Dr Darog Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 (изменено) Решил замутить к концу лета... POINTS BS FRONT SIDE REAR STRUCTURE POINTS 1500......4......12......12.. 10...... 5 UNIT: 1 Stormbird Gunship. TYPE: Superheavy Flyer ACCESS POINTS: 1 access hatch on either side and a forward assault ramp (units disembarking from a Stormbird may assault at the same time). FIRE POINTS: None. WEAPONS AND EQUIPMENT: - Hull-mounted Battle canon (S8 AP3, 7'', Primary Weapon) - 8 sponson-mounted twin-linked Heavy Bolters - 4 Hull-mounted twin-linked autocannons - 6 Bomb Pylons. For each bombing run, the Stormbird may drop 4 Pylons. This may be done 4 times per game, after which the Stormbird is out of bombs. - Searchlight, Extra Armour, Armoured Cockpit. TRANSPORT: The Stormbird has a transport capacity of 100 (Rhino-based vehicles count as 15 models, Land Raiders count as 25, Bikes count as 2, Attack Bikes count as 3, Baneblades and other similar size tanks count as 50). May replace nose-mounted autocannons: 2 multi-meltas…………………….free Battle Cannon………………..……25pts 2 twin-linked lascannons…..35pts Punisher Gatling Cannon…….40pts Demolisher Siege Cannon…..40pts May replace any twin-linked heavy bolter with: A twin-linked autocannon.........15pts A twin-linked lascannon............35pts May replace 8 Bomb Pylons with: 6 Hellfury Missiles……………………...free 6 Hellstrike Missiles………...........free 2 Hellstorms……………………...........free SPECIAL RULES Hover mode Ceramite Shielding Armoured Behemoth: Models without AA weapons use normal BS instead of hitting on 6’s Atomantic Shielding: Grants a 5+ invunerable save Изменено 8 августа, 2011 пользователем Dr Darog Ссылка на комментарий Поделиться на другие сайты Поделиться
Boogiman Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 крутой самолетик) и по чем такое удовольствие? Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 Его надо сделать еще)) в среднем 3-4к р) Ссылка на комментарий Поделиться на другие сайты Поделиться
Kisly Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 Зачем десанту в самолете окна для стрельбы? Ссылка на комментарий Поделиться на другие сайты Поделиться
Boogiman Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 для пакетиков на случай если укачает) Ссылка на комментарий Поделиться на другие сайты Поделиться
Smith Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 Stormbird 850pts А картинка есть? Ссылка на комментарий Поделиться на другие сайты Поделиться
PhD Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 Ceramite Armour назывется Ceramite Plating у Штормрейвена и Цестуса. Преемственно было бы тут также назвать. If the Stormbird suffers a glancing or penetrating hit, you may ask the opponent to re-roll on the vehicle damage table. You MUST select the second result. Может один раз за ход? При 5 структурных очках очень жёстко получается. Такая большая машина и без Machine Spirit'а? Options: MUST choose 1 of the following sides: Imperium.........10pts Chaos..............30pts Зачем это делать в виде апгрейда? Дай имперской версии Machine Spirit и пусть за выбор платить будет не нужно. Из чего делать планируешь? Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 назывется Ceramite Plating у Штормрейвена и Цестуса. Преемственно было бы тут также назвать. Может один раз за ход? При 5 структурных очках очень жёстко получается. Такая большая машина и без Machine Spirit'а? Зачем это делать в виде апгрейда? Дай имперской версии Machine Spirit и пусть за выбор платить будет не нужно. Из чего делать планируешь? У него нет ивуля как у манты, только 5+, так что нормально. У хавка нет машин спирита. Это именно версия марского правила для всех суперхеви, смотри феллблейд. Штормберд + ЛР + модели сторонних производителей. Ссылка на комментарий Поделиться на другие сайты Поделиться
Акабоши но Теньши Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 ИМХО платить за смену автокенона на ХБ 10 очков это слишком странно. А так очень уж он живучий получается. Его же Д блинами то не похреначишь. Ссылка на комментарий Поделиться на другие сайты Поделиться
Tiphus Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 (изменено) венерабельность 10 очков +1 к инвулю 30 имхо бред, венерабельность куда круче смена автопушки на турбо лазер за 30 тоже как-то мягко говоря дешего простая автопушка 15 рипперка 25 тоже не понимаю в чем прикол ну и фаер поинты в космическом транспорте.... это как если бы он еще дымовуху мог включать))) у меня кста на него другие правила STORM BIRD SUPER‐HEAVY TRANSPORT 750 pts BS FRONT SIDE REAR Storm Bird 4 12 12 10 Vehicle Type • Super Heavy Flyer Structure points: 5 Structure points Transport Capacity: 60 (even Assault Marines and Terminators only count as a single model aboard a Storm Bird) Access points: One access hatch on each side and a front and rear assault ramp (units disembarking from a Storm Bird may assault on the same turn it lands). Special Rules: • Hover Mode • Ceramite Shielding • Power of the Machine Spirit Wargear • Two under wing mounted twin linked Autocannon • Nose mounted rotary Autocannon (this counts as two twin‐linked autocannon) • Turret mounted rotary Autocannon (this counts as two twin‐linked autocannon) • Two pairs of under wing bomb pylons (a pair under each wing for four pylons in total) Options: May exchange any of its 2 pairs of bomb pylons with two Hellstrike missiles (72” range Strength 8 AP 3 Ordnance) Large Target: Because of its size and relative speed for atmospheric flight shooting attacks against the Storm Bird are made using the firer’s normal BS rather than hitting on 6s. Ceramite Shielding: In order to resist the heat of atmospheric entry a Storm Bird has thick ceramite shielding. Melta Bombs and weapons with the ‘Melta’ special rule never roll an extra dice for armour penetration against a Storm Bird. Bombing Run: For each bombing run the Storm Bird may drop a pair of bombs which is resolved as a Str 6 AP 4 Apocalyptic barrage (6) weapon. This can be done once per pair of bomb pylons, after which the Storm Bird is out of bombs. Example: If the Storm Bird has replaced a pair of bomb pylons with Hellstrike Missiles (giving it two missiles) it has a pair of bomb pylons remaining. The Storm Bird in the example may therefore make a bombing run for a single turn after which it is out of bombs. Изменено 21 мая, 2011 пользователем Tiphus Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 Эти правила последние. 30 очков хсм, потому что их ваще не должно быть у хсм по беку. смена труболазера на хавке стоит 20 очков ;) Ссылка на комментарий Поделиться на другие сайты Поделиться
Tiphus Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 на хавке там не автопушка меняется же) с чего это их не должно быть у хаоса? это махина времен ереси Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 на хавке там не автопушка меняется же) с чего это их не должно быть у хаоса? это махина времен ереси Какая разница? Батл кенон не сильно лучше. Потому что... бек такой бек)) Их либо оставили, либо просрали + хсм заменили все старое вооружение на новое. А вармбандам они не нужны, нет мошностей. В любом случае, у нурглов и кхорнявых их точно не может быть, возможно у абика 2 осталась, и то не факт. Ссылка на комментарий Поделиться на другие сайты Поделиться
Tiphus Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 (изменено) ога, ток в современных боях и мары тоже не применяют, это все пережиток прошлого)) вон в кодексе для отыгрыша ереси они у хаоса есть О_о пушка хавка немного лучше автопушки?))) давай все АП заменим на пушки хавка за 20 птс?))) Изменено 21 мая, 2011 пользователем Tiphus Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 ога, ток в современных боях и мары тоже не применяют, это все пережиток прошлого)) вон в кодексе для отыгрыша ереси они у хаоса есть О_о пушка хавка немного лучше автопушки?))) давай все АП заменим на пушки хавка за 20 птс?))) Не ереси, а ВКП. Это разные вещи, перед иствааном их уже у ренегатов не было. Турболазер стоит для модели за 900 очков - 20 очков. Пусть так и будет. Не проблема. Ссылка на комментарий Поделиться на другие сайты Поделиться
Tiphus Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 (изменено) стоит не турболазер а смена хавк пушки на него или для тебя нет разницы между ней и АП? да и откуда на тяж транспортнике выросла опция с Д пушкой я не очень понимаю (хоть в бэке и написано что у него было сильное носове орудие, но почему это сразу Д сила?) откуда такой вариант правил на него вообще? и где написано что легионы предателей их просрали?)) по твоей логике у хсм ща нету ни ШБ ни хавков чтоль?) Изменено 21 мая, 2011 пользователем Tiphus Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 стоит не турболазер а смена хавк пушки на него или для тебя нет разницы между ней и АП? да и откуда на тяж транспортнике выросла опция с Д пушкой я не очень понимаю (хоть в бэке и написано что у него было сильное носове орудие, но почему это сразу Д сила?) откуда такой вариант правил на него вообще? и где написано что легионы предателей их просрали?)) по твоей логике у хсм ща нету ни ШБ ни хавков чтоль?) Потому что в беке сказано, что ШБ = хавк, только больше. Это не тяжелый транспортник, а тяжелобронирвоанный десантный корабль поддержки, после приземления он должен выполнять функции тяжелой поддержки для десантуры. По беку во всяком случае. Дака. В беке ;) Например, в битве за фанг скзаано, что из множества ШБ у сынков остался только один и тот сбили на Фенрисе. За 10к лет ни один ШБ у предателей не упоминается, да и нет теперь сил, которые можно высаживать в таких транспортниках, варбанды однако. Хавки есть, только хаоситские и не так много. Дефицит. ПРоизвосдвтенных мошностей малова-то. Ссылка на комментарий Поделиться на другие сайты Поделиться
Boogiman Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 вы про железных войнов забыли наверное у них такие штуки точно хранится должны) Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 вы про железных войнов забыли наверное у них такие штуки точно хранится должны) У них, у аббика и словонесунов. Остальным отказать. У десгарда не было по беку, они все перешли на хавки, остальные давно варбанды, да, и теже детки, последние использовали еще до Истваана. Ссылка на комментарий Поделиться на другие сайты Поделиться
Tiphus Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 ну так и имперцы как бэ их не используют тоже, так же все на хваках) так что при вероятности использования их в апоке у имперцев ни чуть не выше чем у хсм опять таки, варбанды сейчас, да и то легионы тоже остаются у примархов-демонов, в ихних загашниках легко может не один такой корабль оказаться, так же не стоит о дарк механикусах забывать)) он не=хавк, а предтеча его ну видимо на даке их кто-то просто так сочинял, чес слово у темпуса они куда как более бэковы и продуманы Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 ну так и имперцы как бэ их не используют тоже, так же все на хваках) так что при вероятности использования их в апоке у имперцев ни чуть не выше чем у хсм опять таки, варбанды сейчас, да и то легионы тоже остаются у примархов-демонов, в ихних загашниках легко может не один такой корабль оказаться, так же не стоит о дарк механикусах забывать)) он не=хавк, а предтеча его ну видимо на даке их кто-то просто так сочинял, чес слово у темпуса они куда как более бэковы и продуманы Все штормберды у имперцев стоят в ангарах) При масовых высадках им могут взять. Кроме тех, кто был на Истваане, никто своих ШБ не сипользовал. Дарк Ам не производят ШБ, нет знаний. Это четко сказано в беке. А из действующих примархов остался - Морти (не было шб), Лоргар... его уже никто давно не видел, Ангрон (нет шб), Магнус (последний сбили), Омегон (не было у них), Пертурабо. Из тех, у кого был и кто еще тусуется: Лоргар, Пертурабо. Такие дела. Он 2ххавк, и не предтеча, а тяжелый вариант сшк хавка. Это старые правила с темпуса. Новые эти. Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 Кстати, гоню: последние правила на него вот такие Stormbird The venerable Stormbird is the predecessor to the Thunderhawk Gunship, and is rarely seen on the field of battle by loyalist Chapters, because of their rarity and their hard-to-repair parts, but when they are seen on the field of battle, they are majestic and terrible titans of the sky, raining down devastation on those fools who would dare oppose the Angels of Death. Stormbird POINTS BS FRONT SIDE REAR STRUCTURE POINTS 2500......4......13......12.. 11...... 6 UNIT: 1 Stormbird Gunship. TYPE: Superheavy Flyer ACCESS POINTS: 1 access hatch on either side and a forward assault ramp (units disembarking from a Stormbird may assault at the same time). FIRE POINTS: None. WEAPONS AND EQUIPMENT: - Hull-mounted Neutron Cannon - 8 sponson-mounted twin-linked Heavy Bolters - 4 Hull-mounted twin-linked lascannons - 12 Nova Bomb Pylons. For each bombing run, the Stormbird may drop 3 Pylons, which are resolved as Strength 10 AP 2 10" blast weapons. This may be done 4 times per game, after which the Stormbird is out of bombs. TRANSPORT: The Stormbird has a transport capacity of 100. WEAPONS Neutron Cannon - 72" D Heavy D3, 10" blast, Primary Weapon. Nova Bomb - Bomb 10 2 10" blast Heavy Bolter - normal stats Lascannon - normal stats SPECIAL RULES Hover mode Ceramite Shielding As Thunderhawk Имхо оверпрай и оверпавер: Я за такой вариант Stormbird POINTS BS FRONT SIDE REAR STRUCTURE POINTS 1500......4......12......12.. 11...... 5 UNIT: 1 Stormbird Gunship. TYPE: Superheavy Flyer ACCESS POINTS: 1 access hatch on either side and a forward assault ramp (units disembarking from a Stormbird may assault at the same time). FIRE POINTS: None. WEAPONS AND EQUIPMENT: - Hull-mounted Neutron Cannon - 8 sponson-mounted twin-linked Heavy Bolters - 4 Hull-mounted twin-linked autocannons - 12 Nova Bomb Pylons. For each bombing run, the Stormbird may drop 3 Pylons, which are resolved as Strength 8 AP 3 5" blast weapons. This may be done 4 times per game, after which the Stormbird is out of bombs. TRANSPORT: The Stormbird has a transport capacity of 60 (even jump infantry and terminators count as 1 model) Rhino-based vehicles count as 15 models, Land Raiders count as 25, Bikes count as 2, Attack Bikes count as 3, Baneblades and other similar size tanks count as 50. WEAPONS Neutron Cannon - 72" D Heavy 1, 7" blast, Primary Weapon. Nova Bomb - Bomb 8 3 5" blast Heavy Bolter - normal stats Lascannon - normal stats May replace nose-mounted autocannons: 4 twin-linked lascannons.....25pts Battle Cannon………………..……25pts Exterminator Autocannon…..35pts Inferno Cannon…………………..35pts Punisher Gatling Cannon…….40pts Demolisher Siege Cannon…..40pts May replace any twin-linked heavy bolter with: A twin-linked autocannon.........25pts A twin-linked Lascannon...........35pts SPECIAL RULES Hover mode Ceramite Shielding Large Target models without AA weapons use normal BS instead of hitting on 6’s Armoured Behemoth Grants a 5+ invunerable save Ссылка на комментарий Поделиться на другие сайты Поделиться
Tiphus Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 гдеж лежит такой бек ШБ по всем легионам то??? как у драк АМ нет знаний если эта машина времен крестового похода? Эти новые дизбаланснуты, сравни просто с хавком тем же, при большей стоимости он куда слабее выходит Ссылка на комментарий Поделиться на другие сайты Поделиться
Dr Darog Опубликовано 21 мая, 2011 Автор Жалоба Поделиться Опубликовано 21 мая, 2011 гдеж лежит такой бек ШБ по всем легионам то??? как у драк АМ нет знаний если эта машина времен крестового похода? Эти новые дизбаланснуты, сравни просто с хавком тем же, при большей стоимости он куда слабее выходит НН виженс и серия НН от БЛ. Все ШБ были произведены на терре до ВКП. У Ам не выкроек. У дарков тем более. Единичный продукт. 2500 очков за это - это оверпрайс, 850 - мало. Ссылка на комментарий Поделиться на другие сайты Поделиться
Акабоши но Теньши Опубликовано 21 мая, 2011 Жалоба Поделиться Опубликовано 21 мая, 2011 (изменено) гдеж лежит такой бек ШБ по всем легионам то??? как у драк АМ нет знаний если эта машина времен крестового похода? Эти новые дизбаланснуты, сравни просто с хавком тем же, при большей стоимости он куда слабее выходит Ну хавк откровенный оверпарйс. Баланс там рядом не лежал. Хотя вот эти два последних варианта меня смущают тоже. Както стока всего вкусного ацкого... И не нравится что бомбы работают не по стандартной механике бомбежки апока. Изменено 21 мая, 2011 пользователем Акабоши но Теньши Ссылка на комментарий Поделиться на другие сайты Поделиться
