Культ Механикус
Открою тайну - +3 к силе шикарно зайдет в формации сталкерам с тазер-дубинками
а баф ковра очень норм для сталкеров и куриц с перманентным ковром тащемта
а вы сталкеров с инфильтраторами не путаете? именно у вторых тазеры и стелс...
  • Ответов 831
я не путаю , Модер да , походу оговорился
я говорил именно о сталкерах - а баф ковра от песнопений омнисии
Units Effect
1-3 Stubborn
4-7 Stubborn + reroll Fear, Pinning and Moral
8+ Fearless
1-3 In CC, every enemy unit receives a S4 at I10 hit for every Cult model in this combat
4-7 Same as above, but 2 hits per Cult model
8+ Same as above but 3 hits
1-3 Reroll 1 to hit in CC
4-7 Reroll 1 and 2 to hit in CC
8+ Reroll to hit in CC
1-3 Stealth
4-7 Shrouded
8+ Both
1-3 +1S
4-7 +2S
8+ +3S
1-3 Reroll 1 to shot
4-7 Reroll 1 and 2 to shot
8+ Reroll to shot
уточнения по блатняку
Relics:
- 2+ Armour save to bearer + all weapons in the unit have the Cognis SR
- Bearer and unit gain "It will not die" SR
- Every turn may choose to identify a Mistery objective or observe an enemy vehicle. All rolls to penetrate againts an observed vehicle may be re-rolled, as well as glancing hits.
- One CC weapon that only Works againts vehicles. Make only one attack, if hit, roll in a table:
1: Controller of target vehicle may restore one hull point
2-3: Controller of weapon decides if vehicle loses one hull point or restores one.
4-5: Same as above but 1D3
6+: Same as above but 1D6
- Kastelan protocols have an inmediate effect. Previous protocol may not be chosen anymore.
- Model gains 1D6 CC attacks S4, AP5, Shred
There are 4 formations:
- Cohort Cybernetica
1x Dominus
2 Kastelan Robot Maniples
Kastelan protocols have an inmediate effect when chosen
For every Datasmith and Dominus one Robot may fire to a different target.
Dominus and the 2 maniples are a single unit. Dominus may not abandon the unit.
- Elimination Maniple
2-3 unitos of Kataphron Destroyers
1-3 Kastelan Robot Maniples
If one Robot inflincts one unsaved wound or a penetrating hit with a weapon with the Luminogen SR, the rest of the formation gains +1BS and ignore cover when firing to that unit.
- Numinous Maniple
2-3 units of Fulgurite Electro-Priests
2-3 units of Corpuscarii Electo-Priests
If a Corpuscarii unit is at 6" or less of 1 or more Fulgurite unit, they gain +1 shot when firing. If one unit suffers one or more unsaved wounds, it is considered "electrified" until the end of turn.
If a Fulgurite units attacks in CC to an "electrified" unit, they reroll to wound
- Holy Requisitioner
1 Dominus
2-3 Kataphron Breachers
Deep Strike
They have to stay in Reserve. When deployed, the Dom¡nus does not scatter if deployed at 6" or less of an objective marker. Breachers do not scatter as long as they arrive at 6" or less of the Dominus.
They have the Zealot and Counterattack SR when at 6" or less from a objective marker.
Цитата
Well, Carachters may purchase a Stasis Field:
The bearer and the unit get a 2++ save as long as they are "Gone to Ground", but the WS and BS are reduced to 0.
как с этим жить?)))
В рассказике Сандерса "Клада", который на днях вышел, доминус натурально втирает катафронам эти самые баллады (самый низкопробный пафос уровня Рагнара-Победителя, только с уклоном в Омниссию), и те начинают зверски нагибать.
Вообще забавное произведение, словно литературное описание моделей и правил на 4000 слов.
Доминус в конце только соулгриндера топором порубал :rolleyes: а до этого показывал всю свою лютую стрелючесть.
Изменено пользователем Str0chan
при том что визуально бланше и гримдарк , описание худлита выглядит забавно)
Так, а детачмент был уже?
угу , можно повторно заюзать балладу , и рерол трейтов
минимум один хаку и две трупсы
Кстати есть ли произведения про реально гримдарк механиков?
Vanguard Феервари - это продолжение "Касты Огня", которая сама по себе №1 по гримдарку в сороковнике, а там все ещё мрачнее и безысходнее. Ну и моделек там побольше описывается, даже балистарии есть
с наездниками из пилотов сентинелов, погибших в прошлой книге.
Вообще у Петера истинный талант, от каждого предложения жить не хочется (в хорошем смысле).
Доминус в електро жрецах люто залегающий от всего! в 2++))))Это же полом!!!!!!!!!!!!!!!! :D
По артефактам жир только ит вил нот дай и то дата смиту в роботов.Чинить технику тоже неплохо в разрезе датасмит в роботах а рядом онагеры.
Я вижу мейн скитарии вангварды + онагеров много в союз доминус пару тракторных стрелков и роботы 2+2 при том что один датасмит впитывает все в 2+(хотя на любителя можно и 1 брать).Ну можно приколоться добавить куриц с пиками.Как жить растсталкерам, бричерам и електро жрецам я не знаю,может кто-то выдвинет клевую идею по ним :P
А максимум слотов сколько?
Вообще та формация с скитариями и рыцарями вкусно выглядит.
Культ вышел в Австралии.
У доминуса альтернатива: две больших пушки, два пистолета, две головы.
Ещё у него подставка 50 мм :o
Что до электрожрецов — всего пять голов в наборе. И их нельзя покрутить.
доминус шикарен. обязательно надо взять парочку на покрасить. Ну и в тёмного механикума легко переделается) от земли до кончика топора правда больше 6см..
Я так глянул на электрожрецов, они же чётко с десант размером. GW, что за фигня? :(
А что не так?
Ну это же просто чувачки. Да, через них пропущены всякие там проводки, чтобы подзаряжать от себя айфоны, но они не чета генно увеличенным и всё такое космодесантникам.
В последние несколько лет десантнички пошли такие кабанистые, гвардейцы и иже с ними наоборот более точёные стали, а тут на — опять, привет, четвёртая редакция, где гвардеец и десантник одного роста были.
Я не говорю что сейчас всё как по бэку, но если сравнить командник Кадии и любой новый пластиковый пример десантуры, это будет более адекватное соотношение, чем в четвёрке.
Согласен.Именно из за их размера я был четко уверен что там тафна 4 или 2 хп...
