Цитата
Армор пирсинг складываетс? если есть випун и например и майнд разор
Стр. 103
Цитата
Duplicated special rules
Sometimes a model may have the same special rule more than once, for examplewhen a model gains a special rule that
it already had or gains the same special rule from two different sources. In such a case, the effects of the duplicated
special rules do not stack and do not offer any additional benefit, unless specifically noted otherwise. If the duplicate
special rules have different (X) values, use the version with the highest one. If the X is the result of a dice roll, it
sometimes is not clear which X is the highest. In this case you may choose which rule to use (before rolling any dice).
For example, if a unit possesses Magic Resistance (2) and Magic Resistance (3), then it is considered to possess Magic
Resistance (3). As a counterexample, Fight In Extra Rank is one of the rare special rules specifically allowed to stack.A
unit that already has Fight In Extra Rank and gains Fight In Extra Rank is able to fight with two extra ranks
Нет не складывается, т.е. Armour Piercing (1) + Armour Piercing (1) = Armour Piercing (1)
