Фак к рульбуку
http://www.games-workshop.com/MEDIA_Custom..._version1_1.pdf
Внутри богатейшие залежи счастья.
Конкретнее:
1)ботфорт шашечников
(Q: Who gets a cover save when two units are
intermingled? (p21) A: The unit with the model closest to the enemy that is
firing does not have a cover save.)
2) багет релентлессов вне когеренции
Q: What happens if an out of coherency unit is able to
move, but not able to restore unit coherency in a single
Movement phase? (p12)
A: They must attempt to restore unit coherency as soon as
possible, including having to Run! in the Shooting phase if
able.
3) фругурт аббадона
Q: Will one model in a squad that is unable to Sweeping
Advance prevent the entire squad from making a
Sweeping Advance? (p40)
A: Yes.
4) бугурт пользователей одноразовыми ракетами
Q: If a vehicle has a weapon with a limited amount of
shots, and it has none left, for example a hunter-killer
missile that has already been fired, does it count as a
weapon that can be destroyed by a Damaged - Weapon
Destroyed roll on the Vehicle Damage table? (p61)
A: No. Once a weapon cannot possibly fire again during
the battle it is effectively destroyed as far as Damaged -
Weapon Destroyed results on the Vehicle Damage table
are concerned.
5) багор тех, кто кидает много шестёрок
Q: If a vehicle receives multiple Destroyed – Explodes!
results simultaneously how many D6 do you roll to
determine the blast radius? (p61)
A: One.
6) бромгексин механизированных маров
Q: Can any embarked troops shoot out of a vehicle on the
turn it has used its smoke launchers? (p66)
A: No.
7) фуршет танкшокеров из резервов
Q: Can a vehicle that is moving on from reserves perform
a tank shock? (p68)
A: Yes it can, declare the distance it is going to move
along with its direction and move the tank onto the board
that many inches, measuring from the board edge as for a
normal from reserve. The tank shock is performed as
usual. However, if the tank is forced to stop for any reason
before the entire vehicle is on the board then the vehicle,
and any embarked units, count as destroyed and are
removed from play.
8) знатный бургундец танкшокеров скиммерами на флетауте
Q: If a transport vehicle is destroyed in the same turn as it
moved flat out what happens to any embarked models? (p70)
A: They are removed as casualties.
9) брудершафт всё тех же танкшочящих скиммеров на флетауте
Q: Does a skimmer that is moving flat out whilst
performing a tank shock get the 4+ obscured save against
the Death or Glory! Attack? (p71)
A: No.
10) бурбон всех тех, кто спорил со мной про раф райдеров, астората и реликблейды с фуриос чарджем
Q: Does the Furious Charge special rule give +1 Strength
to attacks made with a close combat weapon that strikes
at a specific Strength value? For example are hits from
Gabriel Seth’s Blood Reaver resolved at Strength 8 or 9
when he has Furious Charge? (p75)
A: No. Hits from Gabriel Seth’s Blood Reaver would still be
resolved at Strength 8.
11) бруствер тех, против кого мары выставили скаутов с телионом
Q: If only some of the models in a unit have the Stealth
special rule, does the whole unit benefit from the +1 cover
save? (p76)
A: Yes. In effect the ones with the Stealth special rule
ensure their colleagues also find good places to hide.
12) бандероль всех машинок, выезжающих из резерва в дифф
Q: What happens when a unit arrives from reserves but is
unable to completely move onto the board? (p94)
A: The unit is destroyed and removed from play.
Что хочу сказать в итоге: вот так клепаешь весь день и пол ночи глупый отчёт по глупой теме, перед сном зомбиобразный заходишь на варсир, там видишь новость, и можно радостно ложиться спать, отправив свой несчастный отчёт по почте.
Хоть бы они фак обратно не открутили, хоть бы они фак обратно не открутили %)
  • Ответов 156
Персонаж со стелсом дает стелс отряду....
ОМФГ.
Комисар с плащем...
Еще заметил, что решили поправить кодексы, и факи к волкам и бладам были удалены. Видно они следующии на доработке
Изменено пользователем 4x_Runa
ну вот, теперь никакой интриги( видимо, они ждали столько лет, чтобы почитать отвратительные споры по всему миру.
Здесь имеется ввиду game turn или player turn?
player turn
Q: If a vehicle is specifically stated as being Immobile what
happens if the Damaged – Immobilised result is rolled on
A: Treat it as a Damaged – Weapon Destroyed result
instead.
Тоесть дропподы, орудийные башни из имперской брони итд теперь результат обездвижен будут считать как уничтожен?
Но пятидесятирыльник ИГ с 3+ каверсейвом - это да. А если в руину какую поместятся, то и 2+.
В целом хороший фак. После него и новых факов ФБ есть надежда на качественные факи для 40к.
Изменено пользователем Шахматист
руины дают кавер 4+. 3+ - это фортификации и бункеры, которые почти никогда не используются.
Изменено пользователем _Ustas_
Техмар укрепляет руину и ставим туда платун :)
У них у всех есть оружие. Дропподу всю жизнь отрывало болтер.
Ну если согласно рульбуку то они результат обездвижен считают как оружие уничтожено. А в этом факе написано, что техника у которой указано, что она неподвижная результат обездвижена считается как развалилась.
Изменено пользователем Tirel
Лорд-Комиссар в camo cloak даст всему платуну stealth.
[ Добавлено спустя 53 секунды ]
у если согласно рульбуку то обездвиженна техника результат обездвижен считает как оружие уничтожено. А в этом факе написано, что техника у которой указано что она неподвижная результат обездвижена считает как развалилась.
Да ну? Может стоит внимательнее прочитать фак?
If a vehicle is specifically stated as being Immobile what happens if the Damaged – Immobilised result is rolled on the Vehicle Damage table? (p61)
A: Treat it as a Damaged – Weapon Destroyed result instead.
(перевод: если техника всегда считается Immobile и получает результат immobilised, то что делать?
Вместо этого она получит результат "оружие уничтожено")
Изменено пользователем DenisV
А дарков-то нерфят :)
ГВ говорит решительное НЕТ имбе и полому :)
Изменено пользователем Mouaren
Q: Does an Independent Character count towards the
number of models in a squad when determining if it is
above half strength? (p48)
A: Yes he does. So if an Independent Character joined a
unit of 6 models there would need to be reduced to 2 or
less models for it to be below half strength.
Господа, кто мне объяснит о чем это?!
Если моделей 6, то их "белов халф" и так от 2х... нет?
Изменено пользователем Pax
Протесты морали от стрельбы. считается ли индеп моделью в отряде для такого теста - да, считается.
Черт, перечитал и сам не понял
Изменено пользователем Hide
Видимо подразумевают, что без индепа 3 модели не смогут зарегрупится.
Сори, что то влезло в голову что wrecked а не weapon destroyed
разве ровно половина не регрупится? РБ не под рукой.
А дарков-то нерфят
и крафтвордовских, и бладов на ринках, и орков на трукках - короче, весь цвет чита и полома одним абзацем...
А ведь можно высаживаться из флетаутнувшего транспорта, когда его подбили в ход оппонента, как я понимаю?
Уже ответили: http://forums.warforge.ru/index.php?showto...t&p=1745024
если не сказано иного, то turn - это player turn (самое начало рулбука)
я то в курсе. читай исходный пост Шахматиста
никакого нерфа. так всегда и играли, ибо рульбук об этом прямо говорит.
конечно
Я так рад за шашечки! Я так рад за мельты и леши из дымящих транспортов.... ОМГ! Спасибо ГВ! :)
