Eldar Ynnari, Смерть и перерождение. |
19.04.2018, 08:24
#281
Я так понял теперь не обязательно делать иврейн или двух других варлордами, чтобы иметь детач Иннари
А это весьма вкусно выходит Сообщение отредактировал Duke Roboute Nukem - 19.04.2018, 08:43 -------------------- Even in the heart of Hell, demons can still feel fear...
19.04.2018, 08:44
#282
Lord Раса: Dark Eldar Армия: Black Heart Kabal Группа: Куратор клуба Сообщений: 13 233 Регистрация: 26.12.2004 Из: Москва Пользователь №: 572 Репутация: 1582 |
И как же ты это понял?
19.04.2018, 08:49
#283
Мы этим
If Yvraine, the Visarch or the Yncarne is included in a Detachment, all Aeldari units in that Detachment gain the Ynnari keyword. These units cannot use any of the following abilities, and are not considered to have them: Ancient Doom, Battle Focus, Rising Crescendo, Power From Pain. Instead, Ynnari Infantry and Biker units gain the Strength from Death ability, as described below. The Detachment is still considered to be a Craftworlds, Harlequins or Drukhari Detachment, and so can use Craftworlds, Harlequins or Drukhari Stratagems, Warlord Traits and Relics respectively. Note that these units will not, however, gain any of the Detachment abilities listed in their respective codexes (such as The Path of War, Craftworld Attributes, Masque Forms, Drukhari Obsessions, etc.). Заменяем в факе это Replace this paragraph with the following: ‘If your army is Battle-forged and the Warlord of your army is either Yvraine, the Visarch or the Yncarne then you can include any of these models in any Craftworlds, Harlequins or Drukhari Detachment (as de ned in their respective codexes), provided that the Detachment does not include any of the following: Urien Rakarth, Drazhar, Mandrakes, the Avatar of Khaine or any <Haemonculus Coven> units. You can include these models in the Detachment even if you are using the Battle Brothers matched play rule. Разве нет? -------------------- Even in the heart of Hell, demons can still feel fear...
19.04.2018, 08:53
#284
А если открыть ФАК, а не ответ на форуме?
19.04.2018, 09:00
#285
На форуме выше моего поста таки только половина, Юра
Это Index: Xenos 1 Page 76 – Army of the Reborn Replace this paragraph with the following: ‘If your army is Battle-forged and the Warlord of your army is either Yvraine, the Visarch or the Yncarne then you can include any of these models in any Craftworlds, Harlequins or Drukhari Detachment (as de ned in their respective codexes), provided that the Detachment does not include any of the following: Urien Rakarth, Drazhar, Mandrakes, the Avatar of Khaine or any <Haemonculus Coven> units. You can include these models in the Detachment even if you are using the Battle Brothers matched play rule. Меняется на это If Yvraine, the Visarch or the Yncarne is included in a Detachment, all Aeldari units in that Detachment gain the Ynnari keyword. These units cannot use any of the following abilities, and are not considered to have them: Ancient Doom, Battle Focus, Rising Crescendo, Power From Pain. Instead, Ynnari Infantry and Biker units gain the Strength from Death ability, as described below. The Detachment is still considered to be a Craftworlds, Harlequins or Drukhari Detachment, and so can use Craftworlds, Harlequins or Drukhari Stratagems, Warlord Traits and Relics respectively. Note that these units will not, however, gain any of the Detachment abilities listed in their respective codexes (such as The Path of War, Craftworld Attributes, Masque Forms, Drukhari Obsessions, etc.).’ Но ты же конечно пояснишь своим экспертным мнением, что да как? Или ты считаешь, Грейв, что типа Иврйн может юзать трейты крафтворлдов/друкарей/арлей? Просто я тогда немного не пойму, как мне у иннарей применять варлорды крафтворлдов/друкарей и прочих, если ни у Визарха, ни у Иврейн нет крафтворлда Сообщение отредактировал Duke Roboute Nukem - 19.04.2018, 09:09 -------------------- Even in the heart of Hell, demons can still feel fear...
19.04.2018, 09:26
#286
Exarch Раса: Eldar Армия: Ulthwé Группа: Пользователь Сообщений: 652 Регистрация: 08.03.2008 Из: Петропавловск-Камчатский Пользователь №: 13 141 Репутация: 98 |
Я не смог в написанное в факе, вот честно...
Или для иннари нужен один из тройки, или он должен быть варлордом, или именно в датаче (что дает максимум 3 детача). Про "нельзя миксить юниты из разных армий в одном детаче", в армии подразумевающей микс всех эльдар я вообще молчу (но это не критично), при этом там про трейты крафтов и остальных, кто-нить может мне объяснить внятно как собирать иннари теперь вообще, на примере 3х армий в 3х разных детачах? потому что "моя вааащеее не понимать"... |
19.04.2018, 09:31
#287
Index: Xenos 1 Page 76 – Army of the Reborn Replace this paragraph with the following: ‘If your army is Battle-forged and the Warlord of your army is either Yvraine, the Visarch or the Yncarne then you can include any of these models in any Craftworlds, Harlequins or Drukhari Detachment (as de ned in their respective codexes), provided that the Detachment does not include any of the following: Urien Rakarth, Drazhar, Mandrakes, the Avatar of Khaine or any <Haemonculus Coven> units. You can include these models in the Detachment even if you are using the Battle Brothers matched play rule. Меняется на это If Yvraine, the Visarch or the Yncarne is included in a Detachment, all Aeldari units in that Detachment gain the Ynnari keyword. These units cannot use any of the following abilities, and are not considered to have them: Ancient Doom, Battle Focus, Rising Crescendo, Power From Pain. Instead, Ynnari Infantry and Biker units gain the Strength from Death ability, as described below. The Detachment is still considered to be a Craftworlds, Harlequins or Drukhari Detachment, and so can use Craftworlds, Harlequins or Drukhari Stratagems, Warlord Traits and Relics respectively. Note that these units will not, however, gain any of the Detachment abilities listed in their respective codexes (such as The Path of War, Craftworld Attributes, Masque Forms, Drukhari Obsessions, etc.).’ Почему ты дробишь правило на 2 части и говоришь, что одна заменяет другую? |
19.04.2018, 09:35
#288
Потому что выполнение второго параграфа частично невозможно при первом наверное?
Как я дам варлорда иврейн по тому же крафтам? Или друкари? Если у нее нет ни крафтворлда ни друкари Поэтому я считаю,что первая половина просто заменяется второй. Если бы я был уверен, Я бы не задавал тут этот вопрос если что. Сообщение отредактировал Duke Roboute Nukem - 19.04.2018, 09:39 -------------------- Even in the heart of Hell, demons can still feel fear...
19.04.2018, 09:41
#289
И мандрейков с ковенами бери, чего уж там. Ведь ГВ не могло скопипастить и ошибиться или писать это правило со взглядом на готовящийся кодекс Йннари, так давай за них правила переписывать ) Отличный подход, я тоже так хочу
Сообщение отредактировал Grave - 19.04.2018, 09:42 |
19.04.2018, 09:51
#290
Юра! Ты не растекайся мыслью по древу.
То есть ты считаешь! Что они написали правильно, но ошиблись в трактовке с трейтами? Так как эти три именных не могут в трейты кодексов и это нормально? Но согласно твоему указанию, эльдары могут смешивать все три кодекса в одном детаче иннарей? Честно скажу я немного запутался, так что давай без сарказма. Скажи как ты это видишь. Сообщение отредактировал Duke Roboute Nukem - 19.04.2018, 09:52 -------------------- Even in the heart of Hell, demons can still feel fear...
19.04.2018, 10:32
#291
Даже с сарказмом я достаточно понятно пишу. Прописали, что герои йннари не считаются другой фракцией для взятия в детач по праву боевых братьев. От этого они не становятся варлордами выбранной фрации и трейт из соответствующей книжки не берут. Дибо это ошибка и тупое копирование, либо в будущем им все таки это разрешат.
19.04.2018, 21:42
#292
Chaos Space Marine Раса: Chaos Space Marines Армия: Emperor's Children Группа: Пользователь Сообщений: 116 Регистрация: 11.02.2008 Из: Тверь Пользователь №: 12 750 Репутация: 14 |
Я не смог в написанное в факе, вот честно... Или для иннари нужен один из тройки, или он должен быть варлордом, или именно в датаче (что дает максимум 3 детача). Про "нельзя миксить юниты из разных армий в одном детаче", в армии подразумевающей микс всех эльдар я вообще молчу (но это не критично), при этом там про трейты крафтов и остальных, кто-нить может мне объяснить внятно как собирать иннари теперь вообще, на примере 3х армий в 3х разных детачах? потому что "моя вааащеее не понимать"... Без или. Просто есть 2 пункта: 1 - кто-то из триумвирата является варлордом 2 - для того чтобы появился детач иннари, кроме п.1, необходимо чтобы кто-то из триумвирата был в этом детачи крафтворлдов/друкхари/арлей (и чтобы не было юнитов из стоп списка в этом детаче). При этом детач даёт доступ к стратегемам, реликам (по стратегемам, естественно) и варлорд трейтам...моё ИМХО - последнее является заделом на будущее. P.S. Похоже ГВ видит иннари миксом нескольких помогающих друг другу армий, соединенных ребятами из триумвирата. В том же Ghost Warrior от БЛ это четко прописано. Что каждая часть иннари держится немного обособленно друг от друга. Хотя есть те, кто могут взаимодействовать между собой (эх, вдруг Мелинеиля сделают в его форме Аватара...мечты-мечты ) -------------------- |
20.04.2018, 11:19
#293
Immortal Раса: Necrons Армия: Necrons Группа: Пользователь Сообщений: 270 Регистрация: 03.01.2014 Пользователь №: 39 228 Репутация: 33 |
там написана страница на который параграф, который надо заменить параграфом из фака
20.04.2018, 16:06
#294
Beastmaster Раса: Dark Eldar Армия: Black Heart Kabal Группа: Пользователь Сообщений: 451 Регистрация: 03.02.2018 Из: Москва Пользователь №: 59 477 Репутация: 96 |
Я насколько понял содержание нового фака, детачмента иннари вообще не может быть.
Детачмент может быть либо крафтворлд, либо друкхари, либо арлекины. Герои триувирата могут стать частью одного из таких детачей. При этом, все юниты, которые с этими героями в детаче, получают кейворд "иннари". Также варлордом должен быть этот герой из триумвирата, а варлорд трейт они могут получить только один из трех базовых. По сути поменялось только одно - нельзя брать друкхари и крафтворлдов в один детач (согласно баттл бразерс). -------------------- Say "Hello" to my little friend
20.04.2018, 16:23
#295
Novice Группа: Пользователь Сообщений: 55 Регистрация: 14.08.2016 Пользователь №: 49 632 Репутация: 4 |
Баттл Бразерс бета-рул, пока можно. Это задел на будущее внедрение правила боевых братьев.
20.04.2018, 16:37
#296
Wraithguard Раса: Eldar Армия: Iyanden Группа: Пользователь Сообщений: 564 Регистрация: 20.08.2010 Из: Тула Пользователь №: 24 821 Репутация: 58 |
20.04.2018, 17:34
#297
To Toxa77 1 абзац из индекса, на 2 из фака.
To Oggy Теперь можно получить доступ к стратегемами и к реликам через них. Ну и я бы сказал что теперь у детачмента обязательно должен быть общий кейворд не аэльдари. To LexKrexPex по новым правилам иннарей в факе ребята из триумвирата могут присоединиться только к детачу крафтворлдов, друкхари или арлекин. Эльдарам нет в списке. -------------------- |
10.12.2019, 18:04
#298
Master Группа: Пользователь Сообщений: 238 Регистрация: 30.05.2012 Пользователь №: 33 222 Репутация: 44 |
Вопрос по магии:
В книге Psychic Awakening: Phoenix Rising дали новую школу магии (Runes of Fortune), пси-силы из которой можно брать, заменяя ими Смайт. Описание того, как можно эти силы брать такое: "Instead of knowning the Smite psychic power, <Craftworld> PSYKER models can instead know one of the psychic powers from Runes of Fortune discipline..." В самих заклинаниях в тех случаях, где это бафф на дружественный отряд - там тоже используется формулировка <Craftworld>. В правилах Иннари говорится, что если мы берем детачмент Craftworld-ов по Иннари, то мы заменяем упоминания <Craftworld> на Reborn Asuryani. Значит ли это, что псайкеры Иннари тоже могут заменять Смайт на пси-силы из новой школы? Ведь в разделе Psykers of the Reborn в правилах Иннари написано, что те должны набирать пси-силы из школы Revenant, вместо Runes of Battle, Runes of Fate и Phantasmancy. О том, что нельзя брать спелы из Runes of Fortune не сказано. Сообщение отредактировал Sersis - 10.12.2019, 18:05 |
10.12.2019, 18:38
#299
Warlock Раса: Eldar Армия: Saim-Hann Группа: Пользователь Сообщений: 1 886 Регистрация: 14.04.2008 Из: Москва Пользователь №: 13 820 Репутация: 262 |
If your army is Battle-forged, certain rules found in
this section – Powers of the Aspect Shrines, the Runes of Fortune, and Craftworld Attributes – can only be used to affect units within a Craftworlds Detachment (as defined in Codex: Craftworlds). Remember that a Detachment that includes any YNNARI unit – other than Yvraine, the Visarch, or the Yncarne – is not a Craftworlds Detachment. If you choose for the Detachment to become an YNNARI Detachment, then units in that Detachment gain the YNNARI keyword (note that this is not a Faction keyword). The Detachment is no longer considered to be a Craftworlds, HARLEQUINS or DRUKHARI Detachment, and so cannot use their respective Detachment abilities, Stratagems, Warlord Traits, Relics, psychic powers or Tactical Objectives. Сообщение отредактировал Shadenuat - 10.12.2019, 18:43 |
10.12.2019, 19:59
#300
Спасибо, проглядел.
Текстовая версия | Сейчас: 19.04.2024 - 04:39 |
