Tyranids
Еще чуть-чуть слухов по психосилам http://www.belloflostsouls.net/2013/08/tyr...ror-horror.html
The Hivemind is ever approaching, cutting off and consuming all it touches! Abandon hope and repent! Here is the latest batch on the Tyranids.
Tyranids will get a massive overhaul with Psychic powers. Look for many new non-overt force powers that represent the chilling, horrific, warp-stifling power of the Hive-mind.
Aside from a few old chesnuts, look for almost all new Tyranid enhancing abilities, and other new chilling and damping abilities to use on enemies of reflect the horror, hopelessness, and dread of fighting the swarms under the psychic interference of the hivemind.
Look for concepts such as dampened psychics for opponents mixed with bio-enhancement powers to bolster the swarms.
Shadow in the Warp will remain in the codex, but receive a controversial overhaul.
More existing units will have the option of manifesting Psychic powers.
Изменено пользователем Nimert
  • Ответов 1,9 тыс
Педыдущие слухи офигительно звучат. Что разнообразие в псипаверах, что ноды, что карни с грамотным правилом живого тарана. Гарпия тащит за собой вальку...
Мечта нидовода.
Так кто же пишет кодекс?) Это, пожалуй, самая интересная для меня инфа)
Если верить этому...
"via an Anonymous source on Faeit 212
40k Codex Authors:
Imperial Guard: Vetock
Orks: Ward"
То только Филл не занят.
Also, some of these kits may be condensed into one box. Secondly - Ward is writing the dex. Extra salt here folks - extra salt.
Это в первых слухах из первого поста было. Уже опровергли?
Еще чуть чуть слухов о старых плейтестах
http://natfka.blogspot.ie/2013/08/tyranid-...rules.html#more
This morning we have an older Tyranid playtest set, that is about 6-7 months old according to the source. So while looking at playtest rumors, its important to note that playtest rules tend to look much different than what the codex is, but still gives us a direction and feel for the how the codex might end up.
Please remember that these are rumors of a playtest set.
via an anonymous source on Faeit 212
He states these rules are BETA and are around 7 month old
Hormagaunts :
may add an additional 20 Hormagaunts
Equipment: scything talons & adrenal glans
upgrades:
toxic sacks : (remain the same)
piercing talons : (+1 strength)
tyranid warrior (squad leader):
special rules:
leap, they just keep coming,synaptic back lash (tyranid warrior only) synapse creature (tyranid warrior only)
leap: may charge +6'' extra & do not lose initiative while charging through difficult terrain
they just keep coming: enemies firing at models with this rule suffer -1 bs
models with BS 1 must re-roll any successful hits on a model with this target.
synaptic back lash: after a model with this rules dies then all friendly units within 6'' of the models death suffer a single strength 3 AP - hit.
Old one eye to have his toughness increased
tyranid warriors
may add an additional 3 models
WS T SV
5 5 4+
Equipment:
piercing talons, leap, synaptic back lash,
special rules: will of the hive mind
upgrades:
toxic sacks: (read above)
adrenal glands: (read above)
range biomorph exoskeleton: (+1 bs)
increased exoskeleton: (+1 sv)
barbed strangler: (remains the same)
venom rifles: (tyranid rifles with poison) 18'' range (under re-testing)
will of the hive mind: while the squad remains with the full 3 models then the synapse range increases to 12''
carnifex:
may add an additional 2 models
T W
6 5
Equipment:
scything talons, piercing talons
special rules: rampant rage, living battering ram, natural disaster
upgrades:
Toxic sacks:
armoured shell: (2+ save)_
crushing claws: (+d3 attacks & +1 to range AP)
reinforced plating: (reduced strength of weapon being fired at you by 1)
heavy venom cannon: (strength 9 AP 2 heavy 2)
barbed strangler: (strength 5 AP 5 large blast, pinning)
twin linked devourers: (strength 4 AP 6 assault 4)
rampant range: when charging units the carnifex gains rage & furious charge)
Living battering ram: the carnifex deals d3 hammer of wrath hits
natural disaster: if the carnifex forgoes its turn in a piece of terrain (ruins ect) it can destroy that terrain and remove it from play
Если у хурмы будут такие правила в самом кодексе, я буду просто счастлив. Хотя мне во все это слабо верится, больно уж хорошо, даже 5ая тафна у ворриоров.
Еще интересно, как ворриор будет с хурмой бежать (Leap)? Вприпрыжку чтоли?
Так вард же пишет вроде, он и такое могет. Весьма похоже на правду кстати, в апоке есть формация гантов, там по ним снапшотами стреляют, здесь просто с -1 бс. Норм.
пятая тафна у варов заставляет заподозрить две вунды.
облом.
А сержант наверняка будет получатьпо умолчанию биоморфы отряда, иначе какой смысл. У хормы - ноги, у гаргойлов - крылья, и всё такое.
ООЕ с плюсом к тафне - такое уруру, что хочется выйти на улицу и обстучать все деревья на районе, чтоб не сглазить.
Разрушение террейна - бред.
ход с девурами вполне в духе гв - готовьтесь переклеивать лапы.
а по умолчанию он сколько - 6"? и только у них, или у всех? Оо
Так вот я о том же, и если у гаргойлов это еще понятно (можно крылья приделать), то у хурмы.. Приделать ноги?) Чтоб ворриор бегал и скакал с хурмой как козел по горам?)
Меня больше порадовало это
reinforced plating: (reduced strength of weapon being fired at you by 1).
При адекватной стоимости, это может очень сильно увеличить выживаемость армии, и поможет избежать инсты.
загляни в кодексы третьей-четвёртой редакции. Был там варриор с десятком биоморфов сразу. После этого leaping legs, которые кстати там тоже были общим пунктом - ещё цветочки.
самое лучшее из идей, что я слышал про "избегание инсты" - это "под синапсом тафна модели для определения правила Инстант Дес считается повышенной на 1".
btw, я конечно слоу, но
реролл овервотча это было бы ололо как круто.
Именно, не говоря уж о том, что в 4ке Leaping был биоморфом, дававшим, насколько я помню, 12" чардж. Так что ничего не мешает прикрутить его варриорам. Наконец-то, кстати, они оправдают свое бековое описание самых изменчивых тиранидов /а в отрядах нидов появятся сержанты с хевипушками и павервепонами =) /
Девойреры - печально, но предсказуемо, конечно. Надо будет их всем поотрывать. Но с такими правилами очень надеюсь на играбельных рукопашных или полурукопашных карней - соскучился по ним с 4ки) А вот что давать крылатому тирану пока не ясно.
Кстати, с липом и рероллом овервотчей тираниды даже в 6ке смогут попробовать играть от рукопашной :) (рендом дистанция от 8 до 18" с рероллом за флит греет душу)
Изменено пользователем Shverter
Вся соль в том, что баланс нужно сохранить. Помимо нидов условно хтх армии это ХСМ, орки, демоны
Если хурма умеет столько, да еще и сержант крутой, то стоить должны дофига ввиду того, что они по сути трупсовый демон, только круче. Если будут стоить столько же, тогда баланс вновь пошатнется, как с Тау получилось.
Очень сложно угадать, очень сложно баланс соблюсти.
Если все такое крутое, то дорого должны быть в очках, но тогда анбэк. Если все стоит копейки и крутое, то дисбаланс. Если все дешевое, но ничего не умеет, мертвый кодекс для фан боев.
сравниваем с демонетками: вс, рендинг, фир, автомораль, инвуль. продолжать дальше?
проблема баланса в другом. Предполагается, что ниды должны набигать на пулемёты, когда половина умирает по дороге, а вторая половина добегает и устраивает маму кузьмы. и вот именно это количество проблемно высчитать, чтобы и не оверпавер вышел, и хоть что-то до хетеха дожило. особенно в редакции тау и эльдарасов.
а если "дорогое и ничего не умеет"? ) как сейчас например. Хуже-то не будет
upd. Кстати, только заметил. heavy venom cannon: (strength 9 AP 2 heavy 2)
"Раскрывающийся текст"
блин, ну врут же )) но как приятно
Еще интересно что такое piercing talons. Их получается можно и хурме давать, и фексам.. На миниатюре это ничем не будет отличаться от scything talons, или выйдут новые наборы с этим типом когтей? Надеюсь что первое. Ну и как то очень неожиданно и приятно на самом деле, что так хорошо могут апнуть хурму: встроенные гланды. -1 к бс, 8-18 дюймой чардж с сохранением инициативы.. Сейчас самое плохое, что может быть-это разочарование.. Щас окажется, что эти правила изменили на другие отстойные, или хурма стоит 10-15 очков по базе.
Вс да, не спорю
Рендинг - пойзон, баш на баш
Фир? Что это? :)
Автомораль - фирлес
Инвуль - понижение БС и кавер
До кучи хорма быстрее демонетт и варриор сержант в разы круче алюресс бесполезной
автомораль - это возможность залегать. так что ковёр и тут на стороне демонцов.
а вар и сейчас в голой закачке стоит три десятка. В более-менее боевой становится под сорок-пятьдесят. Мало? Оо
вообще ещё дипстрайк забыл, ну да ладно, не о том разговор
Ним прав, лучше сильно всерьёз это не воспринимать. Ждём книжку, а там видно будет.
Хорм традиционно стоит 12+ очков. Как бы его не бафали, 12 очков за т3 св6+ это много.
Гораздо больше меня интересуют Тригоны. В нынешнем виде они неиграбельны. Ни в 5ке ни в 6ке их звезда не взошла.
А теперь прайм стоит как найт Эльдаров и во всем хуже, обычный как риптайд и имеет все шансы хтх Рипу проиграть.
Странно, что по ним ни слуху ни духу.
Я вожу голые толпы с Свармлордом за 6.
Тут не так важна закачка, а базовая цена. Если она будет где то такой же с этими новыми правилами-буду и дальше гонять их голыми. У них по базе много чего хорошего пишут.
а теперь сходи умойся холодной водичкой и ещё раз перечитай, что написал
имхо хорма должна стоить меньше демонов - она и будет. В интересах геве продавать много-много маленьких моделек.
то-то их ни в одной расписке.
тиранофексы неиграбельны.
карнифексы неиграбельны.
гарпии неиграбельны.
а тригоны одна из самых стабильных и популярных монстр в кодексе, после тиранов и коров.
Чего это вы???
Вунден прав во всём.
И хорма по 6 бесполезна.
если бы корова им яд раздавала, тогда да, а так смысла мало.
Либо качать, но это дорого. и гант при корове и дешевле и лучше.
А уж если сравнивать с гаргульками, то вообще в проигрыше.
Тоже касаемо и тригонов.
То что они идут следом за 2 играющими монстрами, не делает их популярными, они по сути с карнифексами на одном уровне.
Ну может немного лучше.
Изменено пользователем porcupine
А как их сейчас менять? Разве только сбрасывать исходную до четырёх. Апгрейды и должны стоить вдвое больше, чем у гаргов и термей - атак-то вдвое больше. И дамажат они замечательно, проблема только дойти. Если она будет решена чардж рейнджем/снижением баллистика/батлфокусом, то даже за текущие деньги хорми будут наивкусны. Но хотелось бы подешевле, конечно, чтобы можно было умирать и не жалеть.
при почти равной цене тригон в полтора раза толще, и в два-три - мощнее по урону, плюс встроенный дипстрайк.
Тут вопрос количества, а не качества. 50-60 хурмы+ 30 гаргулей+кол-во гантов, рожденных от 2ух коров уже типа орда. Вообще, не хотелось бы спорить щас об этом, а то опять тему прикроют..) Тригона неплохо бы апнуть, хотя бы пофиксить его дыру, через которую потом все подразделения тиранидов потом могут выходить, как бы это двусмысленно не звучало)
То то по столам прям носятся толпы хурмы.
Я что-то кроме дефгантов и гантов от коровы мало что вижу.
Да и привязывать стоимость яда к атакам не правильно.
вон у стилера 2 атаки а яд стоит 3.
либо оставлять, как есть 6 монет и добавлять баф коровы, либо по 6 монет в полной закачке.
Иначе не жильцы в стрелковой редакции.
Опять же, тригон рукопашник, тот же карни стрелковый за 190, местами будет поопаснее.
А карни с спорой сами по себе могут многое.
Нет они не павер, но я бы не говорил, сто чтригон прям так уже и лучше.
Как бахать тригона отдельный разговор.
но по идее 2+ должно ему сильно помочь.
На данный момент качество не переходит в количеству, потери с первого ряда тупо отбрасывают их назад.
Действительно, умолкаем, и ждём новых слухов. :)
