300 Onyx - универсальная |
28.11.2016, 00:22
Apprentice Раса: Combined Army Армия: Combined Army Группа: Пользователь Сообщений: 80 Регистрация: 23.03.2011 Из: Минск Пользователь №: 28 295 Репутация: 5 |
Ростер на ониксе с линкой на умбре и с харисом на самаритянине
Onyx Contact Force ────────────────────────────────────────────────── 10 NEXUS Lieutenant (Specialist Operative) Combi Rifle / Pistol, Knife. (0 | 16) UMBRA LEGATE Hacker (Hacking Device Plus) Boarding Shotgun, Flash Pulse / Pistol, DA CCW. (0.5 | 43) UNIDRON (Forward Observer) Plasma Carbine / Pistol, Electric Pulse. (0 | 15) UNIDRON (Forward Observer) Plasma Carbine / Pistol, Electric Pulse. (0 | 15) UNIDRON Missile Launcher, Light Shotgun / Pistol, Electric Pulse. (1.5 | 20) UMBRA SAMARITAN (EI Assault Hacking Device. UPGRADE: Goodnight) Plasma Carbine, Flash Pulse / Pistol, Vorpal CC Weapon. (0.5 | 43) XEODRON Red Fury, Blitzen / Heavy Pistol. (1 | 59) XEODRON K1 Combi Rifle, Blitzen / Heavy Pistol. (0.5 | 59) Q-DRONE HMG / Electric Pulse. (1 | 26) ÍMETRON . (0 | 4) 5 SWC | 300 Points Open in Infinity Army |
28.11.2016, 00:23
правда, сначала я думал вот такой
Onyx Contact Force ────────────────────────────────────────────────── 9 NEXUS Lieutenant (Specialist Operative) Combi Rifle / Pistol, Knife. (0 | 16) UMBRA LEGATE Hacker (Hacking Device Plus) Boarding Shotgun, Flash Pulse / Pistol, DA CCW. (0.5 | 43) UNIDRON (Forward Observer) Plasma Carbine / Pistol, Electric Pulse. (0 | 15) UNIDRON (Forward Observer) Plasma Carbine / Pistol, Electric Pulse. (0 | 15) UNIDRON (Forward Observer) Plasma Carbine / Pistol, Electric Pulse. (0 | 15) UMBRA SAMARITAN (EI Assault Hacking Device. UPGRADE: Goodnight) Plasma Carbine, Flash Pulse / Pistol, Vorpal CC Weapon. (0.5 | 43) XEODRON Red Fury, Blitzen / Heavy Pistol. (1 | 59) XEODRON K1 Combi Rifle, Blitzen / Heavy Pistol. (0.5 | 59) MAAKREP TRACKER MULTI Sniper Rifle / Pistol, Knife. (1.5 | 33) 4 SWC | 298 Points Open in Infinity Army Предлагают снять с 2-х батроидов форвард обзервер и вклинить иметрона, а вы как думаете? |
04.12.2016, 23:19
Hero Группа: Пользователь Сообщений: 439 Регистрация: 17.12.2009 Пользователь №: 21 398 Репутация: 61 |
Зачем в первом ростере Легат, если в линке уже нексус?
Второй ростер нежизнеспособен из-за отсутствия дальнобойного оружия. У первого такая же проблема, правда, не так ярко выражена. |
05.12.2016, 12:10
Master Flooder Раса: Nomadas Армия: Nomadas Группа: Пользователь Сообщений: 767 Регистрация: 24.12.2009 Пользователь №: 21 515 Репутация: 66 |
я бы взял 1ый ростер за основу и сделал бы следующее:
Выкинул бы тотал реакшн дрона. В линк юнидронов дал бы спитфаер и заменил бы мислу на плазма снайперку. Взял бы багажника дрона или как нить еще добавил приказ. возможно через инфильтратора. А еще я бы не стал давать самаритянину хак девайс ибо любой залетный ТО КХД его вышибает на раз. Сообщение отредактировал marine27 - 05.12.2016, 12:12 |
07.12.2016, 10:19
Тотал реакшн дрона и выкинуть? я вот наоборот подумал над тем чтобы снайпера поменять на E-Drone+imerton и давать Marksmanship2 (а это 5 шоковых пуль игнорирующих кавер!) + решить вопрос с 10 приказом
По линку юнидронов надо курить, брал мислу из расчета - линк дроидов(+нексус+умбра) первые 1-2 хода стоит и активно АРОшит из мислы, ибо действует харис из ксео Поэтому в харисе и обусловлен саморитянин хаккер, задача хариса - брутально выполнять миссии Кончился харис? Есть основная линка, которая идет выполнять остатки миссии (опять же вместе с умброй или по отдельности), для прикрытия линки+ имертонов и e-drona остается дрон с ХМГ. Все кончилось? Остается e-dron специалист c хорошим мувом .. как то так UPD. проверил по очкам- не вмещается E-dron, поэтому assisted fire должен умбра ставить Сообщение отредактировал svoobden - 07.12.2016, 10:27 |
07.12.2016, 11:18
Разберем моменты по порядку.
Цитата Тотал реакшн дрона и выкинуть? я вот наоборот подумал над тем чтобы снайпера поменять на E-Drone+imerton и давать Marksmanship2 (а это 5 шоковых пуль игнорирующих кавер!) + решить вопрос с 10 приказом Откуда 5 пуль то? Речь про ХМГ же? там максимум 4 с дрона. Снайпер юнидрон на аро под прогой выдает 2 выстрела с 15 силой (плазма) с дикой дистанции, игнором ковра при стрельбе и отбросе брони +шок (спасибо плазма снайперке опять же) по 17му БСу против не камо юнитов. Сам же если надо может встать в Доггед (даже при провале 2х сейвов и улетании во 2ой анконш). На активный ход это 3 выстрела с такими же параметрами + дистанции, позволяющие наказать любого пулеметчика. Если надо идти в атаку - то ассистим спитфаер и понеслась) Цитата По линку юнидронов надо курить, брал мислу из расчета - линк дроидов(+нексус+умбра) первые 1-2 хода стоит и активно АРОшит из мислы, ибо действует харис из ксео Выше отписал. Линк Юнидронов просто зэ бест ЛИ линк для "ломать лица" Цитата Поэтому в харисе и обусловлен саморитянин хаккер, задача хариса - брутально выполнять миссии Это проходит ровно до первого Ниндзя КХД в хиддене, который шоком вышебет мозги самаритянину. Тут даже Интервенторы то не спасаются, не говоря о Самаритянине. Поэтому я очень скептически отношусь к такому выбору. Я бы все же использовал такой линк для штурма и закрепления позиции для подхода специалистов. У меня есть небольшой опыт игры с таким линком юнидронов... горит уже неделю, не потухая. |
07.12.2016, 21:03
Maniac! Раса: Nomadas Армия: Nomadas Группа: Пользователь Сообщений: 3 219 Регистрация: 12.06.2010 Из: СаратовОдинцово Пользователь №: 24 036 Репутация: 406 |
У меня есть небольшой опыт игры с таким линком юнидронов... горит уже неделю, не потухая. Рад что тебе понравилось) По линку юнидронов - это топ тема. Туда можно пихнуть отличное АРО-оружие (миссла\плазмаснайперка), шикарное оружие атаки (спитфаер и к1 рифла), выдать тинбота, хакера (умбра\нехус) чтобы баффал не отходя от кассы - и стоит все это копеек. -------------------- Что делать, если вы НОВИЧОК, а вас ОБИЖАЮТ на форуме.
Диванная практика: статьи, репорты, тактики и расписки. Моя инфинити-тема на этому форуме. "Тополный пух, судья петух!"(с) Димка Гайгаров |
08.12.2016, 17:51
Про КХД не соглашусь - не такая простая добыча самаритян. Во-первых 14 вип, во вторых - succer punch, который худо-бедно, но уравнивает шансы.
Если стол с маркерами/целями, то он должен стоять на откртой местности + у вас линка суперджамперов. То есть нужно учитывать чужого хаккера в ТО и по-крайней мере устроить мстю Ксеодронами. Ес-но на любое действие найдется противодействие, но ептель, кто мешает дефлектор какой выставить или дополнительный репитер подогнать ... Обычно самый дальний маркер - это 24 дюйма, то есть 4 приказа (с пострелушками всякими) 1-2 приказа на сбор WP и остаются приказы для отхода или организации подкреплений... смотря у кого какой стиль По линку юнидронов - пока он закреплен на позиции - это красота, но 1 str без брони - ошибок или кривых кубов не прощает. Я их рассматриваю как support team в большей степени |
08.12.2016, 20:31
Про КХД не соглашусь - не такая простая добыча самаритян. Во-первых 14 вип, во вторых - succer punch, который худо-бедно, но уравнивает шансы. Если стол с маркерами/целями, то он должен стоять на откртой местности + у вас линка суперджамперов. То есть нужно учитывать чужого хаккера в ТО и по-крайней мере устроить мстю Ксеодронами. Ес-но на любое действие найдется противодействие, но ептель, кто мешает дефлектор какой выставить или дополнительный репитер подогнать ... Обычно самый дальний маркер - это 24 дюйма, то есть 4 приказа (с пострелушками всякими) 1-2 приказа на сбор WP и остаются приказы для отхода или организации подкреплений... смотря у кого какой стиль По линку юнидронов - пока он закреплен на позиции - это красота, но 1 str без брони - ошибок или кривых кубов не прощает. Я их рассматриваю как support team в большей степени Скажем так - убить интервентора (15 вип, 9 бтс) тем же ниндзей - не проблема. Просто 3 куба против 1. Плюс, если в месте где вы играете достаточно террейна, наверняка в центре стола будут вышки, здания с внутренностями - короче, есть где спрятаться хакеру. И не только киллеру - ассолт хакер надежно займет линк. 1стр + доггед + 2 анконшеса. То есть он имеет шансы пережить крит из мисслы например (да, умрет в конце хода, но в активный ход будут приказы на месть, в реактивный цель - задержать оппонента). Я выгуливаю этот линк тогда, когда "не хочется думать". правда тут тоже бывают мои косяки, но от "вышел на 3 аро сразу всем линком - потерял три миньки" ничего не спасет А, еще он стоит в полтора раза дешевле линка ксеодронов, стреляет больше кубов, выше БС (так как игнор кавера) и генерит пять приказов вместо трех. Что никоим образом не мешает брать в ростер оба (благо ксеодроны харис). -------------------- Что делать, если вы НОВИЧОК, а вас ОБИЖАЮТ на форуме.
09.12.2016, 09:10
На это и расчет - брать линк+харис и первые ходы действовать по большей частью харисом (если тотал фэйл будет, то это хотя бы 3 потерянных приказа ), более того присоединение хаккера - это
1. Возможность выполнять харисом миссии 2. Банально защитить тагов от обычных хаккеров, ну или сделать видимость защиты) Не думаю, что спитфаер в руках саморитяна принесет столь ощутимую пользу, как вариантивность возмоностей хаккера. Игнор кавера? засчет марксмана? |
09.12.2016, 23:19
На это и расчет - брать линк+харис и первые ходы действовать по большей частью харисом (если тотал фэйл будет, то это хотя бы 3 потерянных приказа ), более того присоединение хаккера - это 1. Возможность выполнять харисом миссии 2. Банально защитить тагов от обычных хаккеров, ну или сделать видимость защиты) Не думаю, что спитфаер в руках саморитяна принесет столь ощутимую пользу, как вариантивность возмоностей хаккера. Игнор кавера? засчет марксмана? Да, за счет него самого. Это 17бс на + дистанции, или 14 в камо. Это много. Проблема не в 3 приказах, проблема в том, что это половина ростера. Которая критически зависит от одновундового парня с 1 армором без шок иммуна. -------------------- Что делать, если вы НОВИЧОК, а вас ОБИЖАЮТ на форуме.
12.12.2016, 16:58
От смерти парня зависит только харис, но никак не таги, то есть будь Самаритянин со спитфаером его живучесть сильно увеличивается?) Я так понял, что его роль видится как экономия приказов для перемещения + доп возможности (ближник или метание монофиламента, миссию выполнить... еще что-то). Мне сложно представить этих тагов в роли "выпригивает из-за стеночки в своей деплойке в активный ход на пострелять и прячется". Ну это же также не спасает от ТО хаккеров и прочего
12.12.2016, 21:46
Мне сложно представить этих тагов в роли "выпригивает из-за стеночки в своей деплойке в активный ход на пострелять и прячется". А как еще играют ТАГи? Не танкуют же на АРО? после смерти самаритянина (1\6 ростера) два тага (2\6 ростера по очкам и по свц) резко становятся малоопасны. так как стоят в одном месте = позволяют легко себя переманеврировать (скорее всего). плюс теряется плюшка хариса. при этом, один-два ксеодрона не в линке (например, на разных флангах) - вполне себе хорошие фланковые атакеры, пока пробивной линк (который лучше стреляет, а выживает +- так же благодаря доггеду, двум уровням анконшеса и запасным игрокам за 14 очков, наличию оружия, стреляющего дальше 32" и возможности занести с одного попадания кучу сейвов хорошей силой без бонуса к броне за кавер) делает свое дело. -------------------- Что делать, если вы НОВИЧОК, а вас ОБИЖАЮТ на форуме.
Текстовая версия | Сейчас: 20.04.2024 - 03:57 |
