Aver Опубликовано 13 января, 2015 Жалоба Поделиться Опубликовано 13 января, 2015 Я не уверен, насколько верно выбрал раздел - но если что, надеюсь, что Модеры перенесут куда надо. Собственно, отписывался фордже про некоторые кривые вординги в их правилах на монстру - и получил некоторое кол-во интересных ответов, коии и дублирую сюда. После каждого оригинала будет краткая выжимка на русском для тех, кто не может в английский. Если у кого есть еще такие вопросы-ответы - предлагаю собирать в одном месте. 1. Good day, ... First of all, the Dread Saurian was not supplied with a base therefore I would like to ask you for directions in that regard. At first I fancied to place the great lisard on the arachnarok-sized base - but it didn't fit well. therefore I tried a larger base which was all right - but my fellow gamers supposed that to be a questionable idea ^) The second question is also about the dread saurian - its rules don't have any referances to it being even a large target (not to mention colossal beat or the likes). I really think it is just a misprint or you've just forgotten to place that in the rules.... Can you clarify that issue? The last one is also about the dread saurian (I really liked the miniature and do my best to field it in my games as frequently as possible) - is the player limited in regard to the number of Blessings of the Ancients the beast can take? Or I can dedicate it to several Ancient ones? I really look forward to hearing from you, Ответец: We recommend using a base that is roughly 300mm by 100mm for the Dread Saurian model. The Dread Saurian should have had the Large Target rules so please treat this as such. A Dread Saurian can have as many of the blessings as you would like. Ответец2 (долго не отвечали, я продублировал вопрос - ответили дважды): Thanks for your questions, please find the answers below. We recommend using two Arachnarok bases joined together with the 150mm side forming the front and rear of the base. The Large Target rules were missed off from the Dread Saurian rules profile by mistake so please treat the Dread Saurian as having this rule. There is no limit to the amount of Blessings that a Dread Saurian can take. Краткая выжимка: База для Дред Завриана - два варианта ответа: 300 на 100 мм, второй вариант - две арахнарочные с итоговым фронтом в 150мм Дред Завриан должен иметь правило Большая Цель - просто забыли написать Дред Завриан может брать любое кол-во меток древних. 2. Hi there, ... 1. Warpfire dragon - which of his attacks are magical? Are hits from his aura magical? What about his stonethrower-like shooting attack? Any other attacks? We've had a really fierce debate on that point - especially when it came to playing versus high elves with their World Dragon banner :) 2. Carmine dragon (yes, we are big fans of your dragon models) and his breath weapon. Does the latter work in hth as the other breath weapons do? If yes, how should it be resoled - like 2d6 autohits that wound automatically and are then multiplied into d3 wounds each with no armor? Did you mean that breath attack to be that powerfull? Ответ: 1. All of its close combat attacks are magical. So is its Warpfire Aura and its Warpfire Blast. 2. The Carmine Dragons breath attack should say that it can't be used in close combat, it is only a shooting attack. Краткая выжимка: У варпфаер драгона магические атаки на всех его атаках, ауре и бласте. Карминовый дракон не умеет юзать дыхалку в хтх - только как стрелковую атаку. Ссылка на комментарий Поделиться на другие сайты Поделиться
Даня_кап Опубликовано 22 января, 2015 Жалоба Поделиться Опубликовано 22 января, 2015 Варпфаер тоже в рукопашке не дышит? Эттин. Делаем магом, выбираем голову с разведчиком. Становимся на фулькрум в начале боя. Бред или реальность? Ссылка на комментарий Поделиться на другие сайты Поделиться
