic Visage [2] Models in Army: 38 Total Army Cost: 1495 Маг и 3 аспирина кастуют по 2 болта в ход, что дает 8 выстрелов. Термосов сбрасываешь куда нить или пускаешь рядом с парнями. ДП как контр чардж. Играет чуть подругому, нежели деф+деф+пред :) но не менее весело! Ссылка на комментарий Поделиться на другие сайты Поделиться
Woice from Warp Опубликовано 23 апреля, 2007 Жалоба Поделиться Опубликовано 23 апреля, 2007 Маг и 3 аспирина кастуют по 2 болта в ход, что дает 8 выстрелов. Термосов сбрасываешь куда нить или пускаешь рядом с парнями. ДП как контр чардж. Играет чуть подругому, нежели деф+деф+пред :) но не менее весело! Т.е. похуже... Нет, Ден, его ростер намного интереснее. И кстати, Диск Тзинча фор да вин! Ссылка на комментарий Поделиться на другие сайты Поделиться
Domovoy Опубликовано 24 апреля, 2007 Автор Жалоба Поделиться Опубликовано 24 апреля, 2007 2 WonDen: спасибо за предложение;). Пробовать конечно буду разные варианты, просто сначала хотелось узнать в том ли я направлении хотя бы двигаюсь, начать то с чего-то надо:) ДП со статурой мне не хочется использовать потому что его можно выцелить, что неприятно, а вот два лейтенанта это интереснее, только у них очков маловато на дары и варгир. А вообще стоит закачивать лорда на 8 силу и вайнд оф хаос, или Тзинчу это лишнее?:) Кстати, а Грейтр демонов часто используют, их 3д6 инстабилити им не мешает, или они играют- появиться в нужном месте в нужное время? Ссылка на комментарий Поделиться на другие сайты Поделиться
Grovaks Опубликовано 24 апреля, 2007 Жалоба Поделиться Опубликовано 24 апреля, 2007 (изменено) ДП со статурой мне не хочется использовать потому что его можно выцелить, что неприятно, а вот два лейтенанта это интереснее, только у них очков маловато на дары и варгир. Кстати, а Грейтр демонов часто используют, их 3д6 инстабилити им не мешает, или они играют- появиться в нужном месте в нужное время? Зато его гораздо сложнее убить... ;) . лейт хорошь инфильтрой, хотя я не уверен что сынкам ее можно. грейтер вылезший из мертвого парня - это уже не очень нормально. В любом случае - на твой ход он побежит и предложит много радости противнику. другое дело...тизнчитский гд....инстабилити ему мешает но он должен успеть сделать все что следует до того как улятучится. Короче кхорнит играет точно. делай выводы. П.С. Дени, ты бежишь впереди паровоза. как только сынкам дадут 2+ тотальный (и если) то такая расписка появится через 2,5 минуты после выхода кодекса. а пока "рано, батенька, рано" Изменено 24 апреля, 2007 пользователем Grovaks Ссылка на комментарий Поделиться на другие сайты Поделиться
Xagen Опубликовано 24 апреля, 2007 Жалоба Поделиться Опубликовано 24 апреля, 2007 (изменено) Зато его гораздо сложнее убить... ;) . лейт хорошь инфильтрой, хотя я не уверен что сынкам ее можно. В этом ксати большой минус 1000 сынов , вообще нельзя брать ветеранские скилы Изменено 24 апреля, 2007 пользователем Xagen Ссылка на комментарий Поделиться на другие сайты Поделиться
Usagi san Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 Не буду давать избитых советов, приводящих к избитым ростерам... Фишка подобных армий в том, что ввиду отсутствия явного турнирного решения открывается простор для буйной фантазии и генерированию очень забавных вариантов. Рвать всех не будете (хотя...если чесать мозк время от времени, кое что получается :D ), но море чистого незамутненного фана гарантировано :D Ссылка на комментарий Поделиться на другие сайты Поделиться
Жарптица Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 Дааа, ввиду слухов о новых сынах, то что я написал имеет все шансы стать имбанутой турнирной армией. 38 моделей с 2+ сейвом и болтерами ап3, при огромном колве выстрелов и тзынчитской мислы. Лана, как выйдет кодекс нужно будет сразу написать статьтю: Архитипы нового хаоса. Не играйте так :) Ссылка на комментарий Поделиться на другие сайты Поделиться
Usagi san Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 Дэнни, ты забыл слухи о инвуле 5+. Я вот уже неделю пытаюсь просчитать, где будет засада... :P Ссылка на комментарий Поделиться на другие сайты Поделиться
Artemis Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 Дэнни, ты забыл слухи о инвуле 5+. Я вот уже неделю пытаюсь просчитать, где будет засада... :P Комбат сквадс, чем не засада? Или минимальное количество - 10 штук... Ссылка на комментарий Поделиться на другие сайты Поделиться
Жарптица Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 Если это будет просто инвуль 5+ то, боюсь, големы станут еще более редким явление, чем щас :) Но тут смотреть нужно будет на общую картину. В общем автоору темы я бы посоветовал пока ничего не собирать а подождать релиза кодекса и уж тогда о чем-то думать. Ссылка на комментарий Поделиться на другие сайты Поделиться
Usagi san Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 (изменено) Да их и так по 9 обычно брали :D Мне видятся следующие варианты: 1) глум магии 2) минус фирлесс со всей радостью по бросанию лидершипа 3) нерф аспирина в каку, чтобы ничего из себя в хтх не представляли. 4) отмена правила "Слоу энд перперсфул" в части стрельбы. З.Ы. Все указанное работает в случае если големы получают минус вунд, но 2+/5+ для всех. Если только 5+ инвуль и минус вунд, то прав Дэнни. Изменено 27 апреля, 2007 пользователем Kosh Bunny Ссылка на комментарий Поделиться на другие сайты Поделиться
NoMeKop Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 Големам, имхо, бэково было бы дать фил ноу пейн. У них тел нет. Ссылка на комментарий Поделиться на другие сайты Поделиться
Grave Опубликовано 27 апреля, 2007 Жалоба Поделиться Опубликовано 27 апреля, 2007 Одна трещина в доспехе - минус голем. Ссылка на комментарий Поделиться на другие сайты Поделиться
