Тау 1500
"Вот такой вот"
@HQ [ 1 ]
Cadre Fireblade (60pt.) Combat armour; Pulse rifle; Photon grenades; Markerlight;
@Troops [ 2 ]
3x - Crisis Battlesuit Team (215pt.) Bonding knife ritual;
> 2x - Shas'ui (69pt.); Crisis battlesuit; Multi-tracker; Blacksun filter; Plasma rifle (x2); Target lock; Marker drone;
> 1x - Shas'ui (74pt.); Crisis battlesuit; Multi-tracker; Blacksun filter; Cyclic ion blaster; Target lock; Drone controller; Marker drone (x2);
3x - Crisis Battlesuit Team (234pt.) Bonding knife ritual;
> 2x - Shas'ui (81pt.); Crisis battlesuit; Multi-tracker; Blacksun filter; Missile pod (x2); Target lock; Marker drone (x2);
> 1x - Shas'ui (69pt.); Crisis battlesuit; Multi-tracker; Blacksun filter; Missile pod (x2); Target lock; Marker drone;
@Heavy support [ 3 ]
Sky Ray (115pt.) Seeker missile (x6); Networked markerlight (x2); Velocity tracker; Twin-linked Smart missile system;
Hammerhead (125pt.) Ion cannon; Twin-linked Smart missile system;
@Secondary Detachment [ 2 ]
@Elites [ 2 ]
5x - Legion of the Damned (145pt.)
> 1x - Legionnaire Sergeant (25pt.); Power armour; Frag grenades; Krak grenades; Bolt pistol; Boltgun;
> 1x - Legionnaire (35pt.); Power armour; Frag grenades; Krak grenades; Bolt pistol; Multi-melta;
> 1x - Legionnaire (35pt.); Power armour; Frag grenades; Krak grenades; Bolt pistol; Meltagun;
> 2x - Legionnaire (25pt.); Power armour; Frag grenades; Krak grenades; Bolt pistol; Boltgun;
@HQ [ 2 ]
Commander (154pt.) Crisis battlesuit; Multi-tracker; Blacksun filter; Missile pod (x2); Target lock; Drone controller; Neuroweb System Jammer; Marker drone (x2);
Crisis Bodyguard Team (91pt.)
> 1x - Crisis Bodyguard (91pt.); Crisis battlesuit; Multi-tracker; Blacksun filter; Missile pod (x2); Target lock; Marker drone (x2);
@Troops [ 1 ]
10x - Fire Warrior Team (90pt.)
> 10x - Fire Warrior (9pt.); Combat armour; Photon grenades; Pulse carbine;
В прошлой игре было замечено что кризис как трупса дает понервничать оппоненту, так что не смотря на то что Риптайда нету - маленько разочеровал он меня и в предвкушении чего-то нового - пробую механо-тау.
Идея в чем - плазма-кризы держат домашнюю точку и вешают маркеры всем до которым можно дотянутся. Вторая - с ракетами - к ним приставлю командора прыгают туда-сюда кося вражескую трупсу (можно в комбинации с маркерами первой группы) - дроны тоже вешают маркеры при этом пользуя БС комма (приятный момент). Ну а дальше техника с больших дистанций - используя маркеры косит все что может ионками и смартами. Дамнеды через дип партизанят мельтами у кого шкура потольше - для остальных есть скайрэй.
Войны с Кадром либо разбегаются к ближайшей точки и держат её, либо держат домашнюю точку кося ведрищем кубов, при этом развязывая руки плазма-кризам которые уже сами могут прыгать тыча своими рапидами.
Дальнейшие задумки - Фарсайта (вкусное нон-скатер) и кризы дипом, а маркер-дроны дать отряду фв через кадровика и шас'уи.
Критикуйте. Изменено пользователем dreadangel
Коммандер без бафательных систем. Да, там надо не стрелять, но может лучше было бы бафать кризов рероллами/игнором ковра и т.п.
Хаммерхэнды совсем не страшны, во всяком случае с ионками. Пробовал их с рельсами, не взлетели. Ионками ты никого не подобьешь толком.
БаффО был полезен с риптайдом - но 7ка внесла свои коррективы, ноэтому начал активно использовать маркеры - БС5.6 это неплохо, особенно если стреляешь гет-хотами.
Чем Вам хаммеры не пошли - поделитесь опытом? Очень многие рекомендуют скайреи - неплохо против термо-подобное, но против пятен не особо.
Ионный хаммер стреляет хуже рипа. Ап3, все таки. Дешевле, конечно, но рип универсальней.
Рельсовый хаммер, несмотря наобладание 10 ап1, стреляет только раз. Скорее всего, попадет под маркерами. Но или не пробьет, или не взорвет. В плане уничтожения тяжелой техники лучше мельтасмертники, а легкой - мисслподы ведром.
Бодиграунд на 10 очков дороже кризака, а смысл? Проще взять обычного кризиса в трупсу. Маркер дроны, пусть и по 3бс много маркеров не наставят.
Бодигард офк.
Короче, я так скажу: из всего ростера годны только легионеры и Скайрей. Да и то, легионерам не хватает комби-мельты у сержантов
