Вопросник для новичков
  • Ответов 901
  • 3 месяца спустя...
Добрый вечер!
Давно засматривался на варгеймы, но руки не доходили. Хотелось бы играть в ФБ, приобрел стартер Эпоха Зигмара (у г-на Lee). Почему купил именно его:
1. Переиздание вселенной ФБ (новое начало).
2. Есть всего 1 друг, желающий со мной играть (осваивать) - как раз для стартера.
3. Офигенные фиги!
4. Люблю прикладное хобби (лепка, покрас, моделирование - слава домам пионеров СССР!).
5. Люблю фэнтези.
На данный момент живу в Таразе, переехал по работе из Астаны. В связи со всем вышесказанным имею вопросы:
1. Есть ли варгеймеры в Таразе?
2. Живо ли ФБ в Казахстане?
3. Если начинать собирать малую армию орков по 40ке, с чего начать и играбельна ли она?
Изменено пользователем ArsenB2k
Добрый вечер!
3. Офигенные фиги!
5. Люблю фэнтези.
Hi again
Orks are seen as "uncompetitive" in 40k nowadays. However this only matters if you plan on playing in competitive tournaments or regularly play players who just want to win and build horrible army lists. I have not encountered this in Kazakhstan. People here play with models they like and are very friendly. So that is my advice to you. Buy the models you like and play with them whilst being friendly :D
Models are a big investment in time and money so the most important rule is to get what you like and everything else is secondary. I'm starting a Blood Angels army even though from a gaming side they are "uncompetitive"
You get bonuses in 40k if your army is bound. This means a restriction on what models you take. Nearly all will be
1 HQ choice
2 troops choices
1 elite choice
After that things are optional. This will give you a solid core to your army and allows plenty of cool choices on top.
For orks I'd suggest:
A Warboss as HQ
2 units of boyz and a truck for them each for your troops
A unit of Nobz with a truck for your elite
Check with someone with the latest ork codex because you used to be able to spilt your Nobz up and put them as leaders of your boyz in the future if you don't want to use them as a unit in the future.
One last thing, ork armies tend to be quite big... So lots of models needed. You can build smaller ones so pay less for models. Have a look about on the web. There's plenty of help out there.
Positive is the models are bigger so easier to paint. And a scrappy painting style will suit orks well if you're just learning to paint!
Hope that helps
ФБ слабенько дышит в Казахстане. АоС "взлетит" или нет, кто знает. Но у нас попробовали, и что-то не прониклись.
Орки в 40к сейчас средняя крепкая армия. Но играют они от орды пехоты на копеечных машинках, так что "маленькая" армия орков ну никак не получится.
Покрасил либератора и блудривера - набиваю руку. Вопрос знатокам: как разводить краску на палитре? На каплю краски окунаю кисточку (1ка) на половину в воду - в результате на миньке краска не ложится а собирается в лужицы. Если не разводить, то детали заливаются. Краска варпейентер.
Я обычно развожу краску примерно 2 к 1. Т.е. 2 капли краски и 1 капля воды, капаю воду пипеткой.
Если у тебя краска при разбавлении получается слишком жидкая добавь еще краски, и наоборот если густая, то воды добавь.
А так у тебя получается очень даже хорошо, со временем набьешь руку.
Изменено пользователем the8th
I'm not an expert but there is no formula for water to paint ratio really because it all depends on the paint used and the effect you want. It even varies within one companies range. Some gw paints are very thin and others very thick. So experiment and see what suits your style and what you want.
Some painters prefer several weaker layers to 1 or more stronger layers. Personally I start thin and add more paint if needed
I have found that in heat I need to add more water than normal. I also thoroughly recommend a wet pallete in the summer. You can drop your paint onto it from the bottle and mix as needed with water or other paints and it will stay fresh.
They are cheap and easy to make
http://www.fullborerminiatures.com/articles/wetpalette.html
Thanks a lot! I have studied all available resources on painting this time. So it's going easier now.
Всем спасибо за советы. Терпение и труд...
Покрасил первый отряд! Конвейером прикольнее красить. "Кто вы зигмарцы?!"
Отлично всё, но аккуратненько пролей всё коричневой проливкой (именно аккуратно и только в углубления, не заляпывай всё и вся) ну и глаза бы хорошо одухотворить или проливкой или внутренним свечением
  • 3 недели спустя...
Коллеги, где в Алматы можно купить клей Итальери или аналог с миталическим капиляром?
Магазин "Сборные модели" у Юбилейного не предлагать, там уже нету
Изменено пользователем Ragnarov
У Юбилейного или Столичного?
  • 4 недели спустя...
Господа, кто делает самостоятельно отливки, подскажите пожалуйста насколько сложно сделать это в наших реалиях?
В планах сделать копии колес с резиновой покрышкой в масштабе 1/24. Технологию копирования в интернете нашел.
Есть ли все материалы для этого в наших магазинах/базарах и тд или надо будет что-то заказывать?
http://moldandcast.kz/products/mold_star_30/ для создания силиконовой формы-матрицы
http://moldandcast.kz/products/smooth_cast_305/ жидкий пластик
с доставкой до Тараза вышло около 16500тг, каждой позиции по 1 кг
Ясно, спасибо!
А цены где можно посмотреть?
Ты уже пробовал что-нибудь отливать?
Цены у них зависят от доллара, связь через менеджера (Телефон в г.Алматы: 8 775 347 49 69). Отлил ноба с клешней и слагой. К материалу претензий нет - один из лучших, косяки в виде пузырей из-за моей неопытности. С колесами проблем быть не должно, при соблюдении технологии.
Сергей, забыл совсем, оказывается такой клей есть в Марвине/Меломан.
