[SS] Salamanders / Саламандры. 2.0, - Вера в Императора есть? А если не найду?... |
03.03.2016, 02:15
#21
Ordo Malleus Inquisitor Lord Раса: Daemon Hunters Армия: Ordo Malleus Группа: Куратор Сообщений: 4 153 Регистрация: 23.07.2009 Пользователь №: 19 252 Репутация: 1166 |
Обновленная версия заливается для внутреннего тестирования перед публичным релизом ...
Гамбитом исправленные мелкие, но многочисленные недочеты в коде. "Раскрывающийся текст" Fixes - There was something WAY wrong with the firing of Chaplain's combi-melta gun. Brother Danimator shorted it out and fixed it. Now the model is OK. - Range of sight of the Storm Raven was too big. Reduced, but still kept high. (State it in the UCS) - LR Redeemer ebps dimensions slightly increased. (NOPE, I may have to revert it, it's like BT increased sizes!) - SCaR rules added for SR LIS and valid landing positions. - Vindicator gun fired projectile origin was wrong. (WW is more front and down??? Same is in DA...) - Chaplain's ability was not immobilising him on casting (the anim was "sliding"). Also ability said "nearby", but only affects attached squad. Also added ALL "heat" weapons in the list. - Rhino and Razorback got one more storm bolter weapon each. Razorback got reinforced armour as well. Reason: They cost 2 and 3 veh cap, so I think this was mandatory! - Fixed Art Inheritance. Also, fixed predator's and whirlwind's non-spinning caterpillar wheels. - Restored SR shadow (decal) that was missing. - Fixed cover issues for TF cannon (no covers at all) and skull probes (cover almost inside model). - New FX, new formation for the special Sala termies. - Smoke Grenades ability busy time. - Abilities that directly target entities' weapons do not work, so three abilities were re-worked to produce similar effects. - Masses of all entities were way wrong! Reverted to standard, infantry increased by 2 due to nature (heavy gravity = sturdier build). - Lowered the intensity / changed the type of the FX of the Super Termies. - Removed the stance button from the LPs - it is not needed. - Land Speeder size was TOO small compared to other vehicles. - Fixed a couple icon issues. Changed the Tier Icons, so that to match their name. - "Lowered" the volume of die/combat/charge/damage of squads. Also, the firing sound of thunderfire cannons, was a bit... LOUD. Lowered. - Melta-bombs anim was broken (XREF missing). Now fixed (replaced with frag grenades anim). - Stormraven changed to vehicle_high armour. - Updated the shadows of some entities. - Fixed some issues with poison stats is some entities. - Some models (scouts, assault, etc.) didn't cast any shadow. Fixed. - Fixed a small issue with the thunder hammers of veterans. - Landed Stormraven's veh cap cost fixed to 0 (as it should be). - To the Last Man FC ability, now also disables jump as well. - Deleted some unnecessary files. - Updated most abilities. - Many UCS updates. CHECKS PERFORMED: Heroes, AI Deep Striking + Transport/DS in-game = OK TO GO Checks Pending: All other AI + abilities. Issues Remaining UCS numerous issues + weapon ucs (heavy weapons, snipers) Increase volumes of: Techmarine (good boost), Apothecary (good boost), Scout Sergeant (average boost). Storm bolters of both rhino and razorback, fire no projectiles. Vindicator, problematic caterpillar wheels (reverse spinning!). Missing FXes' textures (I do not know from where) FX -- Texture 'DATA:ART/FX/0' is missing, using default! FX -- Texture 'DATA:ART/FX/' is missing, using default! Сообщение отредактировал jONES - 03.03.2016, 02:19 -------------------- |
07.03.2016, 21:44
#22
релиз версии 1.1 http://www.moddb.com/mods/salamanders-mod-...or-soulstorm-11
cписок изменений в предыдущем посте. Сообщение отредактировал jONES - 07.03.2016, 21:54 -------------------- |
07.03.2016, 22:33
#23
Acolyte Раса: Witch Hunters Армия: Order of the Ebon Chalice Группа: Пользователь Сообщений: 548 Регистрация: 20.11.2011 Из: казахстан, балхаш Пользователь №: 31 184 Репутация: 102 |
Благодарю.
-------------------- [O.F.T. MF] Fielding Smith
Стим-Группа ордена Расчленители http://steamcommunity.com/groups/Order_Fle...ers/discussions Мои скриншоты http://steamcommunity.com/profiles/7656119...815/screenshots |
08.01.2019, 13:19
#24
Terminator Раса: Space Marines Армия: Salamanders Группа: Пользователь Сообщений: 324 Регистрация: 09.12.2007 Из: Санкт-Петербург Пользователь №: 11 655 Репутация: 71 |
Потихоньку обновляю для себя графическую составляющую мода. Небольшие миниатюрки:
В планах расширить набор вооружение отрядам (в рамках доктрины Саламандр) + доп. набор юнитов. По окончании выложу ссылку на архив, возможно кому-то придется по душе пока не выйдет официальный релиз от создателя. Сообщение отредактировал Obsorber - 08.01.2019, 13:19 |
20.01.2019, 04:36
#25
30.05.2019, 21:22
#26
Neophyte Группа: Пользователь Сообщений: 2 Регистрация: 27.06.2012 Пользователь №: 33 496 Репутация: 1 |
Схема по моду - красным - то, что еще предстоит внедрить желтым - уже есть, но требует настройки зеленым - требует 2D доработок Затем баланс по табличками и методам SS_damage_info + прибираюсь в структуре оригинального мода Здравствуйте Obsorber, как продвигается ваша версия Саламандр? От автора оригинального мода ничего не слышно, а ваши скрины дают надежду на более качественный мод по ордену Саламандр. И еще такой вопрос, будет ли он работать с Unification без каких-либо вылетов? |
30.05.2019, 21:39
#27
Здравствуйте Obsorber, как продвигается ваша версия Саламандр? От автора оригинального мода ничего не слышно, а ваши скрины дают надежду на более качественный мод по ордену Саламандр. И еще такой вопрос, будет ли он работать с Unification без каких-либо вылетов? Добрый день. 1. В данный момент орден доукомплектован техникой и пехотой на 85% 2. Практически закончен АЕ код. 3. Есть новое звуковое сопровождение. 4. Работы с интерфейсом и иконками закончена где-то на 90% 5. Как только будет собран основной костяк ордена и закончен АЕ код начнутся работы над текстурами практически всего что там есть включая некоторые постройки (орден должен иметь индивидуальность) 6. Есть идея немного переделать пару моделек в 3D (но это пока все на уровне экспериментов и на скорость выхода мода не влияет) 7. Unification - это основная и наиважнейшая цель. Я ориентируюсь на конец лета, надеюсь успеть а то потом дети вернуться с дачи вместе с любимой женой Сообщение отредактировал Obsorber - 30.05.2019, 23:12 |
25.10.2019, 21:50
#28
Вышло обновление оригинального мода v2.0 на moddB. Скачать можно тут - https://www.moddb.com/mods/salamanders-mod-...or-soulstorm-20 Описание обновы: Раскрывающийся текст OK, this 2.0 version started with me and brother Kekoulis discussing the possibilities of Salamanders. What started as a discussion, ended up in a total remake!!! Needless to say, the visual quality is guaranteed - we are talking about brother Kekoulis here. The same goes for the audio department, where Thudo once again performed his magic! Let's not forget that the first version of Salamanders were (almost exclusively) designed and coded by brother Fuggles, so a big thanks for his huge effort - we simply built upon his "foundations". See at the end of this page for full credits. New Content/Design First, you will see that there is NOTHING missing. Everything you new in the previous version, is still here. Brother Fuggles'es design was already VERY neat But now, there is much more! We are talking flaming/burning swords, Vulkan, Tu'Shan, the Force Commander in THREE forms with full wargear, new Salamanders Sister and Primaris Squads, new vehicles and one... Rather UNUSUAL squad Among other things of course. The 2.0 version is also extensively tested, so you will have no CTDs or AI errors or bugs. All the issues of the previous version are resolved as well, of course. Balance is also very good - I dare say very close to Vanilla. Regardless, whatever you find, WHATEVER you think is misplaced, or if you find something that is not appropriate to be in, just inform us!! We try to keep our mods as proper as possible, but with the huge community and the plethora of assets circulating and all the peoples and modders involved... "Silly" things can happen. We may have forgotten to address credits, or included content that we were not supposed to, or whatever. We definitelly do not want to offend anyone, nor we want to be impolite. So, please, whatever you see misplaced, just say so and we will fix/update/remove/add it, in an instant! * Опробовал новую версию... смешанные чувства, очень заметно влияние Slaanesh и ее "адептов модостроения". Сообщение отредактировал Obsorber - 26.10.2019, 00:09 |
26.10.2019, 07:52
#29
* Опробовал новую версию... смешанные чувства, очень заметно влияние Slaanesh и ее "адептов модостроения". Да, я тоже когда читаю востроженное МЫ ДОБАВИЛИ СЕСТЁР-САЛАМАНДР, думаю : да вы там --------- упоролись в край! Нужен специальный агент-антибагатур, который вычистит из мода всю чушь и анбек! @Obsorber, а где твой исправленный мод? Сообщение отредактировал jONES - 26.10.2019, 07:59 -------------------- |
26.10.2019, 08:35
#30
@Obsorber, а где твой исправленный мод? Скажу честно - на финишной прямой, Основные моменты практически сделаны. В моде не хватает Ai, старый не дружит с текущим билдом. На днях добрый человек согласился мне помочь с Ai, но сперва необходимо сделать приемлемый баланс (дпс оружия и ХП/броня юнитов) для корректного unitstats.ai По ходу написания Ai останется только шлифовать текстуры. Ну и в связи с появлением новых моделек для мода заменить их в моде на обновленные если не будет дерганой запоротой анимации (как это обычно бывает после рукастого китбаша). Работа не идет быстро по 1 причине - я всего 1н и я учусь в процессе, да и времени не более 2-3 часов в день после работы. (но в личку я скину пару скринов) Как Вам rapier armour destroer с анимацией от байка в режиме idle Сообщение отредактировал Obsorber - 26.10.2019, 11:30 |
26.10.2019, 11:51
#31
Скриншоты из дискорда "разработчиков"
"16+" А это - чем вдохновлялись, по видимому "+" Доля юмора правда присутствует. Это хотя бы не так тупо как Механикумы поверившие в высшее благо и рассекающие на тау-вархаунде Сообщение отредактировал jONES - 27.10.2019, 12:22 -------------------- |
26.10.2019, 12:48
#32
Lord Commander Раса: Imperial Guard Армия: Cadian Shock Troops Группа: Пользователь Сообщений: 3 308 Регистрация: 20.11.2009 Из: Екатеринбург Пользователь №: 21 020 Репутация: 1027 |
Если бы не моделька, сделанная довольно нормально, решил бы что к этому приложил что-то багадур.
-------------------- Слава России и её патриотам! Слава тебе, Отчизна моя!
Мои достижения: [*]-55, [+]-98, [!]-30, [-]-25 |
26.10.2019, 12:52
#33
Если бы не моделька, сделанная довольно нормально, решил бы что к этому приложил что-то багадур. Это старая модель демонетки, обновленная и перекрашенная -------------------- |
26.10.2019, 20:31
#34
Flooder Группа: Пользователь Сообщений: 597 Регистрация: 08.06.2011 Пользователь №: 29 239 Репутация: 167 |
Хочу поскорее за сестер саламандр поиграть, моделька классная) пофиг, что анбэк
27.10.2019, 12:22
#35
Хочу поскорее за сестер саламандр поиграть, моделька классная) пофиг, что анбэк Кто мешает? Скачай и играй -------------------- |
Текстовая версия | Сейчас: 20.04.2024 - 02:37 |
