Боги варпа, Тема про добрых и злых |
31.07.2017, 18:14
Veteran Раса: Space Marines Армия: Blood Angels Группа: Пользователь Сообщений: 377 Регистрация: 28.12.2016 Из: Москва Пользователь №: 50 568 Репутация: 37 |
Правильно ли я понимаю, в бэке нигде не описаны причины, по которым в варпе рождаются только темные сущности, от темных эмоций? А альтруизм, самопожертвование, надежда, любовь, уважение, благородство ничего в варпе не рождает? Насколько я понял, это сугубо волюнтористское решение БЛ? Цитата The Gods of Law, sometimes referred to as the Chaos Gods of Law (Chaos in the sense of being made out of the magical element of "physics and logic can go [черт] themselves" like the Chaos (AKA destruction)-aligned Chaos Gods), are three (or more) Gods who were created in the first edition of Warhammer Fantasy Roleplay. They were referenced later in the "Apocrypha Now" supplement, and were vaguely alluded to in various Warhammer works throughout the years. In the Black Library novels for Archaon published in 2014, Be'lakor informs Archaon that they never existed giving them their first mention in the modern Warhammer era. However the canonicity of this is dubious as there was a very distinct disconnect between Black Library and army book canon illustrated particularly well in the End Times event. Be'lakor is not a reliable source of information however as he only claimed once that he never lies apparently because it makes his schemes boring, and this was in a Warhammer 40,000 novel regardless. If the Gods of Law ARE canon, then they would also exist in 40k as well. All three identified ones are siblings. Solkan and Arianka are lovers. It was implied there were additional Chaos Gods of Law, but none were ever identified. Solkan, Arianka, and Alluminas seem to parallel Khorne, Tzeentch, and Nurgle but Slaanesh never had an opposite. Considering Slaanesh's disappearance in Age of Sigmar, this makes an interesting coincidence. Slaanesh's description as the youngest Chaos God also bears mentioning, as it could be possible the fourth Law God would be introduced later. https://1d4chan.org/wiki/Chaos_Gods_of_Law ____________ Предупреждение: незначительное нарушение [*] Выдал: Locke Причина: Нарушение п.3.2 Правил форума. Истекает: через 30 дней Сообщение отредактировал samurai_klim - 13.06.2018, 14:00 -------------------- |
31.07.2017, 18:26
Shas'O Раса: Tau Empire Армия: O'Shova Группа: Пользователь Сообщений: 7 005 Регистрация: 19.01.2013 Из: г. Москва Пользователь №: 35 281 Репутация: 1960 |
Весна вроде прошла, осень не наступила... или ты так потроллировать?
В варпе отражаются ВСЕ эмоции, но ввиду культурно нравственного состояния популяции галактики, варп теперь не подходит для выживания чего то доброго и светлого. Оно если каким то макаром и заводится, то или сдохнет или сожрут-с. Пропорции малость не те. Даже эльдары в бытность свою до декаданса будучи духовно богатыми и вообще при помощи ритуализированного поклонения создали пантеон редкостных отморозков а не что то однозначно хорошее. Куда уж людям и оркам. Ну и позитивные вещи в варп вполне себе аккумулируются воплощаясь в чудесах, актах веры или отключаемой пилонами безумной храбрости из падения Кадии. Ну и да, со всей галактики наскребсти даже на одно доброе божество задача непосильная учитывая сколько отжирает Импи и Тзинч Сообщение отредактировал Rost_Light - 31.07.2017, 18:30 |
31.07.2017, 18:51
Necron Lord Раса: Necrons Армия: Necrons Группа: Пользователь Сообщений: 2 321 Регистрация: 30.05.2012 Из: Москва Пользователь №: 33 219 Репутация: 334 |
Когда у людей, основного источника энергии в галактики, все хорошо, они молятся Импи и сливают все ему. Когда не очень, или же осознанно отворачиваются от импи, то в основном кому-то из четверки или их слуг.
Вот если бы полгалактики внезапно отвернулось и от Хаоса и от Импи, и внезапно начали бы верить в что-то доброе, светлое и пушистое (и производить подобные эмоции) может оно тогда бы в варпе и сфокусировалось. Но у нас в галактике Импи, четвера и экстерминатусы "на всякий случай". И добро "без кулаков" обычно заканчивает свое существование или в желудке, или в кандалах, или подопытным кроликом. Иногда все вместе. -------------------- Жадность Тразина сгубила.
31.07.2017, 18:52
Весна вроде прошла, осень не наступила... или ты так потроллировать? давайте, эту стадию А вопрос этот я изучил по англоязычным форумам и там нет однозначного мнения. Цитата В варпе отражаются ВСЕ эмоции, но ввиду культурно нравственного состояния популяции галактики, варп теперь не подходит для выживания чего то доброго и светлого. Оно если каким то макаром и заводится, то или сдохнет или сожрут-с. Пропорции малость не те. вот это уже похоже на рассуждения, но их базис - темных эмоций больше, поэтому светлых сущностей нет, логически не состоятелен, потому что базируется на двух субъективных утверждениях: 1. светлые сущности есть - их сжирают (возможно и так, только, где указания на это в бэке) 2. светлых эмоций очень мало (опять же в каких килоджоулях измерить? сколько этих эмоций нужно, чтобы сущность родилась? тем более, человеческая история, так и тем более история Вахи дает много примеров торжества света над тьмой, героических самопожертвований, благодарности Императору и т.д.). Цитата Даже эльдары в бытность свою до декаданса будучи духовно богатыми и вообще при помощи ритуализированного поклонения создали пантеон редкостных отморозков а не что то однозначно хорошее. Куда уж людям и оркам. так в чем аргумент-то? извращенцы-эльдары создали ублюдочных божков, как это должно опровергнуть возможность появления светлых сущностей? Цитата Ну и позитивные вещи в варп вполне себе аккумулируются воплощаясь в чудесах, актах веры или отключаемой пилонами безумной храбрости из падения Кадии. на это есть указания в бэке? Цитата Ну и да, со всей галактики наскребсти даже на одно доброе божество задача непосильная учитывая сколько отжирает Импи и Тзинч Тзинч жрет светлые эмоции? -------------------- |
31.07.2017, 19:00
Scout Раса: Space Marines Армия: Red Scorpions Группа: Пользователь Сообщений: 1 907 Регистрация: 10.12.2011 Из: Заебус Минорис Пользователь №: 31 396 Репутация: 861 |
Зачем добрые боги? Если наш чудесный мир вахамы про убить всех чужих и немного своих (на всякий случай). За что и любим.
-------------------- – Хорошее – уже близко.
– А прекрасное? – А прекрасное – далёко, и зависит от каждого из нас. |
31.07.2017, 19:03
Импи отжирает и доброе - мученичество и героизм, отвагу и защиту слабых.
Гвардейцы молятся импи и их врачи молятся импи чтобы спасти хоть еще одну жизнь и уверен хирургеоны иг молятся ничуть не менее искренне, чем госпитальерки сороритас. А молятся они хорошему и доброму делу. И верят в хорошее. У эльдар героизм и самопожертсоввание это заключено в кхаине, ведь юнный принц жертвует собой ради блага крафтворлда, да и их души жертвуют своим покоем, чтобы помогать живым. Сообщение отредактировал Shadow Duke - 31.07.2017, 19:04 -------------------- Even in the heart of Hell, demons can still feel fear...
31.07.2017, 19:05
отсутствие светлых сущностей, даёт одну интересную логическую возможность, которую хорошо выразил один американский юзер.
Если нет светлых божеств, значит статус богов хаоса в нереальности ниже, чем казалось - они не фундаментальны и абсолютны. их можно уничтожить. Цитата I hear what you're saying, and I think it's a good point that there don't have to be good warp entities in 40k.
What I am thinking is that the lack of "good" warp entities is (in my opinion) a clue that the Chaos entities are not absolute universal Pillars of the nature of reality (or the unreality of the warp) in the 40k universe. There are forces in the physical world, or in 40k I guess you could say "real space" such as inertia, gravity, entropy. You couldn't destroy the force of inertia for example. You could, however destroy a Chaos entity like Khorne or Slaanesh. They're independent and in my opinion very destructible. -------------------- |
31.07.2017, 19:09
Maniac! Группа: Куратор Сообщений: 14 039 Регистрация: 06.11.2009 Из: Казахстан Пользователь №: 20 798 Репутация: 3826 |
В древней Хаотике у Четверки были "добрые" воплощения. Кхорн - благородство битвы, Нургл - плодородие круговорота жизни, Тзинч - тяга к знаниям, Слаанеш - радость жизни. Но эти "воплощения" были лишь мелкими частицами, острием иглы, потеряв баланс на котором разумный скатывался к "плохому" у четверки.
-------------------- Кубы подпилены! Несите канделябр.
Не учите меня играть. Лучше помогите битсами. |
31.07.2017, 19:11
Импи отжирает и доброе - мученичество и героизм, отвагу и защиту слабых. Гвардейцы молятся импи и их врачи молятся импи чтобы спасти хоть еще одну жизнь и уверен хирургеоны иг молятся ничуть не менее искренне, чем госпитальерки сороритас. А молятся они хорошему и доброму делу. И верят в хорошее. Вот Вы подошли к самой мякетке непоняток: 1. Ведь религия-Импи была не всегда, до Хереси, человеки никому не сливали позитив, куда он уходил? 2. Вот 10К человечество сливает мегатонны энергии Всеотцу. Почему он до сих пор не исцелился и не восстал с Трона? Цитата У эльдар героизм и самопожертсоввание это заключено в кхаине, ведь юнный принц жертвует собой ради блага крафтворлда, да и их души жертвуют своим покоем, чтобы помогать живым. вот, значит управлять и созидать сущности при помощи позитива можно. Это очень важный пойнт - человечество могло бы создать орду таких Кхаинов, которые бы заставили демонов напрячься. Но их нет. Все исчезает в Тронном Зале. Почему? -------------------- |
31.07.2017, 19:11
Цитата тем более история Вахи дает много примеров торжества света над тьмой Хоть один пример будет? -------------------- |
31.07.2017, 19:13
Хоть один пример будет? Драйго бегающий и надирающий зад всему, что реально плохое? -------------------- Even in the heart of Hell, demons can still feel fear...
31.07.2017, 19:13
31.07.2017, 19:14
Flooder God Группа: Пользователь Сообщений: 838 Регистрация: 02.04.2014 Из: Москва Пользователь №: 40 387 Репутация: 360 |
Боги Хаоса - добрые! Тзинч - б-г надежды и знаний Нургл - б-г жизни, он вообще очень добрый, и последователи его весёлые (кроме Тифуса, он грустный клоун) Слаанеш - б-г стремлений к совершенству, наслаждений, может даже любви Кхорн - б-г безудержной, душевной, непредвзятой кровькишкирастридварасило, воинской чести и мужества А если для вас всё это - зло, то вы лживые трупопоклонники, неблагодарные эльфы, тупые орки или прочие косорылые некроны и грязножопые тау. ____________ Предупреждение: серьезное нарушение [+] Выдал: samurai_klim Причина: Флуд/флейм. Наказание по статье 3.9 раздела III Правил форума. Истекает: через 15 дней |
31.07.2017, 19:16
Победа Рейвенора над Молохом? Все смерти и мучения в процессе перекрывают выхлоп многократно. Цитата Драйго бегающий и надирающий зад всему, что реально плохое? А ведь не поспорить. -------------------- |
31.07.2017, 19:24
#15
Hive Tyrant Раса: Tyranids Армия: Hive Fleet Leviathan Группа: Пользователь Сообщений: 1 185 Регистрация: 12.01.2017 Пользователь №: 50 820 Репутация: 593 |
Лапша бы был тобой доволен, топикстартер. Всё много раз описывалось до вас, поиск в помощь.
31.07.2017, 19:27
#16
Lord Commander Раса: Imperial Guard Армия: Catachan Jungle Fighters Группа: Супер Модератор Сообщений: 11 112 Регистрация: 13.02.2009 Из: г. Апатиты Мурманской области Пользователь №: 17 733 Репутация: 4869 |
Прикрываем. Я за пять минут нашел все поиском
31.07.2017, 19:27
#17
Драйго бегающий и надирающий зад всему, что реально плохое? Вот только он проклят и не может преодолеть проклятье. Все что он уничтожает в Царстве Хаоса, моментально восстанавливается. Так что вряд ли можно назвать это победой. -------------------- Кубы подпилены! Несите канделябр.
13.06.2018, 09:40
#18
Scarab Раса: Necrons Армия: Necrons Группа: Пользователь Сообщений: 1 766 Регистрация: 27.05.2011 Из: Новосибирск Пользователь №: 29 130 Репутация: 723 |
Хаос это отражение ВСЕХ эмоций, он содержит в себе как отрицательные так и положительные.
Просто отрицательных много больше. Сообщение отредактировал CivilWAR - 13.06.2018, 09:41 -------------------- Купил мелок от тараканов.
Теперь в голове тишина и спокойствие. Сидят, рисуют. |
13.06.2018, 11:25
#19
Grand Master Группа: Пользователь Сообщений: 394 Регистрация: 13.02.2018 Пользователь №: 59 694 Репутация: 37 |
Нет. Так получилось что эмоции отражаются в варпе, а из самых низменных из них создается хаос.
13.06.2018, 11:38
#20
Lord Commander Раса: Imperial Guard Армия: Valhallan Ice Warriors Группа: Пользователь Сообщений: 2 394 Регистрация: 10.08.2011 Пользователь №: 30 013 Репутация: 262 |
Это вымышленный мир, на самом деле при таком подходе человечество бы само себя уничтожило. Это вымышленный мир, в котором только такой подход даёт человечеству шанс на выживание (как это было показано во многих книгах). Нам остаётся или принять правила этого мира или пойти играть в "Хоббита". И да, космодесы уже давно не люди. У них даже имена другие, не говоря уж о метаболизме, мышлении и жизненных ценностях. -------------------- |
Текстовая версия | Сейчас: 20.04.2024 - 03:52 |
